Like Tree16Likes
 Old 12-05-2011, 12:41 AM   #1
Axle Breaker
jmhinkle's Avatar
Posts: 4,639   (View Stats)
Groans: 162
Just incase someone is wondering, a GT35 fits just fine on this setup. Playing with one right now just to try it out.
The Following 2 Users Say Thank You to jmhinkle For This Useful Post:
djuosnteisn (12-05-2011), dougefresh_ (12-08-2011)
 Old 12-08-2011, 12:02 AM   #2
dougefresh_'s Avatar
Posts: 4,489   (View Stats)
Dude, I saw you mention the 35 in another thread, but thought you were fooling. Good shit!
 Old 08-30-2012, 06:50 PM   #3
ESB Jiu JItsu's Avatar
Posts: 492   (View Stats)
ESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the world
every time i get angry or upset at the world I look at the pics in this thread and think of a day when i too will be top mount and all is well!
2006 Mazdaspeed6 GT Liquid Platinum Metallic
"because racecar!" " I love this $%&*ing car"
-Gram Lights 57C 18"x7.5/Cooper SR3-A 2254018/H&R Springs/SURE RMM/Diff Straps
-2.75 Blow Through MAF/Custom CXracing FMIC&BOV/Fujita SRI/AEM dryflow/PG TIP/SLS TP/Exhaust Delete/NGK LTR7IX11 plugs/ TB Coolant BP/Bat->Trunk Relocation/JBR egr delete
-TWM Stage 2 Short Shifter/JBR Weighted Shift Knob/TWM 4in Shifter Extender
-Emil Drilled/Slotted rotors/Hawk HP Pads/Clutch Pedal Mod/Shift Counter Weight Mod
-Custom Vented Hood/Custom Front Bumper/Emblem delete/Prosport Mech. boost gauge
ESB Jiu JItsu is offline   Reply With Quote
The Following User Says Thank You to ESB Jiu JItsu For This Useful Post:
dougefresh_ (09-02-2012)
 Old 12-08-2011, 12:38 AM   #4
Schmitty5's Avatar
Posts: 979   (View Stats)
Schmitty5 is the leader of the worldSchmitty5 is the leader of the worldSchmitty5 is the leader of the worldSchmitty5 is the leader of the worldSchmitty5 is the leader of the worldSchmitty5 is the leader of the worldSchmitty5 is the leader of the worldSchmitty5 is the leader of the worldSchmitty5 is the leader of the worldSchmitty5 is the leader of the worldSchmitty5 is the leader of the world
Groaned at 20 Times in 12 Posts
subbed for coming back to when I need to see winning in mazdaspeed6 form.
incredible how to. Only read the 1st page
2010 MS3 - 13.42 at 107 - street tires - 306whp/338tq Moore automotive (dynojet)
Roadcoursing > all http://www.youtube.com/watch?v=GO-xoFpsgj4
Schmitty5 is offline   Reply With Quote
The Following User Says Thank You to Schmitty5 For This Useful Post:
 Old 12-18-2011, 04:03 PM   #5
steedspeed's Avatar
Posts: 582   (View Stats)
Here's the new top mount with 44mm V-band at angle to fix the clearance issue. Angles away from the alternator and also away from the block.
The Following 4 Users Say Thank You to steedspeed For This Useful Post:
crazyp (12-18-2011), dougefresh_ (12-18-2011), Funkster777 (12-18-2011), SPEED6 KILLAH (12-18-2011)
 Old 12-18-2011, 09:27 PM   #6
SPEED6 KILLAH's Avatar
Posts: 1,176   (View Stats)
SPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the world
very nice. what about for the t4 flange did you fix the Angle on that so it does it hit the cly head
SPEED6 KILLAH is offline   Reply With Quote
 Old 12-19-2011, 09:37 AM   #7
steedspeed's Avatar
Haven't had another T4 order yet but I've tilted the flange away from the head a little on the CAD drawing.
 Old 01-17-2012, 01:45 PM   #8
Just a heads up... @crazyp brought up in his thread that his turbo nuts bad backed off (a ton) as a result of the washers we both used (listed in OP, but edited w/ this warning). My turbo was off recently at the dealer, but one had still recently backed out a bit (back left one here):
@jmhinkle said to use lock washers instead, and that should do the trick.
djuosnteisn (01-20-2012)
 Old 01-17-2012, 04:22 PM   #9
Axle Breaker
jmhinkle's Avatar
Groans: 162
I've never had one back out, but I did have the lock nuts seize up and cause the studs to back out when I was trying to swap turbos. That, in turn, caused the studs to gall inside the manifold and break off two of them. Best bet is probably loc-tite on the bottom of the stud into the manifold, and use a lock washer and regular nut on top. Coat the top in anti-seize as well so the nuts don't corrode to the studs.
djuosnteisn (01-20-2012), dougefresh_ (01-17-2012)
 Old 02-26-2012, 03:09 PM   #10
aviator79's Avatar
Posts: 3,934   (View Stats)
Im throwing the idea around of going with a GTX3071R with a top mount like this, throwing some rods and the new mazda pistons in my spare long block (if block OK) with the big valve head and using the spearco 1-992 FMIC. Ive always wanted to do this as that was why I was stockpiling parts, but it is a lot to take on at the moment. Im trying to figure out costs on a spreadsheet. Can I get a twin scroll GTX3071? I think cause the isn't the difference on the compressor side only? Also Ive got to locate a machine shop around here, but should be too much of a problem being right next to Sikorsky.
dougefresh_ (02-26-2012)
 Old 02-26-2012, 05:08 PM   #11
crazyp's Avatar
Posts: 1,093   (View Stats)
Groans: 68
cost wise a gtx3071 is the same as a gtx3076. edgeautosports had the best price when I was turbo shopping
The Following User Says Thank You to crazyp For This Useful Post:
 Old 01-16-2013, 08:17 PM   #12
castner's Avatar
Posts: 26   (View Stats)
castner is a jewel in the roughcastner is a jewel in the roughcastner is a jewel in the roughcastner is a jewel in the rough
Groaned at 7 Times in 4 Posts
i feel stupid for asking but what is the issue with the ms3 and a top mount?
castner is offline   Reply With Quote
 Old 01-16-2013, 08:37 PM   #13
The hood is different, so it doesn't fit under the gad damn hood, lol. But iirc, it can fit if you cut some of the crowl off, but I don't really remember now, tbh. Sell your ms3, buy an ms6, and use excess funds for @SPEED6 KILLAH; SB build and go with top mount set up
@djuosnteisn; could elaborate on ms3 issue.
 Old 01-16-2013, 09:27 PM   #14
Axle Breaker
jmhinkle's Avatar
Groans: 162
Not the hood. It is the cowl area. The 6 has more room to the windshield, but the 3 has more room down lower. Top mount can be done with the twisted Perm kit easier than anything else, but it is another beast altogether.
dougefresh_ (01-21-2013), Funkster777 (02-10-2013)
 Old 10-27-2013, 02:34 PM   #15
aviator79's Avatar
Thanks @dougefresh_; on the mod to cpe fmic hot pipe as I bought a jbr intake that wont fit so going to order 2 18" Ls and a hump coupler. Just hope it will clear my synapse bov.
dougefresh_ (10-28-2013)
 Old 04-12-2014, 08:03 AM   #16
thehead's Avatar
Posts: 1,141   (View Stats)
thehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the world
Groans: 143
Does anyone know of someone who can make an intake for the top mount setup? It is the last thing I have left to do for my top mount setup. @djuosnteisn; doesn't seem to be here anymore and was the only person to have made them.
2016 BMW M235i
[Dead] 2006 MS6 #367 Liquid Platinum 73,000 miles
Engine - Killah built -L19 Headstuds - Steedspeed T3 Twin Scroll top mount goodness - Twin Scroll .83 A/R hotside GTX3071R - JMF V1 IM - Perm 6th Port - CP-E FMIC - SURE 3.25 MAF housing - customized EBay DP - Magnaflow CBE - Autotech HPFP internals
Electrical - GS EBC - Cobb AP Richtune in progress
Drive train - Techna-fit Stainless Steel clutch and brake lines - stoptech rotors - CorkSport RMM - Corksport Trans inserts - SURE Juggernaught & Dreadnaught - E4 heavy knob & Jbarone's Short Shift plate - Tenzo DC-5 Bronze +45 wrapped in ExtremeContact DWS 235/40-18's
Fluids Transmission - Motorcraft synthetic. PTO and Rear diff - Conklin Gold Guard Plus synthetic 75W-90. Engine Oil - Rotella T6 5W-40.
thehead is offline   Reply With Quote
 Old 04-12-2014, 05:07 PM   #17
BobtailedSnail's Avatar
Posts: 1,375   (View Stats)
Skreets be calling...
The Following User Says Thank You to BobtailedSnail For This Useful Post:
thehead (04-12-2014)
 Old 04-15-2014, 05:05 AM   #18
I know a guy, who knew a guy who knows a guy...
jmhinkle (04-15-2014)
 Old 04-15-2014, 05:13 AM   #19
Fracass's Avatar
Posts: 31   (View Stats)
Fracass has much to be proud ofFracass has much to be proud ofFracass has much to be proud ofFracass has much to be proud ofFracass has much to be proud ofFracass has much to be proud ofFracass has much to be proud ofFracass has much to be proud ofFracass has much to be proud of
my topmount setup with meth direct port.
Mazda 6 MPS 2006: H&R bilstein B8, steedspeed t3 top mount TS with HX35, custom 3" downpipe, cpe duplex 3",dbw 3", 5 injectors methanol with devilsown dvc, blow through maf 3", custom fmic, forge blowoff, ported intake manifold vtcs delete and meth bung, intake custom 3.5", Spec stage 3+ clutch and flywheel, Cometic headgasket / ARP stud, balace shaft delete, egr delete,Brembo calipers EVO X, RX8 rims /sessenta 235/40/18, Galaxy tab2 gps mod, & more.....
Fracass is offline   Reply With Quote
The Following User Says Thank You to Fracass For This Useful Post:
dougefresh_ (06-10-2014)
 Old 06-10-2014, 12:16 AM   #20
I can't believe how much work this fucking thing was. The install wasn't that bad, thanks to DJ and Joel, but fuck, the prep work was intensive for a dim witted cpa.
@jmhinkle; is Dustin still making these?
EDIT: I couldn't spell Dustin's MSF name to save both my nuts, or 3" off my prick.
 Old 06-10-2014, 12:45 AM   #21
Axle Breaker
jmhinkle's Avatar
Groans: 162
He's moved on to other things. There were only a limited number of SteedSpeed manifolds to begin with.
The Following User Says Thank You to jmhinkle For This Useful Post:
 Old 06-10-2014, 01:09 AM   #22
Oh shit, I didn't know that. Thanks for the info homie. I hope you're doing well brother! You got a thread on here for your gtr build?
Why is your sig so gad damn big, but there's nothing there? Tell Dusty I said hai
Last edited by dougefresh_; 06-10-2014 at 01:09 AM. Reason: MSF Database - Automerged Doublepost
 Old 06-10-2014, 01:34 AM   #23
Axle Breaker
jmhinkle's Avatar
Groans: 162
That's why I have the WTF? in there. Some mod jacked with it awhile ago and I gave up trying to fix it. I don't frequent these forums much anymore so it doesn't matter. I'm not building the GTR, maybe some light restoration if anything. I have a thread I started from when I maybe the initial purchase with the same pics from facebook. Nothing special.
dougefresh_ likes this.
 Old 06-10-2014, 01:47 AM   #24
Right on broseph. I'm not on here much myself (have nothing to contribute, but do enjoy Internet Gold). Now the WTF makes sense, haha. Hey it's better than "I got this" in your sig or anywhere else. I want the fuckers that started that gay saying shot in the fucking head. I can't get away from it, and it's weaksauce. First it was supposed to be 'urban,' and it sucked balls then. Now I hear it in insurance commercials and on the news, and writers forcibly working it into movies. I'd put my K04 back on (if I still had it), if I never had to to hear those fucking words again. I got this... FUCK YOU.
 Old 06-17-2014, 07:40 AM   #25
SternRitteR's Avatar
Posts: 64   (View Stats)
SternRitteR is a splendid one to beholdSternRitteR is a splendid one to beholdSternRitteR is a splendid one to beholdSternRitteR is a splendid one to beholdSternRitteR is a splendid one to beholdSternRitteR is a splendid one to beholdSternRitteR is a splendid one to behold
Groaned at 7 Times in 5 Posts
Mental build , i know its a old thread but surely you will need an effective way of dissipating that heat .For the sake of the bonnet paint
BNRS3 CORKSPORT STAGE 2 INTAKE AUTOTECH HPFP FORGE INTERCOOLER TOTAL MPS DOWNPIPE MIJ CATBACK COBB 3PORT EBS DICE DUST CAPS TB COOLANT DELETE FORGE V2 BPV
SternRitteR is offline   Reply With Quote
 Old 06-17-2014, 03:43 PM   #26
Axle Breaker
jmhinkle's Avatar
Groans: 162
The airflow through the engine bay is more than enough. Several of us have been on topmounts over 4 years without any problems at all.
crazyp (06-17-2014), dougefresh_ (06-17-2014)
 Old 06-17-2014, 09:01 PM   #27
Well, I've had a few problems in the last 4 years, but it turns out they are mostly related to my alcoholism, and completely unrelated to my car, or airflow under the hood. Go figure.
EDIT: PS Joel, I'm still running that 'upgraded' coolant return line you suggested ($50 for like 3'... my original coolant line fried over time, but corrected info in OP)... the shit that failed on you iirc. I checked mine the other day, and the shit looks brand new. Granted, I have 45K on the car, and only about 15K since BT.
The Following 2 Users Say Thank You to dougefresh_ For This Useful Post:
Micha (06-25-2014), SternRitteR (06-18-2014)
 Old 10-22-2014, 05:42 PM   #28
Bruh, I had another problem with my coolant return line. I need to replace the line again. I was getting dyno tuned by @atvfreek; and it started leaking bad on the second E85 run. But at just 22psi, she's making 345/350, which will keep me content as my daily driver, and I'll turn up the boost a notch once I get the coolant line fixed.
Here's a pull from today:
https://www.youtube.com/watch?v=tpDRlThTCHo
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f498/how-top-mount-turbo-set-up-83344/
Garret GT3071R - Mazda 3 Quebec This thread Refback 11-28-2012 05:25 PM
l'Interet d'un Turbo en Top Mount? This thread Refback 09-05-2012 07:33 AM
2006 MazdaSpeed6 GT with Navi Big Turbo This thread Refback 04-29-2012 01:56 PM
Top mount turbo setups djuosnteisn MazdaSpeed 3/6 - Big Turbo Builds 1856 09-18-2011 08:46 AM
Top Mount Turbo Manifold aminzer Mazdaspeed3/6 General Discussion 25 02-06-2010 08:19 PM
TRZ Transmission Mount/ Mazda3online turbo inlet installed and review! Raider Mazdaspeed Forums User Reviews 0 06-29-2009 06:40 AM
Page generated in 0.59812 seconds with 33 queries
