 Old 06-30-2017, 09:05 AM   #1
mazda_speed_6's Avatar
Posts: 84   (View Stats)
mazda_speed_6 is just really nicemazda_speed_6 is just really nicemazda_speed_6 is just really nicemazda_speed_6 is just really nice
Default mazdaspeed 6 gtx 3576 vs pt 6266 1\4mile
So ive been doing a shit ton of research on big turbo builds after hours of reading it seems every one says pte turbos make more power with better spool but im try to do a build that will dominate at the 1/4 mile i found one thread that talks about garret turbos giving faster 1\4 mile but couldnt really find any info. What would you guys say would be a better choice right now im set on getting the pte 6262 ive read alot of threads about the atp turbo being to restrictive?
2006 MS6 sri/tbe/cpe diff mount/TS bpv/AT internals/jbr motor mounts/COBB acessport/stratified ots map/act 6 puck
mazda_speed_6 is offline   Reply With Quote
 Old 08-12-2017, 09:52 PM   #2
No advice buddys? Trying to hit low 11s by next summer.
 Old 08-12-2017, 10:26 PM   #3
gdawg25's Avatar
Posts: 248   (View Stats)
gdawg25 is the leader of the worldgdawg25 is the leader of the worldgdawg25 is the leader of the worldgdawg25 is the leader of the worldgdawg25 is the leader of the worldgdawg25 is the leader of the worldgdawg25 is the leader of the worldgdawg25 is the leader of the worldgdawg25 is the leader of the worldgdawg25 is the leader of the worldgdawg25 is the leader of the world
You planning on building your motor?
'08 MS3 // Corksport Turbo // JBR 3.5" WP // CNT Racing Turbo-Back // CX Racing FMIC // COBB AP // SURE Ventus // SURE Return // Damond Motorsports PMM & TMM // SURE Torq R3 // Stratified Guardian Angel // Autotech HPFP Internals // JBR EBCS // Corksport 3.5bar MAP // JBR S2 OCC // JBR EGR Delete // JBR TIG's // CP-e Safe Seals // SURE Shortcut // Corksport Swaybars // Bilstein Sports // H&R Springs // Tenzo R Type M 18"x8" // Michelin PSS
gdawg25 is offline   Reply With Quote
 Old 08-12-2017, 10:41 PM   #4
Yes sir i plan on sending my motor to speed performance to get a stage 3 long block build also wanna send my tranny and have them install a upgrade final drive aswell.. Im gonna switch to port injection and run a 50/50 mix e85/91. My goal is to hit around 650 whp would like a turbo that spools fast and makes good tq
 Old 08-12-2017, 10:42 PM   #5
Shwa's Avatar
Posts: 322   (View Stats)
EFR for daysssssssssssssssssss
The Following User Says Thank You to Shwa For This Useful Post:
mazda_speed_6 (08-13-2017)
 Old 08-12-2017, 10:49 PM   #6
Ive never looked in to EFR turbos to be honest there Borg Warner turbos right?
 Old 08-13-2017, 12:16 AM   #7
MSF's Punishing Member
Pu Manchu's Avatar
Posts: 2,992   (View Stats)
Groans: 546
that's going to depend more on your driving than your choice of those 2 turbos. either one has the power to put you in the 10s
94 M
MS6
IS350
The Following User Says Thank You to Pu Manchu For This Useful Post:
 Old 08-13-2017, 09:10 AM   #8
Will the 2 turbos net around the same power ive read that the atp gtx3576 are pretty restrictive on the atp turbine side? read this on the edgeautosport gen 2 gtx turbo thread? I know the gtx 3576 is capable of 10s my brothers sti runs 10.9s but im almost sure it aint a atp turbo his turbo use a vband on the hot side.
Logged my 1/4mile run MTLspeed6 Mazdaspeed3/6 General Discussion 6 08-21-2013 02:01 AM
Page generated in 0.27677 seconds with 23 queries
