Like Tree9Likes
 Old 02-24-2013, 02:46 PM   #1
evidence's Avatar
Posts: 1,033   (View Stats)
::17 years later:: I can only guess at the amount we are scaling, when he went to the 3" intake I just dialed it in for post meth sensor AFRs, and he's never run without spraying. Maybe 8% with the D07 nozzle? At any rate, his most recent logs show 385g/s, so he's likely a bit above 400.
His final map is load based, which fixed the high rpm load compensation and used the new injector scaling tables that were recently added to ATR to get around those load caps. You can see he hit those caps in the above VD which caused him to go rich. Things are pretty steady around 12.1 currently, but since it's a larger intake and he's using boost readings for the meth spray it fluctuates a bit into high 11s. I hear if you tune off the MAF voltage you can clean up that early dip from big nozzle spray, but it's probably not worth the swap.
Post fixes, he made 415whp 400tq @24psi on the dyno yesterday I believe it was.
Some things.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f498/iwg-atp-gtx3071r-how-far-should-flapper-131504/
gt3071 help or suggestions - DFW Mazdas This thread Refback 02-04-2014 05:10 PM
gtx3071r bigRED MazdaSpeed 3/6 - Dyno Sheets/Discussions 7 07-11-2012 05:19 PM
GTX3071R? Cataphract_40 MazdaSpeed 3/6 - Big Turbo Builds 17 10-28-2011 10:46 AM
How far does an IWG flapper door move? Justin Lee MazdaSpeed 3/6 - Turbo Induction 10 07-19-2010 01:48 PM
Open Arms in Open Wheels: reunited IndyCar season kicks off at Homestead Haltech Automotive News 0 04-01-2008 09:20 AM
Page generated in 0.30054 seconds with 22 queries
