 Old 05-25-2011, 06:00 PM   #1
turd burglar's Avatar
Posts: 1,895   (View Stats)
Groans: 39
Default My (hopefully non fail filled) BT battery box
So this thing was a real bitch to make, but i took my time and I think it might end up bein a pretty decent attempt for my special ed self.
Heres the ecu all mounted up to test fitment
The extra room it provides, which after some more trimming for the final design and movin some wires, it should add a little more room even
The negative is sorta close to the frame, but this shouldn't move much so I should be ok
and heres the final product all powdercoated, I will be installing this week hopefully and adding more pics!
The Following 8 Users Say Thank You to turd burglar For This Useful Post:
802MS3 (05-30-2011), Cataphract_40 (05-30-2011), Ckmazdaspeed3 (05-30-2011), drknyte (05-26-2011), essejkcamraw (05-26-2011), kmac (05-31-2011), manelscout4life (05-25-2011), zx2man (05-25-2011)
 Old 05-25-2011, 06:02 PM   #2
noiceeeeeee
turd burglar (05-25-2011)
 Old 05-25-2011, 06:02 PM   #3
qtrmile beast's Avatar
Posts: 2,423   (View Stats)
Shouldn't have to worry about the (-) touching it is the (+) that you should be more concerned about!!
track weight 3220
street weight 3370
The Following User Says Thank You to qtrmile beast For This Useful Post:
 Old 05-25-2011, 06:03 PM   #4
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
Negative is already grounded to the frame anyway so it won't do a thing even if it were to touch.
I got ninja'd
"Exclusivity" - CP-enis
Demodded.
The Seals
Last edited by Tokay444; 05-25-2011 at 06:03 PM. Reason: MSF Database - Automerged Doublepost
 Old 05-25-2011, 06:24 PM   #5
-cj-'s Avatar
Posts: 649   (View Stats)
-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world
Very nice! Group Buy???
What kind of battery is that? I see a lot of people using it. Does it have all the same properties/specs as the stock battery?
Mod List: ATP 3071R @ 22 psi, Grimspeed in 3-port mode, Steedspeed Manifold, Snow Performance Stage 2 Meth Kit, Cobb AP, CP-E 3" Nano SRI, CP-E Big Inlet TIP, Cobb "Stage 2" Suspension Kit, CP-E FMIC, CP-E DP, CP-E HPFP, CP-E MM, TWM STS, Custom Tuned by Fobio.
-cj- is offline   Reply With Quote
The Following User Says Thank You to -cj- For This Useful Post:
 Old 05-25-2011, 06:31 PM   #6
Groans: 39
It's an odyssey pc925. 26lbs, holds a charge alot better than the super light weight odyssey. The actual hold down is available for 25 on eBay, then I made the base outta 3/16" ss and the ecu plate is like 1/16" ss is all. It was a huge pain in the dick to make it fit and it still could be a little cleaner lol so no gb sorry
The Following User Says Thank You to turd burglar For This Useful Post:
-cj- (05-25-2011)
 Old 05-25-2011, 06:34 PM   #7
zx2man's Avatar
Posts: 1,356   (View Stats)
Not toooooo fuckin bad for a Oregon Beaver fan lol Goodshit creed.
2009 MS3
COBB AP
COBB INTAKE
COBB/TURBOXS TBE
DNP TURBO MANIFOLD
CXRACING FMIC
TURBOSMART BPV
JBARONE RMM
TURBOSMART BPV
JBARONE SHIFTERPLATE
COBB RSB
KONIG WHEELS/HANKOOK TIRES
zx2man is offline   Reply With Quote
The Following User Says Thank You to zx2man For This Useful Post:
 Old 05-25-2011, 06:38 PM   #8
Groans: 39
And it's too not to ya Norwegian fuck bag hahaha
zx2man (05-25-2011)
 Old 05-26-2011, 04:39 PM   #9
Tripple OG
NJSPEED3's Avatar
Posts: 5,703   (View Stats)
Groans: 113
how are you fixing that to the car? Curious
 Old 05-26-2011, 06:39 PM   #10
Groans: 39
On the black piece that goes over the tranny, there's 2 bolts that go in front of the battery, and then 2 that are by the ecu. On the ecu side i have rubber mounts to help with vibrations and i"m gonna keep a close eye on em but it should hold fine. If ya think thats a bad idea let me know cuz i dont want shit flying around on this thing lol
NJSPEED3 (05-30-2011)
 Old 05-30-2011, 01:53 PM   #11
Tripple OG
NJSPEED3's Avatar
Groans: 113
You should be more than fine you used a pretty thick base, that battery isn't going anywhere lol.
 Old 05-30-2011, 12:41 PM   #12
rigor's Avatar
Posts: 2,399   (View Stats)
Groans: 40
Looks good man
 Old 05-30-2011, 12:58 PM   #13
03scgt's Avatar
Posts: 400   (View Stats)
03scgt is the leader of the world03scgt is the leader of the world03scgt is the leader of the world03scgt is the leader of the world03scgt is the leader of the world03scgt is the leader of the world03scgt is the leader of the world03scgt is the leader of the world03scgt is the leader of the world03scgt is the leader of the world03scgt is the leader of the world
box looks badass but get rid of that junk ass battery otherwise your gonna start hating life.we use to use them in all the porsches we track prepped and they are absolute garbage after alittle while.we switched it up to the brailles and the problems went away,id carry a jump box with me often atleast until you know you got a good one
03scgt is offline   Reply With Quote
 Old 05-30-2011, 02:55 PM   #14
Groans: 39
i ended up welding it to the black bracket lol i can still undo the whole black mount so its not an issue, and i feel better havin it welded. Its installed just haven't taken pics yet, but even after sittin a few weeks, the battery fired the car right up, so not sure what's junk about it but i musta been fortunate. Plus i don't think there's a braille of the same dimensions so i'd be fucked haha
 Old 05-31-2011, 05:37 PM   #15
nindoja's Avatar
Posts: 2,395   (View Stats)
That looks pretty good. Hopefully you'll post up pics of it on the car soon.
True Red 2009 MS3
Tune: hypnotic tuned
Critical Stats:
// 305whp/352tq
 Old 05-31-2011, 05:59 PM   #16
Groans: 39
Well it might not stay in there long. If this thing is causin all my codes and shit (see thread Rev limit launch and cel) then its goin back to stock, so if anyone has the stock black bracket that goes above the tranny, i need one. Also just got a random misfire code too. I took the ecu harness off the slide clip on the block so it would reach so maybe thats causin an issue, but it was a plastic clip on a metal bracket so i don't see how that could be a grounding point for anything. Fuck fuck fuck
 Old 05-31-2011, 06:01 PM   #17
zx2man's Avatar
These cars just hate to be fucked with lol
2009 MS3
COBB AP
COBB INTAKE
COBB/TURBOXS TBE
DNP TURBO MANIFOLD
CXRACING FMIC
TURBOSMART BPV
JBARONE RMM
TURBOSMART BPV
COBB RSB
 Old 05-31-2011, 06:05 PM   #18
Groans: 39
Dude I'm gettin real close to givin up. I think i busted a tpms sensor last night and thats causing issues as well. I dunno if its the metal battery/ ecu mount causing issues, but rigs and gerry seem to be havin no problem with a metal on metal mount so i probably just have a plethora of fucked up shit to deal with
 Old 05-31-2011, 06:08 PM   #19
bmylez's Avatar
Posts: 3,197   (View Stats)
TPMS shouldn't do anything...I don't have any.
2007 CTS-V - Trying to sell
 Old 05-31-2011, 06:10 PM   #20
Groans: 39
Well i'm throwin a code for failure to communicate with tpms, so something aint right
 Old 06-03-2011, 01:23 AM   #21
Groans: 39
Here it is installed. Will be for sale soon, Lookin for 210 obo shipped and don't really wanna separate the 2 since it'll be almost impossible to sell the battery by itself. Adds about 2.5-3" extra clearance and looks pretty clean imho. I'll pm the buyer some instructions since there's a few technicalities. Car fires right up with it though. Will make an official for sale when i can but someone can call dibs for now.
 Old 09-26-2012, 04:35 PM   #22
Groans: 39
Feelin nostalgic today, who ended up with this thing after doubleflusher sold it?
 Old 09-26-2012, 06:47 PM   #23
doubleflusher's Avatar
Posts: 20,650   (View Stats)
Groans: 1,443
I still have it.
Beanfab / Tuned by Nishan
 Old 09-26-2012, 08:10 PM   #24
Groans: 39
Oh ok lol just was curious. I'm still proud of how that thing turned out
 Old 09-27-2012, 07:23 AM   #25
Groans: 1,443
It's a beautiful piece.
I will, however, sell it once I relocate my battery to the hatch..
 Old 09-27-2012, 05:33 PM   #26
Groans: 39
Oh you still haven't done that yet, explains a lot haha
AutoTrader is filled with fast machines, some might even call them furious Haltech Automotive News 0 04-29-2011 06:50 AM
Super fail, followed by epic win, followed by shit eating grin fail superskaterxes Mazdaspeed3/6 General Discussion 9 03-06-2011 04:12 PM
Researchers make tires from chainmail filled with tiny metal bits Haltech Automotive News 1 01-05-2011 05:35 PM
2010 Indy 500 filled with crashes, drama [SPOILERS] Haltech Automotive News 0 05-30-2010 05:10 PM
FAIL! TURBINETECH L/A IC FAIL! bioevolve MazdaSpeed 3/6 - Turbo Induction 50 07-21-2009 04:25 PM
Page generated in 0.46437 seconds with 31 queries
