Like Tree3Likes
  • 1 Post By JCMS07
  • 1 Post By Jansi
  • 1 Post By JCMS07
 Old 05-26-2014, 02:03 PM   #1
JCMS07's Avatar
Posts: 349   (View Stats)
JCMS07 is the leader of the worldJCMS07 is the leader of the worldJCMS07 is the leader of the worldJCMS07 is the leader of the worldJCMS07 is the leader of the worldJCMS07 is the leader of the worldJCMS07 is the leader of the worldJCMS07 is the leader of the worldJCMS07 is the leader of the worldJCMS07 is the leader of the worldJCMS07 is the leader of the world
Default MS3 GTX3076r EWG
Installing the ATP GTX3076r EWG kit on the MS3 but have hit a road block. When test fitting the downpipe to the turbo, the EWG & DP hit each other. This is preventing the DP from being installed.
Anyone else install this kit and how did you route the WG?
The oil return line is also hitting, but planning on clocking the turbo a little.
WVspeed6 likes this.
11.491@115.94 - GTX3076r
JCMS07 is offline   Reply With Quote
 Old 05-26-2014, 02:16 PM   #2
Fuck sushi rolls
rodrigo's Avatar
Posts: 18,719   (View Stats)
Groans: 356
From pics the oy thing I can think of is make an angled 3 inch pipe to extend the wg farther down and the just cut the dump tube shorter .... That's my ghetto estimation .... I'm sure others with more experience may have a better solution . Well .... Then there is the BFH approach but let's try not to hit shit just yet lol
 Old 05-26-2014, 02:19 PM   #3
Etipp98's Avatar
Posts: 1,947   (View Stats)
Groaned at 7 Times in 4 Posts
They offer a 90* pipe for the wastegate, fitment depends on what do you have installed. Looks like you need the 90.
The Following 2 Users Say Thank You to Etipp98 For This Useful Post:
ItsNox (05-26-2014), JCMS07 (05-26-2014)
 Old 05-26-2014, 02:34 PM   #4
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
Shit looks like u are all set Julio ... They offer 2-2.5 and 3 inch diameter
Elbow, Cast Aluminum, 2.5", 90 Degree : atpturbo.com
Call ATP up I'm sure u aren't the first to run this set up .... It's just a matter of angle and length of piping then just re adjust the angle and length of dump tube
 Old 05-26-2014, 02:37 PM   #5
mtosofsky's Avatar
Posts: 543   (View Stats)
mtosofsky is the leader of the worldmtosofsky is the leader of the worldmtosofsky is the leader of the worldmtosofsky is the leader of the worldmtosofsky is the leader of the worldmtosofsky is the leader of the worldmtosofsky is the leader of the worldmtosofsky is the leader of the worldmtosofsky is the leader of the worldmtosofsky is the leader of the worldmtosofsky is the leader of the world
This has nothing to do with the wastegate, the diameter is far too big. He needs the 90* elbow that they make for the wastegate.
2008 MS3 GT GTX//Relentless Customs//Voltron Approved//Nishan Tuned
mtosofsky is offline   Reply With Quote
The Following User Says Thank You to mtosofsky For This Useful Post:
Micha (05-27-2014)
 Old 05-26-2014, 02:38 PM   #6
Etipp98's Avatar
Edge has the option for $105 with the ewg kit. Did you get it through them?
The Following User Says Thank You to Etipp98 For This Useful Post:
JCMS07 (05-26-2014)
 Old 05-26-2014, 02:44 PM   #7
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
What's the diameter of the wg piping ? Not even 2 ?
 Old 05-26-2014, 02:47 PM   #8
mtosofsky's Avatar
@rodrigo; no its smaller, but atp sells the 90* adapter he needs, its not a universal 90* bend and its not cast like what you posted.
 Old 05-26-2014, 02:52 PM   #9
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
Got it .... You guys help him out . Thank you
 Old 05-26-2014, 02:56 PM   #10
ms6mil's Avatar
Posts: 4,972   (View Stats)
Groans: 307
Not sure if this will help. We ran into this fitment issue when we installed on @Jansi; car. Hopefully something in there might be helpful....
RIP K04, Hello GTX3071r
EDIT: A few post down the end result was extending the DP (with some welding) straight down to undo the dramatic curve causing the fitment issue.
"Here am I. Send me!"
GT3076 - 393/380 3/9 e85
PTE5862 - TBD
The Following 2 Users Say Thank You to ms6mil For This Useful Post:
 Old 05-26-2014, 02:59 PM   #11
JCMS07's Avatar
Yeah, I got the kit from Edge and missed that elbow as an option. Going to contact them.
 Old 05-26-2014, 03:11 PM   #12
JCMS07's Avatar
Any WG issues with not using the water ports on the WG?
 Old 05-26-2014, 03:16 PM   #13
ms6mil's Avatar
Groans: 307
none that I know of, I don't think @Jansi; used them, but will let him chime in. I'm 99% sure he didn't.
It turned out real nice, the way it ended up left lots of room in there. It was too crowded with the DP, EWG, vac lines, return line and dump tube
PTE5862 - TBD
Last edited by ms6mil; 05-26-2014 at 03:16 PM. Reason: MSF Database - Automerged Doublepost
 Old 05-27-2014, 03:37 PM   #14
Jansi's Avatar
Posts: 729   (View Stats)
Jansi is the leader of the worldJansi is the leader of the worldJansi is the leader of the worldJansi is the leader of the worldJansi is the leader of the worldJansi is the leader of the worldJansi is the leader of the worldJansi is the leader of the worldJansi is the leader of the worldJansi is the leader of the worldJansi is the leader of the world
Here's the link to my GTX3071r build.
I ran into the same exact problem you did. Honestly the best thing you could do is just get a downpipe that comes straight down from the hotside instead of that weird bend. What I did was cut up the DP custom build my DP with the existing one. We bought some stainless steel and just added where it needed to be. ***It costs alot of money and time to have someone custom fab a DP like that***
For the water ports, you just leave those open. They are seperatly chambered from the air ports.
"That Other's May Live"
SELF TUNED
380WHP/372WTQ Dyno Jet @SL E85 mix
ENGINE
GTX3071r // CUSTOM exMANI // CUSTOM DP // TAIL 38mm WG // NGK 1 STEP COLDER PLUGS (6510) // HTP 3.5" WP+BATT TRAY // GRIMSPEED 3 PORT EBCS // BOSCH 3 BAR+HARNESS // JBR BYPASS HOSE // GUARDIAN ANGEL // CX PIPING+TR8 CORE // V3 ACCESSPORT // JBR 88a RMM // JBR 88 duro TRANNY // JBR OCC Stg 2 // SYNAPSE DV
SUSPENSION
CorkSport Coils // SPC REAR CAMBER ARMS @-1.5 // 17x9 RPF01's- 255/40/18 FEDERAL RS-R // 5mm(front) EIBACH SPACERS+STUDS
OTHER SHIT
JBR SSP // RALCO RZ SS // DEFI RED RACER BOOST GUAGE // BLOCK8HEAD VENT POD // KENWOOD DDX419 // KICKER ZX300.1 // DX200.4 // KICKER CVR 12" IN PORTED BOX // KICKER MIDS+HIGHS
Jansi is offline   Reply With Quote
 Old 05-27-2014, 03:48 PM   #15
Etipp98's Avatar
Why would someone spend the time and more money to hack up a perfectly good downpipe when all you need is the $105 90 adapter..... I don't get it
 Old 05-27-2014, 04:07 PM   #16
2011speed's Avatar
Posts: 1,497   (View Stats)
Get an atp downpipe. I believe it fits better seems like it provides more room
Got the same kit from atp. Not lookin forward to the install at all
FreeKtuned
fitty fitty
2011speed is offline   Reply With Quote
 Old 05-27-2014, 05:08 PM   #17
Jansi's Avatar
Because I have the capabilty and will to do so ($40 is what it took to do the job)... You don't have to understand why people do it, not your car and not your problem.
But I'll answer your question anyways; It's about pride and accomplishment, its about what you put into your car knowing that you made it happen with what you got.
ms6mil likes this.
SELF TUNED
ENGINE
SUSPENSION
OTHER SHIT
The Following User Says Thank You to Jansi For This Useful Post:
ms6mil (05-27-2014)
 Old 05-27-2014, 05:28 PM   #18
2011speed's Avatar
U snap any pics of the downpipe?
FreeKtuned
fitty fitty
 Old 05-27-2014, 06:00 PM   #19
Jansi's Avatar
Yea, it's in the link that I posted with my comment. Post #42 ,44 give you pics of the DP.
SELF TUNED
ENGINE
SUSPENSION
OTHER SHIT
 Old 05-27-2014, 06:25 PM   #20
ms6mil's Avatar
Groans: 307
Cuz $40 is better than $105.
My local guys charges about $45 for the same work. By just extending the length of the DP, it left more room rather than adding more hardware (piping) going different directions.
Ingenuity: The quality of being clever, original, and inventive...
Looks about right, that would be some good info if you confirm the fitment. I believe the the DP with that dramatic curve is what is making the difference in individual setups
PTE5862 - TBD
Last edited by ms6mil; 05-27-2014 at 06:25 PM. Reason: MSF Database - Automerged Doublepost
 Old 05-27-2014, 10:48 PM   #21
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
If that don't work get a 5.0 .... You will def not regret it
bstover17 (06-29-2014), Mauro_Penguin (05-29-2014)
 Old 05-28-2014, 04:54 AM   #22
ms6mil's Avatar
Groans: 307
Haha, or that.... Seems to be the popular upgrade these days.
PTE5862 - TBD
 Old 05-28-2014, 10:49 PM   #23
JCMS07's Avatar
Received the 90 degree elbow today and it seems like it will work but waiting for the delivery of the v-band clamp.
Anyone have an idea what to put between the stock turbo bracket and the turbo for some support?
 Old 05-29-2014, 03:04 AM   #24
ms6mil's Avatar
Groans: 307
get rid of it, you don't need it unless you have a mani that has shitty welds or prone to cracking.
PTE5862 - TBD
 Old 05-29-2014, 11:40 AM   #25
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
good luck with that julio ...my pg v3 eventually cracked even with a padded bracket holding up the 3071 ..... the dnp does look a lil sturdier though lol
 Old 06-05-2014, 05:23 AM   #26
speed_freak91's Avatar
Posts: 1,189   (View Stats)
Groans: 34
Bump.
@JCMS07; how did this turn out? Curious to know if the 90 degree elbow helped. Whenever I do a BT install, I will be going the same route you did more then likely.
 Old 06-08-2014, 11:07 PM   #27
JCMS07's Avatar
@speed_freak91 The elbow did help to clear the downpipe, but since the location of the WG changed I need to figure out how to best route the dump tube. Right now it points towards the heat shielding above the downpipe so don't want to leave it like that.
The Following User Says Thank You to JCMS07 For This Useful Post:
speed_freak91 (06-09-2014)
 Old 06-15-2014, 05:00 PM   #28
JCMS07's Avatar
The dump tube is finally finished thanks to Rodrigo for coming up with this solution. Ended up not using the dump tube with the 90 degree bend, but a straight pipe which was cut at a slight angle and then a flange welded to it.
The tube was also dented a bit for more clearance from the axle and cut to length.
The Following 3 Users Say Thank You to JCMS07 For This Useful Post:
Code Monkey (06-15-2014), Haltech (06-17-2014), ms3blackmica (06-17-2014)
 Old 06-15-2014, 07:46 PM   #29
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
Sounds nasty lol
 Old 06-17-2014, 12:53 AM   #30
Looks good dude. Lets go racing
 Old 06-29-2014, 03:22 PM   #31
JCMS07's Avatar
When the tuning is done, I'll hitting the track the next time it's open.
Wanted to get opinions to make sure I have the PCV setup the right way. The PERM plate is installed with one opening going to a check valve > Oil Catch Can inlet > Oil Catch Can outlet is vented.
The other PERM plate opening is going to the stock PCV > Oil Catch Can inlet > Oil Catch Can outlet to check valve > Intake Manifold.
The valve cover is vented and the port on the inlet is plugged.
D1Sano likes this.
 Old 02-02-2016, 11:19 PM   #32
hdragster's Avatar
Posts: 30   (View Stats)
hdragster is a splendid one to beholdhdragster is a splendid one to beholdhdragster is a splendid one to beholdhdragster is a splendid one to beholdhdragster is a splendid one to beholdhdragster is a splendid one to beholdhdragster is a splendid one to behold
Good pictures for the installation!
hdragster is offline   Reply With Quote
The Following User Says NO Thank You to hdragster For This Un-useful Post:
WetzMS3 (02-03-2016)
 Old 10-09-2016, 09:21 PM   #33
impossible's Avatar
Posts: 733   (View Stats)
Groans: 30
You just saved me alot of headache, I was gonna run the gate straight off the turbine housing but have a eBay dp and gonna eventually run a CNT one that has same sharp bend that interferes with the EWG dump.. Thankfully I had already bought a 90 + straight 38mm setup that I'll be using, thanks man for the quality high res pics!! This guy's 90* bend is a little longer than the ATP 38mm one but hoping it works
File Type: jpg 13886275_1209845265732175_1812454247267634701_n.jpg (53.3 KB, 20 views)
New GTX3076R smoking bad tommyboy 2010 MS3 - Troubleshoot/Diagnostics 33 05-11-2014 09:33 PM
P0108 after GTX3076r EWG install ms3sub 2010 MS3 - Troubleshoot/Diagnostics 11 01-24-2014 03:04 PM
GTX3076R logs Chimmike Mazdaspeed3/6 General Discussion 2 10-20-2011 08:45 PM
Page generated in 0.50399 seconds with 31 queries
