Like Tree16Likes
 Old 07-12-2011, 02:22 PM   #41
steedspeed's Avatar
Posts: 582   (View Stats)
Originally Posted by turd burglar View Post
I'm goin 5.0 good sir
Nice choice! I took a GT for a rip when they first came out. Good power and excellent handling.
The Following User Says Thank You to steedspeed For This Useful Post:
turd burglar (07-12-2011)
 Old 07-12-2011, 06:17 PM   #42
bmylez's Avatar
Posts: 3,197   (View Stats)
I would love a 5.0, but everyone and their second cousin has one in TX. You lose your soul if you buy one here.
PurplFox likes this.
2007 CTS-V - Trying to sell
The Following 2 Users Say Thank You to bmylez For This Useful Post:
PunjabiPlaya (07-16-2011), sLow6 (07-21-2011)
 Old 07-12-2011, 08:08 PM   #43
steedspeed's Avatar
But do they have twin turbos?
mtnrunner (07-12-2011)
 Old 07-13-2011, 12:40 AM   #44
bmylez's Avatar
If I got a 5.0, I'd put a twin screw blower on it if i wanted F/I.
Sorry for thread derail, haha. Mason...you should make me a downpipe...
 Old 07-13-2011, 04:51 AM   #45
mason's Avatar
Posts: 946   (View Stats)
going to build mine then make a jig off of it.
 Old 07-13-2011, 09:18 AM   #46
bmylez's Avatar
Only problem is, I dont' want twin scroll. Don't need to spend the money on a second WG, among other things. You think it's close enough to mate up to CBE with a stock location manifold?
 Old 07-13-2011, 09:25 AM   #47
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
Then get the TS with no wastegates, and fit the turbo with ATP's new ewg hot side. Or go with IWG.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
 Old 07-13-2011, 10:34 AM   #48
bmylez's Avatar
Hmmmmmmmm......
Only thing is, my plan was to go with the PTE 5557, which I can find for 830 dorrah. A GT30 without exhaust housing is $1000 then the ATP housing is $365. Way more of the monies.
 Old 07-13-2011, 10:42 AM   #49
Captain
Psssssh, then go without any wastegates. POWAH. hahaha.
www.permtuning.com
 Old 07-13-2011, 10:44 AM   #50
bmylez's Avatar
RPM-based boost, haha.
3500 = 15psi
4500 = 25psi
Red line = 50+ psi
djuosnteisn (07-13-2011), manelscout4life (07-13-2011)
 Old 07-13-2011, 10:58 AM   #51
Captain
Hahaha, i know it sounds stupid, but i've heard of people doing it.
www.permtuning.com
 Old 07-13-2011, 11:03 AM   #52
doubleflusher's Avatar
Posts: 20,650   (View Stats)
Groans: 1,443
Right foot is the wastegate.
Beanfab / Tuned by Nishan
The Following User Says Thank You to doubleflusher For This Useful Post:
 Old 07-13-2011, 11:41 AM   #53
bmylez's Avatar
Leen/Mason, how much farther left does the TS manifold sit? I haz idea...
 Old 07-13-2011, 12:56 PM   #54
Captain
I haz idea...
If your idea is EFR... it might just fit perfect.
www.permtuning.com
Alpha (08-07-2011)
 Old 07-13-2011, 01:18 PM   #55
bmylez's Avatar
No. EFR would not fit at all. The EFR housing sticks out I think 2 - 3" over toward the passenger side. It would require a manifold that shifts toward the opposite direction of Leen's manifold.
If I got a regular T3 manifold along with a turbo using a v-band adapter (http://www.atpturbo.com/mm5/merchant..._Code=ATP-FLS1), which is 1.25" wide, and used Mason's downpipe, it would be basically in the same spot as the TS manifold.
 Old 07-13-2011, 01:26 PM   #56
Captain
I think the EFR sticks out on the compressor side. That was the whole reason the TS mani was shifted... to accommodate EFR.
All speculation until someone verifies, but i'm certain that's why it was shifted in the first place.
www.permtuning.com
Alpha (08-07-2011)
 Old 07-13-2011, 02:09 PM   #57
steedspeed's Avatar
Correct. I moved the turbo toward the alternator to allow more room for EFR turbos. I didn't want to go too far though as you still need room for the DP to clear the alternator. I think it came out pretty good considering I don't have a car here to measure/test fit.
The Following 3 Users Say Thank You to steedspeed For This Useful Post:
djuosnteisn (07-13-2011), PapaSmurf (07-13-2011), Realgib3 (07-13-2011)
 Old 07-13-2011, 02:49 PM   #58
mason's Avatar
i dont know the difference between the two mannys as i never have had a regular t3 steed manny. it looks like in pics it was moved over 1.5 - 2 inches. and i think it sits in the same place just moved over? leen?
The Following User Says Thank You to mason For This Useful Post:
 Old 07-13-2011, 02:55 PM   #59
mason's Avatar
plus with the manny tilted back from stock location, turbo dont line rite up with altenator. kinda sits off to the back of it some. the EFR sticks out the turbine housing a lil more than garret but its way wider on the comp. side. i bet a EFR will fit.
 Old 07-13-2011, 03:00 PM   #60
bmylez's Avatar
Ok, well if it's anywhere near 1.25", then your downpipe would basically fit. Are your going to put a flex pipe in it?
 Old 07-13-2011, 04:16 PM   #61
bmylez's Avatar
Ah, interesting. I remember your mentioning that in the twin scroll thread, but it still doesn't make sense in my head, haha. I'm looking at the EFR page right now and the turbine discharge looks to stick out sooo far...I just don't see how you could move the manifold toward the alternator and have that thing fit.
 Old 07-13-2011, 04:20 PM   #62
Captain
Tilt + move probably. And the "stick out" distance should be considered from the inlet flange to the v-band outlet. Not distance from the CHRA.
We won't know for sure until someone tries.
www.permtuning.com
 Old 07-13-2011, 05:00 PM   #63
TWOptSL0W's Avatar
Posts: 3,289   (View Stats)
Groans: 125
ok please dont tear me apart if this is too out there, but for the dp, wouldnt something like this work:
06 07 Mazda Mazdaspeed 6 Turbo 3" Down Pipe Downpipe | eBay
the flange for the stock turbo looks about 1.5 in long which you wouldnt use so that would accommodate for the movement in the mani. its still a 3" v-band, so unless i am missing something huge or am just clueless, this should fit perfectly
ideas?
 Old 07-13-2011, 05:01 PM   #64
bmylez's Avatar
That works just fine on a Mazda housing and a 6. The DP routing on a 3 is totally different.
 Old 07-13-2011, 05:10 PM   #65
TWOptSL0W's Avatar
Groans: 125
damn didnt think of that how much different are the dps from 3 and 6?
 Old 07-13-2011, 05:28 PM   #66
bmylez's Avatar
No idea, but you would spend more money and effort on converting a 6 pipe to fit a 3 than just starting from scratch.
 Old 07-13-2011, 05:41 PM   #67
Captain
Good god..... i've seen knock offs, but how in the hell can this place sell shit for so cheap????
Products | racedesignimports.com
That's who makes that dp you listed above TWOptSLOW. I'm baffled. Not sure how long it would last, few months maybe... but still, so fucking cheap lol.
www.permtuning.com
 Old 07-13-2011, 05:59 PM   #68
mason's Avatar
ive looked a the EFR and it sticks out a lil farther than the GT turbo mabey 2in prolly less on the turbine side. the set up is way longer on the comp side! so steed did what was best! like i said b4 the tilted back placing puts you sorta behind alt. so im pretty sure you could make it fit, also due to there isnt any other room there so its prolly in the best spot possible. and im putting on a 8in flex, so it will tweak were you need it to. also did some measuring and looks like the twinny steed sits 1.5 inch to the left vs stock manny. perfect!
The Following 2 Users Say Thank You to mason For This Useful Post:
djuosnteisn (07-14-2011), PapaSmurf (07-13-2011)
 Old 07-13-2011, 06:06 PM   #69
mason's Avatar
the metal is so thin and cheap! it wouldnt last no time till it blew a hole! i dont even know how its welded together! lol! anyways, im sure you could make it fit! call me when you need a soild one welded up for you
 Old 07-13-2011, 10:16 PM   #70
bmylez's Avatar
Hey man, PM me a price for the DP. Thanks.
 Old 07-14-2011, 03:16 PM   #71
mason's Avatar
does it matter on the turbo the in and out on the water lines? i think there might be confusion on in and out? but i dont think it really matters..... i dont recall on other set ups i had in the past.
 Old 07-14-2011, 03:17 PM   #72
spnkr21's Avatar
Posts: 2,827   (View Stats)
Groans: 105
It doesn't matter.
2012 WRX HB w/mudflaps yo!
The Following 2 Users Say Thank You to spnkr21 For This Useful Post:
djuosnteisn (07-14-2011), mason (07-14-2011)
 Old 07-14-2011, 03:25 PM   #73
Captain
Yup, no matter ever.
www.permtuning.com
mason (07-14-2011)
 Old 07-14-2011, 05:26 PM   #74
Groans: 1,443
http://www.turbobygarrett.com/turbob...er_Cooling.pdf
djuosnteisn (07-18-2011), mason (07-15-2011)
 Old 07-15-2011, 03:36 PM   #75
mason's Avatar
good read!
doubleflusher (07-15-2011)
 Old 07-16-2011, 02:32 PM   #76
Joellc2434's Avatar
Posts: 232   (View Stats)
Joellc2434 is a splendid one to beholdJoellc2434 is a splendid one to beholdJoellc2434 is a splendid one to beholdJoellc2434 is a splendid one to beholdJoellc2434 is a splendid one to beholdJoellc2434 is a splendid one to beholdJoellc2434 is a splendid one to behold
So there are some people here in vegas. Been out here a year and haven't seen or heard much but I am a family man. Its only one step above being a complete shut in. Just recently getting back into moding my now 4 year 40,000 mile car. Hope to run into some of you someday and pick your brains
2007 Mazdaspeed 3 GT: Cobb AP running stage 2+ 91 oct. w/ 3.5 gallons E85, cp-e Xcel CAI, cp-e FMIC, cp-e injector seals, Dashhawk 2 w/ cp-e mount, cp-e side engine mounts, Magnaflow CBE, M2 (ebay) Downpipe, TRZ Dogbone RMM, Denso ITV 22's, SURE Sidewinder TIP, SURE Return, SURE Intake Plenum and Throttle Body TIGs, SURE Shortcut and Countershift, SURE Anchors, KMD HPFP Internals, PNP'd Intake manifold and Throttle Body by Grimmspeed
Working on my Tune
In garage: New exhaust Mani
Joellc2434 is offline   Reply With Quote
 Old 07-16-2011, 03:17 PM   #77
mason's Avatar
i live south jones and the 215. i might need a hand sometime if your close?
 Old 07-16-2011, 03:26 PM   #78
Joellc2434's Avatar
I'm very close. Buffalo and Blue Diamond. I'd love to help to learn a few things. If you don't mind dealing with a complete noob.
Working on my Tune
 Old 07-16-2011, 03:31 PM   #79
mason's Avatar
an extra pair of hands goes along way!
 Old 07-16-2011, 03:41 PM   #80
Joellc2434's Avatar
Thats what I try to tell my wife but she still won't go for it
I have kind of a weird work schedule but pm me if you ever need some help
Working on my Tune
Page generated in 0.55078 seconds with 28 queries
