Like Tree33Likes
 Old 10-17-2013, 06:32 AM   #241
Police - Grammarhead
Vansquish's Avatar
Done:
Psycho's 700hp Speed6
The Following 5 Users Say Thank You to Vansquish For This Useful Post:
atvfreek (10-17-2013), jreiden1 (10-17-2013), Koenig (10-17-2013), phate (10-17-2013), Realgib3 (10-17-2013)
 Old 10-17-2013, 06:42 AM   #242
Vadim aka ScooteR's Avatar
Posts: 206   (View Stats)
Vadim aka ScooteR is the leader of the worldVadim aka ScooteR is the leader of the worldVadim aka ScooteR is the leader of the worldVadim aka ScooteR is the leader of the worldVadim aka ScooteR is the leader of the worldVadim aka ScooteR is the leader of the worldVadim aka ScooteR is the leader of the worldVadim aka ScooteR is the leader of the worldVadim aka ScooteR is the leader of the worldVadim aka ScooteR is the leader of the worldVadim aka ScooteR is the leader of the world
I saw. But is this direct injection? What kind of head and cams?
Can u really call his engine mazdaspeed's engine?)
Vadim aka ScooteR is offline   Reply With Quote
 Old 10-17-2013, 06:44 AM   #243
Vansquish's Avatar
Stock cams. I believe there's some porting of the head, and it uses Direct Injection + Port injection in the JMF manifold.
 Old 10-17-2013, 06:47 AM   #244
SpeedPerf6rmanc3 10.6:1 Pistons, PI Fuel Kit, PnP Head, 75mm TB, Pinned Cams/Keyed Crank, 11mm H11 Head Studs \\ PT&E PT6266 CEA BB S-Comp. \\ Manley H+ Rods \\ JMF V2 PI Intake Mani w/ Bosch 1000cc Injectors
looks like very far from mazdaspeeds engine. my opinion, and are there any road test of this car?
 Old 10-17-2013, 07:00 AM   #245
Don06speed6's Avatar
Posts: 2,492   (View Stats)
Don06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the world
Groans: 62
That car was just driven several hundred miles across the country. What makes very far from a mazdaspeed enigine? All I see are forged internals and an intake mani.
Cobb AP(FREEK TUNED)/CS TBE/SURE AEROS/CPE TIH/ ITV 22/SU RMM/KMD INTERNALS/SURE DREADNAUGHT/JUGGERNAUGHT/WHITELINE RSB/SURE ANCHORS/SURE COUNTERWEIGHT/SURE SHORTCUT/JBR HEAVY KNOB/JBR EGR DELETE/SPC BALL JOINTS/CENTRIC BLANKS/HPS PADS/BNOON BOLT/ALTERED CUSTOMS FMIC/TURBO XS RFL
Don06speed6 is offline   Reply With Quote
The Following 2 Users Say Thank You to Don06speed6 For This Useful Post:
Fail_6 (11-10-2013), superskaterxes (10-17-2013)
 Old 10-17-2013, 07:02 AM   #246
Realgib3's Avatar
Posts: 2,443   (View Stats)
Stock block, stock intake manifold, stock head, stock cams.... Time to just admit you're wrong.
533/436 Dyna Pack
Edit:
And my car with the same setup, but intake dividers cut outa the head, and forged internals.
Realgib3 - 571/442 - Dynapack
The Following 4 Users Say Thank You to Realgib3 For This Useful Post:
atvfreek (10-17-2013), Fail_6 (11-10-2013), jreiden1 (10-17-2013), Vansquish (10-17-2013)
 Old 10-17-2013, 07:09 AM   #247
Vansquish's Avatar
It is a stock block with a bunch of upgraded internals and peripherals. That is, it's a stock block with a built bottom end (connecting rods, pistons, and pinned cams/keyed crank to prevent slippage). It also has a ported and polished head, a larger-than-stock throttle body, and a JMF intake manifold designed to accommodate additional fueling.
It IS an MZR DISI motor, but with a bunch of internal upgrades as well as a supplemental port-injected fueling system.
I'm not sure what you're getting at, but this is, in fact, a Mazdaspeed engine.
Furthermore, the car was just driven from Iowa to Arizona (1400 miles or so), without any trouble at all.
The Following 3 Users Say Thank You to Vansquish For This Useful Post:
BobtailedSnail (10-17-2013), Fail_6 (11-10-2013), superskaterxes (10-17-2013)
 Old 10-17-2013, 07:13 AM   #248
533/436 Dyna Pack
Cause of bosch injectors. Really it is not direct injection, 10.6 degree of reduction.
PnP Head
Really, all the car is stock)
It is without real loading. Have u any test of it? Not on stand but on road?
Last edited by Vadim aka ScooteR; 10-17-2013 at 07:13 AM. Reason: MSF Database - Automerged Doublepost
 Old 10-17-2013, 07:14 AM   #249
Realgib3's Avatar
PnP Head
His motor is completely stock. End of story. And yes, he is using TBI injectors as additional fuel instead of meth.
You use extra fueling too, so I don't see where your argument is here.
The Following 5 Users Say Thank You to Realgib3 For This Useful Post:
Boosted Beluga (10-17-2013), Fail_6 (11-10-2013), Koenig (10-17-2013), phate (10-17-2013), Vansquish (10-17-2013)
 Old 10-17-2013, 07:20 AM   #250
Vansquish's Avatar
PnP Head
1. I guess I would call it a dual-injected motor. It has BOTH direct injection AND port injection.
2. The head is Ported and Polished, but it's otherwise the stock head.
3. The pinned cams/keyed crank are stock items, but reinforced to prevent slippage/losing time.
4. The rods/pistons are what you could call, "drop-in" items. They're not stock, but they don't change the block itself.
5. I never said the car was "stock," just that certain components were.
6. There are road-tests with results here:
Psycho's Speed6 Build (PT6266)
Boosted Beluga (10-17-2013), jreiden1 (10-17-2013), Realgib3 (10-17-2013)
 Old 10-17-2013, 07:26 AM   #251
Karmat's Avatar
Posts: 1,179   (View Stats)
PnP Head
Besides the extra fuel coming through the intake manifold there is nothing exotic about this build.
You guys still use meth to keep up with fueling needs, he uses extra injectors in the intake manifold to accomplish the same thing.
The engine has stock sleeves which makes it more of a stock mazdaspeed engine than yours.
A lot has changed since Pat ran 10s on this side of the pond. You guys just haven't been following and need to catch up.
2002 Corvette Z06 (Black)
The Following 4 Users Say Thank You to Karmat For This Useful Post:
Boosted Beluga (10-17-2013), Koenig (10-17-2013), phate (10-17-2013), Vansquish (10-17-2013)
 Old 10-17-2013, 07:53 AM   #252
Koenig's Avatar
Posts: 4,635   (View Stats)
Koenig is the leader of the worldKoenig is the leader of the worldKoenig is the leader of the worldKoenig is the leader of the worldKoenig is the leader of the worldKoenig is the leader of the worldKoenig is the leader of the worldKoenig is the leader of the worldKoenig is the leader of the worldKoenig is the leader of the worldKoenig is the leader of the world
Groaned at 24 Times in 24 Posts
PnP Head
Which injectors are supplying "primary" fueling? If he were to stock out the car to sell it, which injectors remain on the car?
The port injection is to put it simply, adding the extra fueling needed to make the power. How is that different from people who tap meth into their setups to supply additional fueling?
So does that mean if someone is running meth you do not consider them direct injection either?
Also he did not say the motor was stock. Your question was, is it still a Mazdaspeed motor. He rebutted with his examples and points indicating to you it was still entirely the MZR DISI that came in the Mazdaspeed.
Sent from my S3 using FuckThisShit
Wanna know if those wheels you found will fit your ride?
Click HERE to find out!!
Koenig is offline   Reply With Quote
 Old 10-17-2013, 08:39 AM   #253
PnP Head
the reason you have never seen a 450WHP+ car on your idea of "stock" is because all those "stock" parts are limiting power.
atvfreek likes this.
The Following 5 Users Say Thank You to superskaterxes For This Useful Post:
atvfreek (10-17-2013), Boosted Beluga (10-17-2013), Ezekiel81923 (10-17-2013), Fail_6 (11-10-2013), Koenig (10-17-2013)
 Old 10-17-2013, 09:15 AM   #254
It's difficult to formulate my idea in Russian, and much more difficult to formulate in in English.
This car can reduce direct injection at all, cause has second fuel system. real system. it's very interesting and much more complicated! but it is a real way to use only one system at the end , and not direct injection)
what is a real octane of fuel?
 Old 10-17-2013, 09:17 AM   #255
Boosted Beluga's Avatar
Posts: 4,859   (View Stats)
Groans: 50
Mmmm c16.....116 octane. Or for us, cheap race fuel e85 106 octane. But for us direct injection guys we mix it with 91.
08 Mazdaspeed 3
Fucking FREEK TUNED and shit
 Old 10-17-2013, 09:19 AM   #256
the car uses the DI for 65% of its fueling and PI for the remaining 35% of its fueling. Its impossible to make more then 400whp without bigger direct injectors so the only way to add more fuel is to add injectors.
he was using an E85 blend so the actual octane was prob around 97 RON
The Following 6 Users Say Thank You to superskaterxes For This Useful Post:
atvfreek (10-17-2013), Boosted Beluga (10-17-2013), Fail_6 (11-10-2013), jreiden1 (10-17-2013), Koenig (10-17-2013), Vadim aka ScooteR (10-17-2013)
 Old 10-17-2013, 10:05 AM   #257
jreiden1's Avatar
Posts: 237   (View Stats)
jreiden1 is the leader of the worldjreiden1 is the leader of the worldjreiden1 is the leader of the worldjreiden1 is the leader of the worldjreiden1 is the leader of the worldjreiden1 is the leader of the worldjreiden1 is the leader of the worldjreiden1 is the leader of the worldjreiden1 is the leader of the worldjreiden1 is the leader of the worldjreiden1 is the leader of the world
he is on stock cams, ported head just like pat... you have more of an extensive build then he does... because if i read correctly don't you have dry sleeves? he is on a pump/e85 mix... but before he even got there in the tuning process the port injection wasnt even turned on then after tuning it was turned on, then better fuel was added... all coming from the same fuel tank
the same lines and everything. its like you guys using WMI. Water/Meth Injection is a port injection type of fuel! but you only have 1 extra injector... dustin then created the 5th/6th port, and now we have created a port injection that has 4 extra...
mark i believe you only have the 5th/6th and are seeing amazing numbers... but eventually there is a restriction and you must add even more, because there is no aftermarket injectors for our platform!
all in all i cant wait until dave runs...
i would also like to know how the sleeves affect anything... its one of 2 things i am not doing to my build
2006 WWP Mazdaspeed 6
KILLAH BUILT 700+ AWHP TUNED BY NISHAN
jreiden1 is offline   Reply With Quote
 Old 10-17-2013, 10:20 AM   #258
i have dry sleeves durton, this constraction of fuel system is very interesting, but i haven't tried c16 fuel yet. It seems to me that 500whp is real on my config, but it's a limit.
but next step i thought must be no direct inj and new head for 8000+rpm.
 Old 10-17-2013, 11:03 AM   #259
Can't find what turbo u use...
GTX35R w/Tial .82AR Hotside on 40psi ?
 Old 10-17-2013, 11:16 AM   #260
jreiden1's Avatar
i have dry sleeves durton, this contraction of fuel ystem is very interesting, but i haven't tried c16 fuel yet. It seems to me that 500whp is real on my config, but it's a limit.
I know you have done a lot for this thread and helped many others... Like the diesel trans (I can't wait to try it out) but talk to Pablo and try his port injection kit! The heads seem to become a restriction at 650+ maybe 700+... And the direct injection is still used along with port injection... 8 injectors are better then 4 or 5!
Speed perf6rmanc3!!
 Old 10-17-2013, 11:34 AM   #261
Speed perf6rmanc3!!
interesting and seems to be affective solution, waiting for quartermile results)
 Old 10-17-2013, 12:35 PM   #262
yes
Speed perf6rmanc3!!
the stock head will become a restriction much lower then that, most likely closer to 550whp
jreiden1 (10-17-2013), Vadim aka ScooteR (10-17-2013)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f498/my-bt-way-11-s-82004/
Mazda 6 MPS GTX3076 - ???????? 158 - 500+ ??? - ??????-???? This thread Refback 07-30-2013 07:02 AM
Mazda MPS Owners Club • View topic - 6 MPS runs 1/4 in 11's at 130+ mph This thread Refback 07-27-2012 02:49 AM
??????? ?????, ?????? ??????, ???????? ????? ? ????????... - Opel Performance Center Club Russia - ???????? 917 This thread Refback 06-14-2011 12:45 PM
RACE TO THE 11's!!! qtrmile beast Drag Racing 179 03-13-2011 04:38 PM
Page generated in 0.43127 seconds with 29 queries
