 Old 04-07-2010, 09:37 PM   #1
7mileshome's Avatar
Posts: 350   (View Stats)
7mileshome is the leader of the world7mileshome is the leader of the world7mileshome is the leader of the world7mileshome is the leader of the world7mileshome is the leader of the world7mileshome is the leader of the world7mileshome is the leader of the world7mileshome is the leader of the world7mileshome is the leader of the world7mileshome is the leader of the world7mileshome is the leader of the world
Default Need some ideas
I just finished installing my GT28 and DNP EWG mani, got everything hooked back up,
and the car does not stay on. It cranks up then dies immediately, just like
when you install an intake for the first time, and turn the MAF backwards. (lol)
But the maf is not backwards, I've tried it both ways. The only other thing I can
say about the Intake side, is that I had my ECU reflashed for the 3.5" Maf housing.
Could this be the problem?
Also, I removed the stock boost control solenoid and I am using the grimmspeed EBC
only, could this be it? (yes it is connected to where the stock solenoid went to)
So I need some thoughts as to why a car will turn on, then turn off immediately...
-theres gas in the tank
-all fuel lines are connected properly
-MAF is not facing the wrong way (lol)
-Yes I have the whole intake connected
-Spark Plug wires are connected
**Update 14 April** Got my ecu back and still... still not running right.
I've already talked to Josh and he assured me that CPe Flashed the ecu. He is also
trying to figure out why its not working.
Heres a video, exactly whats happening right now
2012 Mazdaspeed3 LSM
Should have gotten a speed6
2008 Mazdaspeed3 GT Black Mica [sold]
Built motor, Etc.
383 hp 401 tq GTX2867R @ 25 psi
7mileshome is offline   Reply With Quote
 Old 04-08-2010, 08:54 AM   #2
spnkr21's Avatar
Posts: 2,827   (View Stats)
Groans: 105
Default Re: Need some ideas
What kind of intake do you have?
2012 WRX HB w/mudflaps yo!
 Old 04-08-2010, 09:30 AM   #3
7mileshome's Avatar
the cp-e 3.5" maf, it comes with a filter, so it looks just like a nano setup.
Built motor, Etc.
 Old 04-08-2010, 09:42 AM   #4
phillyb's Avatar
Posts: 14,702   (View Stats)
Groans: 1,940
maf is connected?
does fuel pressure die?
 Old 04-08-2010, 09:53 AM   #5
BUNGEEZZ's Avatar
Posts: 426   (View Stats)
BUNGEEZZ is the leader of the worldBUNGEEZZ is the leader of the worldBUNGEEZZ is the leader of the worldBUNGEEZZ is the leader of the worldBUNGEEZZ is the leader of the worldBUNGEEZZ is the leader of the worldBUNGEEZZ is the leader of the worldBUNGEEZZ is the leader of the worldBUNGEEZZ is the leader of the worldBUNGEEZZ is the leader of the worldBUNGEEZZ is the leader of the world
Groaned at 49 Times in 36 Posts
Fuses?.. maybe fuel? or you could just pay 100 buks and get it diagnosed by a tech
Mazdaspeed6,2006, 46k miles.
COBB AP*
Gt3076, 19psi. CPE dp (catless), Dnp Mani 38-EWG, CorkSport Dual CB, CPE BIG MAF SRI, Big Turbo Inlet, CPE Fuel Pump, HKS SSQ Black out edition, Ported stock intake Mani, Intake mani spacer (PT), 2 step colder plugs, FMIC Custom 3.5 inch core, Meth (PT), OCC, BSD, TTFMM, CPE Rear Diff, CPE engine Mount, H&R Springs, Whiteline Rear Sway Bar, Stage 1 short shifter kit Base+bushings, Rotora Break Rotors All 4 (Slotted), Techna fit Brake Lines, Ebc red Stuff pads All 4, Enkei PF01 18's Wrapped in 245/40/18 Falkanzzzz ... Stock clutch until i get some funds.
I HAZ THE FASTEZ CAR ALIVE!!!!!!!!!!!! REDBULL FTW
BUNGEEZZ is offline   Reply With Quote
 Old 04-08-2010, 10:01 AM   #6
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
Try a stock maf to make sure indeed your ecu was flashed, just to rule it out as a possibility.
Also, keep an eye on afr's when it does start, and fuel trims maybe.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
7mileshome (04-08-2010), FreeFlyFreak (04-19-2010), www.cp-e.com (04-08-2010)
 Old 04-08-2010, 10:05 AM   #7
spnkr21's Avatar
Groans: 105
So it is 3.25 and you did get the flash? Does your Maf housing fit a can of soda in it?
 Old 04-08-2010, 10:28 AM   #8
ALL-IN.
AndyMS3's Avatar
Posts: 671   (View Stats)
AndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the world
Groans: 30
Are you getting any CELs?
AndyMS3 is offline   Reply With Quote
 Old 04-08-2010, 01:14 PM   #9
7mileshome's Avatar
maf is connected?
maf is connected, fuel pressure is fine.
If it was a fuse, the car would not even start, fuel is fine. Why would I pay some one $100 to tell me the same thing my Dash Hawk can tell me?
That is a good idea, I will try that. Also, the car does not run enough to get a good A/F reading.
Why yes, and yes.
yes I got a P0113 IAT, high Intake air temp (??)
what im thinking right now is ether CP-e did not actually do the flash, or my MAF is bad somehow.
Built motor, Etc.
 Old 04-08-2010, 01:36 PM   #10
dizzin9's Avatar
Posts: 1,807   (View Stats)
dizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the world
Groans: 77
that sux ron. so it would actually start up then run for a lil bit then dies? am i right?
2008.5 MAZDASPEED3 GT TRUE RED ***GONE***
2012 FORD MUSTANG GT >>> 400A Premium _ Performance White _ 6MT _ 3.73 _ HID & Security Pkg
Koni Yellows _ Whiteline FSB & RSB _ FRPP K-Springs w/ Bump Stops, Boss 302 Strut Tower Brace, GT500 Strut Mounts, GT500 RCA, GT500-style AB
J&M PHB _ Eibach Camber Bolts _ Avant Garde M510 Satin Silver 19x9.5 40ET _ Hankook Ventus S1 noble2 275/40/19
dizzin9 is offline   Reply With Quote
 Old 04-08-2010, 01:38 PM   #11
phillyb's Avatar
Groans: 1,940
iat is measured at the maf, it has to be related to the maf or the flash.
 Old 04-08-2010, 01:54 PM   #12
madvillain's Avatar
Posts: 4,160   (View Stats)
Groans: 78
Yes, it is definitely the maf. Is it completely seated down with the o-ring sealed? I had a hell of a time with my maf sensor last week. If you have someone near by, you could always go grab their maf sensor to borrow for 30 minutes to test like I did haha.
 Old 04-08-2010, 01:57 PM   #13
ALL-IN.
AndyMS3's Avatar
Groans: 30
Is the MAF all shmagged up? Could be dirty or like mad said, a seating issue.
 Old 04-08-2010, 02:40 PM   #14
spnkr21's Avatar
Groans: 105
take a picture of it
 Old 04-08-2010, 03:07 PM   #15
7mileshome's Avatar
yea hopefully dizzin can come to the rescue wth a maf. lol.
maf is not dirty I cleaned it up with MAF cleaner and I cleaned the connectors with electronics cleaner.
and what am I taking a picture of?
Built motor, Etc.
 Old 04-08-2010, 03:26 PM   #16
www.cp-e.com's Avatar
Posts: 1,728   (View Stats)
One of two things here....
My prediction:
1. Not the xcelXL and you have the flash so its not running right which will turn on and then stumble and die immediately.
2. You have the xcelXL and the big maf flash was ommited.
Do me a favor. Take a picture of a soda can in the maf housing and reinstall a factory intake or standard cai / sri and try turning the car on. Doing these two tasks will let me know the problem.
Thanks
 Old 04-08-2010, 03:36 PM   #17
spnkr21's Avatar
Groans: 105
I was saying to take a pic of the maf housing. Cp-e beat me to it.
 Old 04-08-2010, 03:49 PM   #18
MarkyMark's Avatar
Posts: 1,624   (View Stats)
MarkyMark has disabled reputation
Groans: 62
Groaned at 156 Times in 148 Posts
My prediction:
Thanks
Jake, my car has this same problem. I tried stock MAf, and still no workie. everything on my DH checks out and I have gone over my engine bay and SB wiring several times.
I don't know what to do anymore.
MarkyMark is offline   Reply With Quote
 Old 04-08-2010, 03:53 PM   #19
7mileshome's Avatar
Is this what you needed to see? I will update once I get a hold of another intake, I just sold my nano and my xcel DAMMIT!
Built motor, Etc.
 Old 04-08-2010, 03:55 PM   #20
Captain
Now take a picture of your sister.
www.permtuning.com
The Following 11 Users Say Thank You to djuosnteisn For This Useful Post:
7mileshome (04-09-2010), andre0121 (04-17-2010), AndyMS3 (04-08-2010), BUNGEEZZ (04-09-2010), doubleflusher (04-14-2010), Fullmetal (04-19-2010), kgb (04-19-2010), kilik2 (04-10-2010), madvillain (04-08-2010), phillyb (04-08-2010), wankular (04-08-2010)
 Old 04-08-2010, 03:56 PM   #21
madvillain's Avatar
Groans: 78
with a soda can in her........ 'er nevermind..
The Following 9 Users Say Thank You to madvillain For This Useful Post:
andre0121 (04-17-2010), AndyMS3 (04-08-2010), djuosnteisn (04-08-2010), doubleflusher (04-14-2010), FreeFlyFreak (04-19-2010), kilik2 (04-10-2010), phillyb (04-08-2010), predapio (04-16-2010), wankular (04-08-2010)
 Old 04-08-2010, 04:04 PM   #22
Thanks. My guess is the flash got ommitted some how so we'll take care of that. Let me know once you try with a regular intake. If the car works we know the issue
Beeker - you has PM
 Old 04-08-2010, 06:40 PM   #23
7mileshome's Avatar
Ok, FWIW... I hooked Dizzin's Nano up, and the car started right up.
I tried his MAF and my MAF just to make sure.
That leaves only one conclusion...
Built motor, Etc.
The Following User Says Thank You to 7mileshome For This Useful Post:
djuosnteisn (04-09-2010)
 Old 04-09-2010, 06:51 AM   #24
Handled. We'll get your ecu flashed and have it back out to you.
Guys - in the future these tech issues are really easy for me to fix. If you just PM me or email me I am very quick to answer since all the emails go to my phone. Posting up on here gets answers from guys who don't even realize your running a completely different ecu. These flashes that allow BIG power aren't being tested on customer cars. We have locals who have been running them for multiple 1000s of miles. Their results just don't get posted because they are beta testers/shop cars. If something doesnt work its usually something stupid like only 2/3 flashes got loaded. Just let me know.
The Following 2 Users Say Thank You to www.cp-e.com For This Useful Post:
7mileshome (04-09-2010), kilik2 (04-10-2010)
 Old 04-09-2010, 10:25 AM   #25
dizzin9's Avatar
Groans: 77
Neutral  :  -1 score
flashing FAIL
 Old 04-09-2010, 12:11 PM   #26
spnkr21's Avatar
Groans: 105
Do your flashes work dizzi???
 Old 04-09-2010, 03:03 PM   #27
dizzin9's Avatar
Groans: 77
 Old 04-09-2010, 03:26 PM   #28
spnkr21's Avatar
Groans: 105
Oh
 Old 04-10-2010, 07:52 AM   #29
kilik2's Avatar
Posts: 1,254   (View Stats)
kilik2 is the leader of the worldkilik2 is the leader of the worldkilik2 is the leader of the worldkilik2 is the leader of the worldkilik2 is the leader of the worldkilik2 is the leader of the worldkilik2 is the leader of the worldkilik2 is the leader of the worldkilik2 is the leader of the worldkilik2 is the leader of the worldkilik2 is the leader of the world
Groans: 127
Groaned at 40 Times in 31 Posts
Good point Jake, but this thread lets everyone know to just contact you if we have a similar issue. Though I doubt people actually use the search function, they just make a new thread, lol.
kilik2 is offline   Reply With Quote
 Old 04-10-2010, 08:25 AM   #30
myzoomzoom3's Avatar
Posts: 266   (View Stats)
myzoomzoom3 has a brilliant futuremyzoomzoom3 has a brilliant futuremyzoomzoom3 has a brilliant futuremyzoomzoom3 has a brilliant futuremyzoomzoom3 has a brilliant futuremyzoomzoom3 has a brilliant futuremyzoomzoom3 has a brilliant futuremyzoomzoom3 has a brilliant futuremyzoomzoom3 has a brilliant futuremyzoomzoom3 has a brilliant futuremyzoomzoom3 has a brilliant future
so.....hows it run???
[SIGPIC][/SIGPIC]07 MS3 GT
Cpe cai, Corksport turbo back, Hks bov, Trz dog bone, Cobb ap, Cobb knob, Stage 2 JB ssp
myzoomzoom3 is offline   Reply With Quote
 Old 04-10-2010, 03:53 PM   #31
7mileshome's Avatar
soon as I get my ECU back from CP-E... I will let you know! ; )
Built motor, Etc.
 Old 04-10-2010, 05:07 PM   #32
Cagey just called to tell me he is struggling for traction in 4th and we aren't NEAR done tuning
djuosnteisn (04-10-2010), kilik2 (04-10-2010)
 Old 04-14-2010, 04:07 PM   #33
7mileshome's Avatar
Update... video in first post...
Built motor, Etc.
 Old 04-14-2010, 04:19 PM   #34
felt's Avatar
Posts: 1,504   (View Stats)
felt is the leader of the worldfelt is the leader of the worldfelt is the leader of the worldfelt is the leader of the worldfelt is the leader of the worldfelt is the leader of the worldfelt is the leader of the worldfelt is the leader of the worldfelt is the leader of the worldfelt is the leader of the worldfelt is the leader of the world
Groans: 1,364
Groaned at 589 Times in 386 Posts
This is a private video. If you have been sent this video, please make sure you accept the sender's friend request.
felt is offline   Reply With Quote
 Old 04-14-2010, 04:51 PM   #35
7mileshome's Avatar
fixed... also car runs fine with stock intake box
Built motor, Etc.
 Old 04-14-2010, 04:57 PM   #36
dizzin9's Avatar
Groans: 77
woohoo!!! how bout the standback - don't u have to set something in there? did u drive around with the stock box yet?
 Old 04-14-2010, 05:17 PM   #37
c.a.t.a.p's Avatar
Posts: 67   (View Stats)
c.a.t.a.p is a name known to allc.a.t.a.p is a name known to allc.a.t.a.p is a name known to allc.a.t.a.p is a name known to allc.a.t.a.p is a name known to allc.a.t.a.p is a name known to all
now thats where i want to be big turbo and fast as balls where o where to begin
good luck i know the car is going to run great
c.a.t.a.p is offline   Reply With Quote
 Old 04-14-2010, 05:23 PM   #38
What is your issue with our product? The rare issue is to be expected. Nothing ever works 100% for everyone.
Is it because you are using a product proven not to work you are upset?
 Old 04-14-2010, 05:26 PM   #39
felt's Avatar
Groans: 1,364
Dang dude, you just love to pick fights lol...
 Old 04-14-2010, 05:26 PM   #40
dizzin9's Avatar
Groans: 77
what did i say now? lol
cbe ideas speedms6 MazdaSpeed 6 - Engine, Transmission & Driveline 2 11-20-2009 12:05 AM
Guys ... any ideas johnnyspeed6 MazdaSpeed 6 - Engine, Transmission & Driveline 25 06-16-2009 10:12 AM
What should I put into my ms3?? i need ideas!! phantomspeed3 Mazdaspeed3/6 General Discussion 13 12-29-2008 08:09 AM
not sure what my issues are... ideas? myms3 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 12 04-11-2008 01:46 PM
Page generated in 0.56223 seconds with 33 queries
