![]() Join Date: Jun 2014 Location: Montreal
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 40
Groaned at 26 Times in 11 Posts
(Thread Starter) | Not Ranked : 0 score So here's the question. I have a CS turbo with WMI kit and was wondering if a 375ml/min meth nozzle should be able to max out the CS turbo? Thanks |
![]() Join Date: Nov 2011 Location: Victoria, BC, Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 86
| Not Ranked : 0 score What mix are you going to use with the WMI system? 50:50? 100% meth?
__________________ '08 MS3 // Corksport Turbo // JBR 3.5" WP // CNT Racing Turbo-Back // CX Racing FMIC // COBB AP // SURE Ventus // SURE Return // Damond Motorsports PMM & TMM // SURE Torq R3 // Stratified Guardian Angel // Autotech HPFP Internals // JBR EBCS // Corksport 3.5bar MAP // JBR S2 OCC // JBR EGR Delete // JBR TIG's // CP-e Safe Seals // SURE Shortcut // Corksport Swaybars // Bilstein Sports // H&R Springs // Tenzo R Type M 18"x8" // Michelin PSS |
![]() Join Date: Nov 2010 Location: Riverhead, NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,457
| Not Ranked : 0 score I would run the 625 ml/min nozzle. You will run out of fuel around 22-23 psi on the 375 ml/min nozzle. I run the 625 at 26 psi (gtx3071), and see ~85% inj duty cycle. |
| The Following 2 Users Say Thank You to Boost_creep For This Useful Post: | mize13 (05-24-2016), Xxblinddzxx (05-25-2016) |
| Maxing out flow | someguy | 2010 MS3 - ECU Computer Tuning | 35 | 08-17-2013 07:18 PM |
| Maxing out flow | someguy | 2010 MS3 - Turbo Induction | 0 | 07-30-2013 09:07 PM |
| Maxing out my wastegate? | Grim | MazdaSpeed 3/6 - Turbo Induction | 45 | 02-22-2009 05:06 PM |
| Maxing my Fuelpump with these mods? | arkenzo | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 14 | 09-23-2008 05:50 PM |
