| Not Ranked : 0 score I got mine from @SilverDemon; Thanks again! But I don't have the boost switch. Also when I get misfire codes, they always pop up at idle or under normal highway driving. I know it's not blowout, but still I wonder if this unit will be effective if it's enabled under all conditions and not just under boost.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f498/kenne-bell-boost-spark-63536/ | ||||
| side gapping plugs - Page 2 | This thread | Refback | 07-24-2014 06:06 PM | |
| Boost-A-Spark - Kenne Bell - Page 3 | This thread | Refback | 04-30-2014 02:33 PM | |
| 'Saved by the Bell' Fan Takes It to the Max | Haltech | Celeberty Smut | 0 | 07-05-2009 07:50 AM |
| 'Saved by the Bell' Fan Takes It to the Max | Haltech | Celeberty Smut | 0 | 07-04-2009 03:10 AM |
| Billy Mays Had Just Inked a Deal with Taco Bell | Haltech | Celeberty Smut | 2 | 06-28-2009 05:36 PM |
