Like Tree6Likes
 Old 11-03-2010, 09:21 PM   #1
turd burglar's Avatar
Posts: 1,895   (View Stats)
Groans: 39
Default Kenne bell boost a spark
Got my BAS in the mail the other day and had a few questions if anyone might know the answer to em. Its in cabin adjustable from 0-50% boost in spark and it has 2 wires meant for boost sensing so it can kick in only under boost conditions and not be running full spark all the time, my question is, does the hks unit react only under boost, or is it giving a full increase in spark the whole time? since it supposesdly improves mileage and such, i'd think its giving full spark boost the entire time, but maybe it puts out more or less givin different variables. any input is appreciated!
 Old 11-03-2010, 10:03 PM   #2
rigor's Avatar
Posts: 2,399   (View Stats)
Groans: 40
ok here is the how to, with a little test @ the beginning.
i pulled my plugs, and replaced them, and gaped them @ 42 thou
it made a major difference in my situation, smoother idle, crisper acceleration, and no missing!! what a huge difference!
im so excited!!
ok first i tested the battery !
this is with it hooked up, with the switch off
on 0, in boost switch satisfied
on 10
on 20
0n 30
on 40
on 50
testing is done it works! any way that gives you an idea how it works it has everywhere in between for ajustment!
a little velcro
and placed it
boost switch
boost switch, and vacuum hose, and tee
assembled
cut the line to my boost gauge
installed the boost switch in line
wires h/u from the bas
grounded bas
wires routed
adjustment knob in glove box
2nd wire on the bottom of the plug to the left, it is green
quick continuity test
back side of the plug
cut this wire, and the end that goes into the harness, is hooked to the non fused red wire off the bas
now the end that comes off the plug, is wired to the fused red wire from bas
here are the plugs im running
well i hope that helped, and that is all their is to it!
at 104000 2 bent rods
tuned by nishan
The Following 9 Users Say Thank You to rigor For This Useful Post:
cld12pk2go (01-23-2011), djuosnteisn (01-23-2011), Docnox (03-19-2011), dougefresh_ (04-02-2011), LuczOr (03-24-2011), SJP0tato (07-19-2011), SpeedSixxx (03-17-2011), spnkr21 (01-23-2011), turd burglar (01-22-2011)
 Old 11-03-2010, 10:55 PM   #3
Groans: 39
cleaner spark can improve mileage, not alot but somewhat, i need to order the switch from kenne bell. rigor pm me with the how to on one of the things! gracias!
 Old 11-03-2010, 11:49 PM   #4
rigor's Avatar
Groans: 40
here shoot them an email ask for the install instructions they reply quick
KenneBell@KenneBell.net
tuned by nishan
 Old 11-06-2010, 01:45 PM   #5
kmac's Avatar
Posts: 1,792   (View Stats)
I wanted to order one as well,but I never did being lazy. I do like how it ups the voltage on the coils only under boost pretty dope. Good luck let me know how u like it, I'm very interested.
The Following User Says Thank You to kmac For This Useful Post:
 Old 11-06-2010, 07:19 PM   #6
Groans: 39
it'll be awhile before i install it, i is slow movin lol
 Old 11-06-2010, 07:24 PM   #7
2007speed3's Avatar
Posts: 1,486   (View Stats)
2007speed3 is the leader of the world2007speed3 is the leader of the world2007speed3 is the leader of the world2007speed3 is the leader of the world2007speed3 is the leader of the world2007speed3 is the leader of the world2007speed3 is the leader of the world2007speed3 is the leader of the world2007speed3 is the leader of the world2007speed3 is the leader of the world2007speed3 is the leader of the world
Groans: 70
is this like the HKS unit?
2007speed3 is offline   Reply With Quote
 Old 01-07-2011, 07:09 AM   #8
turd what ever happened with this?
 Old 01-07-2011, 07:37 AM   #9
spnkr21's Avatar
Posts: 2,827   (View Stats)
Groans: 105
For real...
2012 WRX HB w/mudflaps yo!
 Old 01-07-2011, 11:52 AM   #10
rigor's Avatar
Groans: 40
i got it, and i have some parts in route to do the install
here is what i interrupted, the way it hooks up ill post the real way later
their sending me the directions it should be here today or Monday
ground not pictured
tuned by nishan
The Following 7 Users Say Thank You to rigor For This Useful Post:
doubleflusher (01-09-2011), dougefresh_ (04-02-2011), fishin53 (01-09-2011), I Love Brownies (01-07-2011), JacksonMS30 (01-11-2011), NJSPEED3 (01-09-2011), rfinkle2 (07-20-2011)
 Old 01-09-2011, 08:47 AM   #11
Tripple OG
NJSPEED3's Avatar
Posts: 5,703   (View Stats)
Groans: 113
keep us updated Rigs!
rigor (01-09-2011)
 Old 01-09-2011, 09:03 AM   #12
rigor's Avatar
Groans: 40
ill do a install with pics if you like
tuned by nishan
The Following 4 Users Say Thank You to rigor For This Useful Post:
dougefresh_ (04-02-2011), JacksonMS30 (01-11-2011), NJSPEED3 (01-09-2011), turd burglar (01-09-2011)
 Old 01-09-2011, 09:29 AM   #13
Tripple OG
NJSPEED3's Avatar
Groans: 113
please do add some before and after logs showing timing,gs,load,afr from the sb to compare. Thanks bud
The Following 2 Users Say Thank You to NJSPEED3 For This Useful Post:
dougefresh_ (04-02-2011), rigor (01-09-2011)
 Old 01-09-2011, 09:35 AM   #14
cpolly69's Avatar
Posts: 2,116   (View Stats)
Groans: 27
I'm curious about the long term on this thing as well. It's nice to know there is a def alternative to the HKS that costs close to half the price. I just fear the before mentioned "melting of coils" and keep in mind that the coils are connected directly to the ecu, so nasty spikes through the system could wind up being very costly.... Not to say that stuff is def going to happen, just being skeptical....
08 CB MS3 Sport
Sold
01 MX-5 (Project)
03 P5 (DD)
The Following User Says Thank You to cpolly69 For This Useful Post:
NJSPEED3 (01-10-2011)
 Old 01-09-2011, 10:53 PM   #15
rigor's Avatar
Groans: 40
they have been around about 11 years or longer, so i dont think that is a problem, and it only juices the coils under boost! and you can choose how much added voltage you need by a dial from 12-20V
tuned by nishan
The Following 6 Users Say Thank You to rigor For This Useful Post:
cpolly69 (01-10-2011), djuosnteisn (01-11-2011), dougefresh_ (04-02-2011), NJSPEED3 (01-10-2011), SpeedSixxx (03-17-2011), spnkr21 (01-10-2011)
 Old 01-10-2011, 12:46 AM   #16
Tripple OG
NJSPEED3's Avatar
Groans: 113
This ignition kit has been in use for a long time I really dont think spikes are possible, there should be something implemented in the hardware to avoid something like that, not to mention there is a fuse inline.
The Following 4 Users Say Thank You to NJSPEED3 For This Useful Post:
cpolly69 (01-10-2011), dougefresh_ (04-02-2011), SpeedSixxx (03-17-2011), spnkr21 (01-10-2011)
 Old 01-10-2011, 03:46 PM   #17
jax ms3gt's Avatar
Posts: 1,151   (View Stats)
I agree that there probably aren't spikes to worry about if it has been around for awhile it was probably properly engineered, but fuses don't protect against voltage spikes. They protect circuits from drawing too much power (amps). Probably integrated into ckt is a filter (think capacitor and coil for example) to prevent spikes and noise..just saying
PERM TUNED
 Old 01-10-2011, 03:28 PM   #18
cpolly69's Avatar
Groans: 27
yeah i wasn't really clear on exactly where the fuse was in relation to the coils and their wires leading into the ecu just by going off that diagram drawn above - i guess i'd like to see either some real pics or the install instructions -
and just b/c the company has experience amping up coil packs on other cars that may or may not have a can-bus setup like we do where everything goes in and out of the main ecu doesn't mean it's 100% full proof on our car
msd has been around forever - a few years ago i was installing a simple shift light and made a few wiring mistakes and toasted my ecu, along with a coil, and my maf - granted they were my mistakes, but anything is possible when messing with this type of stuff.......
08 CB MS3 Sport
Sold
01 MX-5 (Project)
03 P5 (DD)
 Old 01-10-2011, 03:32 PM   #19
just to note i think the MS6 has a separate control box for the CP's compared to the MS3 having them directly connected to the ECU.
 Old 01-10-2011, 03:33 PM   #20
cpolly69's Avatar
Groans: 27
it does - just like lots of other cars w/ cps
08 CB MS3 Sport
Sold
01 MX-5 (Project)
03 P5 (DD)
 Old 01-10-2011, 04:27 PM   #21
rigor's Avatar
Groans: 40
ill shoot kb a e mail on the subject
tuned by nishan
 Old 01-10-2011, 04:28 PM   #22
kmac's Avatar
Just put in a diode so it can't back feed the pcm if your worried about spikes.
btstarcher (05-11-2013)
 Old 01-10-2011, 06:14 PM   #23
rigor's Avatar
Groans: 40
it has to have one ^^ or a couple anyway they have been out for years on boosted fords and their on fuel injected cars ,so they has computer too
i deleted his stinkin email dammit, now it will take a little while to get a response
tuned by nishan
The Following User Says Thank You to rigor For This Useful Post:
kmac (01-10-2011)
 Old 01-10-2011, 07:47 PM   #24
kmac's Avatar
Yup,I kind of figured that it would have it installed I've delt with kenne bell before they're pretty awesome. By the way, I love the intercooler.
rigor (01-13-2011)
 Old 01-11-2011, 12:26 PM   #25
rigor's Avatar
Groans: 40
HERE IS HIS RESPONSE
Hey Justin
LOL well they need to take a basic electrical class if they think the voltage going to the coils is a AC Voltage type of system. The voltage going through the BAS as well as to the pump could not suddenly change direction. It is a DC (direct current) electrical system, the voltage flows one way negative to positive. If this was the case it would do it stock even without the BAS, blowing up computers. They are looking too far into it we have never had a PCM fail from the BAS. All we are doing is increasing the amount of voltage going to the COILS using the stock wiring nothing else. Plus the system is protected by minimum two fuses and a relay it would pop those before damaging the PCM, IF the voltage/current could change direction. Hope this helps,
tuned by nishan
dougefresh_ (04-02-2011), NJSPEED3 (01-24-2011), SpeedSixxx (03-17-2011), thanox2 (01-11-2011)
 Old 01-11-2011, 06:41 PM   #26
kmac's Avatar
Hey Justin
LOL well they need to take a basic electrical class if they think the voltage going to the coils is a AC Voltage type of system. The voltage going through the BAS as well as to the pump could not suddenly change direction. It is a DC (direct current) electrical system, the voltage flows one way positive to negative. If this was the case it would do it stock even without the BAS, blowing up computers. They are looking too far into it we have never had a PCM fail from the BAS. All we are doing is increasing the amount of voltage going to the COILS using the stock wiring nothing else. Plus the system is protected by minimum two fuses and a relay it would pop those before damaging the PCM, IF the voltage/current could change direction. Hope this helps, tell them to pick up a book or take a electrical class it makes it so much easier to understand LOL jkWinking smile emoticon.
He should prob pick up a basic electrical book considering dc is the movement of electrons which flow from neg to pos not pos to neg.
The Following 3 Users Say Thank You to kmac For This Useful Post:
jax ms3gt (01-12-2011), rigor (01-13-2011), SpeedSixxx (03-17-2011)
 Old 01-12-2011, 02:43 PM   #27
jax ms3gt's Avatar
HAHA I was going to say the same thing, that electrons flow from negative to positive source. DC says it all direct current, not direct voltage lol..oh well I still think he made a decent point as far as protection
PERM TUNED
The Following User Says Thank You to jax ms3gt For This Useful Post:
rigor (01-13-2011)
 Old 01-11-2011, 12:42 PM   #28
spnkr21's Avatar
Groans: 105
Rigor did you get the instructions from KB via email? I have a hard copy and can put it on here if you don't have it yet. Not sure what wires to hook this up to. Group effort? I got the b-a-s in hand now so need some help!!
The Following 2 Users Say Thank You to spnkr21 For This Useful Post:
dougefresh_ (04-02-2011), rigor (01-13-2011)
 Old 01-11-2011, 12:45 PM   #29
rigor's Avatar
Groans: 40
ya go ahead my stuff hasn't showed yet
dj we need to know witch wire to the coil packs is the hot
thanks!
tuned by nishan
 Old 01-11-2011, 12:47 PM   #30
spnkr21's Avatar
Groans: 105
done ^^^ Now someone tell me what to do haha. So close don't wanna fuck it up
rigor (01-13-2011)
 Old 01-11-2011, 01:21 PM   #31
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
The injectors on the MS6 have a separate driver, the coils are driven by the ECM just like the MS3
thanks!
The +12v wire on the MS3 and MS6 is green at the coils... You should be able to trace the individual wires back to the junction in the harness, but make sure you get just the coils... The diagram for the MS3 shows the power wire for the condenser as the same color and coming from the same junction...
The Following 4 Users Say Thank You to SSinstaller For This Useful Post:
djuosnteisn (01-11-2011), dougefresh_ (04-02-2011), rigor (01-13-2011), spnkr21 (01-11-2011)
 Old 01-11-2011, 06:57 PM   #32
spnkr21's Avatar
Groans: 105
OK I traced the 4 green wires to the junction in the middle of the wiring harness
The 4 wires go in, then 2 wires come out. So which is which? I tried looking through the manual but I must be dumb and can't find shit.
The red arrow is one of the green wires that goes towards the cdfp area.
The orange arrow goes to the orange box.
Any ideas?
The Following 3 Users Say Thank You to spnkr21 For This Useful Post:
djuosnteisn (01-12-2011), rigor (01-13-2011), turd burglar (01-11-2011)
 Old 01-11-2011, 07:38 PM   #33
Groans: 60
Any ideas?
According to the posted instructions..
All you need to do is disconnect the four green coil wires from the main bundle..
The output of your BAS connects to those four wires running to the coils...
The input to the BAS get connected to the green wire(s) running back into the main bundle..
The Following 2 Users Say Thank You to SSinstaller For This Useful Post:
rigor (01-13-2011), spnkr21 (01-23-2011)
 Old 01-11-2011, 12:52 PM   #34
rigor's Avatar
Groans: 40
you just need to know the correct wire right ?
need to pm dj
tuned by nishan
 Old 01-11-2011, 12:58 PM   #35
spnkr21's Avatar
Groans: 105
If we all think hard enough, I bet he will sense it and come in here...
djuosnteisn (01-11-2011), rigor (01-11-2011)
 Old 01-11-2011, 01:00 PM   #36
rigor's Avatar
Groans: 40
wow he is a god!
tuned by nishan
 Old 01-11-2011, 01:02 PM   #37
spnkr21's Avatar
Groans: 105
No I'm not silly
rigor (01-13-2011)
 Old 01-11-2011, 01:03 PM   #38
rigor's Avatar
Groans: 40
noooo dj he thanked your post already
tuned by nishan
 Old 01-11-2011, 01:04 PM   #39
spnkr21's Avatar
Groans: 105
SHit son!!!
rigor (01-11-2011)
 Old 01-11-2011, 01:07 PM   #40
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
I'd need to look at my car or a manual for the color and location of the wire.
Don't have my car with me at work, and don't have time to look through the manual right now. I can help later tonight probably.
sorry....
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f498/kenne-bell-boost-spark-63536/
side gapping plugs - Page 2 This thread Refback 07-24-2014 06:06 PM
Boost-A-Spark - Kenne Bell - Page 3 This thread Refback 04-30-2014 02:33 PM
'Saved by the Bell' Fan Takes It to the Max Haltech Celeberty Smut 0 07-05-2009 07:50 AM
'Saved by the Bell' Fan Takes It to the Max Haltech Celeberty Smut 0 07-04-2009 03:10 AM
Billy Mays Had Just Inked a Deal with Taco Bell Haltech Celeberty Smut 2 06-28-2009 05:36 PM
Page generated in 0.83514 seconds with 31 queries
