 Old 05-14-2012, 10:47 AM   #41
Deldran's Avatar
Posts: 3,139   (View Stats)
Groans: 118
Yeah there is really no way to do it without some sort of ecu mounting modifications
I thought that the thread ended up more or less at the consensus that a 3" intake was kind of a waste if you had no plans for BT?
I agree that it will not hurt to have one, but will the full effects of such a part really show on the stock turbo? I myself happen to be in the camp that says "no it wont". But im hardly any authority on the topic.
I do not know if i will go BT, i would most deffently like to but funds gota be there. So to me the 3" is worth it, it wont hurt and if i ever do go BT i wont need to spend another 200+ on a big intake
Damond Built Speed 6
The Following 2 Users Say Thank You to Deldran For This Useful Post:
mrmonk7663 (05-14-2012), smoogs12 (05-14-2012)
 Old 05-14-2012, 10:53 AM   #42
smoogs12's Avatar
Posts: 7,731   (View Stats)
Groans: 423
I do agree that if you havent bought an intake yet and you can get a 3" for the same price, then why not.
It just seems that an ms3 with a k04 really makes the most of its power through tuning the timing. So trying to flow more air through the stock turbo than you would with a 2.5 inch intake, is just kind of unneeded imo
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
 Old 05-14-2012, 10:53 AM   #43
radbrad's Avatar
Posts: 538   (View Stats)
the k04 can utilize a 3" intake. There is a thread out there somewhere, discussing the effects of a full 3" intake on the k04. it can be argued weather or not it does or doesnt give you a power gain, but it will not hurt your k04 and if you decide to go BT you already have the intake needed
Well, I just bought the 3 inch and put it in last night. It is a tightfit but it will work. I did widen the holes on the battery box to move to over about 1/4 of an inch but that's the only modification I had to do.
I am sticking with the k04 and ill post some before and after logs while on the same tune, and I think I will over boost by about ~1.5 psi. Ill get back later today or tommorrow and show a before and after.
How ever, it will be a huge improvement over stock tip, and it still have the pcv breather on the tip and not on the intake, which I like.
07Speed3
 Old 05-14-2012, 11:08 AM   #44
I <3 your mom
Dash08's Avatar
Posts: 7,166   (View Stats)
Groans: 293
Well, thanks for bumping this thread.
Because of this, I just cancelled my order through CS and went with HTP for the TIP.
CS has been back ordered for weeks and now they're out of silicone couplers.
Just talked to HTP, I'll have my TIP this week. So far so good.
this forum serves 2 purposes
The Following 2 Users Say Thank You to Dash08 For This Useful Post:
 Old 05-14-2012, 01:54 PM   #45
mrmonk7663's Avatar
Posts: 2,997   (View Stats)
Yes, tight fit but fits for sure...and I also modified the battery tray holes. I can confirm this was the only modification necessary.
2011 Speed3-BT and shit
TEAM LBN BEERS -- FYCN
TEAM MUMFORD -- FYCN
 Old 05-14-2012, 03:45 PM   #46
smoogs12's Avatar
Groans: 423
I don't understand how you guys managed to fit it in there just by adjusting the mounting holes.
Gen2 must have more space?
Anyway you can get some pics up of how you did it?
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
 Old 05-14-2012, 03:55 PM   #47
m249saw's Avatar
Posts: 718   (View Stats)
m249saw is the leader of the worldm249saw is the leader of the worldm249saw is the leader of the worldm249saw is the leader of the worldm249saw is the leader of the worldm249saw is the leader of the worldm249saw is the leader of the worldm249saw is the leader of the worldm249saw is the leader of the worldm249saw is the leader of the worldm249saw is the leader of the world
HTPs customer service is fantastic. You will get your stuff quick.
Sent from my DROIDX using Tapatalk 2
2012 Subaru STi Wagon, Dark Grey Metallic. Stock as fuck.
m249saw is offline   Reply With Quote
 Old 05-14-2012, 04:08 PM   #48
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
On the topic if benefit for stock turbo, here's my $.02.
Stock intake/tip will still result in significant vacuum under higher air flows. This vacuum plays directly into the operating pressure ratio across the compressor, and makes it that much more difficult for the lil flame thrower to hold boost.
Reduce this vacuum (as a bigger intake/tip will do), and you'll see an improvement in turbo efficiency.
I'd be curious to see if anybody has actually measured the vac present at the tip under wot... Would be pretty simple to do I think.
Sent from my weiner antenna using Tapa Talk 2
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
86AmishMs3 (05-17-2012), silvapain (05-17-2012), smoogs12 (05-14-2012)
 Old 05-14-2012, 04:23 PM   #49
smoogs12's Avatar
Groans: 423
So the million dollar question. Do you think it's worth it?
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
 Old 05-14-2012, 04:27 PM   #50
I<3Groceries's Avatar
Posts: 1,990   (View Stats)
I bought a HTP 3" TIP, and mated it to a OE K04. I had a CS TIP originally, felt like doing something different, so went with a SURE Sidewinder. Didn't like how loud it made the BPV, so went back to aluminum. Right now I have:
Stock K04 -> HTP 3" -> Random 45 degree silicone coupler -> SURE Aeros MAF housing -> air filter
Ahhh...sounds much better again.
 Old 05-14-2012, 04:59 PM   #51
mrmonk7663's Avatar
Pictures wouldn't help really. It simply went in place of where my previous 2.5" HTP went. After it was in place, I put the battery box on...holes were off a tad, so I took a drill bit and enlarged the hole so I could line the bolts up for battery box. That's all there was to it.
The Following 2 Users Say Thank You to mrmonk7663 For This Useful Post:
eljefe62 (05-15-2012), smoogs12 (05-14-2012)
 Old 05-14-2012, 05:33 PM   #52
Captain
Sure man. It's not a very expensive mod, and i think it would help considerably.
www.permtuning.com
 Old 05-14-2012, 05:40 PM   #53
mrmonk7663's Avatar
Definitely worth it...if you haven't already upgraded the TIP, and are planning on it, then there is no reason not to go with a 3"
 Old 05-14-2012, 06:16 PM   #54
smoogs12's Avatar
Groans: 423
Well I'm already bt and have the full htp intake.
Thanks for the info though you guys
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
 Old 05-15-2012, 05:03 AM   #55
Deldran's Avatar
Groans: 118
I still have stock tip/air box. I plan on going with a 3" intake when I buy one. Or maybe jbr 3.5. What the best way to measure vac in the tip
djuosnteisn (05-15-2012)
 Old 05-15-2012, 11:17 AM   #56
bmylez's Avatar
Posts: 3,197   (View Stats)
For anybody who has aftermarket boost gauge, just hook it up to the nipple that's normally for your EBCS line. It doesn't hurt anything to dump the air coming from your EBCS. Boost gauge will just read vacuum while you're in boost. As boost increases, vacuum in the TIP should increase.
2007 CTS-V - Trying to sell
 Old 05-15-2012, 11:24 AM   #57
eljefe62's Avatar
Posts: 31   (View Stats)
eljefe62 is a splendid one to beholdeljefe62 is a splendid one to beholdeljefe62 is a splendid one to beholdeljefe62 is a splendid one to beholdeljefe62 is a splendid one to beholdeljefe62 is a splendid one to beholdeljefe62 is a splendid one to behold
Just installed 3" HTP TIP and treadstone MAF, I had to drill out the battery box holes AND remove the plastic ECU cover. Even then I really had to jam it in there.
2009 Mazdaspeed3 Crystal White Pearl Mica
3" MAF/TIP, Corksport TMIC, Forge BPV, FP Internals, E85 50/50 AP tuned
front strut tower bar, short shifter
eljefe62 is offline   Reply With Quote
 Old 05-15-2012, 11:29 AM   #58
Deldran's Avatar
Groans: 118
Any thoughts on how low it would go. Mine is in HG and I think it only goes down to -30
 Old 05-15-2012, 11:42 AM   #59
smoogs12's Avatar
Groans: 423
^was just going to say this
What kind of vacuum readings should we see?
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
 Old 05-15-2012, 12:48 PM   #60
I <3 your mom
Dash08's Avatar
Groans: 293
Just to clarify, I went with the 2.5" TIP. Not the 3".
I don't plan on going BT and having a whale penis intake is an instant red flag for California smog shit if a cop decides he wants to see your motor.
I'm all about going fast while deceiving the authorities.
 Old 05-15-2012, 02:03 PM   #61
Captain
Who knows... hahaha. Someone should hook up their boost gauge and see
Like bmylez suggested, just use your oem ebcs nipple and vent that line off the ebcs. Then get a go-pro or video camera, and film the vac gauge while doing a 4th gear pull. If possible, try to get rpm and MAF g/s in the shot too, so we can see how the vac increases with airflow
I wouldn't be surprised to see 1 or 2 psi of vac (2-4 inHg) on the stock tip with somewhat significant airflow (275-300 g/s).
What seems to be the problem, officer?
www.permtuning.com
Last edited by djuosnteisn; 05-15-2012 at 02:03 PM. Reason: MSF Database - Automerged Doublepost
Dash08 (05-15-2012), I<3Groceries (05-15-2012), smoogs12 (05-15-2012)
 Old 05-15-2012, 02:13 PM   #62
Deldran's Avatar
Groans: 118
^ me wants PERM top mount mani
djuosnteisn (05-15-2012), smoogs12 (05-15-2012)
 Old 05-15-2012, 02:29 PM   #63
I <3 your mom
Dash08's Avatar
Groans: 293
I swear, it's all stock.
The car has speed in the name, it's supposed to look like that.
The Following 3 Users Say Thank You to Dash08 For This Useful Post:
djuosnteisn (05-15-2012), maisonvi (05-15-2012), smoogs12 (05-15-2012)
 Old 05-15-2012, 02:58 PM   #64
smoogs12's Avatar
Groans: 423
Just to clarify. Am i tapping the nipple on the ebcs (which I do hot have -__-) or the nipple on the inlet?
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
 Old 05-15-2012, 02:59 PM   #65
Captain
Nipple on the inlet. We want to see how much vac is present there
www.permtuning.com
 Old 05-15-2012, 03:21 PM   #66
Interestingly, my car hasn't smoked since I installed the 3"...
Isn't more vac on the valve cover breather one of Mazda's smoking turbo fixes?
 Old 05-15-2012, 03:22 PM   #67
smoogs12's Avatar
Groans: 423
Ok. So I will try to get vacuum readings for a 3" intake. No gopro though, because poor. Will do my best.
Now we need someone to do it with a stock and/or 2.5 inch system.
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
 Old 05-15-2012, 10:29 PM   #68
dead-zone's Avatar
Posts: 442   (View Stats)
dead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the world
Groaned at 53 Times in 17 Posts
I agree with you. I do not think that there will be difference unless you go BT.
dead-zone is offline   Reply With Quote
 Old 05-16-2012, 06:57 AM   #69
Deldran's Avatar
Groans: 118
I will try and do it on the stock intake. I should have time to maybe Sunday if I can get some one to video. Don't have a go pro but gnex video should be good enough. All I have is a boost gauge but I will have the AP monitor GS and have it in the frame as well.
Will also log so I can post that. I do have a full 3" exhaust so I would assume that I would have different results than someone completely stock
djuosnteisn (05-16-2012), smoogs12 (05-16-2012)
 Old 05-16-2012, 07:17 AM   #70
smoogs12's Avatar
Groans: 423
@djuosnteisn how will all my gt30 affect vacuum readings compared to k04? Any idea?
Just wondering if these results will be able to be treated as "apples to apples" or not.
Edit: @Deldran I have a full 3" exhaust too, so assuming that my turbo doesnt significantly effect my results, we should be able to directly compare our results I would think.
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
 Old 05-16-2012, 07:43 AM   #71
Deldran's Avatar
Groans: 118
@djuosnteisn
Would a 3rd gear pull work. I can do a 4th if needed but i have a road just outside my house that will work well for a 3rd. gota go outside of town for a 4th
 Old 05-16-2012, 04:10 PM   #72
Captain
More airflow the better IMO, gives us more data on the vacuum present at different airflows. Who cares if it's not apples to apples... we just want to see some data at this point. We can get more accurate later on if need be.
Other things that will affect the results will be elevation, temperature, etc etc. So to do real apples to apples, someone would have to do an A-B comparison on the same day with both intakes.
@djuosnteisn
3rd is fine i'm sure.
www.permtuning.com
 Old 05-16-2012, 05:37 PM   #73
smoogs12's Avatar
Groans: 423
@djuosnteisn so in spirit of keeping everything as scientific as possible, i"m gonna do both the 3" intake and the 2.5" using my car.
What would you suggest scaling the maf by when I step down to the 2.5"? 20%?
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
djuosnteisn (05-17-2012)
 Old 05-17-2012, 12:37 PM   #74
I <3 your mom
Dash08's Avatar
Groans: 293
Thought I'd let you guys know of my recent experience with HTP.
Ordered a 2.5" TIP from them on Monday 5/14 and received the part today 5/17. Everything was perfect. Great communication on their behalf with timely shipping and instant email invoices and tracking numbers.
The piece is excellent. Pipe finish is perfect and the welds are flawless.
Overall, I couldn't be more pleased. I highly recommend them.
smoogs12 (05-17-2012), xdm88 (05-17-2012)
 Old 05-17-2012, 01:58 PM   #75
Captain
None if the intake is staying the same (e.g. if your only changing the tip). You may see some drift of the fuel trims, but most likely won't require a change in tune unless they're really off (which is fairly unlikely).
Once you swap it out, just do the usual 20-40 mile cruise "break in" period. Then do a maf cal from ~10-100g/s. See if the trims have changed much, and if so... use the higher g/s trims as a best guess for wot. For instance if the LTFT + STFT around 100 g/s is +8% or something, scale the whole maf curve from that point on up by 8%.
www.permtuning.com
 Old 05-17-2012, 02:03 PM   #76
smoogs12's Avatar
Groans: 423
I would be swapping out the whole intake, MAF housing and all.
I would like to just swap out the TIP buy I don't have any way to reduce down from a 3" MAF to a 2.5" tip.
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
 Old 05-17-2012, 03:20 PM   #77
Captain
Actually, swapping out everything is probably best. Dropping from a 3" to 2.5" diameter intake will be roughly a 30% reduction in area, so if you multiplied the entire maf curve by about 0.7, it should get you in the ball park.
I'd do the 30% maf scale, throw on the 2.5" intake/tip, and do a proper maf cal to make sure things are "wot-safe". Then do the log / video stuff and get the vac measurement. After that, go back to your old map, and throw the 3" intake/tip back on.
www.permtuning.com
 Old 05-17-2012, 03:25 PM   #78
smoogs12's Avatar
Groans: 423
Thanks DJ. Will do.
Really looking forward to seeing some real numbers relating to this all of the sudden "hot topic". Will be interesting to see how it effects my turbos ability to move air too.
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
 Old 05-17-2012, 03:26 PM   #79
Captain
Thanks DJ. Will do.
Me too man! Thanks for taking the initiative.
www.permtuning.com
 Old 05-17-2012, 04:36 PM   #80
bmylez's Avatar
With the way they hand out gear head status, you'll probably get it for doing this simple test.
The Following 2 Users Say Thank You to bmylez For This Useful Post:
djuosnteisn (05-17-2012), smoogs12 (05-17-2012)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f498/htp-3-turbo-inlet-98602/
Mazda MPS Owners Club • View topic - HTP Turbo Inlet Pipe This thread Refback 02-21-2012 09:52 AM
3" turbo inlet cageyvet Mazdaspeed3/6 General Discussion 17 06-18-2010 12:48 PM
cp-e / whoosh "BIG" MAF & turbo inlet *teaser pics inside whoosh@Realtune MazdaSpeed 3/6 - Turbo Induction 33 11-05-2008 09:49 AM
3" Turbo Inlet Pressure Question corsa MazdaSpeed 3/6 - Turbo Induction 14 08-16-2008 10:16 AM
Page generated in 0.61561 seconds with 31 queries
