 Old 02-21-2011, 06:21 AM   #1
jracer's Avatar
Posts: 1,706   (View Stats)
Groans: 89
Default how long do Journal Bearing turbo's last ?
i was wondering whats the life span of a Journal Bearing turbo over a ball bearing ??
starting to look at turbos for my build i am starting in a few weeks.
maybe looking at a precision turbo..what size would be best for a 400hp goal ?
thanks !
H&R springs/H&R 15mm spacers
MAP catless testpipe
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
TWM Desert Eagle shift knob
AEM wideband gauge
Prosport boost gauge
EvoX piller pod
30%Tint
Slowpoke Tuned 339hp/336tq
**** SOLD *****
2006 speed6
 Old 02-21-2011, 07:16 AM   #2
essejkcamraw's Avatar
Posts: 922   (View Stats)
essejkcamraw is the leader of the worldessejkcamraw is the leader of the worldessejkcamraw is the leader of the worldessejkcamraw is the leader of the worldessejkcamraw is the leader of the worldessejkcamraw is the leader of the worldessejkcamraw is the leader of the worldessejkcamraw is the leader of the worldessejkcamraw is the leader of the worldessejkcamraw is the leader of the worldessejkcamraw is the leader of the world
Groans: 47
Groaned at 25 Times in 19 Posts
journals last just fine so long as your tuned and take car of your car. go 5557 .63ar like i told you man. perfect.
From built & Big turbo to Miata Gheys
essejkcamraw is offline   Reply With Quote
The Following User Says Thank You to essejkcamraw For This Useful Post:
jracer (02-21-2011)
 Old 02-21-2011, 07:18 AM   #3
kmac's Avatar
Posts: 1,792   (View Stats)
It really depends on how much boost u run and how well u maintain the car. They Do last a long time and they can be rebuilt where bb center sections can not u have to buy a whole chra. Plus bb only helps on respool not spool also with the displacement of our engines I don't think respool will be a problem unless u go with a monster turbo.
The Following User Says Thank You to kmac For This Useful Post:
jracer (02-21-2011)
 Old 02-21-2011, 07:26 AM   #4
jracer's Avatar
Groans: 89
just looking at 20 ish psi .. my goal is close to 400 awhp
looking to use my cobb sri and i do have a cobb inlet but i think i will need a adapter or something to make it work with the bigger inlet on the turbo
you think the ARP main studs are needed ?? i am gunna get the head studs for sure...
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
AEM wideband gauge
EvoX piller pod
30%Tint
**** SOLD *****
2006 speed6
 Old 02-21-2011, 07:38 AM   #5
bmylez's Avatar
Posts: 3,197   (View Stats)
It's less than $200 for the main studs, right? Shouldn't even be considering otherwise. If you're going to push your motor hard, do you really want your mains letting go and completely destroying the motor?
400awhp out of a 5557 at 20 pounds...not experienced with the MS6, but you might need to push a little more boost. Someone else can chime in on that one, though.
2007 CTS-V - Trying to sell
jracer (02-21-2011)
 Old 02-21-2011, 08:19 AM   #6
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
Mains typically let go due to RPM, not power. I'm not saying its a bad idea, but there are other things I would get first.
 Old 02-21-2011, 07:41 AM   #7
kmac's Avatar
I would go with one of those new garrett billet or bw extended tip turbos for the money.
jracer (02-21-2011)
 Old 02-21-2011, 08:50 AM   #8
There are 3 things that affect the life or any turbo:
1. Lubrication. Use a proper oil, have it get enough of it.
2. Heat. Goes hand in hand with lubrication. If you run it too hot, you will damage it prematurely
3. Rotational speed, efficiency. If you are overworking a little turbo, it will have a much shorter life.
A well maintained journal turbo suitable for the application that is water cooled as well should have no issues for 100+k miles. Best of all, they are much cheaper to rebuild.
jracer (02-21-2011)
 Old 02-21-2011, 08:54 AM   #9
jracer's Avatar
Groans: 89
thats what i wanted to hear....lol
new precision turbos are pretty good priced...
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
AEM wideband gauge
EvoX piller pod
30%Tint
**** SOLD *****
2006 speed6
 Old 02-21-2011, 10:06 AM   #10
SRTie4k's Avatar
Posts: 1,715   (View Stats)
As an addendum, build quality highly effects the life of a turbo, more so than any of the items that Lex listed.
Buying an ebay turbo that was made in China, you have a much greater chance of a catastrophic failure than buying a turbo that was hand-built and balanced by professionals.
That said, I ran 2 different journal bearing turbos in my SRT-4, both built by AGP Turbochargers, and they both lasted well over the 10-15k miles I ran them for, with little to no extra shaft play from the time I bought them to the time I sold them. I'm a big fan of oil-only lubrication simply for the fact that they are much easier to install.
The Following User Says Thank You to SRTie4k For This Useful Post:
jracer (02-21-2011)
 Old 02-21-2011, 10:55 AM   #11
^ Oil only is simpler but heat is a bigger issue and they require more cool down period. As always, quality is a big factor - say no to cheap turbos.
jracer (02-21-2011)
 Old 02-21-2011, 11:34 AM   #12
bmylez's Avatar
Unless you are cageyvet
He hasn't reported on the status of his Godspeed turbo in a little while, but it was making crazy power.
jracer (02-21-2011)
 Old 02-21-2011, 11:40 AM   #13
Depends how much your time is worth to you and if you want to take that gamble.
jracer (02-21-2011)
 Old 02-21-2011, 12:39 PM   #14
turd burglar's Avatar
Posts: 1,895   (View Stats)
Groans: 39
cummins uses jb turbos and those things last 5xxxxxxxxxxx miles before rebuilds if you take care of zem
The Following 2 Users Say Thank You to turd burglar For This Useful Post:
jracer (02-21-2011), rigor (03-09-2011)
 Old 02-21-2011, 02:55 PM   #15
kmac's Avatar
I'm running a precision 6262 and I would recommend a precision but considering mine fail with 2k on it and they pretty much told me to blow it out my ass I can't stand behind their product. I took it to my builder and I thought it was something that failed on my car like collapsed oil line or something , but he told me they looked fine as far as lubrication went . He said the bearing probably was defective and I was an unlucky consumer. So even though they perform well they don't stand behind their product so neither can I.
cld12pk2go (02-25-2011)
 Old 02-21-2011, 03:02 PM   #16
madvillain's Avatar
Posts: 4,160   (View Stats)
Groans: 78
Journal bearing turbos have always been used in many industrial and hauling applications for a long time, since long before BB turbos were even invented.
Some say - durability wise - that journal bearing turbos are superior, but who knows. There are too many variables.
As everyone else has said, build quality is key. I personally really stand by the quality and service that Precision has provided me.. Especially for the price.
The Following User Says Thank You to madvillain For This Useful Post:
jracer (02-21-2011)
 Old 03-09-2011, 12:16 PM   #17
rigor's Avatar
Posts: 2,399   (View Stats)
Groans: 40
mine is also working great!! .5557 pte
at 104000 2 bent rods
tuned by nishan
The Following User Says Thank You to rigor For This Useful Post:
jracer (03-10-2011)
where is eveyone buying there turbo's jracer MazdaSpeed 3/6 - Turbo Induction 2 03-07-2010 03:04 PM
Precision 5557 Impressions (journal bearing) cageyvet MazdaSpeed 3/6 - Turbo Induction 9 02-28-2010 12:11 AM
Proof of Hennessey Challenger SRT600 Turbo's punch: 11.9 sec @ 121 mph Haltech Automotive News 0 08-22-2008 01:40 PM
Page generated in 0.37377 seconds with 29 queries
