Like Tree13Likes
 Old 03-30-2012, 11:19 AM   #41
StayBroke's Avatar
Posts: 2,075   (View Stats)
yea i pulled the trigger on a 3076 yesterday.
The Following 4 Users Say Thank You to StayBroke For This Useful Post:
EdgeAutosport.com (04-03-2012), jracer (04-14-2012), Manny3 (03-30-2012), Ms3_Miami (03-30-2012)
 Old 04-03-2012, 09:57 AM   #42
Aztec(h)'s Avatar
Posts: 332   (View Stats)
Aztec(h) is the leader of the worldAztec(h) is the leader of the worldAztec(h) is the leader of the worldAztec(h) is the leader of the worldAztec(h) is the leader of the worldAztec(h) is the leader of the worldAztec(h) is the leader of the worldAztec(h) is the leader of the worldAztec(h) is the leader of the worldAztec(h) is the leader of the worldAztec(h) is the leader of the world
Not I. Not yet, anyway. There's way too much I need to take care of before I do that. Plus, I have too many projects going on at the moment, so I've gotten pretty behind. Ah well. I have a t4 at the house, but I'm not sure I want to install it. I'm thinking a 3076 would be more ideal, unless I keep the k04 and go sequential, but I doubt there's enough space for that in the engine bay. Haha!!
Aztec(h) is offline   Reply With Quote
 Old 04-03-2012, 03:33 PM   #43
Ms3_Miami's Avatar
Posts: 3,185   (View Stats)
Ms3_Miami is the leader of the worldMs3_Miami is the leader of the worldMs3_Miami is the leader of the worldMs3_Miami is the leader of the worldMs3_Miami is the leader of the worldMs3_Miami is the leader of the worldMs3_Miami is the leader of the worldMs3_Miami is the leader of the worldMs3_Miami is the leader of the worldMs3_Miami is the leader of the worldMs3_Miami is the leader of the world
Groans: 55
Maybe you can Keefover is doing a twin k04 setup.
http://www.mazdaspeedforum.org/forum/foru...ld-time-99820/
08 Black Mica Ms3~full bolt ons/Nishan Tuned-Sold
NATOR FL
Ms3_Miami is offline   Reply With Quote
 Old 04-03-2012, 05:36 PM   #44
Manny3's Avatar
Posts: 815   (View Stats)
Manny3 is the leader of the worldManny3 is the leader of the worldManny3 is the leader of the worldManny3 is the leader of the worldManny3 is the leader of the worldManny3 is the leader of the worldManny3 is the leader of the worldManny3 is the leader of the worldManny3 is the leader of the worldManny3 is the leader of the worldManny3 is the leader of the world
So I bought a second Grimmspeed ebcs from Maperformance, cause still waiting for more than two weeks now from first vendor, but is cool, shit happens. I got it overnight at the house, now I need the one and only good set up there is for a EWG setup, pics if you have them or a good solid how to. I look around and I have seen 20,000,000,000 different setup, maybe I exaggerated a little but you get my point thanks gent's.
09 CWP MS3 sold
15 DCB Mazda 6
Manny3 is offline   Reply With Quote
 Old 04-03-2012, 07:06 PM   #45
7mileshome's Avatar
Posts: 350   (View Stats)
7mileshome is the leader of the world7mileshome is the leader of the world7mileshome is the leader of the world7mileshome is the leader of the world7mileshome is the leader of the world7mileshome is the leader of the world7mileshome is the leader of the world7mileshome is the leader of the world7mileshome is the leader of the world7mileshome is the leader of the world7mileshome is the leader of the world
I am assuming you are going to run it in 3 port mode?
The best way is to take the hose that you have running
from your intercooler pipe (the one that is running to your
wastegate actuator right now,) and run that to the No. 3 on the Grimmspeed.
You will need a reducer and a 1/8" ID vaccum hose to connect to the GS EBCS.
Now run 1/8" Vaccum hose (use another reducer to go back to 5/16" ID) from
No. 2 back to your wastegate actuator (should be the nipple closest to the turbo.)
Run vaccum hose (5/16" ID) from the second nipple (wastegate return) back to
your turbo inlet pipe. You will need a T-connector.
The top of the "T" will have one end coming from your wastegate return,
the other end goes to the No. 1 on the GS EBCS. The bottom of the "T" goes to your TIP.
GS recommends a 30% reduction in WGDC if you are using it in 3 port mode.
P.S. - I have all the connectors and should have vaccum tubing, and
I'd be willing to help you set it up, no problem.
Manny3 and Ms3_Miami like this.
2012 Mazdaspeed3 LSM
Should have gotten a speed6
2008 Mazdaspeed3 GT Black Mica [sold]
Built motor, Etc.
383 hp 401 tq GTX2867R @ 25 psi
7mileshome is offline   Reply With Quote
The Following User Says Thank You to 7mileshome For This Useful Post:
Manny3 (04-03-2012)
 Old 04-03-2012, 11:53 PM   #46
Aztec(h)'s Avatar
Oddly enough, I'm in socal right now. I could probably drop in and check it out if my dad improves enough that I don't need to worry about him so much. Still, that's on a MS6, and I have a MS3, so some differences will abound.
 Old 04-05-2012, 06:19 AM   #47
Manny3's Avatar
MAYBE you can go to shout or stay a little closer to my thread subject. Is not an invitation for an open discussion either.
So I found out yesterday that my dump tube is on need of a tune, LOL, it rip off the front part of the insulation on the car LOL!!!
09 CWP MS3 sold
15 DCB Mazda 6
Last edited by Manny3; 04-05-2012 at 06:19 AM. Reason: MSF Database - Automerged Doublepost
The Following User Says Thank You to Manny3 For This Useful Post:
Ms3_Miami (04-05-2012)
 Old 04-05-2012, 06:41 AM   #48
Spirry's Avatar
Posts: 700   (View Stats)
Spirry is the leader of the worldSpirry is the leader of the worldSpirry is the leader of the worldSpirry is the leader of the worldSpirry is the leader of the worldSpirry is the leader of the worldSpirry is the leader of the worldSpirry is the leader of the worldSpirry is the leader of the worldSpirry is the leader of the worldSpirry is the leader of the world
Groaned at 28 Times in 15 Posts
Going to be finished by the dragon?
Spirry is offline   Reply With Quote
 Old 04-05-2012, 10:06 AM   #49
Eric28243's Avatar
Posts: 554   (View Stats)
Eric28243 is the leader of the worldEric28243 is the leader of the worldEric28243 is the leader of the worldEric28243 is the leader of the worldEric28243 is the leader of the worldEric28243 is the leader of the worldEric28243 is the leader of the worldEric28243 is the leader of the worldEric28243 is the leader of the worldEric28243 is the leader of the worldEric28243 is the leader of the world
You tell 'em! Yeah I'm thinking that insulation is just for show anyway. I have seen so many pictures of people sporting a big ugly tan patch of foam where the tin foil peeled off. No worries, right?
'08 Polar White Saturn SKY Redline - "The RAWRmobile"
BorgWarner EFR 6758 + IWG Mani, forge v2 BPV, Energy Full Suspension Bushings, GMPP 3-Bars, Vibrant Racing Catted HiFlow Downpipe, WERKS Boost Tubes, Intake, Power-Steering Relocation Kit, Radiator Hoses, and Race FMIC, Koni Yellows + Eibach Pro-Kit's, RPi GT CBE, HP Tuner SquishyTooned on E40, RK Sport Rotors/Pads, DDMWorks 2-gauge Pillarpod and Armrest, Prosport HALO Electronic Wideband and Boost Gauges, Spec Stage 2+ Clutch + Fidanza Single-Mass FryWhee, XTUNERS Gauge Cluster, GM Roadster.com HID/LED Full Exterior and Interior Light Conversion
Dyno: Uhh... fast as hell?
'08.0 Cosmic Blue MS3 - "The Daily" STOCKED OUT (almost)
COBB SRI/TIP - COBB AP SquishyTooned on E40 - COBB XLE BPV - HKS Hi-Power CBE - ITV22s - Corksport RMM Inserts - JBR Shifter Bushings and SSP - PTP Fuel Pump - PG + Treadstone - 35% Tint - ebaY Double-Penetrator - MS3 Vent Kit Install
Dyno: 319 / 331
CWP_MS3 is my mackdaddy
Eric28243 is offline   Reply With Quote
 Old 04-06-2012, 01:44 PM   #50
Manny3's Avatar
Tuning has started with the pioneer of the 400hp on the Gen1 @socks , wont reach the final results today due to running the Dragon Tomorrow, but then again Im only running the OEM MAF so still limited. Next week I might hook up the new map sensor, still debating on it, or just swapping to BIG MAF.
09 CWP MS3 sold
15 DCB Mazda 6
 Old 04-11-2012, 09:07 AM   #51
Manny3's Avatar
Well had fun at the Dragon, good hanging with GA and NC Nator peeps.
Bucker likes this.
09 CWP MS3 sold
15 DCB Mazda 6
Bucker (04-14-2012)
 Old 04-14-2012, 07:57 AM   #52
7mileshome's Avatar
Any updates?
Built motor, Etc.
 Old 04-14-2012, 08:14 AM   #53
bmylez's Avatar
Posts: 3,197   (View Stats)
Originally Posted by 7mileshome View Post
Any updates?
Sorry, irrelevant to topic, but you have the turbo I really really wanted. How do you like it?
2007 CTS-V - Trying to sell
The Following 2 Users Say Thank You to bmylez For This Useful Post:
Manny3 (04-14-2012), Ms3_Miami (04-14-2012)
 Old 04-14-2012, 08:44 AM   #54
StayBroke's Avatar
Think manny is still in tuning progress. Hopefully its done soon so i can get a taste of what to expect.
The Following User Says Thank You to StayBroke For This Useful Post:
Manny3 (04-14-2012)
 Old 04-14-2012, 01:22 PM   #55
7mileshome's Avatar
@bmylez I have not installed it yet I am waiting on a race built manifold
To install it at the same time. I will probably make a new thread for my build once I get it tuned and dynoed.
@StayBroke did you already install your turbo?
Built motor, Etc.
 Old 04-14-2012, 06:28 PM   #56
StayBroke's Avatar
Yea i got a build thread on it. Check it out.
86AmishMs3 (04-14-2012)
 Old 04-14-2012, 07:15 PM   #57
Manny3's Avatar
On the matter at hand, been doing some tuning with @socks and the latest and greatest is the air flow is getting restricted because I havent ported and still have my vtcs with rod and butterflies in it and stock exhaust mani, so yeah yeah I know I just been lazy. I actually mentioned this to @StayBroke but when I did my BT build, my whole reasoning was to not tackle everything at the same time that way if a problem came up it was restricted to the BT install part of it, now that is working and went to the Dragon once I think is safe to say that I can tackle the IM and maybe I can get my hand on a Exhaust Mani too AND a big MAF, so there is my next couple of thing to do. But yes is running good just limited.
09 CWP MS3 sold
15 DCB Mazda 6
The Following 3 Users Say Thank You to Manny3 For This Useful Post:
86AmishMs3 (04-14-2012), Ms3_Miami (04-16-2012), socks (04-14-2012)
 Old 04-14-2012, 07:27 PM   #58
Manny3's Avatar
Love it! I think everyone has a different opinion like how fast or slow spools up but is all a matter of opinions at the end is yours to have. I can give away the low end personally and be happy with the longer top end power band, for example Manny Run - YouTube
my 2cents.
09 CWP MS3 sold
15 DCB Mazda 6
 Old 04-14-2012, 07:32 PM   #59
irishking03's Avatar
Posts: 2,136   (View Stats)
irishking03 is the leader of the worldirishking03 is the leader of the worldirishking03 is the leader of the worldirishking03 is the leader of the worldirishking03 is the leader of the worldirishking03 is the leader of the worldirishking03 is the leader of the worldirishking03 is the leader of the worldirishking03 is the leader of the worldirishking03 is the leader of the worldirishking03 is the leader of the world
This is pure SEXY
2009 Metro Grey Numbers Fully Bolted.
Nator Pa Dyno Day: 311HP 328TQ Pump 93
Nator Pa Dyno Day: 310HP 329TQ Pump 93
End of Drive 9/24/2013
2012 Liquid Silver
Cobb AP
irishking03 is offline   Reply With Quote
The Following User Says Thank You to irishking03 For This Useful Post:
Manny3 (04-14-2012)
 Old 04-14-2012, 07:36 PM   #60
socks's Avatar
Posts: 3,250   (View Stats)
Groans: 125
I gotta give @Spirry credit. those are the fairest 3 honks i've ever heard. lol.
 Old 04-14-2012, 07:38 PM   #61
Manny3's Avatar
Originally Posted by irishking03 View Post
This is pure SEXY
I see on your sig you decided for the Steedspeed mani, what made you go for that one Im still looking for options, Thanks.
09 CWP MS3 sold
15 DCB Mazda 6
 Old 04-14-2012, 07:40 PM   #62
bmylez's Avatar
my 2cents.
Haha, that was directed at 7mileshome. That's why I said sorry, heh.
Manny3 (04-14-2012)
 Old 04-14-2012, 07:41 PM   #63
Manny3's Avatar
He was aware his car was talking to a Rican so he was just talking slow LOL
No worries I got that.
09 CWP MS3 sold
15 DCB Mazda 6
Last edited by Manny3; 04-14-2012 at 07:41 PM. Reason: MSF Database - Automerged Doublepost
 Old 04-14-2012, 08:34 PM   #64
StayBroke's Avatar
@Manny3,let me no on im. I be glad to help.
Manny3 (04-15-2012)
 Old 04-14-2012, 11:16 PM   #65
86AmishMs3's Avatar
Posts: 3,639   (View Stats)
Groans: 338
What makes you think you're being restricted by the IM and vtcs. I'm still stock on that end and flowing awesome for 22.5psi. 406 VD @ 1.01.
Current: N54 135i
DCI, DP's, Exhaust, FMIC
12.3@122
2009 Mazdaspeed 3:
GT3076 - Corkey tuned
390whp/400wtq
12.8@114
Sold
 Old 04-15-2012, 02:41 PM   #66
Manny3's Avatar
Targeting 22psi Im only hitting 21
09 CWP MS3 sold
15 DCB Mazda 6
 Old 04-15-2012, 07:43 PM   #67
socks's Avatar
Groans: 125
well, no, we could get it up to 22, but the problem is its not actually increasing airflow. we're pretty much to the point where any changes dont actually effect much.
 Old 04-15-2012, 08:14 PM   #68
Manny3's Avatar
What he said^^^ LOL, I just got some more work to do, slowly but surely we will get there
09 CWP MS3 sold
15 DCB Mazda 6
 Old 04-16-2012, 04:24 AM   #69
StayBroke's Avatar
What have you got to change now manny? The maf is limiting you? @Manny3
 Old 04-16-2012, 08:14 AM   #70
socks's Avatar
Groans: 125
Well, its not the maf limiting him, but when he finds out what is, the maf will peg out.
hes at 4.7-4.8v on the stock maf whether hes at 18 or 22psi.
so when he cracks the flow open, im sure he'll be at 4.7v at 18 (or less), and pegging 5.0v and cutting at 22
The Following User Says Thank You to socks For This Useful Post:
Manny3 (04-16-2012)
 Old 04-16-2012, 12:13 PM   #71
omgvance's Avatar
Posts: 1,221   (View Stats)
my 2cents.
Manny, you must Brake Boost!!!!!! If you bb'd that would have been a completely different run and by that I mean you would have never fallen back, just taken off.
Partnered with DeftMotion
deftmotion.com
2013 Mica Black Pu
Performance
Suspension
Ricer Shit
The Following User Says Thank You to omgvance For This Useful Post:
Manny3 (04-16-2012)
 Old 04-16-2012, 12:42 PM   #72
Manny3's Avatar
To tell you the truth I just learned about brake boosting yesterday LOL, next time I just might hire stick to do the driving lol, is my DD so I do shift gears so slow I probably can do it without a clutch. One of this day Ill become proficient at it, have to learn the new powerband all over, oh well. You should see me trying to take off from the hole, 1st and 2nd are even shorter for me redline comes in so fast holy crap especially if tires come loose, like I said, learning, if you grandpa's feel like giving me a lesson let me know Am all about it.
09 CWP MS3 sold
15 DCB Mazda 6
omgvance (04-16-2012)
 Old 04-16-2012, 01:00 PM   #73
omgvance's Avatar
Haha, I'm sure its still a blast to drive regardless! Hey now I'm only 22 who are you calling a grandpa?
deftmotion.com
2013 Mica Black Pu
Performance
Suspension
Ricer Shit
Manny3 (04-16-2012)
 Old 04-16-2012, 06:47 PM   #74
StayBroke's Avatar
Manny, i forgot to ask you but what boost levels are you going to run?
 Old 04-16-2012, 08:34 PM   #75
Manny3's Avatar
Who knows I wasnt supposed to mod my car to begin with! LOL
09 CWP MS3 sold
15 DCB Mazda 6
 Old 04-17-2012, 04:07 AM   #76
StayBroke's Avatar
lol, i gotcha. Well hope it all goes good man and you dont have any trouble.
 Old 04-18-2012, 07:15 PM   #77
Manny3's Avatar
So I found a CPE Big MAF intake at the @RPMstore, should be here this week, Ill be doing the IM PNP, 3 Bar MAP sensor and the OCC this Saturday.
09 CWP MS3 sold
15 DCB Mazda 6
 Old 04-18-2012, 07:40 PM   #78
TRSpeed's Avatar
Posts: 1,537   (View Stats)
TRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the world
Which occ you getting? And you PP your I'M yourself?
Sent from my DROID4 using Tapatalk 2
2008.05 True Red Mazdaspeed3
Lex Tuned
GTX3071r | 38mm Tial WG | Hallman MBC
Cobb AP E85 30% |CPE Big MAF | CPE Big TIP | CPE FMIC | SS Ex Mani | CPE Catted DP | CNT CBE | CPE Triple Gauge Pod |
Autotech HPFP Internals | Denso ITV22 | TS BPV | TWM ShortShifter | JBR Shifter Bushings | JBR 88 RMM |
Razo Heavy Shift Knob | 20% Tint | DDM 55W HID | Hankook Ventus V12 | H&R Springs
TRSpeed is offline   Reply With Quote
 Old 04-18-2012, 08:01 PM   #79
Manny3's Avatar
I have JBR OCC for a while now, just didnt got to install, IM will be done by this guy, yes sir.
09 CWP MS3 sold
15 DCB Mazda 6
StayBroke (04-19-2012)
 Old 04-19-2012, 03:54 PM   #80
i probably need to change my coming soon sig cause i ran into some financial diffulculties recently so my big turbo build is on the back burner. i was gonna go with the steedspeed only because i heard good things about it.
2012 Liquid Silver
Cobb AP
GTK-450 turbo build matgod MazdaSpeed 3/6 - Big Turbo Builds 18 09-09-2013 08:00 PM
MX-5 EFR Turbo Build Andy@Killshot Miata - Forced Induction 40 12-28-2011 04:01 PM
Turbo Build UKMPS3MK2 2010 MS3 - Turbo Induction 12 05-10-2011 09:53 AM
Big turbo kit, build one or not? ptperformance Mazdaspeed3/6 General Discussion 33 10-12-2008 02:55 PM
Page generated in 0.61292 seconds with 33 queries
