Like Tree34Likes
 Old 01-03-2011, 06:08 AM   #1
MSP611's Avatar
Posts: 2,291   (View Stats)
Default MSP611's big motor/turbo build
So I'm starting a thread to get questions answered and post my interest in wat I wanna run. Here's the motor and turbo set up I wanna run. (motor has 65,xxx on it should I rebuild only goin for about 400AWHP AND 400AWFTLBS.)
-Same block I have now
-pauter rods(dunno if I should get upgraded pistons open for suggestions kinda dont wanna fuck with raising/lowering compression)
-Garrett T3/60-1 with Stage III turbine wheel and 60-1 compressor wheel with .78 A/R t3 divided housing.
-steedspeed top mount exh. Mani(still in the works)
-DJ's top mount kit with DP
-Cosmedic head gasket
-tial 38mm EWG
-have valves adjusted And head looked at for any problems.
-OEM gasket kit
-all OEM bearings
-cobb AP
-altered customs FMIC KIT
-ARP main block studs and head studs
any other suggestions or parts I might need? I know I will run into lil stuff along the way. This will also be built by me and will be my first motor build on a car. ( i am jet engine mechanic is y I say this)
In progress:
The Following User Says Thank You to MSP611 For This Useful Post:
dougefresh_ (01-17-2012)
 Old 01-03-2011, 07:02 AM   #2
psychophyr's Avatar
Posts: 770   (View Stats)
psychophyr is the leader of the worldpsychophyr is the leader of the worldpsychophyr is the leader of the worldpsychophyr is the leader of the worldpsychophyr is the leader of the worldpsychophyr is the leader of the worldpsychophyr is the leader of the worldpsychophyr is the leader of the worldpsychophyr is the leader of the worldpsychophyr is the leader of the worldpsychophyr is the leader of the world
This just for looks?
lol GL with the build! wish I had the money to drop right now and do this.
2006 Mazdaspeed6 GT BCM
SpeedPerf6rmanc3 10.6:1 Pistons, PI Fuel Kit, PnP Head, 75mm TB, Pinned Cams/Keyed Crank, 11mm H11 Head Studs \\ PT&E PT6266 CEA BB S-Comp. \\ Manley H+ Rods \\ JMF V2 PI Intake Mani w/ Bosch 1000cc Injectors
Squash Performance Top Hat w/ Dual DW300 Pumps \\ AEM FPR \\ Split Second AIC1 \\ CP-e LRT Ex. Mani, SAFEseals, RDM, EGRD \\ SURE TMM, PMM, Juggernaut, Anchors \\ TiAL MVR, Q \\ Bosch 4 Bar MAP
HTP 4" Intake \\ Autotech HPFP Internals \\ ATP Catless DP \\ ACT HD 6-Puck w/ Streetlite FW \\ Cobb AP \\ Treadstone TR10 \\ Magnaflow CBE \\ MSD Dashhawk \\ JBR SSP, BSD, RMM
Stratified EBCS \\ Corksport SS Braided Clutch Line \\ H&R Coilovers \\ SPC BJs \\ Rotora Drilled/Slotted Rotors \\ H2 Ceramic Pads \\ Enkei EKM3 7.5+45 \\ VG Sharkfin \\ RHO-Plate
Most powerful MS6 720/584 @42psi E42 9Oct13 Tuned by NISHAN
psychophyr is offline   Reply With Quote
 Old 01-03-2011, 07:22 AM   #3
MS3-a(sore)ASS-rex's Avatar
Posts: 7,012   (View Stats)
Groans: 224
I'll get you the price on that turbo asap
NATOR PA
 Old 01-03-2011, 07:59 AM   #4
Tripple OG
NJSPEED3's Avatar
Posts: 5,703   (View Stats)
Groans: 113
Good luck!
Why not do pistons,rings if you're already taking the motor apart, you could get stock compression.
my2 pennies rubbing!
 Old 01-03-2011, 08:19 AM   #5
cageyvet's Avatar
Posts: 715   (View Stats)
-tial 38mm EWG
-OEM gasket kit
-all OEM bearings
-cobb AP
Make sure you delete the balance shaft; F2 has a BSD kit. Also, might as well lower the compression a little compared to stock so the car will be less likely to knock. Also, since your car has a decent amount of miles a .20 over on the pistons wouldnt be a bad idea.
The Following 3 Users Say Thank You to cageyvet For This Useful Post:
Alpha (01-03-2011), djuosnteisn (01-04-2011), dougefresh_ (01-17-2012)
 Old 01-03-2011, 08:55 AM   #6
MSP611's Avatar
So buying .20over pistons and would i need block to be milled? Any suggestions on pistons then like cp, Carrillo?? Over are u jst talkin milling the pistons? O ^ya balance BSD shoulda been on there duh and step colder plugs.
In progress:
 Old 01-03-2011, 03:08 PM   #7
Tripple OG
NJSPEED3's Avatar
Groans: 113
I think F2 went out of business!
 Old 01-03-2011, 03:14 PM   #8
aviator79's Avatar
Posts: 3,934   (View Stats)
I think the business was 'sold' and the parts should still be made. Think I read it on 6crew.
 Old 01-04-2011, 12:09 PM   #9
spiker98's Avatar
Posts: 427   (View Stats)
spiker98 is the leader of the worldspiker98 is the leader of the worldspiker98 is the leader of the worldspiker98 is the leader of the worldspiker98 is the leader of the worldspiker98 is the leader of the worldspiker98 is the leader of the worldspiker98 is the leader of the worldspiker98 is the leader of the worldspiker98 is the leader of the worldspiker98 is the leader of the world
He meant cometic, not cosmedic...
2006 LP MS6 sport-
Garret GT30, Carillo rods, ARP mainstuds, CP custom forged pistons, Custom Downpipe, Creative Performance exhaust manifold, MAP intake manifold, Tial 38mm external wastegate, Cp-e Nviscid BT inlet pipe, Cp-e XL Xcel intake, Cp-e standback, Cp-e fuel cut fix/ Maf/ full throttle flash, Custom screamer pipe, Cp-e FMIC Blacked out, HKS SSQV blackout edition, KMD v2 fuel pump internals, BSD kit, Oil baffle, SU stiff diff brace, TWM stage 2 short shifter, BC coilovers, AWR endlinks font/ rear, SPC balljoints, SURE Juggernaut, Car-led tail lights, Cp-e center gauge pod, Prosport premium boost/ Air fuel/ Oil pressure gauges. All the little shit that goes with that. In coordination with Ginger performance and DDMworks.
spiker98 is offline   Reply With Quote
 Old 01-04-2011, 12:36 PM   #10
essejkcamraw's Avatar
Posts: 922   (View Stats)
essejkcamraw is the leader of the worldessejkcamraw is the leader of the worldessejkcamraw is the leader of the worldessejkcamraw is the leader of the worldessejkcamraw is the leader of the worldessejkcamraw is the leader of the worldessejkcamraw is the leader of the worldessejkcamraw is the leader of the worldessejkcamraw is the leader of the worldessejkcamraw is the leader of the worldessejkcamraw is the leader of the world
Groans: 47
Groaned at 25 Times in 19 Posts
go wiseco pistons. if you go .20 it will need to be bored.
have you looked at K1 rods? very affordable and more than capable of doing what you want and is a nice rod. cp-e actually uses this rod/piston set up on their motors.
From built & Big turbo to Miata Gheys
essejkcamraw is offline   Reply With Quote
The Following User Says Thank You to essejkcamraw For This Useful Post:
 Old 01-04-2011, 01:44 PM   #11
MSP611's Avatar
^ya thx spiker^^ and haven't looked at k1 rods. Where can u find them? And what's the running price? Y wiseco pistons? I've always ran those pistons in my dirt bikes but nvr really heard anything about them with cars
In progress:
 Old 01-04-2011, 02:23 PM   #12
Groans: 224
Wiseco pistons has been around for like 70 years making the best pistons money can buy. They're the only pistons I've ever run in my race bikes and I wouldn't think any less of their excellent quality would carry over to the automotive market
NATOR PA
 Old 01-04-2011, 02:50 PM   #13
Groans: 47
cp-e sells the K1 rods as does protege garage.
MZR 2.3 DISI Rods | Custom Performance Engineering
both at the same price. this rod/piston combo is actually what i will be using also with my high HP target build.
and as long as wiseco has been around and quality of their products, cants go wrong. esp for the price.
 Old 01-04-2011, 03:00 PM   #14
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
cp-e sells wiseco as well.... so possible 2 birds with one stone there.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
essejkcamraw (01-04-2011)
 Old 01-04-2011, 03:19 PM   #15
MSP611's Avatar
^ya I found the rods they are a lil cheaper then pauters. Haven't looked at the wiseco pistons yet. What's advantages of runnin .20 over pistons?
In progress:
 Old 01-04-2011, 04:20 PM   #16
MS3KO's Avatar
Posts: 579   (View Stats)
MS3KO is the leader of the worldMS3KO is the leader of the worldMS3KO is the leader of the worldMS3KO is the leader of the worldMS3KO is the leader of the worldMS3KO is the leader of the worldMS3KO is the leader of the worldMS3KO is the leader of the worldMS3KO is the leader of the worldMS3KO is the leader of the worldMS3KO is the leader of the world
Im gonna be running to wiseco piston/K1 rod combo too from what i hear their both pretty top notch brands
2009 MazdaSpeed 3 Metro Grey-T3 Gt3071, Re-flanged RR mani, 44mm Tial WG, Cusom DP, Custom 4in to 3.5in intake, Custom 3.5in maf, Custom FMIC kit, Tial BOV, EVO Prosport Boost gauge, EVO oil temp gauge, AEM wideband, TRZ RMM, JBR PMM, JBR TM, JBR Shifter Plate, TWM SS, Hks CBE, COBB AP, Road Magnet Springs.
PERM Tuned!///389hp 360tq///Best time:12.2 @117 (with new tires 11's here i come!)
Hit up BC Autoworks for all your powder coating needs!
MS3KO is offline   Reply With Quote
 Old 01-04-2011, 04:37 PM   #17
bmylez's Avatar
Posts: 3,197   (View Stats)
If you have your block bored out to make sure you have perfectly round cylinders, .20" is a very common amount to have taken out so you have to get .20 pistons to match. Increases your displacement a tiny tiny bit as well . 2.35L!!!111!!
 Old 01-05-2011, 03:30 AM   #18
MSP611's Avatar
Hmm should I just buy a block from street unit with this set up? What would be cheaper?
In progress:
 Old 01-05-2011, 04:57 AM   #19
Groans: 224
I don't think there's any reason to pick up a new block. Unless you ejected a rod or just want to have a spare one laying around...
Do the blocks from SU come as an assembled short block? If so, it'd save you a bunch of time from having to do it yourself.
NATOR PA
 Old 01-05-2011, 05:15 AM   #20
easy's Avatar
Posts: 539   (View Stats)
easy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the world
Groans: 27
su seems to only sells the stock short-block assembled. If you choose the "build-a-block" option it will be sent unassembled.
08 MS3
() Arias Pistons & Pauter Rods, P&P Head, Port match IM, DCR VVT, ARP Head Studs, Autotech CDFP internals, F2 BSD & Baffle, Cobb AP, Cobb SRI, PG TIP, CS Test Pipe, FMIC, Tial QR, JBR RMM/TMM, Oil spin-on Conversion, NGK iridiums IX
() Koni Yellows, Roadmagnet springs(6.5k Front, 6.4k Rear), Cobb RSB, TB trunk brace, AWR Rear Endlinks, SPC rear camber arms
() Centric Slotted Rotors/ Posi-Quiet pad
() Fidanza 11lbs. Flywheel, E4P STS, Cobb Shifter Weight, TWM Bushings, Redline MT-90
easy is offline   Reply With Quote
The Following User Says Thank You to easy For This Useful Post:
MS3-a(sore)ASS-rex (01-05-2011)
 Old 03-09-2011, 11:21 AM   #21
Kyle's Avatar
Posts: 24   (View Stats)
Kyle has a spectacular aura aboutKyle has a spectacular aura about
Goodluck man I'm getting there slowly. Getting the basics done first. Gonna take some time to get that kinda money together too.
2006 Mazdaspeed6 Black & White Leather Interior - Act Street Kit | TMW STS STG II & Bushings W/ Desert Eagle WSK| cp-e HKS SSQV BOV | cp-e XCel CAI | cp-e Wishbone Engine Mount | SU STIFFDIFF RDM | Turbine Tech RDFM | Turbine Tech Front Eng Mount | Edge Insight CTS Scan Tool | 500hp rear axles... Zoom-Freakin-Zoom
Kyle is offline   Reply With Quote
 Old 10-14-2011, 01:10 PM   #22
MSP611's Avatar
Alright guys huge update. i will.no longer be going BT at this time, instead i will be going for more of an all around car. I still plan on going BT down the line, but this is when im ready to rebuild. For now im going to be doing precautionary mods and a PG reworked. Im doing this for the tuning exp and to have more time with the car, so when i do go BT i know what im doin. Here are some pics of wat I've got in the mail so far
Still waiting on: PG reworked turbo, fuel pump internals, BSD kit and oil pan baffle, AWR front and rear adjustable endlinks, GT spec trailing braces, Autoexe rear floor brace, Perrin EBCS, Matt damond OCC... I think thts it??
Sent from my GT-I9000 using Tapatalk
In progress:
AZSPEED3 (01-09-2012)
 Old 10-14-2011, 02:11 PM   #23
Alpha's Avatar
Posts: 3,711   (View Stats)
Attachment 42648Attachment 42650
And some pimp ass tails! Haha!
 Old 10-14-2011, 02:24 PM   #24
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
PG reworked? might have been better off with a BNR, or just a stocker for a while rather than wasting money on a reworked k04.
GL.
07 MS3
The original Genpoo Hater
Alpha (10-14-2011)
 Old 10-14-2011, 02:33 PM   #25
Alpha's Avatar
GL.
+1 If you plan on going BT eventually, don't waste your money on anything less IMHO. I'd put that money toward a nice, (Soon to be released hush hush) Exhaust manifold and FMIC kit.
 Old 10-15-2011, 09:14 AM   #26
MSP611's Avatar
I got a steal on the PG reworked thts y im going with it. If i wanted to go BNR i would of just gone BT and or a gt 2871. Don't get me wrong BNRs r great but i couldn't pick one up for wat i got the reworked for
Sent from my GT-I9100 using Tapatalk
In progress:
 Old 12-10-2011, 11:25 PM   #27
MSP611's Avatar
Default A huge update!!!
Alright guys so i finally began working on the car after i got back from the desert. i have acquired some more tools, but am still waiting on my other tool set to come in the mail.
The first picture is all the parts im installing on this build. Im still missing my Autotech fuel pump internals and my Perrin ECBS. I also still need to order a catch can (@MATT DAMOND).
The rest of these pictures are wat i got done today in about a 2-3 hour solid working time in between all the other shit i got done today. Pretty much have the DP (o2 sensors were pretty easy with a lot of a PB blaster look alike) out, TP is off, just need to loosen the bracket. Exh. mani is close to out just have to get one more nut. Turbo needs all wastegate connections taken off, coolant line removed etc etc... Drinking some Belgian blonde Hoegaarden's on the side.
Got a lot of work to do. Im going to finish the motor, then do the suspension stuff on a lift on base just to mae it easy. The SPC ball joints are gunna be a bitch.
Hopefully the weather stays good becuz im up on the PERM tune list and @Lex he wants to work with me ASAP so i need to get these hard parts installed. Hopefully these fuel pump internals show up soon.
Other then that i hope i finish here soon to get to tuning. Gunna be a good learning exp.
In progress:
The Following 2 Users Say Thank You to MSP611 For This Useful Post:
djuosnteisn (12-12-2011), dougefresh_ (12-13-2011)
 Old 12-30-2011, 05:18 PM   #28
MSP611's Avatar
Default New update of Whats going on!!!
Hey Guys Wats up,
First off, prior to this i was on a 5 or 6 day party binge, because i had the last 1.5 weeks off so it took me awhile to sober up and get to work ....
Me and a buddy were attempting to take off my DP, Exh. Mani and Turbo / intake system
So me and a buddy named Dick Started to pull of my Exh. mani and into a few tight pinches...
First real problem Was getting the bottom drivers side stud on the Exh. mani. The stud is recess in the mani and there is little room between the coolant feed line and the stud itself. I could get the 14mm wrench on there but i couldn't get the pressure and grip to break the nut. My friend had the bright idea to prevent slippage and to put one of the Exh. mani nuts on the stud to keep the wrench from slipping. I tightened it on down to the wrench finger tight and it helped you not have to apply inward pressure on the wrench to keep it on the nut. Since the nuts were previously sprayed with Break free... i gave one full pull and broke the last on the hard nuts (no homo)....
After that the DP slid out quite easily and could be maneuvered to your specific liking.
Only real pain on turbo pull was oil feed line..... Those two small 8mm bolts that hold it on are in an odd spot and you just have to do it blind.... (actually was quite used to it because on jets most things you work on with out sight) just didn't it expect it like that on the turbo.
I've attached some pics of the build and where it sits. The minimalistic tool selection i have, because of USPS system. Pics of the garage and the progress for the accumulative work of maybe 12hrs in 2 days with beer drinking and Hookah sessions in-between.
Next weekend is fuel pump pull and internals install, then intake manifold removal and injector seal change. TB coolant bypass mod(SURE TB gasket as well) and SURE intake manifold gasket as well. EGR delete and if it shows up in the mail, my BSD kit and oil pan baffle install.
pics... for some reason it wont let me upload the pics from my computer will try tomorrow...
In progress:
Last edited by MSP611; 12-30-2011 at 05:18 PM. Reason: MSF Database - Automerged Doublepost
crazyp (12-30-2011)
 Old 12-31-2011, 06:36 AM   #29
psychophyr's Avatar
Damn wish i would have seen this thread earlier. This trick by DJ made working with the DP and any parts back there incredibly easy.
How to: Free up room for turbo work
takes like 5 minutes to take that shroud off and gives your at least 3 inches more room across the whole firewall. I pulled the DP through the top without removing anything else.
The Following User Says Thank You to psychophyr For This Useful Post:
djuosnteisn (01-09-2012)
 Old 12-31-2011, 06:11 PM   #30
Navy_Mech2's Avatar
Posts: 484   (View Stats)
Navy_Mech2 is the leader of the worldNavy_Mech2 is the leader of the worldNavy_Mech2 is the leader of the worldNavy_Mech2 is the leader of the worldNavy_Mech2 is the leader of the worldNavy_Mech2 is the leader of the worldNavy_Mech2 is the leader of the worldNavy_Mech2 is the leader of the worldNavy_Mech2 is the leader of the worldNavy_Mech2 is the leader of the worldNavy_Mech2 is the leader of the world
@MSP611- what branch? and which a/c?
06 MS6 |SP Built motor - Weisco Pistons .020" over, Manley H-Beam Rods, Ported Head, Ported Intake, VTCS Delete, BS Delete, VVT Actuator, Keyed Crank, 6th Port Fuel Injection | ACT 6 Puck w/ Streetlite Flywheel | Bullseye S259 .70 A/R Single Scroll | 3.5" Intake/MAF Housing | Steedspeed Twin Scroll T3 Top Mount Manifold | Tubosmart 40mm EWG | Custom DP | Custom TBE | Custom LTA Intercooler | HKS Type IV TT | Dashhawk | COBB AP | AWR RMM | PTP HPFP Guts |
KILLAH BUILT
Navy_Mech2 is offline   Reply With Quote
 Old 01-01-2012, 09:12 AM   #31
MSP611's Avatar
alright heres the pics hopefully they load this time...
@navy_mech.... im air force, i work on f-16s, im a jet engine mechanic on the flightline.
@earlier post (forgot userid) i would of pulled the plastic shroud i jst didnt think of it at a time and i was already like half way through the removal so i just kept pressing.
dougefresh_ likes this.
In progress:
The Following 4 Users Say Thank You to MSP611 For This Useful Post:
djuosnteisn (01-09-2012), dougefresh_ (01-01-2012), kmac (01-10-2012), psychophyr (01-09-2012)
 Old 01-06-2012, 10:39 AM   #32
LilVic's Avatar
Posts: 187   (View Stats)
LilVic has a reputation beyond reputeLilVic has a reputation beyond reputeLilVic has a reputation beyond reputeLilVic has a reputation beyond reputeLilVic has a reputation beyond reputeLilVic has a reputation beyond reputeLilVic has a reputation beyond reputeLilVic has a reputation beyond reputeLilVic has a reputation beyond reputeLilVic has a reputation beyond reputeLilVic has a reputation beyond repute
Groaned at 8 Times in 3 Posts
that manifold can be such a bitch to take off also the dp.. PB blaster was my new best friend... Also you gonna wrap the manifold?? some nice DEI titanium wrap..
keep us updated
LilVic is offline   Reply With Quote
 Old 01-06-2012, 11:22 AM   #33
Jsn_Rob's Avatar
Posts: 116   (View Stats)
Jsn_Rob has a reputation beyond reputeJsn_Rob has a reputation beyond reputeJsn_Rob has a reputation beyond reputeJsn_Rob has a reputation beyond reputeJsn_Rob has a reputation beyond reputeJsn_Rob has a reputation beyond reputeJsn_Rob has a reputation beyond reputeJsn_Rob has a reputation beyond reputeJsn_Rob has a reputation beyond reputeJsn_Rob has a reputation beyond reputeJsn_Rob has a reputation beyond repute
I'm currently in the dessert but when I return state side I'll be looking to go BT. I have a Hypertec controller I'll be selling and I will be be in the market for a COBB AP. Also ditching my TMIC. Also a 3076r and fuel pump are on my grocery list. My plan is to take it slow and do the installs little by little so if my cars starts acting funky I'll have an easier time diagnossing the problem. Would be great to hook up with a "Perm" specialist too.
Silver 08 MS3-
Purple Drank Racing Tune l CXRACING FMI l DO Methanol Injection l JBR 3.5 intake l Turbo XS DP, TP l ProSport Boost Gauge l HKS TT l Cobb AP l Cobb RMM l H&R Springs l Turbo Smart BPV l WOT Box l JBR side mounts l KMD internals l BNR Stage 1 turbo l Protegegarage SS l VTCS Delete | TB Spacer | CPE Injector Seals l BSD l 3 port EBC l Bosch 3bar MAP.
Jsn_Rob is offline   Reply With Quote
 Old 01-09-2012, 02:16 PM   #34
Captain
picture of bolts in zip lock baggies
HAHAHAHA, great minds think alike man. I zip lock all my bolts exactly like you. Makes reassembly 1000x easier. Good form.
www.permtuning.com
Lex (01-14-2012)
 Old 01-14-2012, 09:54 AM   #35
MSP611's Avatar
@djuosnteisn ya man we have to do tht at work for tearing apart jets and i dont get to work on my car every day or every weekend for tht matter so it keeps my brain fresh when i look at them lol...
@LilVic ya i didnt think about wrapping it but thts a good idea.... wrap it then get it some ceramic coating... its lame because i dont wanna put tht lame ass stock Exh. mani back in for all the work it took to get off, but i dont wanna spend the money on another mani when im going BT after this setup anyways.
@Jsn_Rob this is not a random posting excursion... get your post count somewhere else if you dont have something productive or a cool suggestion please do not post. (stay on topic)
In progress:
djuosnteisn (01-16-2012)
 Old 01-14-2012, 01:42 PM   #36
greg08's Avatar
Posts: 480   (View Stats)
greg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond repute
Groaned at 22 Times in 15 Posts
Yea it sux man but ull still be fast
greg08 is offline   Reply With Quote
 Old 01-21-2012, 09:55 AM   #37
MSP611's Avatar
Default what i got done today
alright guys got some more done today...
i first read the how to injector and intake manifold removal probably 3 times making sure i understood every aspect prior to jumping on this task.
1. removed TB
2. removed intake mani.
3. looked at all the nasty buildup on my intake valves... (guess im doing the how to clean your intake valves next lol)
4. gawked at all my new tools i got in the mail lol
Heres some pics of what all i got done (not much only really worked for about 1.5hrs so i feel pretty accomplished. ) and one extra pic of an f100-129b turbofan engine with a goofy ass co-worker lol...
That hose going from the PCV valve to the intake mani. was the only hiccup i ran into.... had a good time figuring out how to loosen the clamps and pull the hose off, but figured it out.
In progress:
psychophyr (01-21-2012)
 Old 01-21-2012, 05:59 PM   #38
psychophyr's Avatar
LOL reflective belt... fuck those things!
 Old 01-21-2012, 11:31 PM   #39
Navy_Mech2's Avatar
KILLAH BUILT
The Following User Says Thank You to Navy_Mech2 For This Useful Post:
psychophyr (01-22-2012)
 Old 01-22-2012, 11:06 AM   #40
MSP611's Avatar
WOW thts good^^^^
In progress:
HOW TO build an mzr motor!! qtrmile beast MazdaSpeed 6 - Engine, Transmission & Driveline 4 09-12-2012 05:07 AM
Coaststarlight's Forged Motor Build Thread! Coaststarlight MazdaSpeed 6 - Engine, Transmission & Driveline 37 02-09-2011 02:30 PM
Motor build parts list ? jracer MazdaSpeed 3/6 - Big Turbo Builds 6 12-25-2010 06:20 PM
everything neded to build motor? ms3boost MazdaSpeed 3 - Engine, Transmission & Driveline 15 05-04-2009 11:14 PM
Page generated in 0.59541 seconds with 39 queries
