Like Tree9Likes
  • 1 Post By snailD
  • 1 Post By Voltwings
  • 1 Post By Justin@Freektune
  • 3 Post By Lex
  • 1 Post By jdmage_mx5
  • 1 Post By sidekick
 Old 03-20-2014, 09:00 AM   #1
MS6_Newb's Avatar
Posts: 105   (View Stats)
MS6_Newb has much to be proud ofMS6_Newb has much to be proud ofMS6_Newb has much to be proud ofMS6_Newb has much to be proud ofMS6_Newb has much to be proud ofMS6_Newb has much to be proud ofMS6_Newb has much to be proud ofMS6_Newb has much to be proud ofMS6_Newb has much to be proud of
Groaned at 7 Times in 3 Posts
Default Low hp GT3071 help
My mods are in the sig. I put down 280 Virtual Dyno hp @ 22psi on 91 octane. I have 9* max timing any more it knocks. Its lex tuned. 175 bats at redline under wot. 75* at cruise. iat was at 81*. Help please.
Mods: AEM CAI, Cobb AP, AT internals, Juggernaut, Dreadnaught, R6, Ebay DP catted, SURE TMIC, custom 3" Y to dual 2.5" CBE, ATP GT3071, Cobb 3 port, CP-e 4" TIP, LEX Tuned (stratified auto) in progress
MS6_Newb is offline   Reply With Quote
 Old 03-20-2014, 09:09 AM   #2
anavrinIV's Avatar
Posts: 4,490   (View Stats)
Groans: 63
BATS are through the roof and your timing is pretty low. have you, by chance, asked @Lex; about this issue? You're not providing any real information here
Blue Pu.
 Old 03-20-2014, 09:13 AM   #3
Voltwings's Avatar
Posts: 3,713   (View Stats)
A datalog would be much more useful
Past:
-Sold-
-Sold-
Current:
2012 Loaded Speed3 - Stock
2001 Miata - Basically stock
The Following 5 Users Say Thank You to Voltwings For This Useful Post:
chaser27 (03-20-2014), Easter Bunny (03-20-2014), Fail_6 (03-20-2014), MHHC5280 (03-21-2014), snailD (03-20-2014)
 Old 03-20-2014, 09:16 AM   #4
MS6_Newb's Avatar
I yes I talked to him. We're both pretty stumped. Here are 2 datalogs of the finished tune. I'm thinking I need a FMIC and meth. I want to stay away from meth if at all possible. You'll see my TMIC heatsoaks really fast which leads me to believe the core can't flow enough. before my gt3071 I had 130 bats on a OTS stage 2.
 Old 03-20-2014, 09:25 AM   #5
snailD's Avatar
Posts: 3,039   (View Stats)
everything looks pretty on point, that is about the timing curve i typically end up with around here for BT's on pump gas or else we run into knock issues, so thats not a huge concern. I have seen a few people with exhaust issues, like a clogged cat run into similar issues. everything looks great but there is just no power, she can't breathe. Looked into that at all?
MZRSPEED likes this.
 Old 03-20-2014, 09:29 AM   #6
Voltwings's Avatar
You're running a small intake, a Catted DP (probably best for the creep), and are running what i would consider to be rich the entire time.
I ran my 3071 through an ETS top mount, and have since sold that turbo to somone else also running an ETS top mount and it performed just fine, but i am willing to bet something is off somewhere...
Edit: Derp, you're on a speed6, the Gen1 hood scopp design is sub par at best. The ETS core is a great core, but a FMIC would probably do you a world of good at this point. Its not a flow issue, its a heat issue.
Past:
-Sold-
-Sold-
Current:
The Following 3 Users Say Thank You to Voltwings For This Useful Post:
Chimmike (03-20-2014), Easter Bunny (03-20-2014), ItsNox (05-25-2014)
 Old 03-20-2014, 09:30 AM   #7
Captain KR's Avatar
Posts: 2,320   (View Stats)
Captain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the world
Groans: 391
Groaned at 75 Times in 49 Posts
10.6 afrs, high as fuck bats, 300 g/s....... seems right
moore automitive 4/13/13 515whp 511 tq
Mason Dixon Raceway 11.289 @125 1.845 60'
Killah Built
Powered By Purple Drank
Captain KR is offline   Reply With Quote
The Following 10 Users Say Thank You to Captain KR For This Useful Post:
anavrinIV (03-20-2014), DSIT995 (03-21-2014), Easter Bunny (03-20-2014), Fail_6 (03-20-2014), Hammology (03-22-2014), Justin@Freektune (03-20-2014), LumberJack (03-20-2014), mxlplx71 (03-20-2014), SarcasticOne (03-20-2014), Voltwings (03-20-2014)
 Old 03-20-2014, 09:38 AM   #8
MS6_Newb's Avatar
I bought the ebay DP catless and installed the 3" cat. I have to run a cat due to emission laws. The cat has 5000km on it but I'll check some time. As for power to car pulls hard just the dyno says otherwise. I have the SURE TMIC which is worse than the ETS if this matters. We are targetting 11.4 AFR but had to richen it due to knock. Lex did say that a 4" intake should get me to the 300hp marker. He also said that my fuel must be really bad.
What I was thinking of doing is getting a bigger intake( please chime in on which one I should get) FMIC ( Cxracing kit with treadstone core suggestions are welcomed) and maybe meth.
 Old 03-20-2014, 09:46 AM   #9
Voltwings's Avatar
I'm thinking there was a misunderstanding somewhere along the lines, if you're targeting an 11.4, then you should be running an 11.4 . As far as the intake is concerned, i have always been a fan of HTP products, their fitment and customer service is top notch. I have always used Lex's MAF cals on the cars with those intakes as well and they've never given me grief.
Past:
-Sold-
-Sold-
Current:
 Old 03-20-2014, 09:55 AM   #10
Justin@Freektune's Avatar
Posts: 954   (View Stats)
Try less boost, more timing. The heat generated by lack of sufficient intercooling is making the car knock happy
ItsNox likes this.
PTE 6062
633HP/523TQ
Quickest/Fastest Mazdaspeed
4/22/2017 New England Dragway
The Following 8 Users Say Thank You to Justin@Freektune For This Useful Post:
Bleupit80 (03-21-2014), chaser27 (03-20-2014), Chimmike (03-20-2014), Easter Bunny (03-20-2014), Hammology (03-22-2014), ItsNox (05-25-2014), LumberJack (03-20-2014), mxlplx71 (03-20-2014)
 Old 03-20-2014, 10:21 AM   #11
manila's Avatar
Posts: 1,767   (View Stats)
I see you're running a AEM CAI w/ 4" TIP?
Try swapping out the CAI for a 3" or 3.5" SRI.
Do you have the shroud installed with the SU TMIC?
Also, put on all necessary heat shields to block off the heat from the ex mani. and DP
'12 MS3 Black Mica w/ Tech
The Following 2 Users Say Thank You to manila For This Useful Post:
 Old 03-20-2014, 10:26 AM   #12
jdmage_mx5's Avatar
Posts: 1,877   (View Stats)
Im with others change out the intake for a bigger SRI, go FMIC since you are MS6. Your BATS seem outrageous. When I was running CPE TMIC I saw about 20 above ambient typically, now that I am FMIC I see about 8-10 degrees on pulls.
 Old 03-20-2014, 10:50 AM   #13
When did we do this tune? I am drawing a blank here since I don't remember an MS6 with these BATs in recent history. The ECU will richen AFRs another half point when BATs get over 130.
The biggest issue here is the outrageous temperatures (resulting in low oxygen density) and the 91 octane fuel which prevents further timing. The tune is set to pull timing further when BATs get to these levels so the fact it is knock free at 160-170* BAT on 91 and 21psi is good.
Send me a PM with your name so I can look through my records.
Captain KR, MZRSPEED and ItsNox like this.
The Following 17 Users Say Thank You to Lex For This Useful Post:
anavrinIV (03-20-2014), Bleupit80 (03-21-2014), bstover17 (03-20-2014), Captain KR (03-22-2014), chaser27 (03-20-2014), Chimmike (03-20-2014), Easter Bunny (03-20-2014), Fail_6 (03-20-2014), Hammology (03-22-2014), ItsNox (05-25-2014), jdmage_mx5 (03-20-2014), Justin@Freektune (03-20-2014), Mike@Stratified (03-20-2014), mxlplx71 (03-20-2014), sidekick (03-20-2014), taf0422 (03-21-2014), Voltwings (03-20-2014)
 Old 03-20-2014, 12:31 PM   #14
MS6_Newb's Avatar
Lex - the tune as done last summer. it doesn't knock but I noticed that everyone is putting down more power. Other than that the tune is great.
I have all heat shields except the dp one as it didn't fit. I have the shroud on the TMIC but theres a 1/4 inch gap all around it.
I guess I'll get the CXRacing FMIC and the HTP intake and see how this goes. I hate throwing money at it but I hate seeing the bats that high and being 50whp below where I should be so to speak.
The Following 2 Users Say Thank You to MS6_Newb For This Useful Post:
ItsNox (05-25-2014), Lex (03-20-2014)
 Old 03-20-2014, 12:39 PM   #15
Cooling should definitely be a first priority.
Not only is the car more knock prone when running this hot, but you are leaving HP on the table simply due to the drop in efficiency of compressing air that is heated to 170*. As you cool the air you will see you will be flowing a good amount more at the same boost level.
Once you get an IC in there to keep BATs at bay send me a message and we can do a top up on the tune.
ItsNox (05-25-2014)
 Old 03-20-2014, 01:16 PM   #16
MS6_Newb's Avatar
This was my plan. should I get meth as well or no?
The Following User Says Thank You to MS6_Newb For This Useful Post:
andrew88 (03-20-2014)
 Old 03-20-2014, 02:53 PM   #17
jdmage_mx5's Avatar
You might look at getting a better intercooler with the cx racing piping kit.
PS lex is the man.
 Old 03-20-2014, 03:03 PM   #18
Boostin'likeAboss's Avatar
Posts: 1,792   (View Stats)
you already shelled out the cash to go BT. might as well shell out the extra 1k for the fmic and meth kit to get a comfortable 350+ whp
or run 50/50 e85 instead of the meth
08 cwp ms3
 Old 03-20-2014, 03:05 PM   #19
MS6_Newb's Avatar
Lex is the man, no argument here. Quick question, am I correct in assuming the MS3 cxracing kit fits on the ms6? I've looked at numerous photos and my car and it seems that it will. I don't like the ms6 kit they offer as it gets rid of the washer fluid which a definitely need where I live.
 Old 03-20-2014, 03:27 PM   #20
sidekick's Avatar
Posts: 3,093   (View Stats)
Groans: 47
Fuck the FMIC, just get meth and tap the cold pipe for it. A better TMIC wouldn't hurt either, but a FMIC is just asking for more headaches with boost leaks, more piping, and losing the washer fluid reservoir.
ItsNox likes this.
The Following 4 Users Say Thank You to sidekick For This Useful Post:
BigjohnB20 (03-21-2014), ItsNox (05-25-2014), speed23 (03-20-2014), Voltwings (03-20-2014)
 Old 03-20-2014, 03:34 PM   #21
fredricktsang's Avatar
Posts: 459   (View Stats)
fredricktsang is the leader of the worldfredricktsang is the leader of the worldfredricktsang is the leader of the worldfredricktsang is the leader of the worldfredricktsang is the leader of the worldfredricktsang is the leader of the worldfredricktsang is the leader of the worldfredricktsang is the leader of the worldfredricktsang is the leader of the worldfredricktsang is the leader of the worldfredricktsang is the leader of the world
Did your intake tract ever get coated in oil from a turbo dying or shooting oil out of the breathers? If so maybe the inside of your IC is coated in oil and not letting the air in there cool properly, just looking at the numbers alone looks as if you have no intercooler.
fredricktsang is offline   Reply With Quote
 Old 03-20-2014, 03:40 PM   #22
MS6_Newb's Avatar
I have a Street Unit 3.25" TMIC and if I change it I'm going FMIC. My intercooler is clean on the inside, double checked to make sure.
Sidekick - the ms3 kits dont remove the washer hence why I asked if they would fit. The ms3 cxracing kit looks just like the cobb kit and the cobb kit works on the ms6 if I'm not mistaken.
 Old 03-20-2014, 03:54 PM   #23
Thehead's GTX3071R, fmic, cp-e exhaust mani build
I'm just gonna follow what this bro did
08 cwp ms3
 Old 03-20-2014, 04:22 PM   #24
MS6_Newb's Avatar
Thanks for the link. That looks identical to the ms3 cxracing kit except for being black and more silicon tubes in his. This confirms to me that the ms3 kit will fit.
 Old 03-20-2014, 08:07 PM   #25
WMI is another very effective way to chemically cool the air charge. With 91 in the tank the bump in octane is very welcome as well.
If I were to suggest the first step in your case between FMIC and WMI it would be WMI due to cost, complexity, and benefits.
ItsNox (05-25-2014)
 Old 03-21-2014, 08:45 AM   #26
MS6_Newb's Avatar
WMI scares me in the form that if it fails how will the computer know and go back to a safe pump gas tune.
 Old 03-21-2014, 11:18 AM   #27
A high end system will have a failsafe. Lower end systems you can watch your BATs occasionally. The tune can be setup such that if it does stop at one point the motor is not instantly hurt.
 Old 03-21-2014, 09:48 AM   #28
Boost_creep's Avatar
Posts: 829   (View Stats)
BAT flags.
You will be happy you installed it, once you do.
www.dizzytuning.com
www.facebook.com/dizzytuning
The Following User Says Thank You to Boost_creep For This Useful Post:
Voltwings (03-22-2014)
 Old 03-21-2014, 01:09 PM   #29
I would advise getting to the root of the problem before getting new parts to band-aid the issue. Assuming the intercooler is fine (possibly try addressing the gap in the shroud gap to see if it helps), I don't think you are running the turbo outside of it's efficiency zone. Have you looked into the BAT sensor?
 Old 03-21-2014, 01:27 PM   #30
BigjohnB20's Avatar
Posts: 779   (View Stats)
It doesn't say in your profile where you are located. What kind of ambient temps are you seeing that is causing BATS to climb into the 170 range? Did you park a hot car in the sun for a while then go do a WOT pull immediately afterwards?
I have an MS6 with TMIC and do struggle with high BATs in the summer when ambient gets up into the 90+ range and the sun is blazin. But even then I really have to try to get BATs up much more than 140 rnage.
2006 BCM MS6 GT
CS SRI/TIP
Jbarone SSP/bushings
cp-e RMM, TMIC, Stiff Diff
AP
KMD V2.whatever
Ebay Catless DP
Grom Ipod
 Old 03-21-2014, 03:19 PM   #31
MS6_Newb's Avatar
I'm from kingsville close to detroit. Ambient was around 85. But it's huMidity here that is the killer, 70%+
 Old 03-21-2014, 07:48 PM   #32
boostdmazda3's Avatar
Posts: 1,177   (View Stats)
boostdmazda3 is the leader of the worldboostdmazda3 is the leader of the worldboostdmazda3 is the leader of the worldboostdmazda3 is the leader of the worldboostdmazda3 is the leader of the worldboostdmazda3 is the leader of the worldboostdmazda3 is the leader of the worldboostdmazda3 is the leader of the worldboostdmazda3 is the leader of the worldboostdmazda3 is the leader of the worldboostdmazda3 is the leader of the world
a gt3071 with 91 piss water octane is a horrible combo espically with that tmic.
Bnr s3/Act 6 puck/sure full 3inch intake/cobb fmic/cobb downpipe/grimmspeed ebc/3 bar map/hks catback/autotech hpfp internals/turbosmart bpv/bc coilovers/jbr trilogy mounts/ngk one step colder plugs/ms6 rims on nt-01 tires. 24 psi E85 freektuned.
Freektuned e85 Focus st as the daily.
boostdmazda3 is offline   Reply With Quote
 Old 03-22-2014, 01:58 AM   #33
Gr33ntumb's Avatar
Posts: 348   (View Stats)
Gr33ntumb has a reputation beyond reputeGr33ntumb has a reputation beyond reputeGr33ntumb has a reputation beyond reputeGr33ntumb has a reputation beyond reputeGr33ntumb has a reputation beyond reputeGr33ntumb has a reputation beyond reputeGr33ntumb has a reputation beyond reputeGr33ntumb has a reputation beyond reputeGr33ntumb has a reputation beyond reputeGr33ntumb has a reputation beyond reputeGr33ntumb has a reputation beyond repute
Detroit skip meth go with crack
170 BAT wtf
CS 3inch intake, CS FP internals, CS Test pipe, Forge V2, AP v3, JBR 88a RMM and mud flops
Gr33ntumb is offline   Reply With Quote
Page generated in 0.53591 seconds with 36 queries
