Like Tree16Likes
 Old 04-05-2013, 06:15 AM   #841
mason's Avatar
Posts: 946   (View Stats)
no, i bought a stiffer set of springs earlier that put me at 22-23 just on spring and still got the erratic issues just the same as with a MBC. i put the softer springs back in after figuring it wasnt the MBC.
so this means when i hit 22 psi on spring or MBC i get the erratic surging.
id really like to figure the problem rather than work around it. im not sure it is surge anymore. i looked and listened to several u tube videos on compressor sure and the sound i hear on the vids sound nothing like my issue.
im just kinda clueless were to look.
i just remembered i did get a code, then i cleared it and it hasent come back. i havent looked it up yet.
PO335 CKP sensor problem
i been praying for a code to tell me wtf the problem is LOL. not sure what sensor this is or does yet.
ok its the cam crank sensor, im going to take car to work again today and see if the code comes back. any thoughts?
 Old 04-06-2013, 01:17 AM   #842
Axle Breaker
jmhinkle's Avatar
Posts: 4,639   (View Stats)
Groans: 162
p0335 is just crank position sensor. I used to get that if I tried adjusting my MAF cal too far. I had three things cause it. First was a bad MAF, second was a replacement MAF from autozone because they think the regular MAF works on our cars. Both eventually burned up and were out of the equation. Lastly, was an intake leak that I couldn't find and tried cal'ing around. Are you running a Mazda MAF or a replacement?
 Old 04-06-2013, 03:58 AM   #843
PapaSmurf's Avatar
Posts: 8,236   (View Stats)
I got the same code when I first built
My engine, it was because I used a replacement maf and some metal shavings from my engine break in where stuck to the bottom of my cam position sensor because its magnetized.
Sent from my flying tapadildo
860whp/677wtq
2.7 V6 Ecoboost
 Old 04-06-2013, 06:24 AM   #844
Ziggo's Avatar
Posts: 3,843   (View Stats)
P0335 is unrelated and has to do with the mafcal see this post.
P0335 Crank Position Sensor A Circuit Malfunction
Zigatapatalka
Ask Me About My:
 Old 04-06-2013, 04:47 PM   #845
mason's Avatar
thanks guys and its the stock factory maf
with my new upgrades seems ill have to re calibrate the MAF. ill have to look back and remember how to.
Last edited by mason; 04-06-2013 at 04:47 PM. Reason: MSF Database - Automerged Doublepost
 Old 04-15-2013, 05:46 AM   #846
mason's Avatar
Jeff,
100% normal and designed in to the system. Garrett decided not to put an o-ring there.
Skip right past it as it's a non-issue. We stand behind it 100%.
Thank you!
this is from atp turbo. i asked if it is normal to leak a small amount around comp housing during a boost leak test on the system. i thought id share this info.
id did perform yet another boost leak test and everything is tight. i did have a couple bubbles coming from the egr flange. snugged the bolts and went away.
The Following User Says Thank You to mason For This Useful Post:
jmhinkle (04-15-2013)
 Old 04-16-2013, 04:31 PM   #847
mason's Avatar
ok, we looked at and made minor changes to my maf cal. and i logged short term trims during logs and we seen a spot under very lite throttle were stft was +25.
after changes, i started to notice alot more than befor under very light throttle ( just enough to maintain speed) i was getting some jerking around and was looking at stft and they are bouncing around everywere. if i give it just a little more gas everything zeros out. and it zeros out from there on up. only getting this a very lite throttle.
befpr changes i would VERY rare get a jerk or two under light throttle, i thought mabey it was my foot jerking a lil. but after looking at maf cal logs and after changes im getting it all the time. i do have a log.
and also feels like the stutter i was/ am getting under my WOT pulls, when i was at 20-21 psi. i called it stutter then. so im hoping they are related
here is log
Ziggo (04-16-2013)
 Old 04-16-2013, 09:02 PM   #848
Ziggo's Avatar
I dont think this is actually an issue with the MAF calibration. There is no correlation between STFTs and the maf voltage.
Ask Me About My:
mason (04-17-2013)
 Old 04-17-2013, 12:31 AM   #849
Axle Breaker
jmhinkle's Avatar
Groans: 162
Beyond the fact that his cal is adding a lot of fuel over the whole range if I'm reading your axes correct?
The Following User Says Thank You to jmhinkle For This Useful Post:
mason (04-17-2013)
 Old 04-17-2013, 05:30 AM   #850
Ziggo's Avatar
Well it is always positive, but varies from close to zero to all the way to +25 so it's all over the map. Usually when you look at it this way, there is a clear trend in the STFT relative to the maf voltage
Zigatapatalka
Dahouse702 likes this.
Ask Me About My:
mason (04-17-2013)
 Old 07-22-2013, 08:02 PM   #851
Dahouse702's Avatar
Posts: 487   (View Stats)
Dahouse702 is the leader of the worldDahouse702 is the leader of the worldDahouse702 is the leader of the worldDahouse702 is the leader of the worldDahouse702 is the leader of the worldDahouse702 is the leader of the worldDahouse702 is the leader of the worldDahouse702 is the leader of the worldDahouse702 is the leader of the worldDahouse702 is the leader of the worldDahouse702 is the leader of the world
How's it going?
2007 MS3 Black Mica-Totaled @98500 on 09/2014
Current Car...
2009 MS3 Black Mica GT JBR TRU 3.0 Widepath full intake, BNR S3 v1, GS EBCS, 3 BAR , Forge BPV V2, Autotech internals , Denso Itv22, CNT Downpipe, CX-Racing piping with Cobb v2 core, Cobb AP v2, JBR RMM, JBR PMM, JBR TMM, JBR Oil Catch Can, EGR Delete, JBR TIG, Toyota Seals, HTP battery tray, DashHAWK
Zoom Zoom
Dahouse702 is offline   Reply With Quote
 Old 10-12-2013, 04:51 PM   #852
mason's Avatar
cars been sitting in garage for like 6- 8 months........ just recently starting thinking about her again. got a code to fix, and ill start tuning again
The Following 2 Users Say Thank You to mason For This Useful Post:
Dahouse702 (10-12-2013), Hanzodurrr (10-12-2013)
 Old 11-03-2013, 02:44 PM   #853
mason's Avatar
a sad day for me, but got to do what i got to do........ my car is in the cars for sale section
thanks
 Old 11-03-2013, 03:03 PM   #854
Hanzodurrr's Avatar
Posts: 240   (View Stats)
Hanzodurrr is the leader of the worldHanzodurrr is the leader of the worldHanzodurrr is the leader of the worldHanzodurrr is the leader of the worldHanzodurrr is the leader of the worldHanzodurrr is the leader of the worldHanzodurrr is the leader of the worldHanzodurrr is the leader of the worldHanzodurrr is the leader of the worldHanzodurrr is the leader of the worldHanzodurrr is the leader of the world
Damn was really hoping to spy you around vegas with this beast running good. Sorry you have to sell. I'll pass it on the the vegas mazda group to see if anyone is interested.
Note 2 Tappin
JBR Wrinkly Black Dong//CX FMIC w/Wrinkle black piping//PPT Tune//Autotech HPFP//Corksport Springs//TWM Full Replacement//JBR 88tmm 88rmm 80pmm//JBR OCC//JBR EGR delete//JBR TIG//GFB 100% Rice to Air//TB bypass// Kozmic Vband DP//CP-E ExMani//PTE 5558//Stoptech Power Slots all around//Stoptech SS lines//EBC Yellows//
BLEW UP AUG 2014
Aug 2015 SP63 Long Block coming soon!!!
Hanzodurrr is offline   Reply With Quote
The Following User Says Thank You to Hanzodurrr For This Useful Post:
mason (11-05-2013)
 Old 01-08-2015, 04:07 PM   #855
Jkelley's Avatar
Posts: 218   (View Stats)
Jkelley is the leader of the worldJkelley is the leader of the worldJkelley is the leader of the worldJkelley is the leader of the worldJkelley is the leader of the worldJkelley is the leader of the worldJkelley is the leader of the worldJkelley is the leader of the worldJkelley is the leader of the worldJkelley is the leader of the worldJkelley is the leader of the world
Originally Posted by mason View Post
a sad day for me, but got to do what i got to do........ my car is in the cars for sale section thanks
I'm in Las Vegas also.. Who tuned your car bro?
2008 Mazda Mazdaspeed3 GT (True Red) SOLD
~Mods: ATP GTX3071r IWG, JBR Tru 3.5" WP, UR V2 3" catless DP & TP, Tr8+JBR FMIC, Turbosmart BPV, CP-e HPFP, NGK 6510, Bosch 3bar MAP, Cobb 3-port EBCS, PERM PCV Plate, Damond OCC (1sealed, 1 VTA), Kozmic 1°/Damond 2° EGR Delete, Corksport seals, CP-e RMM 75A, JBR side MM 80A, Cobb AP V2, spin-on oil conversion, KSport Coilovers, SPC Performance Camber Arms, JBR IM/TB TIG, SURE Anchors
~~332whp @5300rpm / 354wtq @4800rpm @ 21psi on 91oct FREEKTUNED
~~380whp @6500rpm / 367wtq @4800rpm @ 20psi on e33 FREEKTUNED
2007 Mazda CX-7 (Burgundy Wine) SOLD
Jkelley is offline   Reply With Quote
The Following User Says NO Thank You to Jkelley For This Un-useful Post:
mghtymouse380 (01-09-2015)
 Old 01-13-2015, 08:12 PM   #856
mr_mazda329's Avatar
Posts: 798   (View Stats)
mr_mazda329 is the leader of the worldmr_mazda329 is the leader of the worldmr_mazda329 is the leader of the worldmr_mazda329 is the leader of the worldmr_mazda329 is the leader of the worldmr_mazda329 is the leader of the worldmr_mazda329 is the leader of the worldmr_mazda329 is the leader of the worldmr_mazda329 is the leader of the worldmr_mazda329 is the leader of the worldmr_mazda329 is the leader of the world
Groans: 55
Bruh, where have you been hiding.
09 MS3 CWP BNR-S3 GFB Respons BPV, HTP 3.5in whalepenis , CXRacing/TR8L Core FMIC CorkSport CBE CNT Catless long DP, NGK Plugs, DM Trilogy, Cobb AP VEGA Tuned, CP-e HPFP CP-e Injector Seals
97 Miata Daily Driver
04' Mazdaspeed Miata Track Car
Road Racing > Autocross > Spirited Driving > Sitting in Traffic > Mowing Lawns > Drag Racing
mr_mazda329 is offline   Reply With Quote
 Old 01-13-2015, 09:26 PM   #857
Jkelley's Avatar
Haha.. Been busy. Just blew my motor.. Gonna be building it now.
 Old 02-20-2015, 12:35 PM   #858
Groans: 55
damn, super ouchies. You're not on LVmazdas on FB so its hard to keep tabs on you. lol
 Old 02-21-2015, 01:39 PM   #859
Jkelley's Avatar
no facebook bro..
i have an ig though... jktheoreo
Page generated in 0.39038 seconds with 28 queries
