![]() Join Date: Jun 2010 Location: West Jordan, UT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 91
Groans: 32
Groaned at 27 Times in 12 Posts
(Thread Starter) | Not Ranked : 0 score so i finished my turbo install about a month ago and it is leaking coolant and oil from the feed lines. i used the crush washers provided. how tight should i get these bolts. i tightened them pretty good, but they leak and its pissing me off. will they leak if i tighten them too much? any help is apreciated.
__________________ CP-E INTAKE W/ AMSOIL FILTER, CP-E INLET, TURBOSMART BOV, DENSO ITV22, AWR RMM, STREET-UNIT TMM & PMM, STEEDSPEED MANI CERAMIC COATED, T3 GT3076, TIAL EWG, CUSTOM V-BAND DOWNPIPE, UR CATTED TESTPIPE, TURBO XS CATBACK EXHAUST, COBB FMIC, CP-E FUEL PUMP, DASHHAWK+CP-E MOUNT, JBARONE SSP, COBB ACCESSPORT STAGE 2 SF 91 FMIC. SELF TUNED WITH 400HP/375TQ @ 21 PSI ON 100 OCTANE. |
Groans: 32
(Thread Starter) | Not Ranked : 0 score Anyone? Sent from my SGH-T959V using Tapatalk
![]() Join Date: Dec 2010 Location: TX
| Not Ranked : 0 score Are you positive it's leaking from where the fittings meet the crush washers? If you have any sort of -AN fitting, you have to make sure they're pretty tight to have perfect seal. Post a pic of your setup.
__________________ 2007 CTS-V - Trying to sell 2009 CTS-V - Not getting a cam. Ever. |
Groans: 32
(Thread Starter) | Not Ranked : 0 score Ya its leaking front the bottom crush washer. Sent from my SGH-T959V using Tapatalk
Groans: 356
| Not Ranked : 0 score use one hand strength and thats enough. on a 3/8ths drive ratchet.
| Not Ranked : 0 score Hmmm. Hope you didn't strip some threads. Maybe take the fittings off and use some Teflon tape.
Groans: 32
(Thread Starter) | Not Ranked : 0 score I think i just over tightened them. Do u think teflon tape will hold up with how hot a turbo gets? Sent from my SGH-T959V using Tapatalk
| Not Ranked : 0 score Well if they are crush washers, I would think you'd need new ones.
Groans: 78
| Not Ranked : 0 score Wtf? Really? Something is definitely wrong. I would pull them out and make sure threads are not seriously damaged. Most importantly you obviously don't want a small oil leak to turn into a large one, and you also don't want any of those potential metal shavings to get into your oil supply at either end. There is definitely a leak AT the crush washer though? What kind of lines are you using, silicon/teflon or braided? I've heard of some leaking where the line itself is pressed into the fitting, could it be possible that is where your leak is arising? Either way, you definitely shouldn't have to tighten them much at all. Just til its tight, its certainly not something you want to crank on and strip out.
![]() Join Date: Mar 2008 Location: Navarre, FL
Rep Power: 4956 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,585
Groans: 370
| Not Ranked : 0 score i used permatex sealant on all fittings and connections like that, especially oil: Last edited by aaronc7; 03-17-2011 at 12:47 AM. Reason: MSF Database - Automerged Doublepost |
Groans: 32
(Thread Starter) | Not Ranked : 0 score I used the permatex and didn't tighten the bolts too tight and its not leaking. I think i just over tightened them. Sent from my SGH-T959V using Tapatalk
| gt3076 oil feed banjo size | pearl_ms3 | MazdaSpeed 3/6 - Big Turbo Builds | 14 | 01-13-2011 03:09 PM |
| Seafoam to clean our carbon deposits, where to feed it in? | bast525 | MazdaSpeed 3 - Engine, Transmission & Driveline | 46 | 11-03-2008 08:38 PM |
| Shifter shaft bolts: How tight can they go? | desperado callado | MazdaSpeed 3/6 - ECU Computer Tuning | 5 | 09-26-2008 05:04 AM |
