![]() Join Date: Apr 2013 Location: Long Island, NY
(Thread Starter) | Not Ranked : 0 score I did not run the wastegate dump tube in the same hole as the downpipe. There is an opening to the left (passenger side) of the downpipe. What I did is crushed the tip of the dump tube so it would slide in there.
__________________ [SIGPIC][/SIGPIC] 2007 Mazdaspeed 6 GTX3076 - CPE- EX-mani w/ 44mm EWG - CPE Safe Seals - COBB APv3 - COBB Shifter Weight - DO Stage 2 Meth - PnP Intake Mani - Catless TBE - Corksport FMIC - Corksport Rear Diff Mount - Corksport OCC - AWR RRM, TMM, PMM - TT Front Engine Mount - TT Front Diff Mount - HTP 3.5 " - GFB 50/50 - AT internals - GrimSpeed ECBS - 3 Bar Map - Perm PCV plate - JBR BSD w/ baffle - JBR TIGS - Sure Shortcut - Tower Strut Bar - EGR Delete - EGR Valve Deleted - Shifter Bushings - H&R Springs - Koni Yellow Shocks - Stoptech D&S rotors - EBC Pads - Stainless Steel Brake Lines - Denso ITV 22 - Whiteline RSB - Guardian Angel |
| Wes' 2010 GTX3076 build | Wes10S3 | 2010 MS3 - Build Diaries | 7 | 08-02-2014 11:04 AM |
| 447HP GTX3076 | Lakespeed6 | MazdaSpeed 3/6 - Dyno Sheets/Discussions | 31 | 02-23-2014 01:44 PM |
| MonkTuning GTX3076 | mrmonk7663 | 2010 MS3 - Big Turbo Builds | 17 | 12-08-2013 10:36 PM |
| Mazda 6 MPS GTX3076 1.06 tial | Vadim aka ScooteR | MazdaSpeed 3/6 - Dyno Sheets/Discussions | 4 | 10-15-2013 12:51 AM |
