  • 1 Post By Stew
 Old 10-03-2013, 10:55 PM   #1
Stew's Avatar
Posts: 176   (View Stats)
Stew has a reputation beyond reputeStew has a reputation beyond reputeStew has a reputation beyond reputeStew has a reputation beyond reputeStew has a reputation beyond reputeStew has a reputation beyond reputeStew has a reputation beyond reputeStew has a reputation beyond reputeStew has a reputation beyond reputeStew has a reputation beyond reputeStew has a reputation beyond repute
Default MS6 BNRS3 install
Turbo started smoking recently and I decided it was time to take the leap and get a bigger turbo. I decided on a BNR because it seems to be one of the easier installs and I am not ready to go really big turbo. I will be installing it next week and then getting a tune from @Lex;
I just installed my DO Meth kit and while installing the boost actuated controller, I realized that I will be needing at least 3 boost sources for my install as I also ordered a Gaurdian Angel. Where do all of you tap into boost? I am assuming you don't just add 3 "T's" to the boost line into the BPV. I currently need boost sources for my Boost gauge, WMI controller, and GA. I don't know if I will need one for the boost dial as well or not.
Stew is offline   Reply With Quote
The Following 3 Users Say Thank You to Stew For This Useful Post:
Lex (10-03-2013), redboat (11-27-2013), Status Update (10-03-2013)
 Old 10-03-2013, 10:59 PM   #2
Status Update's Avatar
Posts: 461   (View Stats)
Status Update is the leader of the worldStatus Update is the leader of the worldStatus Update is the leader of the worldStatus Update is the leader of the worldStatus Update is the leader of the worldStatus Update is the leader of the worldStatus Update is the leader of the worldStatus Update is the leader of the worldStatus Update is the leader of the worldStatus Update is the leader of the worldStatus Update is the leader of the world
Subbed for results! looking forward to seeing what numbers you put down
BMW 335xi 6MT
AR Catless Downpipes///HPF Fmic///BMS DCI///CP-e Chargepipe///Cobb AP V2///Volk TE37sl 18x9.5+22F 18x10.5+20R
2007 BM Mazdaspeed 6 GT #10477
SOLD 8/29/14
Status Update is offline   Reply With Quote
 Old 10-03-2013, 11:02 PM   #3
Stew's Avatar
Lex said to go straight to a D010 nozzle for the meth. I would like to get close to 330 hp and 350 tq. I think those are reasonable numbers. 350 hp would be my ideal goal.
Stewart
 Old 10-03-2013, 11:28 PM   #4
I might copy your build later on as those are roughly the same numbers im looking hit.
BMW 335xi 6MT
SOLD 8/29/14
 Old 10-03-2013, 11:36 PM   #5
For the boost sources here's what I use:
1. The GA will simply interrupt the line to your BPV
2. Connect the WMI controller and boost gauge to the line going to the BPV
3. The boost source for boost control will come off the BNR S3 compressor housing.
redboat (11-27-2013), Stew (10-03-2013)
 Old 10-04-2013, 12:14 AM   #6
breakfstincluded's Avatar
Posts: 3,588   (View Stats)
Wish my hks worked with GA
Jh8909 (10-04-2013)
 Old 10-04-2013, 12:17 AM   #7
Swinger13's Avatar
Posts: 3,480   (View Stats)
Groans: 53
Stewart
Same wheel (gt28) and a lot of your mods mirror my mods too. The only major difference it looks like is I don't have meth.......(yet )
Interested to see what happens. GL with this set up
Performance:
Stratified Tune in progress
 Old 10-04-2013, 12:31 AM   #8
Stew's Avatar
Yes. I have been following your build. I was hoping since you got those number without that I could get 350 with. We'll see.
The Following User Says Thank You to Stew For This Useful Post:
Swinger13 (10-04-2013)
 Old 10-04-2013, 12:44 AM   #9
Swinger13's Avatar
Groans: 53
My latest numbers uncorrected 350whp and 370 wtq was in 10~ degree celcius so like 46 ish fahrenheit? your power goals seem within reach. I'm also at 2200 ft so a marginal loss there.
Performance:
 Old 10-11-2013, 06:53 AM   #10
Stew's Avatar
Turbo is now in after a fairly painful install. Probly just because I am a rather inexprienced mechanic. And that oil return line is the biggest pain to get out and even more to get back in on the MS6. Started the car with an appropriate base map, and AFRs started going lean after a few minutes of idling. Did a boost test tonight and @Lex; told me I had the boost dial hooked up wrong. Fixed that and a T-bolt clamp I forgot to clamp down. That fixed AFR's until I drove it. Did a few WOT pulls and an MAF cal log. Realized I had my GA set to activate and too little boost. and something must have come off or loosened because idling AFR's are back to being lean as in AFRs are in the 18 range.
 Old 10-11-2013, 08:44 AM   #11
Swinger13's Avatar
Groans: 53
Vacuum leak most likely after the turbo. Boost leak test again!
Performance:
 Old 10-11-2013, 09:34 AM   #12
Stew's Avatar
yep. but no need to this time. Saw it as soon as I opened the hood. The boost tube from the turbo to the intercooler partially came off. I need a smaller tube.
The Following 2 Users Say Thank You to Stew For This Useful Post:
memin (10-11-2013), Swinger13 (10-11-2013)
 Old 10-27-2013, 09:52 AM   #13
aviator79's Avatar
Posts: 3,934   (View Stats)
Installing mine now. Ive got everything undone except oil and coolant. Trying to determine how I get these off. Oil feed is easy but oil drain not sure. Assume coolant feed line is a PITA too with PTO in the way.
Any help?
 Old 10-27-2013, 10:11 AM   #14
Any help?
You have a helper?
For the oil drain, small hands and lots of patience.
For the coolant drain, it is easier if you have one person under the car, then from the top you unhook the coolant drain from the T-case while the person underneath puts some rags over so that coolant loss is minimal. With the coolant line freed, you will be able to tilt the turbo and unhook the line from the turbo, then put it back on the T-case and clamp.
I would use new clamps for all the hoses, the clamp on my coolant line was worn out at the T-case and had a subtle coolant leak after the install. Fortunately, the shop was able to sneak a new clamp on the hose without taking anything apart, but imagine if that was the connection at the turbo.
 Old 10-27-2013, 12:51 PM   #15
aviator79's Avatar
Working alone. Got bottom oil drain off block. Had to run to sears to get 6pt 8mm and did 2nd bolt from bottom.
Had to turn clamp on diff cooler and got that off. Plugged with a bolt with electrical tape wrapped around it.
Turbo out.
Can BNR be installed before work tomorrow...that is the mystery
What sucks is all I have is Zyrex which is blue and so when I add it to replace the antifreeze I lost my coolant will turn brownish..
 Old 10-27-2013, 02:43 PM   #16
aviator79's Avatar
If Im using stock EBCS do I hook comp port to WG like OEM?
 Old 10-27-2013, 11:40 PM   #17
i think theres a diagram on stratified for this, look at their 2 port mode
 Old 10-30-2013, 11:25 PM   #18
Stew's Avatar
Yeah, the oil drain is a pain in the butt.
So far everything is going ok for me. Still have not done a base line VD. I think I am driving Lex a little nuts because I am not used to having to consult someone else as far as mechanical fixes to different problems.
Right now I am fighting some sort of throttle body issue. The car throws a P2100 code and will run very rough and the gas peddle will not work. However, usually, I can restart it and it will be fine. But sometimes it takes multiple restarts before it works. It will even happen while driving. I will lose power, the DSC light will come on, and I will have to restart. I think it could be a poor connection at the throttle body so I am trying to dissasemble the connector to tighten the pins. Have to see if that works.
Stewart
 Old 11-23-2013, 11:00 AM   #19
Stew's Avatar
Well I haven't really kept this thread updated, so here is where I'm at. Car is running solidly. Fourth iteration of the tune on the car and it pulls pretty hard. 2nd pulls like a mother, 3rd and 4th are a little meh. Averaging out the number on the Vdyno (runs are both ways on the road) I have about 320 horse and 325 torque. Pretty good numbers and well on the way to reaching my goal of ~350 WHP and TQ.
STew
File Type: jpg 563745_553696288054744_1518447716_n.jpg (50.4 KB, 71 views)
breakfstincluded (12-01-2013)
 Old 11-27-2013, 08:37 PM   #20
redboat's Avatar
Posts: 634   (View Stats)
redboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the world
how's the car running now?
redboat is offline   Reply With Quote
 Old 11-27-2013, 10:30 PM   #21
Stew's Avatar
Running like a champ. Pulls pretty hard. But had to promise my girlfriend no racing :/ LOL
 Old 11-28-2013, 03:41 AM   #22
kish89's Avatar
Posts: 292   (View Stats)
kish89 is the leader of the worldkish89 is the leader of the worldkish89 is the leader of the worldkish89 is the leader of the worldkish89 is the leader of the worldkish89 is the leader of the worldkish89 is the leader of the worldkish89 is the leader of the worldkish89 is the leader of the worldkish89 is the leader of the worldkish89 is the leader of the world
STew
Why is there such a big difference in numbers between runs?
06 MS6, Versatuner, Stratified Tuned
BNR Stage 3 turbo, Eagle con. rods, HTP Full 3" intake + AEM DryFlow filter
Autotech HPFP internals, Forge V1 BPV
Custom 3" cat-back with stock mufflers, M2 3" catless Downpipe
Grimmspeed EBCS + Stratified Boost Dial, 3BAR BOSCH MAP
NGK Iridium IX one step colder plugs, CPE SafeSeals & studs
Custom FMIC with 2.5" piping and Treadstone TR8 IC
SnowPerfomance WMI, Stratified Guardian Angel
Eibach pro kit lowering springs
kish89 is offline   Reply With Quote
 Old 11-28-2013, 05:54 AM   #23
Stew's Avatar
Road wasn't completely flat. Doing runs going both ways.
Stew
 Old 11-28-2013, 07:22 AM   #24
Mistersix's Avatar
Posts: 2,585   (View Stats)
Glad to see it's coming along. You need to find a nice flat spot for those VD runs though.
 Old 11-28-2013, 07:49 AM   #25
Stew's Avatar
I got one. My ambient temps are fairly cool right now so power is looking pretty good. Did another vdyno on a flat spot and I'm looking at about 330 hp 335 tq. Will load up another vdyno after I get my next tune from lex.
friedricebob likes this.
Mistersix (11-28-2013), redboat (11-28-2013)
 Old 06-21-2014, 12:10 PM   #26
Mazdazilla6's Avatar
Posts: 3,657   (View Stats)
@Stew; How does the 3.5" intake fit with the s3? Did you relocate your battery before you swapped the s3?
VersaTuner = Versatune
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Autotech = HPFP Internals
Grimmspeed = EBCS
MS6 BNRS3 kish89 Mazdaspeed3/6 General Discussion 9 08-20-2013 03:22 AM
First Install Cobb SRI/TIP/Airbox looking for TIP install video? Phog Mazdaspeed3/6 General Discussion 3 12-14-2012 04:26 PM
What to install/not install for autocross. maisonvi Auto-X / Road Racing / Time Attack 17 06-22-2012 09:02 AM
Page generated in 0.44021 seconds with 31 queries
