Like Tree3Likes
  • 1 Post By bmylez
  • 1 Post By djuosnteisn
  • 1 Post By bcmurphy87
 Old 10-24-2011, 10:04 PM   #1
bcmurphy87's Avatar
Posts: 1,435   (View Stats)
Default Low Oil Pressure Built Motor
Hey i was wondering if any of you guys are experiencing low oil pressure on your built motors? At idle im seeing about 19psi and my oil light is flickering. the shop that did the build said they built it loose at about 3000 of tolerance. I used wiesco piston but we moved the oil squirters. Im using carrlilo rods and my compression is 190-190-190-190.
Also what oil and weight are you guys running. Im currently using 15w-40 no synthetic. I have almost put 500 miles on the motor then ill be changing over to synthetic.
I keep getting a cel for p0012. We have checked the timing and believe this light because of the low oil pressure and the vvt can not properly engage.
06 Speed6 GT- Sold
 Old 10-25-2011, 05:05 AM   #2
bmylez's Avatar
Posts: 3,197   (View Stats)
I run Rotella T6 5w40, but I'm not sure if that would help you...ask Dustin what his clearances are since I know he has good oil pressure.
bcmurphy87 likes this.
2007 CTS-V - Trying to sell
bcmurphy87 (10-25-2011)
 Old 10-25-2011, 05:14 AM   #3
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
Yeah that's mad low. Usually a blocked passage would result in high oil pressure, but I wouldn't rule it out.
I'd pull that oil filter and see if there's anything obvious in there.
Also, you may end up needing to pull the pan to inspect the pickup.
"Exclusivity" - CP-enis
Demodded.
The Seals
 Old 10-25-2011, 05:46 AM   #4
Fux Wit It
Darksun280's Avatar
Posts: 9,214   (View Stats)
Groans: 175
I think a local guy had this issue after his built motor and it was his rear main seal. end of the day that motor is going to have to come out to investigate. Sorry man. But give us the run down on the situation? is it your stock block built? did your stock motor die? who did the work? did you reuse any parts. did one shop do the entire build?
Carry on citizens....
10.7 @ 133 auto 1G DSM
 Old 10-25-2011, 06:13 AM   #5
unless the blockage is right before the OP sensor, then the pressure drop would cause this.
i would move your OP sender around to different parts of the oil system and see if you can trace any abnormalities
bcmurphy87 (10-25-2011), Tokay444 (10-25-2011)
 Old 10-25-2011, 09:13 AM   #6
bcmurphy87's Avatar
Thanks for the info guys. I been working with DJ on the matter because were also trying to dial in a tune. The same shop did the entire build. I started with a used block and head but had it all sent off to the machine shop and checked out. I have no oil leaks to my knowledge.
Dj was thinking it was my rod bearing even though there brand new might be to thin for the build. Since no one makes over sized rod bearing my only option would be to get them coated.
I just trying to see if anyone else had this issues
What are you guys oil pressure? What should i be aiming for?
06 Speed6 GT- Sold
Last edited by bcmurphy87; 10-25-2011 at 09:13 AM. Reason: MSF Database - Automerged Doublepost
The Following User Says Thank You to bcmurphy87 For This Useful Post:
djuosnteisn (11-09-2011)
 Old 10-25-2011, 11:12 AM   #7
bcmurphy87's Avatar
I am summoning @djuosnteisn
06 Speed6 GT- Sold
 Old 10-25-2011, 11:36 AM   #8
bcmurphy87's Avatar
do you have an oil pressure gauge? what is your pressure running this oil. Dj suggested the same oil to me.
06 Speed6 GT- Sold
 Old 10-25-2011, 11:49 AM   #9
kmac's Avatar
Posts: 1,792   (View Stats)
It sounds like a clearance issue . Did they plasi-gauge everything ? Also take a reading of oil pressure at the head . There should be a spot u can check it at , you should have some real low pressure there.
 Old 10-25-2011, 12:25 PM   #10
Im not sure how loose that tolerance is, but if the motor is buil loose you will need to run heavier oil to account for the larger gaps
 Old 10-25-2011, 01:04 PM   #11
bcmurphy87's Avatar
Im gonna switch over to the 5w-50 tonight and see how that does, but i think that is only masking an issue.
06 Speed6 GT- Sold
 Old 10-25-2011, 01:10 PM   #12
spnkr21's Avatar
Posts: 2,827   (View Stats)
Groans: 105
BSD? Did you plug the oil feed to the bs?
2012 WRX HB w/mudflaps yo!
 Old 10-25-2011, 01:46 PM   #13
bcmurphy87's Avatar
Oh wow i wonder if that did get plugged. I know the BSD is out. man i really dont want to have to drop the pan lol.
06 Speed6 GT- Sold
 Old 10-25-2011, 02:25 PM   #14
spnkr21's Avatar
Groans: 105
Did you buy a plug for them to install?
If not it's a pretty easy fix.
I wouldn't run the car without one.
 Old 10-25-2011, 02:48 PM   #15
ALIEN3T's Avatar
Posts: 169   (View Stats)
ALIEN3T has a reputation beyond reputeALIEN3T has a reputation beyond reputeALIEN3T has a reputation beyond reputeALIEN3T has a reputation beyond reputeALIEN3T has a reputation beyond reputeALIEN3T has a reputation beyond reputeALIEN3T has a reputation beyond reputeALIEN3T has a reputation beyond reputeALIEN3T has a reputation beyond reputeALIEN3T has a reputation beyond reputeALIEN3T has a reputation beyond repute
We had that issues, I installed a motor. he had another shop build. Once car got warm oil preassure ligh flicked at idle. (light comes on around 10psi) dropped pan (its usually not that bad). and sure enough the BSD kit was not there. Bolt or plate to block hole. Installed it, Cheacked preassure after instal. Ran to specs. Car has been running fine (and tracked and bolt ons added) since then. he has a few thousand miles. already.
ALIEN3T is offline   Reply With Quote
The Following 5 Users Say Thank You to ALIEN3T For This Useful Post:
bcmurphy87 (11-07-2011), bertrand_CX_7 (11-07-2011), Darksun280 (10-26-2011), Easter Bunny (10-26-2011), wolly6973 (11-07-2011)
 Old 11-07-2011, 11:41 AM   #16
bcmurphy87's Avatar
Still getting the flickering of the oil light at idle. The prosport gauge shows 20+ psi and im still getting the flickering dash light. Any idea what this maybe. I am on thicker oil now though.
06 Speed6 GT- Sold
 Old 11-07-2011, 11:56 AM   #17
kmac's Avatar
Did u drop the pan and make sure your bs delete is in ? Also did you make sure the pick up is tight and has the o-ring installed?
First 500whp stock block mazdaspeed3 (503whp 423wtq)
<3 Tokay.
The Following 2 Users Say Thank You to kmac For This Useful Post:
bcmurphy87 (11-07-2011), wolly6973 (11-07-2011)
 Old 11-07-2011, 12:46 PM   #18
bcmurphy87's Avatar
i did drop the oil pan the bsd is there and ill check the oil pick up. i need to change my oil this weekend.
06 Speed6 GT- Sold
The Following 2 Users Say Thank You to bcmurphy87 For This Useful Post:
kmac (11-07-2011), Tokay444 (11-07-2011)
 Old 11-07-2011, 02:01 PM   #19
rabble rabble
802MS3's Avatar
Posts: 5,318   (View Stats)
Groans: 221
19psi of oil pressure is pretty normal at idle i believe. i have the sandwich plate above the filter and when the motor is warm, oil pressure reads about 12-15psi. increases linearly with rpm.
'08 CWP MS3 w/ T3 3071r
kmac (11-07-2011)
 Old 11-07-2011, 02:10 PM   #20
Tokay444's Avatar
Groans: 793
Possibly just a bad sensor then.
Demodded.
The Seals
kmac (11-07-2011)
 Old 11-07-2011, 02:18 PM   #21
708
Erich's Avatar
Posts: 4,274   (View Stats)
Same for me. Routinely have seen between 15-20 PSI at idle for 3 years now. Both on the stock block (from about 3000 miles on) and now on the built block. I would have to guess your dummy light sensor is bad.
 Old 11-09-2011, 09:42 AM   #22
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
Pssshhhh..... OP's oil issue has nothing on his fueling issue.
Hahaha.
Should have lit a match Chris, hahaha.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
rigor (11-10-2011)
 Old 11-13-2011, 12:15 AM   #23
SPEED6 KILLAH's Avatar
Posts: 1,176   (View Stats)
SPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the world
Do you have the oil pressure sensor on the sandwich plate or on the filter housing ?
Try this
1. Remove the oil pressure switch.
2. Screw in a oil pressure gauge into oil pressure switch installation hole.
3. Warm up the engine to normal operating temperature.
4. Run the engine at the specified speed, and note the gauge readings.
If not within the specification, inspect for the cause and repair or replace if necessary.
NOTE:
The oil pressure can vary with oil viscosity and temperature.
Oil pressure (reference value)
[oil temperature: 100 °C {212 °F}]
297—551 kPa {3.03—5.61 kgf/cm2, 43.1—79.9 psi} [3,000 rpm]
SPEED6 KILLAH is offline   Reply With Quote
The Following 2 Users Say Thank You to SPEED6 KILLAH For This Useful Post:
802MS3 (07-18-2012), qtrmile beast (11-13-2011)
 Old 11-13-2011, 06:46 AM   #24
pinkcheese's Avatar
Posts: 339   (View Stats)
pinkcheese is the leader of the worldpinkcheese is the leader of the worldpinkcheese is the leader of the worldpinkcheese is the leader of the worldpinkcheese is the leader of the worldpinkcheese is the leader of the worldpinkcheese is the leader of the worldpinkcheese is the leader of the worldpinkcheese is the leader of the worldpinkcheese is the leader of the worldpinkcheese is the leader of the world
If you are pushing low oil pressure and everything is accounted for such as the BSD you might consider running a 20w50 oil. On a built turbo engine you really should run the thickest oil possible. AMSoil has some great articles on built engines tolerances and oil weight. If you want some reference material. Also fuck plasti gauge use a proper tool sense that only measures one area and is a biased measurement.
Did you check the BSD by removing it and inspecting the O-ring? I have seen these fail on a few kits if the O-ring is made of rubber just a heads up. Best is to ether have a plug pressed into the hole with a back plate for support or welding it shut.
pinkcheese is offline   Reply With Quote
The Following User Says Thank You to pinkcheese For This Useful Post:
bcmurphy87 (07-16-2012)
 Old 07-16-2012, 10:01 AM   #25
Captain KR's Avatar
Posts: 2,320   (View Stats)
Captain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the world
Groans: 391
Groaned at 75 Times in 49 Posts
@bcmurphy87 did you ever resolve the flickering light or learn to live with it
@superskaterxes
moore automitive 4/13/13 515whp 511 tq
Mason Dixon Raceway 11.289 @125 1.845 60'
Killah Built
Powered By Purple Drank
Captain KR is offline   Reply With Quote
 Old 07-16-2012, 10:12 AM   #26
bcmurphy87's Avatar
Yea i solved it after i spun 3 of 4 bearings lol. The PTP bsd plug that was in my used block failed and wasnt holding pressure and finally gave out and dropped all pressure. It was a freeze plug design. Im now using a sure bsd plug and no issues.
Captain KR likes this.
06 Speed6 GT- Sold
The Following 7 Users Say Thank You to bcmurphy87 For This Useful Post:
802MS3 (07-18-2012), atvfreek (07-16-2012), Captain KR (07-16-2012), doubleflusher (07-16-2012), Easter Bunny (07-16-2012), phate (07-19-2012), superskaterxes (07-16-2012)
 Old 07-16-2012, 10:15 AM   #27
doubleflusher's Avatar
Posts: 20,650   (View Stats)
Groans: 1,443
Add that to the list of failed PTP products.
Beanfab / Tuned by Nishan
802MS3 (07-18-2012), atvfreek (07-16-2012), SilverDemon (07-16-2012)
 Old 07-16-2012, 10:19 AM   #28
Captain KR's Avatar
Groans: 391
@qtrmile beast this is my issues to the ...... what bsd was used???
i fucking hate you btw
Killah Built
Last edited by Captain KR; 07-16-2012 at 10:43 AM. Reason: MSF Database - Automerged Doublepost
 Old 07-16-2012, 10:54 AM   #29
bcmurphy87's Avatar
why am i hated its because im a jew isnt it
06 Speed6 GT- Sold
Tokay444 (07-16-2012)
 Old 07-16-2012, 11:01 AM   #30
Captain KR's Avatar
Groans: 391
lol damn whiteys holding niggas down making me down and now you jew's start holding me down wtf is up with that bro?
Killah Built
 Old 07-16-2012, 11:02 AM   #31
qtrmile beast's Avatar
Posts: 2,423   (View Stats)
Can't remember but i think we got this from street unit.. you can see a pic of it here... sorta
As i told you this morning that my car is doing this wild LOW OIL LIGHT thing in my car as well. It just started on my car though and i have 20,000 miles on my built motor. But my DEFI oil pressure gauge shows i am getting the same oil pressure as i have always gotten as its warming up it is about 60 psi. At idle i get about 19-21 psi i believe. I will take a video tomorrow as to what mine is doing. I also checked my oil and the level is fine. I let my car Idle for about 20 minutes or so this morning and the flickering light was there. This is the first i have ever seen of this..
track weight 3220
street weight 3370
 Old 07-16-2012, 11:49 AM   #32
bcmurphy87's Avatar
Stop driving it!!!! you should have like 45-50+ at idle. i had the same oil pressure 19-20 before i spun all 3 something is wrong!!!! trust me. i bet the oil light goes away instantly when you drive or rev too. its sounds just like mine and its bad. I switched up to a heavy oil and it only masked the problem. i as using 20-50 and it helped but really all it did was buy me time before i was dead in the water
06 Speed6 GT- Sold
 Old 07-16-2012, 12:55 PM   #33
I think that your problem might be different than ours. i think your problem might have been oil pump related or tolerance related.. None of the motors that we have built has ever spun a bearing at least not to my knowledge. About the 50-60 psi at idle.. yes my car does do that when it is cold starting, but when it is normal operating temperature it will go down to about 19-21 psi.
track weight 3220
street weight 3370
 Old 07-16-2012, 01:09 PM   #34
bcmurphy87's Avatar
oh ok well let me know what you find
06 Speed6 GT- Sold
 Old 07-16-2012, 04:12 PM   #35
Captain KR's Avatar
Groans: 391
ughhhhh need oil filter conversion and oil pressure gauge
Killah Built
 Old 07-16-2012, 05:01 PM   #36
708
Erich's Avatar
Holding up to the stress I put it through just fine.
2 years after hitting 700hp and still running strong. Happy to see others joining the club.
The Following User Says Thank You to Erich For This Useful Post:
rfinkle2 (05-26-2015)
 Old 07-17-2012, 12:04 PM   #37
pinkcheese's Avatar
19-21psi at idle is just fine a good rule of thumb is you want to keep 10psi for every 1000rpm you go.
The Following 2 Users Say Thank You to pinkcheese For This Useful Post:
802MS3 (07-18-2012), chuckms6 (07-17-2012)
FML and possibly my built motor turd burglar MazdaSpeed 3/6 - Troubleshoot/Diagnostics 14 04-19-2011 10:02 PM
Built Motor is Done..... yoichi MazdaSpeed 6 - Engine, Transmission & Driveline 107 12-14-2009 10:52 AM
has anyone with built motor broke a rod cbspeed3 MazdaSpeed 3 - Engine, Transmission & Driveline 41 08-05-2009 12:24 PM
built motor ms3boost MazdaSpeed 3 - Engine, Transmission & Driveline 17 05-20-2009 10:22 AM
Who Has A Built Motor? Need Impressions Haltech MazdaSpeed 3 - Engine, Transmission & Driveline 99 12-22-2008 08:51 AM
Page generated in 0.54560 seconds with 36 queries
