Like Tree28Likes
 Old 08-07-2016, 02:28 AM   #1
Ben Diesel's Avatar
Posts: 4   (View Stats)
Ben Diesel is infamous around these parts
Default I think my turbo is smoking...?
So I'm fully bolted, but on the stock Ko4 and every once on a while I'll get white smoke out the exhaust in 1st or neutral idle. Mechanics have said change the oil or check to make sure there's no oil in my intake hoses, but I just read on a thread that if I don't have a meth injector my turbo could be running hot... help? I just had the oil changed (my first since buying the car, switched to full synthetic) and I'll see of that resolves the issue...
Last edited by Ben Diesel; 08-07-2016 at 02:32 AM. Reason: figured out how to upload photos
Ben Diesel is offline   Reply With Quote
The Following 3 Users Say NO Thank You to Ben Diesel For This Un-useful Post:
g00s3y (08-08-2016), MS3Shadow (08-09-2016), WetzMS3 (08-08-2016)
 Old 08-07-2016, 03:03 AM   #2
Ben Diesel's Avatar
Will adding a water-methanol injector fix this? I'd like the extra kick but I'm not really in the market to drop $500 plus install
 Old 08-07-2016, 06:30 AM   #3
Davey's Avatar
Posts: 52   (View Stats)
Davey has a spectacular aura aboutDavey has a spectacular aura aboutDavey has a spectacular aura about
A lot of guys on here run T6 Rotella 5w40 oil, myself included. It helps with the turbo smoking issue. If its the turbo I don't think it normally has anything to do with the tempters of the turbo just the seals, oil blows by. Just search for smoking turbo and you'll find better answers and solutions.
Davey is offline   Reply With Quote
 Old 08-07-2016, 07:32 AM   #4
Djohns's Avatar
Posts: 3,944   (View Stats)
Meth would not help at all.
2010 black mica speed3
Soon:built motor
 Old 08-07-2016, 07:44 AM   #5
MD1032's Avatar
Posts: 2,624   (View Stats)
Groans: 143
Your K04's turbo seals are starting to go bad. Save up for an upgrade, or locate a known good, low-mile replacement. Alternatively you can buy reman K04's from Edge, RPM, etc.
2007 Mazdaspeed3 GT
The Following 3 Users Say Thank You to MD1032 For This Useful Post:
g00s3y (08-07-2016), SofaKingAwesome (08-09-2016), Varomnia (03-10-2017)
 Old 08-07-2016, 08:26 AM   #6
g00s3y's Avatar
Posts: 2,127   (View Stats)
Groans: 438
Just bought a "fully bolted" car, but can't change his own oil...
This should end well...
A little searching would have easily given you your answers. But since you have other people do hard things like an oil change for you, I can see why you wouldn't want to have to do the hard work of searching for the answer yourself either.
Meth injector... Lol
The Following 7 Users Say Thank You to g00s3y For This Useful Post:
5doorsoffury (08-10-2016), AwAfrican (08-10-2016), Djohns (08-08-2016), knocturnal (08-09-2016), Thor Hammer (09-04-2016), WetzMS3 (08-08-2016), Worbit (08-11-2016)
 Old 08-07-2016, 10:53 AM   #7
Don
Don's Avatar
Posts: 181   (View Stats)
Don has a reputation beyond reputeDon has a reputation beyond reputeDon has a reputation beyond reputeDon has a reputation beyond reputeDon has a reputation beyond reputeDon has a reputation beyond reputeDon has a reputation beyond reputeDon has a reputation beyond reputeDon has a reputation beyond reputeDon has a reputation beyond reputeDon has a reputation beyond repute
Save for an upgrade.. I'm having the same issue right now. I used my access port to bump up my idle and that worked for now. You might want to try that out
2010 speed3
Corksport catted turbo back
Corksport SRI W/TIP
Autotech internals
AP3 Running PD tune
Stock turbo. Waiting for it to go
Konig deception wheels
BC br coilovers
Oh yea..... I won the lottery!!!!!
Don is offline   Reply With Quote
 Old 08-07-2016, 10:29 PM   #8
Ben Diesel's Avatar
Hey friend. Just thought I'd say hi. You're a wonderful person I'm sure, but you kind of sound like a huge prick right now. Let me give a frame of reference here: 1) I don't know why you put fully bolted in quotations, I know what that means and I meant what I said. 2) I have been doing research and multiple mechanics have told me different reasons for the smoke. 3) "the hard things" like an oil change require jacking the car up, and I don't own jacks, so there's your explaination on that topic. Furthermore, I recently installed coilovers solo so your horse might be a little too high. 4) In my research that you claim I decided to forgo, I saw a few different threads hinting that the colder intake achieved with a meth injector could help stop the smoking. Have a wonderful day, and try not to come across as such a conceited jackoff next time 😘
I'll give that a try! Thanks
I'll run that oil on my next change, thanks!
Last edited by Ben Diesel; 08-07-2016 at 10:29 PM. Reason: MSF Database - Automerged Doublepost
g00s3y (08-08-2016), Thor Hammer (09-04-2016), Worbit (08-11-2016)
 Old 08-07-2016, 10:37 PM   #9
Djohns's Avatar
Aren't you the guy that was asking for us to donate to you because your car is needing repairs or something like that?
Soon:built motor
The Following 2 Users Say Thank You to Djohns For This Useful Post:
g00s3y (08-08-2016), SofaKingAwesome (08-09-2016)
 Old 08-07-2016, 10:48 PM   #10
Ben Diesel's Avatar
Ya haha I didn't know GoFundMe links were against moderator guidelines. I removed the thread, no worries.
The Following 9 Users Say NO Thank You to Ben Diesel For This Un-useful Post:
Bingo (08-08-2016), g00s3y (08-08-2016), Hush (08-08-2016), MS3Shadow (08-08-2016), Neverlift (08-09-2016), SofaKingAwesome (08-09-2016), stockms3 (08-08-2016), WetzMS3 (08-08-2016), Worbit (08-11-2016)
 Old 08-07-2016, 11:02 PM   #11
BLKspd5's Avatar
Posts: 65   (View Stats)
BLKspd5 is just really niceBLKspd5 is just really niceBLKspd5 is just really niceBLKspd5 is just really nice
Like everyone else said. Throw in some Rotella T6 until you can upgrade or get a replacement K04. You'll be much happier getting rid of that paperweight and getting something slightly larger.
Engine/Exhaust/Intake
Corksport:Injector Seals, OCC, EBCS, HPFP Internals, Long Catted DP||Magnaflow:CBE||HTP:3.5" Intake & 51r Tray||JBR:Boost Tubes, Recirc. Hose||CP-E:TMIC||Cobb:Accessport V3(Freektune)||Forge:V2 BPV(Blue Spring)||Damond Motorsports:Full EGR Delete||NGK 6510
Suspension/Chassis
Corksport:Camber Plates, FSB/RSB, Endlinks, Short Shifter||JBR:Rear Camber Arms||CP-E:RMM||H&R:Street Performance Coilovers||Damond Motorsports:PMM, TMM
BLKspd5 is offline   Reply With Quote
 Old 08-08-2016, 03:59 AM   #12
stockms3's Avatar
Posts: 840   (View Stats)
Groans: 74
What the fuck? WHAT?
Almost made me spill my coffee. Thanks for pointing that out because I was actually going to make a valuable comment.
I have seen a girl trying goFundMe for nursing school, when going out and driving a BMW. I called her out so hard she removed the page. However, a GoFundMe page to fix a turbocharged car worth at least $3k with a rod knock. What the fuck is wrong with people? Like how does ones brain operate that makes em think its cool?
Like:
-Oh man I just signed up to this car forum.
-Gotta make a new post, hmm gotta share my GoFundMe page because I bought a turbocharged car and installed coilovers, now I don't have money to fix the smoking turbo.
-Man these guys are going to love me
I will remember this post forever.
Cheapspeed and Mack_Sant like this.
The Following 6 Users Say Thank You to stockms3 For This Useful Post:
Cheapspeed (08-08-2016), KiwiFlavor (08-08-2016), Mack_Sant (08-17-2016), MS3Shadow (08-08-2016), SofaKingAwesome (08-09-2016), Worbit (08-11-2016)
 Old 08-08-2016, 05:16 AM   #13
KiwiFlavor's Avatar
Posts: 2,447   (View Stats)
Or walmart...
2012 NASA Spaceship Gray MS3
MD1032 (08-08-2016)
 Old 08-08-2016, 06:29 AM   #14
stockms3's Avatar
Groans: 74
You can buy a new k04 on eBay for like $150. Easy fix. Can't believe everyone is buying this bnr turbo.
(Sarcasm bnr = love)
 Old 08-08-2016, 08:01 AM   #15
g00s3y's Avatar
Groans: 438
1. List all your mods, lets see if it's "fully" bolted. Or do you need someone to tell you what mods you have?
2. Cool
3. You have a jack that came with the car, no excuse. And if you are talking about jack stands (not jacks), they are about $30 at anywhere. If you can't afford them, you can't afford to mod a car.
4. You installed coils, but can't do an oil change?
5. "colder intake" and "meth injector", you definitely have a lot of learning to do.
Did I come across any less "jackoffy" this time?
And you're fucking pathetic for starting a gofundme to try and fix your car. Go get a fucking job and earn money like everyone else.
Cheapspeed and robbspeed like this.
The Following 15 Users Say Thank You to g00s3y For This Useful Post:
BLKspd5 (08-08-2016), Cheapspeed (08-08-2016), CJ Speed6 (10-13-2016), Djohns (08-08-2016), Jdab (08-08-2016), KiwiFlavor (08-08-2016), knocturnal (08-09-2016), MD1032 (08-08-2016), MS3Shadow (08-08-2016), robbspeed (08-08-2016), Snip (08-09-2016), Thor Hammer (09-04-2016), WetzMS3 (08-08-2016), Worbit (08-11-2016), _SPEED3GT_ (08-10-2016)
 Old 08-08-2016, 08:07 AM   #16
CJ Speed6 (10-13-2016), KiwiFlavor (08-08-2016), monkey.bones.007 (08-09-2016), Speed3Pedro (08-09-2016), Worbit (08-11-2016)
 Old 08-08-2016, 08:50 AM   #17
The Following 4 Users Say Thank You to MS3Shadow For This Useful Post:
alden (08-08-2016), CJ Speed6 (10-13-2016), KiwiFlavor (08-08-2016), Worbit (08-11-2016)
 Old 08-08-2016, 08:51 AM   #18
CJ Speed6 (10-13-2016), Worbit (08-11-2016), _SPEED3GT_ (08-10-2016)
 Old 08-08-2016, 08:54 AM   #19
KiwiFlavor's Avatar
Worbit (08-11-2016)
 Old 08-08-2016, 09:01 AM   #20
g00s3y's Avatar
Groans: 438
 Old 08-08-2016, 09:01 AM   #21
Worbit (08-11-2016)
 Old 08-08-2016, 09:17 AM   #22
Worbit (08-11-2016)
 Old 08-08-2016, 09:25 AM   #23
Worbit (08-11-2016)
 Old 08-08-2016, 06:45 PM   #24
sheston's Avatar
Posts: 1,847   (View Stats)
I hate to break up the What the fuck? thread, but doesn't white smoke mean moisture? Is that a sign of the K04 seal failing? I thought they blew blue or gray smoke with oil.
Other things besides the higher weight oil, rpm increase to 900 rpm (or 1k since I like round numbers), the B-bolt thingy, and the don't care and drive it like you stole it philosophy.
I forgot to add my wise ass comment of don't let your K04 smoke, that will kill it :-)
robbspeed and BenderIsGreat like this.
 Old 08-08-2016, 07:44 PM   #25
Posts: 2,826   (View Stats)
Can't do coil overs without lifting the chassis, for sure. A floor jack and stands are inexpensive. Looking forward to the mod list, too.
OP: do your homework in the threads here. Rotella T6 and a bump up to +200 in idle rpm are good ways to address your issues.
FWIW, we are tough on newbies who expect to be spoon fed on things that are the subject of repeated threads and special "stickies" intended to collect commonly recurring issues.
Welcome to MSF. Get a thick skin and read the wealth of information before asking stupid questions that have been answered over, and over, and over, and over . . .
 Old 08-08-2016, 08:25 PM   #26
Bingo's Avatar
Posts: 740   (View Stats)
Groaned at 9 Times in 7 Posts
@Ben Diesel; if you'd like me to re-type my rant I posted on your "charity for my toy because I'm too proud to drive a car I can actually afford, and it's more important than underpaid veterans or overly-expensive cancer treatments" thread please let me know.
VulgarKyle and robbspeed like this.
The Following 9 Users Say Thank You to Bingo For This Useful Post:
Djohns (08-08-2016), jdutch (08-14-2016), KiwiFlavor (08-09-2016), MD1032 (08-09-2016), MS3Shadow (08-09-2016), robbspeed (08-08-2016), Speed3Pedro (08-09-2016), stockms3 (08-08-2016), Worbit (08-11-2016)
 Old 08-08-2016, 10:26 PM   #27
stockms3's Avatar
Groans: 74
OP right now
robbspeed likes this.
The Following 10 Users Say Thank You to stockms3 For This Useful Post:
alden (08-08-2016), Djohns (08-08-2016), KiwiFlavor (08-09-2016), MD1032 (08-09-2016), MS3Shadow (08-09-2016), OCspeed (08-11-2016), Speed3Pedro (08-09-2016), WetzMS3 (08-09-2016), Worbit (08-11-2016), _SPEED3GT_ (08-11-2016)
 Old 08-09-2016, 08:12 AM   #28
COCKSTRONG
SofaKingAwesome's Avatar
Posts: 8,447   (View Stats)
Groans: 890
Now THIS is a perfect example of threads that should be consumed by a dumpster fire of GIFs
The Following 5 Users Say Thank You to SofaKingAwesome For This Useful Post:
g00s3y (08-09-2016), KiwiFlavor (08-09-2016), MD1032 (08-09-2016), MS3Shadow (08-09-2016), Worbit (08-11-2016)
 Old 08-09-2016, 08:16 AM   #29
O rly?
The Following 6 Users Say Thank You to WetzMS3 For This Useful Post:
AwAfrican (08-10-2016), KiwiFlavor (08-09-2016), MD1032 (08-09-2016), MS3Shadow (08-09-2016), SofaKingAwesome (08-09-2016), Worbit (08-11-2016)
 Old 08-09-2016, 09:13 AM   #30
monkey.bones.007's Avatar
Posts: 3,853   (View Stats)
The Following 3 Users Say Thank You to monkey.bones.007 For This Useful Post:
KiwiFlavor (08-09-2016), MD1032 (08-09-2016), Worbit (08-11-2016)
 Old 08-09-2016, 09:49 AM   #31
g00s3y's Avatar
Groans: 438
I'm really hoping OP comes back to respond. @Ben Diesel; please, we request your presence here. Also, we need answers to the questions asked previously in this thread.
Thank you and enjoy the rest of your stay here at MSF.
The Following 3 Users Say Thank You to g00s3y For This Useful Post:
KiwiFlavor (08-09-2016), WetzMS3 (08-09-2016), Worbit (08-11-2016)
 Old 08-09-2016, 09:56 AM   #32
@Ben Diesel; how do you like those Raceland Ultimo's bro?
Djohns (08-09-2016), g00s3y (08-09-2016), Worbit (08-11-2016)
 Old 08-09-2016, 10:12 AM   #33
 Old 08-09-2016, 10:17 AM   #34
Djohns's Avatar
I would much prefer stock suspension over raceland.
Neverlift likes this.
Soon:built motor
KiwiFlavor (08-09-2016), Neverlift (08-09-2016), Worbit (08-11-2016)
 Old 08-09-2016, 10:22 AM   #35
g00s3y's Avatar
Groans: 438
Awesome ride quality, he's now able to hit every bump in the road, feel them, and the bottom of the car getting scraped up each time. All while his rear wheels sit at an angle where only 70% of the tire is making contact with the road. And a 100% decrease in ride quality all around.
Still wondering how he was able to install them without a jack, and by himself apparently. Quite amazing for a guy who can't do his own oil change.
@Ben Diesel; come on back. All you have to do is apologize and start telling the truth and we can all be best friends again.
Seawing likes this.
The Following 4 Users Say Thank You to g00s3y For This Useful Post:
Djohns (08-09-2016), KiwiFlavor (08-09-2016), WetzMS3 (08-09-2016), Worbit (08-11-2016)
 Old 08-09-2016, 10:26 AM   #36
KiwiFlavor's Avatar
You forgot nudes from certain family members..
The Following 3 Users Say Thank You to KiwiFlavor For This Useful Post:
g00s3y (08-09-2016), monkey.bones.007 (08-09-2016), Worbit (08-11-2016)
 Old 08-09-2016, 10:27 AM   #37
Well, he must have a forklift or something. It'd be equally amazing to be "fully bolted" without a jack.
@Ben Diesel; is this how you did all your bolting?
g00s3y (08-09-2016), KiwiFlavor (08-09-2016), Speed3Pedro (08-09-2016), Worbit (08-11-2016)
 Old 08-09-2016, 10:53 AM   #38
g00s3y's Avatar
Groans: 438
I'm almost 100% sure he bought it "fully bolted".
And I'm very curious to know about him, because asking for money from random people on the internet to help fix a "fully bolted" car that he just bought, is on a whole different level of pathetic. I'm assuming he's under 21, someone helped buy him the car. Car has problems, and instead of spending the money he had to fix the problems the car has, he decided to put shitty coils on it and lower the car because "it's cool". Then go create a gofundme to try and get other people to pay for his shit. Sounds like the typical entitled millennial twat.
Of course, i'm just assuming, what do I know.
 Old 08-09-2016, 11:03 AM   #39
g00s3y likes this.
g00s3y (08-09-2016), KiwiFlavor (08-09-2016), Worbit (08-11-2016)
 Old 08-09-2016, 11:12 AM   #40
KiwiFlavor's Avatar
AwAfrican likes this.
Worbit (08-11-2016)
Page generated in 0.60755 seconds with 36 queries
