 Old 05-18-2010, 09:47 AM   #81
austin102085's Avatar
Posts: 1,195   (View Stats)
Groans: 32
You're going up there?! Yes!
yes im going up there to get tuned. i have been talking about it with him for a couple weeks now. the e-tune thing is good but hands on is better
I'll be there the last weekend of May, sooooo you should go the same weekend!
i would go then but im planing this around work and am actually lieing to them about where im going so.....................
2008.5 Mazdaspeed 3
513whp MS3<-- for now (sold)
 Old 05-18-2010, 09:55 AM   #82
Fagwagon's Avatar
Posts: 2,090   (View Stats)
Groans: 75
lol, yah the army is like that, last time i needed to skip drill i said my grandpa was in serious condish.
 Old 05-18-2010, 06:00 PM   #83
Groans: 32
so here is my intake. not 100% sure if its gonna work or not. it is not the cp-e maf and i think i may run in to some problems with the air flow and how the ecu is programed in the big maf flash. i may end up cutting the maf off and attaching the cp-e one any way. great just another waste of money. i should have just got the cp-e maf to start with. o well u live and learn.
2008.5 Mazdaspeed 3
The Following User Says Thank You to austin102085 For This Useful Post:
madvillain (05-18-2010)
 Old 05-18-2010, 06:08 PM   #84
madvillain's Avatar
Posts: 4,160   (View Stats)
Groans: 78
What's the ID of that housing?
 Old 05-18-2010, 06:14 PM   #85
Groans: 32
3.25 ID
2008.5 Mazdaspeed 3
 Old 05-18-2010, 06:51 PM   #86
spnkr21's Avatar
Posts: 2,827   (View Stats)
Groans: 105
Default holset turbo powa
If it's 3.25 I'm sure it's fine.
2012 WRX HB w/mudflaps yo!
nutsac76 (05-18-2010)
 Old 05-18-2010, 06:56 PM   #87
nutsac76's Avatar
Posts: 694   (View Stats)
nutsac76 is the leader of the worldnutsac76 is the leader of the worldnutsac76 is the leader of the worldnutsac76 is the leader of the worldnutsac76 is the leader of the worldnutsac76 is the leader of the worldnutsac76 is the leader of the worldnutsac76 is the leader of the worldnutsac76 is the leader of the worldnutsac76 is the leader of the worldnutsac76 is the leader of the world
Groans: 100
Groaned at 39 Times in 26 Posts
yeah youre good. i started with a 3" and a/f was 11.0 @ idle. as long as the internal dia. is 3.25" youre alright.
Whats wrong with a cloned turbo?
nutsac76 is offline   Reply With Quote
 Old 05-18-2010, 07:05 PM   #88
madvillain's Avatar
Groans: 78
Yeah man, same thing as Cp-e's. I wish I had done what you did.. where'd you get that?
 Old 05-18-2010, 07:15 PM   #89
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
I've seen it in person, it's close to 3.25, but the fabricator just crushed the pipe and welded on some flat stock to bolt the MAF to. You can't see the distortion in the pipe in the pictures...
I think MAF is off enough that it will cause him some issues, especially when he starts turning up the boost. It may be close, but close isn't good enough when it comes to the MAF housing on a big turbo motor...
 Old 05-18-2010, 08:12 PM   #90
Groans: 32
yea i had it made at the same shop that did my engine build and turbo install. it runs all the way back till the turbo inlet was 3.25 so its a true 3.25 intake. no step downs
i see what ur saying and am still not sure if its gonna be an issue. is there a way to tell ie: look at fuel trims or maf volts or somethin?
im gonna wait till jake comes back and bounce some ideas off him. like i said i may just have to cut some off and add theres to be certain its right. ive come this far whats another $200.00 to get it right.
2008.5 Mazdaspeed 3
 Old 05-18-2010, 08:21 PM   #91
Groans: 60
Just watch the idle and part throttle fuel trims.. My CP-E MAF holds the trims around +-2%, I've never seen anything higher.
I don't think your housing is horrible or anything, but even 8 or 10% at idle could mean a huge difference at redline and 20psi, this car is hard enough to tune without having to compensate for incorrect MAF readings..
 Old 05-19-2010, 08:57 AM   #92
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
You can calibrate any maf housing with the MAF xfer table. It's really no different than what you do with the ap, except for changing the table directly, your simply tweaking the voltages to get the same effect.
Austin, if you need help with it, lemme know and i'll explain how you do it.
Quick, summary though:
log: Maf volts, LTFT & STFT, and do a steady pull from very light throttle. Don't get too heavy on the throttle cause you want to avoid tip-in enrichment.
Then check your log out, add up the STFT & LTFT to get your total trim at each maf voltage, and make some tweaks on the MAF xfer table.
I just did this last weekend, and worked well. I will note that i don't believe the MAF xfer table is in %, cause it took very small values like 2-4 to calibrate for trims that were off by like 10+.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
 Old 05-23-2010, 10:20 AM   #93
RayRayBauder's Avatar
Posts: 1,999   (View Stats)
RayRayBauder is the leader of the worldRayRayBauder is the leader of the worldRayRayBauder is the leader of the worldRayRayBauder is the leader of the worldRayRayBauder is the leader of the worldRayRayBauder is the leader of the worldRayRayBauder is the leader of the worldRayRayBauder is the leader of the worldRayRayBauder is the leader of the worldRayRayBauder is the leader of the worldRayRayBauder is the leader of the world
Groans: 234
Groaned at 154 Times in 122 Posts
where did you get your h1c? ebay?
'08 MazdaSpeed3 - sold
RayRayBauder is offline   Reply With Quote
 Old 05-23-2010, 10:30 AM   #94
Groans: 32
a member from this forums
2008.5 Mazdaspeed 3
RayRayBauder (05-23-2010)
 Old 06-03-2010, 04:04 PM   #95
Groans: 32
UPDATE!!!............
so i went up to dc area and hit up jake from cp-e did a couple loops on his "race way" and did some street tuning. we got to 20.5 psi. and everything is spot on. i will post some dh logs latter on, im out of town and i dont have a computer i can get online that also has the program on it. i am going to get a bigger map and tune for more psi in the future and will continue to work with jake on that as well via e-tuning.
before the tuning car was sloww... when i say slow i mean prolly 290-310 whp nowww.... i can break loose and boost builds like a champ prolly in the 360-380 whp in less than 2 hours. now dont take these numbers to heart cause i didnt dyno tune and we deff arnt done yet. i will dyno this tune when i get home next week and see where im at now.
let me just say about jake --he sat in my pass. seat as we did these tunes. i would make a pull and he would do his thing and be like "go again" id hit it and have more power. this guy is the shit. if you are near him or not (hell i drove from nc) hit this man up. THANKS AGAIN JAKE.
2008.5 Mazdaspeed 3
The Following 7 Users Say Thank You to austin102085 For This Useful Post:
-cj- (06-20-2010), 11cruzito11 (06-03-2010), djuosnteisn (06-08-2010), NJSPEED3 (06-29-2010), RayRayBauder (06-03-2010), Realgib3 (06-07-2010), SSinstaller (06-03-2010)
 Old 06-03-2010, 05:07 PM   #96
Groans: 60
The tune makes all the difference....
 Old 06-03-2010, 05:09 PM   #97
Groans: 32
yes it does. o and the intake worked so thats a plus
2008.5 Mazdaspeed 3
 Old 06-03-2010, 05:22 PM   #98
cageyvet's Avatar
Posts: 715   (View Stats)
please make more power than me!!
The Following User Says Thank You to cageyvet For This Useful Post:
 Old 06-03-2010, 08:13 PM   #99
turd burglar's Avatar
Posts: 1,895   (View Stats)
Groans: 39
damnit i need more money and for shit to quit breakin!
 Old 06-05-2010, 07:55 PM   #100
idaners7's Avatar
Posts: 55   (View Stats)
idaners7 has a spectacular aura aboutidaners7 has a spectacular aura about
Groaned at 24 Times in 3 Posts
nice pictures man..
idaners7 is offline   Reply With Quote
 Old 06-05-2010, 08:02 PM   #101
Groans: 32
for the record ^^^owes me a BJ hahaha
2008.5 Mazdaspeed 3
 Old 06-07-2010, 07:59 PM   #102
Groans: 32
new logs posted on page 1. videos will post soon for sure. im just busy trying to move.
2008.5 Mazdaspeed 3
The Following 2 Users Say Thank You to austin102085 For This Useful Post:
djuosnteisn (06-20-2010), KeysMS3 (06-24-2010)
 Old 06-20-2010, 07:47 PM   #103
nyghtryder's Avatar
Posts: 1,903   (View Stats)
nyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the world
i got to ride in this thing yesterday and wow. I want to go out and get my engine built tommorrow. This thing is nasty loud and I love it. Cant wait for the dyno tunes cuz you have the ability to make more power. Even with the car tuned how it is now it rides amazing and way smoother than any other tuned speed ive been in.
A Kabar is just a paper weight until it's in the hand of a Marine.
If a Marine can't fight it, f@#k it, or eat it, he's going to destroy it and burn it to the ground.
COBB SRI | COBB TURBO INLET | TURBOSMART BPV | APEXI TT | SAIKOU MICHI STAGE II OCC | DENSO ITV22 PLUGS | MSD DASHHAWK | SU SHIFTER BUSHINGS | JBARONE SSP | SPEEDLINE HEATED CONVEX MIRRORS | CLEAR SIDEMARKERS | 5000K 35W D2S BULBS | 3000K 35W HID FOG LIGHTS | 6000K REVERSE LIGHT HID KIT | RALLY ARMOR URETHANE MUD FLAPS | PROGRESS TECHNOLOGY RSB | TRZ RMM | GRIMMSPEED EBCS
NATOR PA
nyghtryder is offline   Reply With Quote
The Following 3 Users Say Thank You to nyghtryder For This Useful Post:
austin102085 (06-20-2010), djuosnteisn (06-20-2010), KeysMS3 (06-24-2010)
 Old 06-20-2010, 10:27 PM   #104
Groans: 32
thanks man glad u liked it. sorry no one wanted to race yesterday it would have been good. were u there when that speed6 came back thru and i asked homwhat turbo he was running and he told me "haha take a guess" hahahah then i asked what he tuned with and his reply was "i have a apex turbo timer"hahahahah fuck that guy.... this is the shit we deal with in jacksonville bunch of lieing ass holes.....
2008.5 Mazdaspeed 3
 Old 06-23-2010, 09:54 AM   #105
nyghtryder's Avatar
what a faggot. i saw him get out when i was leaving and was going to ask him if he wanted to run, but the fucker ran into mcdonalds. btw still cant get that srt-4 to bite, fag keeps reving on me but nothing. I know what shop he works in too so i should just go to work and call his ass out.
my car told me on the way home that night it wanted a new engine and bigger turbo, i shead a tear kissed her goodnight and went to bed dreaming of bt's and new engines.
NATOR PA
The Following User Says Thank You to nyghtryder For This Useful Post:
austin102085 (06-24-2010)
 Old 06-23-2010, 10:02 AM   #106
BrianZX10R's Avatar
Posts: 1,163   (View Stats)
BrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the world
Groans: 88
Groaned at 121 Times in 75 Posts
dyno yet?
1995 honda civic. 1.6L slow
2007 Kawasaki ZX10r
BrianZX10R is offline   Reply With Quote
 Old 06-24-2010, 01:09 PM   #107
Groans: 32
Originally Posted by BrianGT3076 View Post
dyno yet?
no not yet. i am in the middle of a move.... in ga right now.... but will be in fl tomm and will get a house and all my stuff moved in and then its back to powa. sorry i know im a fail at this thread ie: no vids, dynos, not keeping the logs up to date but trust me me and jake from cp-e are working on it and it is feeling great. we have been keeping the tune very mild knowing i needed my car to get me thru the move to fl. well now that the move is near the end. we will start getting more aggressive with the tuning and upping the boost. so i will try to keep yall more up to date.......
2008.5 Mazdaspeed 3
The Following 3 Users Say Thank You to austin102085 For This Useful Post:
djuosnteisn (06-24-2010), madvillain (06-24-2010), nyghtryder (06-27-2010)
holset hx35? Fagwagon MazdaSpeed 3/6 - Turbo Induction 154 09-13-2012 01:39 PM
Geneva Preview: Techart to debut 911 Turbo, Turbo S Haltech Automotive News 0 02-16-2010 03:20 PM
POWA!!! PG MANI INSTALLED!!! gsrtype1 MazdaSpeed 3/6 - Turbo Induction 102 06-03-2009 09:07 PM
First Drive: 2008 Ford Falcon G6E Turbo and XR6 Turbo Haltech Automotive News 2 05-04-2009 06:48 PM
I NEED MORE POWA!!!! Eazy Mazdaspeed3/6 General Discussion 8 01-27-2009 02:00 PM
Page generated in 0.45275 seconds with 32 queries
