Like Tree128Likes
 Old 02-07-2011, 09:58 AM   #1
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
Default My twin scroll BW s300sx 88-75 BT build
My original BT setup was a 0.82 a/r t3 3071... and was plagued with a cracked manifold. When i finally pulled it off to start working on my new setup, I even found an unfinished weld on the manifold.... which was incredibly frustrating. That meant i had exh leaks since day 1 with that setup... and with a manifold that cost $1k plus 6 mos of waiting... was just unacceptable.
So i set out to do it again, and hopefully right this time.
I picked up a Borg Warner 88-75 from a local buddy for cheap:
Full-Race Motorsports
He gave me 2 different hot sides with it, one of which was a 1.0 a/r (t4 flanged) twin scroll. So i figured with only 2.3 liters of displacement, and a monster journal bearing turbo to spin, i'll need all the spool help i can get... thus a twin scroll manifold was in order.
I figured, since i'm building it, and absolutely loathe working on a turbo in the stock location.... might as well go top mount.
This was the first manifold i've ever built, so i hope it works out well. I used schedule 10 stainless cast elbows & piping, which has nearly double the wall thickness of my previous $1k manifold. Many people use sched 40... but i'm hoping sched 10 will cut it, especially with an additional brace between the flanges.
In order for the hood to close... i had to cut and angle the compressor outlet some. It's a 3" O.D. compressor outlet lol. Here it is gonzo-fied.
The turbo is a monster. Capable of 75 lbs/min.
I then fabbed up a 3" down pipe to mate the monster turbo.
I wanted to keep the car somewhat mild mannered off-boost, so i threw in a resonator pipe i had just laying around. Should help keep the volume down quite a bit.
Also threw together an intake to feed the beast. This one is 3.25" I.D. but eventually i'll probably max the maf, and need to go to a 4" pipe. I already have the couplers and pipe to do this, just need to get a few other things squared away.
For oil feed and return, i modded the oem lines by cutting them off part way, and welding on AN fittings.
The oil return line was awfully close to the wastegates, and wouldn't easily route up under the CHRA without touching exh runners... and thats a def no-no. So i had to fab up a oil slide to bring the AN fitting out from under the turbo.
Once that was done, it was time to start bolting shit up and get the dump tubes fabbed.
First i threw on the manifold & twin gates.
And routed the dumps down and out by the axle. This is a pic of the first part of the dumps. I still need to get a better shot of how the look complete, cause it's awesome. I'll update the post with the better pic when i have it.
Here's a pic of the finished piping tacked together.
Once the dumps were done, it was time to throw on the turbo and oil lines.
You can see how the return line is far enough away from the WG's and turbo, which is good. I plan on putting some heat shielding around the return just to be safe.
There was some bend in the return line, but no kink, so i think it should work fine.
The feed line comes out from under the alternator... all the way under the manifold, up and around by the intake. It wasn't hooked up in this pic, but you can see the routing fairly well.
Then throw on the down pipe and hook up the o2 sensors.
You can see the oil feed line better in this pic.
Then throw on the hot pipe section from the turbo outlet.
Install the intake and MAF sensor.
And voila.... one absolutely ridiculous looking turbo setup lol. The pictures don't really do it justice IMO, cause this things look insane in person.
I started it up Sunday evening... but still need some more hose clamps, a boost 'T' for the WG's and coolant. It was making a clacking noise from under the valve cover, but i'm hoping it's just a lifter, and the noise will go away lol. Tonight i'm gonna start it again and let it warm up, and maybe even take it for a very light cruise. After a heat cycle, I'll also re-torque all the exhaust hardware.
I hope to god the clack goes away.... hahaha.
Next up on the list is HKS ignition amp, tap my cold pipe for wmi and a few other nick nacks. I have a triple gauge pod with an oil pressure gauge (courtesy of Matt Damond, big thanks) that needs to go on as well.
And once all the hardware is vetted... it's time to tune and see what this setup can do.... oh and yea.... stock block.... so this will certainly be a good test for it's capabilities.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
The Following 228 Users Say Thank You to djuosnteisn For This Useful Post:
-cj- (02-07-2011), 06Speed6 (02-07-2011), 09Speed3Z (02-07-2011), 09speedaddict (04-15-2013), 3dpilot (04-22-2013), 3mazdaspeed (02-08-2011), 4G63 (03-10-2011), 8.5MS3 (02-07-2011), 801MS3 (02-07-2011), 802MS3 (02-07-2011), 86AmishMs3 (06-11-2013), aaronc7 (04-05-2011), ABQ Speed6 (06-26-2011), ABSpeed3 (12-14-2011), Adam is so pro (04-29-2013), Addikted To Boost (02-07-2011), aggierandy (04-24-2013), AJ713 (02-10-2011), alexryan (04-23-2013), alien_sporez (06-16-2011), Amazon (02-07-2011), amggilly305 (07-11-2013), AmillieMS6 (03-07-2011), amoosenamedhank (02-07-2011), ARES28 (02-10-2011), asiandude74 (02-10-2011), AZRushki (02-07-2011), banditscout (02-13-2011), bcmurphy87 (06-18-2011), Biggs (02-07-2011), BigjohnB20 (02-07-2011), bioevolve (02-07-2011), Blackspeed (02-08-2011), BlueStreak (08-30-2011), BobtailedSnail (12-03-2011), Boonestafa (05-21-2013), breakfasteatre (04-22-2013), BrianB6 (02-07-2011), BrianZX10R (02-07-2011), Broxer (08-16-2011), cbusby (06-13-2011), charlesfist (05-17-2011), ChimmyChong (02-10-2011), Chriscote (02-16-2011), Ckmazdaspeed3 (02-10-2011), Click Here (02-07-2011), Coaststarlight (05-13-2012), cocoanton (04-12-2011), cpolly69 (02-07-2011), crtguns (05-22-2013), daafisch (02-07-2011), DaleNixon (02-08-2011), danesti (03-06-2011), Dano (02-07-2011), Darksun280 (02-07-2011), Dash08 (02-07-2011), dead-zone (07-24-2013), Decepticon (02-10-2011), derek13p (04-24-2013), DingoDave (06-14-2011), Docnox (02-07-2011), doubleflusher (02-08-2011), dougefresh_ (03-19-2011), Downmented (12-02-2011), EdgeAutosport.com (02-17-2012), efispeed (02-18-2011), essejkcamraw (02-08-2011), EwMPS (02-18-2011), faeker (05-06-2011), Fagwagon (02-08-2011), FantasmoNegro (02-18-2011), fastdreams (02-08-2011), Ferg (08-30-2011), fhaze (09-13-2011), fishin53 (02-07-2011), Fobio (02-07-2011), focoms3 (09-22-2011), forcedinduktion (02-10-2011), frivolous_rob (05-05-2011), fywdyl (02-07-2011), ganque (09-24-2011), gtlaw (02-07-2011), h.h.sk1nny (01-06-2012), h0ckeyman (05-22-2013), H3R3TIC (02-07-2011), Hamilton69 (02-12-2011), hamptotl (08-05-2011), helmetface (08-31-2011), I Love Brownies (02-07-2011), i8urgti (02-21-2011), Illmatic MS3 (02-11-2011), IshiKage (02-07-2011), J-Liss (08-23-2011), JacksonMS30 (02-07-2011), jack_hammer (02-07-2011), jax ms3gt (02-07-2011), jayspeed3 (02-10-2011), jeek (07-18-2013), JMEngineer (02-07-2011), jmhinkle (02-08-2011), JmkC (09-17-2011), josurr (09-20-2011), jracer (02-07-2011), Jsn_Rob (08-21-2011), jtspells (02-07-2011), Juyoung (04-23-2013), jv92red (02-07-2011), jwilkins88 (02-10-2011), karl-hungus (03-08-2011), Keemo577 (08-22-2011), KeysMS3 (02-07-2011), kilik2 (02-15-2011), kmac (02-10-2011), kunfu (02-07-2011), kylec_2003 (02-08-2011), LiEast (03-07-2011), locorasta (08-29-2011), LumberJack (05-23-2013), M4Nathan (02-10-2011), m4tic (02-07-2011), madvillain (02-07-2011), manelscout4life (02-07-2011), Manny (08-30-2013), MarkyMark (02-07-2011), mason (02-07-2011), MATT DAMOND (05-06-2011), MattJackson86 (02-07-2011), mazda.speed3 (02-07-2011), MazdaGaragePat (11-09-2012), mazdaspeed619sd (08-24-2011), mazdaspeedemon3 (05-28-2013), mazpro (02-07-2011), mdl3v8 (07-10-2013), MDRracing13 (02-10-2011), memin (07-07-2011), Menace1 (12-11-2012), merkinsquirrel (07-01-2011), Mfinlay04 (04-22-2013), MGM_GT3 (03-08-2011), Mistersix (08-07-2011), Mizzle (07-25-2011), Monotonous ONE (02-07-2011), MPSdriver (02-08-2011), mrdouble99 (04-23-2013), mrFanel (06-16-2011), mr_mazda329 (02-08-2011), MS3 Ventura (02-19-2011), MS3-a(sore)ASS-rex (02-07-2011), MS33SM (02-07-2011), ms3blackmica (10-01-2012), mtnrunner (02-07-2011), Nazarite (02-10-2011), Neverlift (02-10-2011), Night Wolf (06-22-2011), nighthawk358 (02-07-2011), NJSPEED3 (02-07-2011), NoLeftTurn (02-11-2011), NoRegrets (02-16-2011), NRSpeed (02-11-2011), nybe0010 (05-23-2013), nycMS3 (02-21-2011), obijack (03-08-2011), OgCoda (09-19-2011), onelove221 (07-18-2011), PapaSmurf (05-06-2011), phillyb (02-07-2011), Post pwned (08-07-2011), PPD369Speed3 (06-12-2013), psychophyr (02-07-2011), PunjabiPlaya (02-07-2011), qtrmile beast (02-07-2011), QwkEVO (12-27-2011), RayRayBauder (02-10-2011), Realgib3 (02-07-2011), rfinkle2 (06-14-2011), RhoadBlock (04-05-2011), Rich990 (06-10-2013), rigor (02-07-2011), Roddiy (04-22-2013), rodrigo (02-07-2011), Rokusek (07-17-2013), Scynfewl (02-12-2011), sellers (02-09-2011), SilverDemon (02-07-2011), spd6guy90 (02-07-2011), speed d3mon (03-07-2011), Speed freak (02-07-2011), speed23 (07-13-2013), Speed3eak (02-07-2011), SpeedLife (08-19-2013), SpeedNess (02-07-2011), SpeedSixxx (02-17-2011), speedtown (02-07-2011), speedtoz (02-08-2011), speed_3 (12-04-2011), spiker98 (02-07-2011), spnkr21 (02-07-2011), spoolin00 (02-07-2011), Sport6 (02-09-2011), stefan (02-07-2011), superskaterxes (02-07-2011), super_pablo_ (02-07-2011), taf0422 (02-09-2011), TexasSpeed3 (06-18-2011), themdamnstingrays (05-31-2013), the_caruch (02-07-2011), Toddy22587 (03-12-2011), Tomas (04-29-2013), trancehead (05-21-2013), triplejumper18 (02-07-2011), turboKart (09-05-2013), turd burglar (02-07-2011), uncorked11 (04-22-2013), vbt101 (04-28-2011), Vinnie (05-15-2011), wankular (02-07-2011), wette460 (04-13-2011), wolly6973 (02-08-2011), Worbit (08-29-2011), X-Man (02-07-2011), xcoldricex (02-07-2011), xdm88 (02-07-2011), xfeejayx (02-10-2011), xhymer (04-04-2011), xI Leveler Ix (04-22-2013), xPEPEx (04-07-2011), zpele (07-25-2011)
 Old 02-07-2011, 10:07 AM   #2
BrianZX10R's Avatar
Posts: 1,163   (View Stats)
BrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the world
Groans: 88
Groaned at 121 Times in 75 Posts
fucking A dustin
your Hot side on that turbo is so big that your Exhaust looks like a macaroni Noodle
1995 honda civic. 1.6L slow
2007 Kawasaki ZX10r
BrianZX10R is offline   Reply With Quote
The Following 5 Users Say Thank You to BrianZX10R For This Useful Post:
DaleNixon (02-08-2011), djuosnteisn (02-07-2011), LiEast (03-07-2011), mr_mazda329 (02-08-2011), SpeedSixxx (02-17-2011)
 Old 02-07-2011, 10:23 AM   #3
Click Here's Avatar
Posts: 202   (View Stats)
Click Here is the leader of the worldClick Here is the leader of the worldClick Here is the leader of the worldClick Here is the leader of the worldClick Here is the leader of the worldClick Here is the leader of the worldClick Here is the leader of the worldClick Here is the leader of the worldClick Here is the leader of the worldClick Here is the leader of the worldClick Here is the leader of the world
This looks fucking unbelievable!!!!!
Fantastic job man. I cannot wait to see what thing can do when you start tuning.
Click Here is offline   Reply With Quote
The Following User Says Thank You to Click Here For This Useful Post:
 Old 02-07-2011, 10:20 AM   #4
turd burglar's Avatar
Posts: 1,895   (View Stats)
Groans: 39
skeet skeet skeet skeet skeet! clickin might be your vvt even, but either way, good luck man, looks foooookin amazing!
The Following User Says Thank You to turd burglar For This Useful Post:
 Old 02-07-2011, 10:36 AM   #5
Docnox's Avatar
Posts: 1,435   (View Stats)
Docnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the world
Groans: 35
Craziness. I can't even handle how fucking awesome that looks. Can't wait to hear that puppy spool up!
'06 Speed 6
Black Mica
Mazdaspeed SRI, Medieval inlet, Eibach Springs, Magnaflow cbe,
3 ebay catless dp, SU rmm, HKS ssqv, JBR stage 2 ssp
Altered Customs fmic, Autotech fp internals
Cobb AP, Stage 2+ 93 tweaked
Centric blanks, EBC red pads
Lotek center gauge pod: AEM wideband, Autometer boost and volts
Tints, blacked emblems, spec-v front lip, Shark fin
Redline MT-90, ITV-22s, Matt Damond OCC
13.66@102 Lebanon Valley 4/10/11 (sri, tp, rmm, ap)
DO Meth kit waiting on install
Docnox is offline   Reply With Quote
The Following User Says Thank You to Docnox For This Useful Post:
 Old 02-07-2011, 10:45 AM   #6
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
as always, excellent work Dustin!
lovin your oil return fix....
 Old 02-07-2011, 10:36 AM   #7
Chriscote's Avatar
Posts: 913   (View Stats)
Chriscote is the leader of the worldChriscote is the leader of the worldChriscote is the leader of the worldChriscote is the leader of the worldChriscote is the leader of the worldChriscote is the leader of the worldChriscote is the leader of the worldChriscote is the leader of the worldChriscote is the leader of the worldChriscote is the leader of the worldChriscote is the leader of the world
Groans: 137
your the man btw
Chriscote is offline   Reply With Quote
The Following User Says Thank You to Chriscote For This Useful Post:
 Old 02-07-2011, 10:36 AM   #8
m4tic's Avatar
Posts: 4,928   (View Stats)
dustin are you fucking serious?
i hope your mind is the only thing thats blown
2017 Daytona 392
STOLEN//2015 BMW S1000R
2007 MS6 w/ Cheez
The Following 5 Users Say Thank You to m4tic For This Useful Post:
djuosnteisn (02-07-2011), dougefresh_ (03-19-2011), Juyoung (04-23-2013), NoRegrets (02-16-2011), xcoldricex (02-07-2011)
 Old 02-07-2011, 10:38 AM   #9
jack_hammer's Avatar
Posts: 6,822   (View Stats)
Groans: 549
very nice!
it's fun to do bad things
The Following User Says Thank You to jack_hammer For This Useful Post:
 Old 02-07-2011, 10:40 AM   #10
socks's Avatar
Posts: 3,250   (View Stats)
Groans: 125
ibtw
in before the win!
The Following 2 Users Say Thank You to socks For This Useful Post:
06Speed6 (02-07-2011), djuosnteisn (02-07-2011)
 Old 02-07-2011, 10:44 AM   #11
IshiKage's Avatar
Posts: 6,231   (View Stats)
Groans: 278
fucking tits. that set up is b-e-a-utiful. awesome work
2015 Mazda 6
The Following User Says Thank You to IshiKage For This Useful Post:
 Old 02-07-2011, 10:50 AM   #12
PunjabiPlaya's Avatar
Posts: 5,131   (View Stats)
Groans: 131
hot shit. need vids ASAP, even if they're like this guy:
skip to 1:08 for the show
Cobb SRI
CPE 75 duro RMM
AP - tune in progress
broke ass college student
 Old 02-07-2011, 10:51 AM   #13
MS33SM's Avatar
Posts: 1,821   (View Stats)
MS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the world
Groans: 132
Groaned at 166 Times in 92 Posts
That thing is huge! How tight is the clearance against your hood?
also:
MS33SM is offline   Reply With Quote
The Following User Says Thank You to MS33SM For This Useful Post:
 Old 02-07-2011, 10:51 AM   #14
Speed13's Avatar
Posts: 497   (View Stats)
Speed13 is the leader of the worldSpeed13 is the leader of the worldSpeed13 is the leader of the worldSpeed13 is the leader of the worldSpeed13 is the leader of the worldSpeed13 is the leader of the worldSpeed13 is the leader of the worldSpeed13 is the leader of the worldSpeed13 is the leader of the worldSpeed13 is the leader of the worldSpeed13 is the leader of the world
That turbo is insane!!! everything looks insane, but so so wonderful
2006 Mazdaspeed6 Black Mica GT w/ Navi ~34k miles Sold
2008 Mazdaspeed3 Black Mica GT~55k miles
NATOR PA IS NUMERO UNO
Speed13 is offline   Reply With Quote
The Following User Says Thank You to Speed13 For This Useful Post:
 Old 02-07-2011, 10:52 AM   #15
-cj-'s Avatar
Posts: 649   (View Stats)
-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world
Nice setup man! I'm jealous. I'm definitely leaning towards a top mount setup now....
Did you do all this in your home garage? What kind of fabrication tools do you have access to??
Mod List: ATP 3071R @ 22 psi, Grimspeed in 3-port mode, Steedspeed Manifold, Snow Performance Stage 2 Meth Kit, Cobb AP, CP-E 3" Nano SRI, CP-E Big Inlet TIP, Cobb "Stage 2" Suspension Kit, CP-E FMIC, CP-E DP, CP-E HPFP, CP-E MM, TWM STS, Custom Tuned by Fobio.
-cj- is offline   Reply With Quote
The Following User Says Thank You to -cj- For This Useful Post:
 Old 02-07-2011, 10:58 AM   #16
Captain
also:
Not horrible actually. I'm gonna pull the liner off and put my turbo sock on the hot side. Things clear great though IMO.
Yup, did it all in the garage. I have a band saw, belt sander, grinders / cut off wheels, and a TIG welder. My TIG is a Hobart EZ Tig (same exact thing as the Miller Diversion 165).
You'd be surprised how much you can do with some basic tools and a lot of patience lol.
www.permtuning.com
The Following 7 Users Say Thank You to djuosnteisn For This Useful Post:
-cj- (02-07-2011), I Love Brownies (02-07-2011), JBR (07-20-2011), Juyoung (04-23-2013), SilverDemon (02-07-2011), spoolin00 (02-07-2011), xdm88 (02-07-2011)
 Old 02-07-2011, 11:02 AM   #17
AZSPEED3's Avatar
Posts: 3,148   (View Stats)
AZSPEED3 is the leader of the worldAZSPEED3 is the leader of the worldAZSPEED3 is the leader of the worldAZSPEED3 is the leader of the worldAZSPEED3 is the leader of the worldAZSPEED3 is the leader of the worldAZSPEED3 is the leader of the worldAZSPEED3 is the leader of the worldAZSPEED3 is the leader of the worldAZSPEED3 is the leader of the worldAZSPEED3 is the leader of the world
Groans: 65
Awesome man, that is beautiful.
That thing is a monster, keep the cats away so they don't get sucked in.
AZSPEED3 is offline   Reply With Quote
The Following User Says Thank You to AZSPEED3 For This Useful Post:
 Old 02-07-2011, 11:03 AM   #18
Captain
I think your supposed to actually feed it a cat every thousand miles or so just to keep it happy... That's exactly why i've been stocking up on the kitt3hs
www.permtuning.com
The Following 14 Users Say Thank You to djuosnteisn For This Useful Post:
AZSPEED3 (02-07-2011), charlesfist (05-17-2011), cocoanton (04-12-2011), DaleNixon (02-08-2011), JacksonMS30 (02-07-2011), JMEngineer (02-07-2011), Juyoung (04-23-2013), kunfu (02-07-2011), LiEast (03-07-2011), MPSdriver (02-08-2011), Scynfewl (02-12-2011), Snotrocket (08-07-2011), spoolin00 (02-07-2011), xdm88 (02-07-2011)
 Old 02-07-2011, 11:12 AM   #19
AZSPEED3's Avatar
Groans: 65
I got one that I could send your way, lol.
The Following 2 Users Say Thank You to AZSPEED3 For This Useful Post:
 Old 02-07-2011, 11:14 AM   #20
the_caruch's Avatar
Posts: 698   (View Stats)
the_caruch is the leader of the worldthe_caruch is the leader of the worldthe_caruch is the leader of the worldthe_caruch is the leader of the worldthe_caruch is the leader of the worldthe_caruch is the leader of the worldthe_caruch is the leader of the worldthe_caruch is the leader of the worldthe_caruch is the leader of the worldthe_caruch is the leader of the worldthe_caruch is the leader of the world
god dammit dustin. you make me feel like an automotive-dumbass when you post up shit like this.
that setup is ridiculous! MUST HAVE VIDEOS
i applaud you on your continued custom work to the platform
cp-e CAI, cp-e Turbo Inlet, cp-e catted DP, cp-e HPFP, cp-e flashes, cp-e Standback w/PNP, cp-e FMIC, TRZ RMM, TS Compact BOV (full re-circ), DDM 55W 6k HID's, Cobb RSB. HKS Hi-Power Exhaust, OCC
the_caruch is offline   Reply With Quote
The Following User Says Thank You to the_caruch For This Useful Post:
 Old 02-07-2011, 11:03 AM   #21
JacksonMS30's Avatar
Posts: 2,242   (View Stats)
^^ Dustins fabrication tool...
Very nicely done sir! What kind of power are you thinking it will make?
The Following 10 Users Say Thank You to JacksonMS30 For This Useful Post:
-cj- (02-07-2011), Dash08 (02-07-2011), djuosnteisn (02-07-2011), doubleflusher (02-08-2011), fishin53 (02-07-2011), i8urgti (07-10-2011), Juyoung (04-23-2013), madvillain (02-07-2011), mr_mazda329 (02-08-2011), spoolin00 (02-07-2011)
 Old 02-07-2011, 11:16 AM   #22
qtrmile beast's Avatar
Posts: 2,423   (View Stats)
If you are going to blow the stocker you are not going to pussy out like the rest of us with just a little rod through the back of the block you are going to COMPLETELY destroy that fucker!!!!!!
Cant wait to see this against that mustang you raced in the last vid or maybe you can catch up with that supra this time and have a rematch!!!! GOOD LUCK DJ i'm pulling for you!!!!
track weight 3220
street weight 3370
The Following 6 Users Say Thank You to qtrmile beast For This Useful Post:
Alpha (02-07-2011), DaleNixon (02-08-2011), djuosnteisn (02-07-2011), Juyoung (04-23-2013), wette460 (04-13-2011), xdm88 (02-07-2011)
 Old 02-07-2011, 11:10 AM   #23
mtnrunner's Avatar
Posts: 864   (View Stats)
mtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the world
Looks sick man! must be nice to be sooooo close to being done after this long. Cant wait to see vids of this thing ripping and spinning all four!
Murdered out 2007 speed3 GT with navi.
mtnrunner is offline   Reply With Quote
The Following User Says Thank You to mtnrunner For This Useful Post:
 Old 02-07-2011, 11:21 AM   #24
triplejumper18's Avatar
Posts: 2,569   (View Stats)
Groans: 196
You're gonna feed Kat to the turbo gods?
The Following 4 Users Say Thank You to triplejumper18 For This Useful Post:
DaleNixon (02-08-2011), djuosnteisn (02-07-2011), I Love Brownies (02-07-2011), jmhinkle (02-08-2011)
 Old 02-07-2011, 11:21 AM   #25
Fuck sushi rolls
rodrigo's Avatar
Posts: 18,719   (View Stats)
Groans: 356
looks great mr. hawkins , awesome that you took so many pictures as well. Cant wait to see this at a SEA LEVEL drag strip.
keep kicking ass ese
 Old 02-07-2011, 11:29 AM   #26
Captain
I'm hoping this turbo is big enough to bring sea level to me.
bcmurphy87 likes this.
www.permtuning.com
The Following 64 Users Say Thank You to djuosnteisn For This Useful Post:
-cj- (02-07-2011), 8.5MS3 (02-07-2011), banditscout (02-13-2011), bcmurphy87 (06-18-2011), BobtailedSnail (12-03-2011), charlesfist (05-17-2011), Chriscote (02-07-2011), cocoanton (04-12-2011), cpolly69 (02-08-2011), DaleNixon (02-08-2011), danesti (03-06-2011), Darksun280 (02-07-2011), Dash08 (02-07-2011), DingoDave (06-14-2011), dougefresh_ (08-28-2011), efispeed (02-18-2011), essejkcamraw (02-08-2011), fishin53 (02-07-2011), Fobio (02-07-2011), I Love Brownies (02-07-2011), i8urgti (07-10-2011), JacksonMS30 (02-07-2011), jax ms3gt (02-07-2011), jmhinkle (02-08-2011), jracer (02-08-2011), jtspells (02-07-2011), Juyoung (04-23-2013), kunfu (02-07-2011), madvillain (02-07-2011), MATT DAMOND (05-06-2011), MDRracing13 (02-10-2011), MPSdriver (02-08-2011), mtnrunner (02-07-2011), NJSPEED3 (02-07-2011), NoRegrets (02-16-2011), psychophyr (02-07-2011), PunjabiPlaya (02-07-2011), qtrmile beast (02-07-2011), ReD BoY (09-09-2011), reidclark (09-18-2011), rodrigo (02-07-2011), Scynfewl (02-12-2011), SilverDemon (02-07-2011), Snotrocket (08-07-2011), spd6guy90 (02-07-2011), Speed freak (02-07-2011), Speed2006 (07-14-2015), Speed3eak (02-07-2011), spoolin00 (02-07-2011), Sport6 (02-09-2011), Stealth01 (02-07-2011), superskaterxes (02-07-2011), taf0422 (02-09-2011), the_caruch (02-07-2011), turd burglar (02-07-2011), wankular (02-07-2011), wette460 (04-13-2011), wolly6973 (02-08-2011), Worbit (08-29-2011), X-Man (02-07-2011), xdm88 (02-07-2011), xfeejayx (02-10-2011), ZoomZoomPSSH (02-07-2011)
 Old 02-07-2011, 11:30 AM   #27
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
lol, well put.
 Old 02-07-2011, 11:31 AM   #28
as i said the other night, lolz @ last march when you said your built motor setup would only take a month hahahaha
hopefully it was all worth it!!! make us proud!!!
The Following 5 Users Say Thank You to superskaterxes For This Useful Post:
Alpha (02-07-2011), djuosnteisn (02-07-2011), Juyoung (04-23-2013), MPSdriver (02-08-2011), NJSPEED3 (02-07-2011)
 Old 02-07-2011, 11:35 AM   #29
I think Dustin is trying to be the first to put an MZR rod into outerspace...
The Following 22 Users Say Thank You to JacksonMS30 For This Useful Post:
09Speed3Z (02-07-2011), banditscout (02-13-2011), Broxer (09-06-2011), charlesfist (05-17-2011), cpolly69 (02-08-2011), DaleNixon (02-08-2011), Dash08 (02-07-2011), djuosnteisn (02-07-2011), easy (02-08-2011), i8urgti (07-10-2011), JMEngineer (02-07-2011), Juyoung (04-23-2013), kunfu (02-07-2011), MATT DAMOND (05-06-2011), Mazdaspeed3GT (08-19-2011), NoRegrets (02-16-2011), reidclark (09-18-2011), rigor (02-07-2011), Scynfewl (02-12-2011), Stealth01 (02-07-2011), vbt101 (04-28-2011), Worbit (08-29-2011)
 Old 02-07-2011, 11:46 AM   #30
Alpha's Avatar
Posts: 3,711   (View Stats)
NASTY! I can't wait to have my fab guy tackle a nice top mount EFR setup!
 Old 02-07-2011, 12:10 PM   #31
R.MS3's Avatar
Posts: 987   (View Stats)
R.MS3 is the leader of the worldR.MS3 is the leader of the worldR.MS3 is the leader of the worldR.MS3 is the leader of the worldR.MS3 is the leader of the worldR.MS3 is the leader of the worldR.MS3 is the leader of the worldR.MS3 is the leader of the worldR.MS3 is the leader of the worldR.MS3 is the leader of the worldR.MS3 is the leader of the world
Tits... that reminds me i need to get my rebuild going... fuck.
R.MS3 is offline   Reply With Quote
The Following User Says Thank You to R.MS3 For This Useful Post:
 Old 02-07-2011, 12:21 PM   #32
Speed3eak's Avatar
Posts: 2,290   (View Stats)
Groans: 82
DJ, between you and jwilks I guess we're going to find out how much power these rods can take before they give out with a good tune.
cue applause
The Following User Says Thank You to Speed3eak For This Useful Post:
 Old 02-07-2011, 12:34 PM   #33
2zz mr-s
dooderek's Avatar
Posts: 5,119   (View Stats)
Groans: 239
god i hate you
The Following User Says Thank You to dooderek For This Useful Post:
 Old 02-07-2011, 12:40 PM   #34
X-Man's Avatar
Posts: 103   (View Stats)
X-Man is the leader of the worldX-Man is the leader of the worldX-Man is the leader of the worldX-Man is the leader of the worldX-Man is the leader of the worldX-Man is the leader of the worldX-Man is the leader of the worldX-Man is the leader of the worldX-Man is the leader of the worldX-Man is the leader of the worldX-Man is the leader of the world
Stock block... man... i cant even imagine the size of your nuts
But if there´s anyone that can pull it of it´s you
Oversteer - when passanger screams.
Understeer - when driver screams.
X-Man is offline   Reply With Quote
The Following 2 Users Say Thank You to X-Man For This Useful Post:
 Old 02-07-2011, 12:42 PM   #35
I <3 your mom
Dash08's Avatar
Posts: 7,166   (View Stats)
Groans: 293
I think half the forum wants to stick their dick in your turbo because that shit is fucking sexy.
Nice job on all the fab work man.
Seeing this makes me want to learn to weld. I'm tired of buying other peoples shit. I'd rather make my own.
this forum serves 2 purposes
The Following 10 Users Say Thank You to Dash08 For This Useful Post:
Alpha (02-07-2011), amoosenamedhank (02-07-2011), charlesfist (05-17-2011), DaleNixon (02-08-2011), djuosnteisn (02-07-2011), dougefresh_ (08-28-2011), JacksonMS30 (02-07-2011), Juyoung (04-23-2013), qtrmile beast (02-07-2011), Scynfewl (02-12-2011)
 Old 02-07-2011, 12:48 PM   #36
2zz mr-s
dooderek's Avatar
Groans: 239
i bet even in your car ill still run 15's
 Old 02-07-2011, 12:50 PM   #37
Robust Mongoloid
09Speed3Z's Avatar
Groans: 399
So, uhhhhhh yeahhhhh, East Coast Meet in Myrtle in May.
You bringie?!?!?!?!?!! SHOTGUN!!!! Hahahahahaha
______________________
Built By NATOR
Tons of Ricer Mods
The Following 2 Users Say Thank You to 09Speed3Z For This Useful Post:
djuosnteisn (02-07-2011), qtrmile beast (02-07-2011)
 Old 02-07-2011, 01:18 PM   #38
Fux Wit It
Darksun280's Avatar
Posts: 9,214   (View Stats)
Groans: 175
DJ you haven't learned from my fail? You're maf is going to hate life on that bend plus it really should be about 11 inches away from the turbo and 5-6 inchs away from any bend. MY 240 couldn't catch idle for shit off Decel being as close as yours is to the turbo and on a bend to boot. Pre pare you're self for tunning issues.
Carry on citizens....
10.7 @ 133 auto 1G DSM
The Following 2 Users Say Thank You to Darksun280 For This Useful Post:
djuosnteisn (02-07-2011), silvapain (02-08-2011)
 Old 02-07-2011, 04:44 PM   #39
Eth/Meth Junkie
cld12pk2go's Avatar
Posts: 2,998   (View Stats)
Exactly what I was going to mention.
Everything else looks like pure win though...
djuosnteisn (02-07-2011), jack_hammer (02-07-2011)
 Old 02-08-2011, 04:19 AM   #40
silvapain's Avatar
Posts: 6,665   (View Stats)
Groans: 136
Agreed. The MAF needs laminar flow to accurately read mass airflow, and the closer you put the MAF to the turbo or a bend, the less laminar the flow will be. The rule of thumb I've been taught is 2 times the MAF diameter from any bend (upstream or downstream), and as far from the turbo (or throttle plate in N/A applications) as possible.
In addition, you may have to rotate the MAF around while tuning to get the best (i.e. most linear) response in relation to engine/turbo RPM's.
Don't get me wrong, I'm not hating; I just want the car to run as well as possible.
Darksun280 (02-08-2011), djuosnteisn (02-08-2011)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f498/my-twin-scroll-bw-s300sx-88-75-a-71706/
PERM's MS6 This thread Refback 09-19-2012 11:10 PM
Mazdaspeed 3 > Any Evo :) - Page 3 - evolutionm.net This thread Refback 07-21-2011 07:18 PM
Mazdaspeed 3 > Any Evo :) - Page 2 - evolutionm.net This thread Pingback 07-13-2011 02:03 PM
exhaust manifold $250 twin scroll Justin Lee MazdaSpeed 3/6 - Turbo Induction 20 10-14-2013 08:08 PM
removing twin scroll divider turd burglar MazdaSpeed 3/6 - Turbo Induction 11 05-12-2010 11:06 PM
Twin-Scroll K04?!?!? Mfinlay04 Mazdaspeed3/6 General Discussion 37 05-27-2009 06:28 PM
Page generated in 2.14694 seconds with 53 queries
