Like Tree115Likes
 Old 12-22-2012, 04:14 PM   #81
Nishan
ms3blackmica's Avatar
Posts: 5,635   (View Stats)
Well done sir lol
www.tunedbynishan.com
NJSPEED3 (12-22-2012)
 Old 12-22-2012, 07:20 PM   #82
 Old 12-22-2012, 09:15 PM   #83
Voltron's Avatar
Posts: 4,556   (View Stats)
Groans: 77
Again...I beg to ask Gerry this...
WHY THE FUCK ARE YOU NOT A MECHANIC????????????????????????????
@NJSPEED3;
Voltron is offline   Reply With Quote
The Following 3 Users Say Thank You to Voltron For This Useful Post:
dantes5823 (12-22-2012), ms3blackmica (12-22-2012), NJSPEED3 (12-22-2012)
 Old 12-22-2012, 09:16 PM   #84
atvfreek's Avatar
Posts: 7,787   (View Stats)
@NJSPEED3;
Because then he would have to live my life
Sent from freeks kitchen
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
The Following 3 Users Say Thank You to atvfreek For This Useful Post:
NJSPEED3 (12-22-2012), rfinkle2 (12-23-2012), Voltron (12-22-2012)
 Old 12-22-2012, 09:19 PM   #85
Voltron's Avatar
Groans: 77
I likes coming home with dirty nails.
@atvfreek;
The Following 4 Users Say Thank You to Voltron For This Useful Post:
atvfreek (12-22-2012), dantes5823 (12-22-2012), NJSPEED3 (12-22-2012), rfinkle2 (12-23-2012)
 Old 12-22-2012, 09:20 PM   #86
atvfreek's Avatar
@atvfreek;
Gotta wear gloves yo. Like csi type shit. Then when you want to put a finger in your wife, its still somewhat clean
2010 Speed3-PTE5858
510hp420tq
11.321@129.93
ms3blackmica (12-22-2012), rfinkle2 (12-23-2012), SLOWHATCH (03-27-2013)
 Old 12-22-2012, 09:26 PM   #87
Nishan
lmfao @voltron;'s user title
The Following 3 Users Say Thank You to ms3blackmica For This Useful Post:
amggilly305 (12-22-2012), atvfreek (12-22-2012), Voltron (12-22-2012)
 Old 12-22-2012, 09:26 PM   #88
Voltron's Avatar
Groans: 77
Lol I do....go thru 50 sets every other week. wifey no likey teh finger..she likes the Minispeed.
But back on track...Gerry is no fucking joke. I watched this guy in action so many times and his mechanical skills are crazy.
atvfreek (12-22-2012), dantes5823 (12-22-2012), doubleflusher (12-22-2012), NJSPEED3 (12-22-2012)
 Old 12-22-2012, 09:33 PM   #89
dantes5823's Avatar
Posts: 6,576   (View Stats)
dantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the world
Groaned at 52 Times in 48 Posts
Some of his tricks are finally starting to rub off on me.
dantes5823 is offline   Reply With Quote
The Following User Says Thank You to dantes5823 For This Useful Post:
 Old 12-22-2012, 09:51 PM   #90
Tripple OG
NJSPEED3's Avatar
Posts: 5,703   (View Stats)
Groans: 113
Ohh stop it!
The Following 5 Users Say Thank You to NJSPEED3 For This Useful Post:
atvfreek (12-23-2012), dantes5823 (12-22-2012), ms3blackmica (12-22-2012), MS3inDC (04-02-2013), rfinkle2 (12-23-2012)
 Old 01-03-2013, 08:37 AM   #91
Tripple OG
NJSPEED3's Avatar
Groans: 113
lil update on this bish.
both fans are wired in with the 190* temp controller now. i still need to trace out the A/C signal. The only weird thing is that this sensor is coming on at 220* lol just like the stock one. We tried mounting the sensor near the head where the stock coolant sensor is. Then we tried near the radiator and same thing. Sensor always kicks on when my dashawk reads 219-220. Once the fans kick on temps drop to 190* with the car not moving in less than 1 minute. lol.
In the summer the coolant temps like to sit around 215ish so the fans wont turn on. I just dont like the constant heat, when my car was stock coolant would never go above 200, so the plan is to try and keep shit close to what it was when the car ran stock.
Next step is find a different 190* temp sensor that will come on at 205* max.
The Following 8 Users Say Thank You to NJSPEED3 For This Useful Post:
atvfreek (01-03-2013), BlueStreak (01-03-2013), doubleflusher (01-03-2013), h0ckeyman (01-04-2013), mituc (01-03-2013), ms3blackmica (01-03-2013), rfinkle2 (01-03-2013), uncorked11 (01-03-2013)
 Old 01-03-2013, 08:42 AM   #92
I think that A/C signal was talked about later in that thread you posted (that superskaterxes started).
IIRC, username po57 has a speed3 and was talking about the A/C signal.
NJSPEED3 (01-03-2013)
 Old 01-03-2013, 09:54 AM   #93
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
I kind of have the same problem and I'll probably opt for the same solution (one more fan). However, I think that the stock heat shields in the first cat and turbo area were doing a pretty big deal in forcing the heat underneath the car.
If I'll mess with the downpipe again (I may want to change the cat in the DP) I will look into hooking back up as many of the stock heat shields as I can.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
 Old 01-03-2013, 10:28 PM   #94
11cruzito11's Avatar
Posts: 824   (View Stats)
Groaned at 5 Times in 2 Posts
You have the derale kit? Mine fan turns on at 200 degrees via Dashhawk.
The extra wire for the AC signal can be used with a manual switch. I have a switch wired up and can turn on the fan manually before 200 degrees!
Cobb AP, 504whp 492wtq
The Following 3 Users Say Thank You to 11cruzito11 For This Useful Post:
ms3blackmica (01-04-2013), NJSPEED3 (01-04-2013), SLOWHATCH (03-27-2013)
 Old 01-04-2013, 07:38 AM   #95
Tripple OG
NJSPEED3's Avatar
Groans: 113
Yup, which sensor do you (180*/190*) have Carlos?
 Old 01-04-2013, 10:08 AM   #96
I have the 190* one.
The Following User Says Thank You to 11cruzito11 For This Useful Post:
 Old 01-04-2013, 12:09 PM   #97
Tripple OG
NJSPEED3's Avatar
Groans: 113
The mishimoto adapter I have, has the threads tapered down so I can only get about 3-4 threads of the sensor into the adapter. I didn't think this was a big deal since I have the sensor positioned around 4-5 o'clock so coolant should always be present. But as I think about it more maybe the aluminum adapter is transferring some of the heat and making the sensor come on a bit late. Like I said the sensor isn't thread to deep, its sunk in maybe 3/16".
I'm going to try tapping the adapted and getting the sensor in further.
The Following 3 Users Say Thank You to NJSPEED3 For This Useful Post:
atvfreek (01-04-2013), ms3blackmica (01-04-2013), rfinkle2 (01-04-2013)
 Old 01-04-2013, 12:11 PM   #98
NPT FTL in this application.
 Old 01-04-2013, 12:14 PM   #99
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
So the adapter maybe 1/8 BSPT, which is tapered, meant for nissan-style pressure senders.
07 MS3
The original Genpoo Hater
 Old 01-04-2013, 12:21 PM   #100
Tripple OG
NJSPEED3's Avatar
Groans: 113
Nah its def says 1/8 npt but there is no fucking way lol. I'm gonna tap the damn thing and call it a day. Hope that does the trick.
http://m.mishimoto.com/mishimoto-30-...connector.html
atvfreek (01-04-2013), Chimmike (01-04-2013), rfinkle2 (01-04-2013)
 Old 01-04-2013, 12:32 PM   #101
Will fuck up ur day
Chimmike's Avatar
Groans: 433
I have one of those things somewhere in my garage for a miata. Had it for at least 6-7 years, lol. never used.
07 MS3
NJSPEED3 (01-04-2013), rfinkle2 (01-04-2013)
 Old 01-04-2013, 04:49 PM   #102
XLT_66's Avatar
Posts: 850   (View Stats)
Sigh....I need fuel. Then my BT can finally be all happy in the 30 PSI range like all the other cool kids.
2009 CWP MS3 Sport
SOLD!
XLT_66 is offline   Reply With Quote
The Following 4 Users Say Thank You to XLT_66 For This Useful Post:
doubleflusher (01-05-2013), NJSPEED3 (01-05-2013), Realgib3 (01-05-2013), rfinkle2 (01-04-2013)
 Old 01-10-2013, 07:17 AM   #103
amoosenamedhank's Avatar
Posts: 1,368   (View Stats)
Groans: 53
Are you going to pick up the JMF v.2 intake manifold with PI? I think that would compliment your setup and kill 2 birds with one stone.
You know.... Moose stuff
 Old 01-10-2013, 02:23 PM   #104
Robust Mongoloid
09Speed3Z's Avatar
Groans: 399
IIRC I *believe* Gerry is going to wait for the CPe manifold.
Don't quote me on that though
Sent using my legendary mouth
______________________
Built By NATOR
Tons of Ricer Mods
 Old 03-27-2013, 08:35 AM   #105
Tripple OG
NJSPEED3's Avatar
Groans: 113
Gather around Kids Uncle NJ has a story to tell.
atvfreek likes this.
The Following 7 Users Say Thank You to NJSPEED3 For This Useful Post:
atvfreek (03-27-2013), BlueStreak (03-27-2013), fishin53 (03-27-2013), GunGuru727 (03-28-2013), Micha (08-04-2013), ms3blackmica (03-27-2013), SLOWHATCH (03-27-2013)
 Old 03-27-2013, 08:36 AM   #106
atvfreek's Avatar
Sitting patiently
2010 Speed3-PTE5858
510hp420tq
11.321@129.93
Micha (08-04-2013), NJSPEED3 (03-27-2013), rfinkle2 (03-27-2013)
 Old 03-27-2013, 08:45 AM   #107
Happy ending stories only please.
Easter Bunny (03-27-2013), Micha (08-04-2013), NJSPEED3 (03-27-2013), Rokusek (04-01-2013)
 Old 03-27-2013, 09:07 AM   #108
Nishan
You raced that GTR you ran into last summer and took his Brazilian girl home!?
The Following 9 Users Say Thank You to ms3blackmica For This Useful Post:
09Speed3Z (03-27-2013), 802MS3 (03-27-2013), atvfreek (03-27-2013), dantes5823 (03-27-2013), doubleflusher (03-27-2013), Easter Bunny (03-27-2013), Micha (08-04-2013), rfinkle2 (03-27-2013), Rokusek (04-01-2013)
 Old 03-27-2013, 09:13 AM   #109
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
Tappin
 Old 03-27-2013, 10:57 AM   #110
Tripple OG
NJSPEED3's Avatar
Groans: 113
ugh this day isn't cooperating with me. Basically the cliff notes are................................ I has no head right now..................................more to come.
The Following 6 Users Say Thank You to NJSPEED3 For This Useful Post:
atvfreek (03-27-2013), BlueStreak (03-27-2013), dantes5823 (03-27-2013), Easter Bunny (03-27-2013), GunGuru727 (03-28-2013), Micha (08-04-2013)
 Old 03-27-2013, 10:58 AM   #111
kritz's Avatar
Posts: 7,290   (View Stats)
Groans: 95
Oh damn!
Sent from my frontal cortex.
Nator is what it does.
The Following 2 Users Say Thank You to kritz For This Useful Post:
 Old 03-27-2013, 11:10 AM   #112
doubleflusher's Avatar
Posts: 20,650   (View Stats)
Groans: 1,443
Time for da supahead?
NJSPEED3 likes this.
The Following 5 Users Say Thank You to doubleflusher For This Useful Post:
atvfreek (03-27-2013), GunGuru727 (03-28-2013), Micha (08-04-2013), MS3inDC (04-02-2013), TWOptSL0W (03-27-2013)
 Old 03-27-2013, 11:23 AM   #113
BlueStreak's Avatar
Posts: 1,467   (View Stats)
I ask my GF about this all the time. Has nothing to do with cars tho.
'07 CWP MS3
Forged.
The Following 17 Users Say Thank You to BlueStreak For This Useful Post:
atvfreek (03-27-2013), Dano (03-27-2013), dantes5823 (03-27-2013), doubleflusher (03-27-2013), Easter Bunny (03-27-2013), Ezekiel81923 (03-27-2013), fishin53 (03-27-2013), GunGuru727 (03-28-2013), lilred (03-27-2013), Micha (04-09-2013), MS3-a(sore)ASS-rex (03-28-2013), ms3blackmica (03-27-2013), MS3inDC (04-02-2013), NJSPEED3 (03-27-2013), rfinkle2 (03-27-2013), SarcasticOne (04-02-2013), TWOptSL0W (03-27-2013)
 Old 03-27-2013, 12:43 PM   #114
Tripple OG
NJSPEED3's Avatar
Groans: 113
FAWKKKKKKKKK I lost the big asss post I was working on. FML.
 Old 03-27-2013, 12:53 PM   #115
dantes5823's Avatar
Tl;Dr mcy
 Old 03-27-2013, 01:01 PM   #116
Robust Mongoloid
09Speed3Z's Avatar
Groans: 399
Omg I thought the EXACT same thing.
Built By NATOR
Tons of Ricer Mods
The Following User Says Thank You to 09Speed3Z For This Useful Post:
Micha (08-04-2013)
 Old 03-27-2013, 01:19 PM   #117
Tripple OG
NJSPEED3's Avatar
Groans: 113
After finally getting my dual fans set up in order, I wanted to get the car ready for MNM. Last week I did a compression test and #1 and #2 were a bit lower than the others
#1 -165
#2 -160
#3 -170
#4 -170
Keep in mind I run 8.5:1 cp pistons. So first thing we think of is injector seals. Of course #1 and #2 are leaking. Fast forward a few days later the seals arrive from CPE and I pull the stock intake manifold. This is where shit gets interesting. Seal #1 and #2 are stuck in the head and #2 and #4 are stuck in the injector. Right away I get nervous. Having installed seals in the past with permatex #2 I knew this was going to likely be a downhill battle. Sure enough a 2 days later, lots of cursing and screaming I give up and tell Pablo.... Pablo fuck this bullshit lets pull the head and pop the seals out from the inside.
Well Thank goodness we decided to pull the head off. We found the head gasket was on its way out. More than likely it would have blown at MNM had I kept it together. Pablo compared my HG to Anthony's and it was failing in the exact same area. I've seen alot of HG and none ever bubble up or are marked with those ridges like we saw in Anthony's blown gasket. It seems like the gasket or the clamping force around #4 isnt being distributes as well as the other cylinders. IDk I'll leave that for the engineers to discuss. All I know is that we mistakenly saved my motor and new turbo.
As of right now the plan for my car is to get the head cut open around the intake ports and upgrade the fuel system to supply a shit load more fuel pressure for the 6th port system. This will be my stepping stone to full PI. After MNM I'm going to set up my stock manifold with individual injectors.
Here are some pics of Anthony's HG
Here is mine
Car should be running by Monday again hopefully, Dustin start cracking those knuckles pimp daddy.
MS3inDC, SLOWHATCH and Voltron like this.
The Following 25 Users Say Thank You to NJSPEED3 For This Useful Post:
Apollo (03-28-2013), BlueStreak (03-27-2013), Dano (03-27-2013), dantes5823 (03-27-2013), djuosnteisn (04-03-2013), Easter Bunny (03-27-2013), fishin53 (03-27-2013), GunGuru727 (03-28-2013), KusteLokal (03-27-2013), lilred (03-27-2013), Micha (04-09-2013), ms3blackmica (03-27-2013), MS3inDC (04-02-2013), Realgib3 (03-27-2013), rfinkle2 (03-27-2013), rigor (04-06-2013), SarcasticOne (04-02-2013), SLOWHATCH (03-27-2013), spnkr21 (03-27-2013), trf5000 (03-27-2013), TWOptSL0W (03-27-2013), uncorked11 (03-27-2013), Vader (03-27-2013), Voltron (03-27-2013), Voltwings (04-03-2013)
 Old 03-27-2013, 01:29 PM   #118
Nishan
OH.
You need that kind of head.
I was about to send this chick I know from high school over your way.
Her name is Cindy. She is brazilian.
Well, best of luck with that other kind of head you needed.
The Following 13 Users Say Thank You to ms3blackmica For This Useful Post:
BlueStreak (03-27-2013), dantes5823 (03-27-2013), fishin53 (03-27-2013), GunGuru727 (03-28-2013), Micha (04-09-2013), MS3inDC (04-02-2013), NJSPEED3 (03-27-2013), Payne Racing 67 (03-27-2013), pharoh (03-27-2013), rfinkle2 (03-27-2013), trini247 (03-27-2013), uncorked11 (03-27-2013), Voltron (03-27-2013)
 Old 03-27-2013, 01:36 PM   #119
Realgib3's Avatar
Posts: 2,443   (View Stats)
Hmmmm this may or may not be exactly what happened to me 3 weeks ago... supaheads fo errrbody!
 Old 03-27-2013, 01:37 PM   #120
Groans: 1,443
That head and intake mani look awfully familiar.
The Following 4 Users Say Thank You to doubleflusher For This Useful Post:
Micha (08-04-2013), NJSPEED3 (03-27-2013), rfinkle2 (03-27-2013), TWOptSL0W (03-27-2013)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f498/my-hta3586-build-132009/
MPS and RPM - Page 3 This thread Refback 11-08-2013 12:46 AM
New build? forcedinduktion Computers & Technology News 2 12-08-2010 09:24 PM
Page generated in 0.63762 seconds with 37 queries
