Like Tree16Likes
 Old 06-14-2011, 07:17 PM   #1
spnkr21's Avatar
Posts: 2,827   (View Stats)
Groans: 105
Once you up the boost it won't creep .
2012 WRX HB w/mudflaps yo!
The Following 4 Users Say Thank You to spnkr21 For This Useful Post:
Alpha (08-05-2011), djuosnteisn (06-15-2011), dougefresh_ (06-14-2011), jmhinkle (06-15-2011)
 Old 06-14-2011, 08:31 PM   #2
dougefresh_'s Avatar
Posts: 4,489   (View Stats)
Well, I plan on running the ebcs to bring boost on sooner... I hit 16psi at like 3,500 (depends when I dip in), and then slowly creep to 21. I want to run looow ass wgdc, and have them descending (following the creep), so I hit and hold 21psi. I may tune the ebcs to 23 psi, or I may use an MBC to bump it up a bit. IDK yet. I should really put in a softer spring, but I really don't feel like fucking with that ewg again. Plus, I gotta hit the books asap.
 Old 06-15-2011, 08:59 AM   #3
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
MBC on my setup = instaboost so that will drop your spool time dramatically. It also caused BPV flutter anytime you do a partial throttle lift...didn't like it.
if you are going to safely run 23 PSI [have the limit tables work] you need the MAP upgrade if you don't already have it.
djuosnteisn (06-15-2011), dougefresh_ (06-25-2011)
 Old 06-15-2011, 09:10 AM   #4
Or @Lex needs to bring his overboost valve to market...
 Old 06-15-2011, 09:29 AM   #5
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
Originally Posted by dougefresh_ View Post
Tial 44mm should fix the creep. You can also get that mani w/ dual ewg's as well .
I have a twin gated top mount mani in my garage, and i'm not sure the second wastegate will clear the alternator, so there may be some issues with the twin gate.
One of these days when i get time, i'll bolt it up to my spare block and do some more formal test fitments, and if there is a clearance issue, i'll figure out how to rework em.
We'll cross that bridge when we get there.
Doug, i probably missed it, but how high does your boost "creep" to?
Rigor brought up an interesting concern with the coolant. He suggested that since the turbo is the new "high point" in the coolant system, a manual purge may be necessary.
I don't have a good sense on coolant setups, but if anyone cares to chime in on it, feel free. I would think the water pump would simply push any air bubbles out, but possibly not.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
Last edited by djuosnteisn; 06-15-2011 at 09:29 AM. Reason: MSF Database - Automerged Doublepost
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f498/how-top-mount-turbo-set-up-83344/
Garret GT3071R - Mazda 3 Quebec This thread Refback 11-28-2012 05:25 PM
l'Interet d'un Turbo en Top Mount? This thread Refback 09-05-2012 07:33 AM
2006 MazdaSpeed6 GT with Navi Big Turbo This thread Refback 04-29-2012 01:56 PM
Top mount turbo setups djuosnteisn MazdaSpeed 3/6 - Big Turbo Builds 1856 09-18-2011 08:46 AM
Top Mount Turbo Manifold aminzer Mazdaspeed3/6 General Discussion 25 02-06-2010 08:19 PM
TRZ Transmission Mount/ Mazda3online turbo inlet installed and review! Raider Mazdaspeed Forums User Reviews 0 06-29-2009 06:40 AM
Page generated in 0.38283 seconds with 26 queries
