  • 1 Post By Lex
  • 1 Post By shawn.
 Old 09-05-2013, 03:42 PM   #1
biggman026's Avatar
Posts: 453   (View Stats)
biggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the world
Groaned at 49 Times in 12 Posts
Default Modifying the battery tray?
I'm gearing up for my bnr s3 install, getting all the parts together, and I'm stuck on one question.
I would like to get a JBR 3.5" intake, but really don't want to have to get the smaller battery tray and go to a 51R battery. I just bought a brand new interstate mtp-40R battery about 6 months ago when my old one died, and I really don't want to replace a brand new $150 battery when theres nothing wrong with it.
Has anyone attempted modifying the stock battery tray to fit with a 3.5" intake instead of going to a 51R size battery and tray? I've got a cs tip and intake right now, and it looks to me like the only place there isn't any room to go to a 3.5" tip is where the battery tray sticks out for the latch to hold the battery down. From what I can tell, it looks like there would be enough room for the 40r battery itself if the tray was cut down. I'be looked it up, and the 51R battery is about 1.5" thinner and shorter than the 40R. Looking at pics of the 3.5" intake installed with the small battery tray, there seems to be more than 1.5" clearance between the intake and the battery.
I've searched all over this site and Google, but can't find anyone talking about whether or not this would work.
2007 Mazdaspeed 6 - Black Mica - ZZB RIP 2016!
BNR S3, JBR 3" wp intake, JBR rmm, JBR heavy shift knob, JBR shifter bushings, JBR SSP, South Bend Stage 3 Endurance clutch, Juggernaught/Dreadnaught, Autotech HPFP, 3 bar map sensor, Stratified Boost Dial, Streetunit TMIC, Forge V2 BPV, ebay DP/TP, 3 inch custom single exit cat-back, magnaflow muffler, H&R springs, Cobb AP, JL Audio 12" W3 w/ 500w Alpine amp, 6000k HIDs, LED fogs, dipped and tinted - Stratified 369awhp/383awtq vdyno on 4 gallons of corn
biggman026 is offline   Reply With Quote
 Old 09-05-2013, 03:45 PM   #2
The MS6 has more room in that section. An MS3 would not fit a 3.5" intake. A little trick you can use is to slot the battery tray holes and move it as close to the strut tower as possible.
biggman026 (09-05-2013), El_Diablo (09-05-2013), Mauro_Penguin (09-07-2013)
 Old 09-05-2013, 04:12 PM   #3
biggman026's Avatar
That's a great idea! I think I'll slot the holes in the tray first and push it back as far as it will go, and then if I need to just trim about an inch off the width and length of the battery tray (leaving just enough width to cut a notch for the hook holding down the battery).
I was stuck between the JBR 3.5" and the 3" (I don't wanna worry about maxing out the 3") but I feel confident enough with this plan to go 3.5".
The Following User Says Thank You to biggman026 For This Useful Post:
djrich26 (08-12-2016)
 Old 11-27-2013, 08:56 PM   #4
redboat's Avatar
Posts: 634   (View Stats)
redboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the world
That's what I did, and I fit a 3" CPe and 3" HTP inlet on mine.
redboat is offline   Reply With Quote
 Old 09-05-2013, 04:25 PM   #5
BigjohnB20's Avatar
Posts: 779   (View Stats)
Lex knows his stuff, but he does have a 3...I am not sure a 3.5 will fit with the stock tray (at least fit well). I have a stock size Corksport intake/TIP on now and in order to get it to fit with their cold air box, I've had quite the struggle. It is TIGHT getting it to fit with my stock size battery/tray. I have slotted the shit out of the stock tray and removed two different wire harness clips and it just barely fits. I moved the tray over so far towards the strut tower that now my stock tie down doesn't really fit very well and does not hold the battery very tightly.
I am actually pretty unhappy wiht the way it stands now and am looking for alternatives. I have read that moving the batt/tray back towards the firewall may help some too and shouldn't affect the tie down as much, but I need to find a few minutes to look at doing this. Let us know how it all goes though as I have been eyeing a HTP 3" for a while now.
2006 BCM MS6 GT
CS SRI/TIP
Jbarone SSP/bushings
cp-e RMM, TMIC, Stiff Diff
AP
KMD V2.whatever
Ebay Catless DP
Grom Ipod
The Following User Says Thank You to BigjohnB20 For This Useful Post:
 Old 09-05-2013, 05:03 PM   #6
If you are concerned about maxing out the MAF, this is a non issue with the WP 3". The BNR S3 will not flow nearly enough air to max out the MAF. The injectors in the car will be maxed out long before the MAF as well.
DSIT995 likes this.
biggman026 (09-05-2013), Code Monkey (09-05-2013), DSIT995 (09-07-2013), Easter Bunny (09-07-2013), Mauro_Penguin (09-07-2013), redboat (11-27-2013)
 Old 09-05-2013, 05:15 PM   #7
biggman026's Avatar
OK, that makes my decision for me then. What had me concerned was another thread (I'd have to go back and try to find it) where someone posted that they were pushing 340 g/s with the 3" on a k04, and you had a post in the thread stating that the HTP 3" intake maxed earliest of the 3" intakes at 440 g/s. I was worried that the bnr might hit or come close to that 440 g/s mark but couldn't find anything on point. If a 3" will work on the bnr that'll be fine, won't have to worry about the battery.
 Old 09-07-2013, 08:28 PM   #8
DSIT995's Avatar
Posts: 1,768   (View Stats)
This is what I did... stock batt and ecu placement with bnr3 and 3"wp. So far so good
tapping.... tap tap
99 Miata NB - Stock for now
 Old 09-07-2013, 11:36 AM   #9
shawn.'s Avatar
Posts: 541   (View Stats)
shawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the world
Groaned at 22 Times in 16 Posts
i'm rocking a jbr 3.5" intake with nothing done to the battery/battery tray. only had to relocate the ecu, i ended up putting it on the fuse box cover.
Prodigalson likes this.
ATP GTX3071r// Cobb 3 Port EBCS // 3 Bar MAP // Cobb Accessport Freek Tuned // E85 Mix // JBR 3.5" Intake/TIP // Treadstone TR8C FMIC // Autotech HPFP Internals // Ported IM //C-pe Catted Downpipe // TRZ RMM // Corksport CBE // ISC Coilovers // EBC Slotted Rotors--Redstuff Pads // TWM shifter bushings // Dashhawk v2 // 6000k HIDs
Built engine--Manley H Beam Rods--Wiseco Pistons
shawn. is offline   Reply With Quote
The Following User Says Thank You to shawn. For This Useful Post:
biggman026 (09-09-2013)
 Old 09-07-2013, 11:46 AM   #10
boostdmazda3's Avatar
Posts: 1,177   (View Stats)
boostdmazda3 is the leader of the worldboostdmazda3 is the leader of the worldboostdmazda3 is the leader of the worldboostdmazda3 is the leader of the worldboostdmazda3 is the leader of the worldboostdmazda3 is the leader of the worldboostdmazda3 is the leader of the worldboostdmazda3 is the leader of the worldboostdmazda3 is the leader of the worldboostdmazda3 is the leader of the worldboostdmazda3 is the leader of the world
i was having the same concerns. I wasn't to hyped on it but I just dished out the money for the jbr small battery box and a new 51r battery. You can always sell the current battery.
Bnr s3/Act 6 puck/sure full 3inch intake/cobb fmic/cobb downpipe/grimmspeed ebc/3 bar map/hks catback/autotech hpfp internals/turbosmart bpv/bc coilovers/jbr trilogy mounts/ngk one step colder plugs/ms6 rims on nt-01 tires. 24 psi E85 freektuned.
Freektuned e85 Focus st as the daily.
boostdmazda3 is offline   Reply With Quote
The Following User Says Thank You to boostdmazda3 For This Useful Post:
 Old 09-07-2013, 12:39 PM   #11
SLOWHATCH's Avatar
Posts: 2,461   (View Stats)
Groans: 274
Also running a 3.5" htp intake with stock battery. Just make a bracket to relocate ecu to front of battery.
The Following User Says Thank You to SLOWHATCH For This Useful Post:
 Old 09-09-2013, 04:32 PM   #12
biggman026's Avatar
Thanks guys, I appreciate all the input. I've just gotta go buy some 6AN hose and some new exhaust bolts and studs (just in case any of the old studs break or strip).
I'm doing most of my planning based on the how-to threads created by himurax13 and Ziggo, incredibly useful stuff.
BNR Stage 3 Checklist.
BNR S3 Swap How To
Quick question while I'm thinking about it (I'll be starting a build thread in the near future once I've got everything together) - himurax notes near the top of his original post that you should buy 10 new exhaust nuts for the exhaust manifold if you're going to remove it during the install. In section 1.8 of ziggo's how to he appears to state that these are 14mm nuts. Would I be correct that these should be grade 8 14mm exhaust nuts?
I'd tag himurax13 and Ziggo, but.....I have no idea how to do that :/
 Old 09-09-2013, 04:50 PM   #13
himurax13's Avatar
Posts: 4,585   (View Stats)
Groans: 255
BNR S3 Swap How To
The OEM Exhaust nuts are 14mm. Since the exhaust nuts are an oval shaped locking variety, I recommend replacing instead of reusing.
The ones from Edge Auto are either 15 or 17mm, don't remember offhand.
The copper looking ones from Edge Auto are beefier than the OEM nuts and I haven never had one back out.
Pickles Tune in progress
 Old 09-09-2013, 05:24 PM   #14
15mm
biggman026 (09-09-2013), himurax13 (09-09-2013)
 Old 09-09-2013, 04:46 PM   #15
skiptowncat's Avatar
Posts: 1,592   (View Stats)
@himurax13; @Ziggo;
Tuned with by
The Following User Says Thank You to skiptowncat For This Useful Post:
 Old 09-09-2013, 05:19 PM   #16
biggman026's Avatar
I think I found the 10mm nuts and studs here:
Year - 2007 - Mazda - Mazdaspeed 6 - Engine - Accessories - EdgeAutosport.com
But I can't find any 15-17 mm nuts. Would those 10mm nuts work on the manifold ?
I think I found the 10mm nuts and studs on Edge auto, but can't find any that are 15-17mm. Would these nuts work for the exhaust manifold studs too?
Scratch that. I'm an idiot. Those are the 15mm nuts you spoke of. I was confusing the internal and wrench head diameter.
Last edited by biggman026; 09-09-2013 at 05:19 PM. Reason: MSF Database - Automerged Doublepost
 Old 09-09-2013, 06:40 PM   #17
Ziggo's Avatar
Posts: 3,843   (View Stats)
Seems like you got it all figured out, 10mm studs, but the size of the head varies.
If its worth anything I agree with replacing. I had two of the stock ones back out on me, I replaced with big ass copper locking thread nuts. I just got lucky that they were both easily accessible
Ask Me About My:
 Old 09-09-2013, 06:48 PM   #18
alphasaur's Avatar
Posts: 2,847   (View Stats)
Groans: 235
seems like everyone commenting has a speed 3....
I have a speed 6 (also had a speed 3 with a 3", removing ecu would allow for 3.5 on speed 3 easily IMO) with a 3" htp and I modified the tray to sit closer to the strut tower/rear of the car. It's an extremely tight fit and I definitely don't see a 3.5" intake fitting.
/Turbo ep3 BWAAAAA PSH
/speed 3- bye
/lol nator.
The Following 2 Users Say Thank You to alphasaur For This Useful Post:
biggman026 (09-09-2013), BigjohnB20 (09-10-2013)
 Old 09-09-2013, 07:08 PM   #19
biggman026's Avatar
Thanks alphasaur, I'm gonna be going with a 3" JBR. It seems like consensus is that a 3" will pair well with the bnr s3, and I don't want to worry about fitment if I don't need to.
Do you guys think it's worth it to get new gaskets as well if I recently had my k04 replaced under warranty about 6k miles ago (smoking turbo tsb)? I figure the gaskets should be relatively good to go at this point if they were replaced with the turbo. The nuts and studs I'm definitely buying since I tend to have terrible luck with them, but the gaskets I'm ambivalent on (not to mention that the gaskets are exponentially more expensive than the nuts and studs lol).
alphasaur (09-09-2013)
 Old 09-09-2013, 07:15 PM   #20
alphasaur's Avatar
Groans: 235
I would reuse gaskets with copper spray, but am cheap.
/speed 3- bye
/lol nator.
 Old 11-27-2013, 09:02 PM   #21
biggman026's Avatar
I went with a 3" full WP JBR intake and the only problem I have is that the TIP rubs against the brake booster pretty hard. I had to stick a piece of silicone between the TIP and the brake booster to protect the TIP. Fitment really isn't the best on the MS6.
Battery Tray HTP HTP (Hi-Tuned Performance) 196 05-26-2013 03:43 PM
JBR Ms6 Battery Tray! nextgenerationx1 JAMES BARONE RACING 2 04-26-2013 10:20 PM
Installed HTP Battery Tray w/ Affordable Smaller Battery GreyGhost Gen2 MS3 General Discussion 13 03-11-2013 10:44 PM
MS6 Battery Tray Release HTP HTP (Hi-Tuned Performance) 28 09-30-2012 02:54 AM
Battery Tray DJBY 2010 MS3 - Engine, Transmission & Driveline 4 08-23-2011 06:10 PM
Page generated in 0.44338 seconds with 33 queries
