Like Tree439Likes
 Old 05-30-2012, 09:11 PM   #41
Fail_6's Avatar
Posts: 2,305   (View Stats)
Fail_6 is the leader of the worldFail_6 is the leader of the worldFail_6 is the leader of the worldFail_6 is the leader of the worldFail_6 is the leader of the worldFail_6 is the leader of the worldFail_6 is the leader of the worldFail_6 is the leader of the worldFail_6 is the leader of the worldFail_6 is the leader of the worldFail_6 is the leader of the world
Ok, update time.
Picked up the snail this week. Well it's pretty heavy lol....dnp mani looks pretty serious in person. Welds are tight, no chips or cracks or anything. In need of a little cleaning to come very soon. Tial wastegate is a monster as well. Attached is a Perrin ebcs, not grimmspeed. My mistake.
Current tasks are creating a dump tube solution and welding the turbo.
Dump tube is currently vta, as evidenced in the closeup pic. That happens to be illegal as hell haha, so options are to chance running it vta as is, and just lengthen and reroute the exit towards the opening around the dp so I don't get soot on everything, or have a shop create a custom weld in my dp to recirc it back into the exhaust. I'll be going for route 2, and will most likely have bay state muffler do it.
Second is welding the turbo. It was originally iwg, so I will be welding the flap for the iwg closed, and removing the arm that was connected to the iwg all together. More details and pics to come soon
2006 Black Mica MS6 GT
FreekBuilt Longblock, Manley 9.5:1, Manley H Beams, BW S300SX 6268 1.00 A/R, Dual Tial 38mm MVR EWG, Twinscroll Tubular Top Mount, EGR Delete, Labontes Stage 2 Meth Kit w/ D10, Grimmspeed 3 port EBCS, 3 Bar Map Sensor w/ Matt Jackson Harness, PERM 4" Intake, Cp-E HPFP, CX Racing FMIC, HKS SSQV V3, NGK IX 6510's, Toyota Injector Seals, PERM Catless 3" Turboback w/ dual Magnaflow Magnapaks, PERM Top Mount Valve Cover, PNP Intake Mani, BSD, ACT ZX4-HDG6, Bilstein HD Shocks, H & R Springs, Stoptech Slotted Rotors w/ API Ceramic Pads, JBR Heavy Shift Knob
Stock motor w/ GT2871r:
380 awhp, 375 awtq @ 24 psi (e85 only)
- 13.1 @ 110, 2.1 60 ft
Fail_6 is offline   Reply With Quote
The Following 4 Users Say Thank You to Fail_6 For This Useful Post:
atvfreek (05-31-2012), BigJimMs3 (05-31-2012), bwspeed (06-01-2012), jman46 (05-30-2012)
 Old 05-30-2012, 09:55 PM   #42
jrlms6's Avatar
Posts: 1,436   (View Stats)
jrlms6 is the leader of the worldjrlms6 is the leader of the worldjrlms6 is the leader of the worldjrlms6 is the leader of the worldjrlms6 is the leader of the worldjrlms6 is the leader of the worldjrlms6 is the leader of the worldjrlms6 is the leader of the worldjrlms6 is the leader of the worldjrlms6 is the leader of the worldjrlms6 is the leader of the world
@PartiAudiMazdarati you going to dyno again before the new turbo? Maybe to see the graphical difference the BT makes over the k04...?
I'd be curious to see the pre and post dynos.
2006 Mazdaspeed6 GT - SOLD
Titanium Gray Metallic
SURE Aeros | SURE Sidewinder
Forge V1 | CPE TMIC
Magnaflow CBE | Corksport DP | TXS RP
COBB AP | Autotech Internals
JBR SSP | JBR Shift Weight | JBR Knob
Denso ITV22
2012 MS3 w/Tech - Hit and traded
Velocity Red Mica
COBB SRI | COBB TIP
2006 Mazdaspeed6 GT - Totaled
Liquid Platinum Metallic
CS Stage 2 | COBB AP | CPE HPFP
2006 Mazdaspeed6 GT
Black Mica
CS Stage 2 | CS BPV | CS TBE
COBB AP | CPE HPFP | CPE TMIC
DM RMM
Last edited by jrlms6; 05-30-2012 at 09:56 PM. Reason: MSF Database - Automerged Doublepost
jrlms6 is offline   Reply With Quote
 Old 05-30-2012, 10:23 PM   #43
Fail_6's Avatar
Of course. I need some sort of benchmark to know what I've picked up, plus I'm curious as well. Not sure when, but I'll make time before install. Once the turbo is welded, she's ready to go in, save for the 3 bar map sensor and the mounts; I'll have to plan for this soon. Wouldn't mind hitting the track again and pulling this 12 out, but I also risk breaking something each run, so I think I might lay low and dyno, then run with the bt after mounts are in
The Following User Says Thank You to Fail_6 For This Useful Post:
jrlms6 (05-31-2012)
 Old 05-31-2012, 05:29 AM   #44
mczimer's Avatar
Posts: 1,249   (View Stats)
mczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the world
I will be selling my dreadnaught in the next week or two, if that would be good for your build success. Have you considered upgrading the front engine mount as well, or is that not needed?
Oh, are the TQ/HP numbers in your sig after being tuned with those mods?
mczimer is offline   Reply With Quote
 Old 05-31-2012, 05:42 AM   #45
atvfreek's Avatar
Posts: 7,787   (View Stats)
@PartiAudiMazdarati, looking sexy man!
@jrlms6 the difference in tq won't be huge, but the hp number will be about 30 over Darnells current tune. Although peak numbers won't seem huge, the way the gt28 continues to make power past 5200 will be the biggest improvement, and biggest difference at the track/street when riding out 4th gear!!
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
The Following 4 Users Say Thank You to atvfreek For This Useful Post:
BigJimMs3 (05-31-2012), Fail_6 (05-31-2012), helmetface (06-05-2012), jrlms6 (06-01-2012)
 Old 05-31-2012, 06:31 AM   #46
BigJimMs3's Avatar
Posts: 4,859   (View Stats)
BigJimMs3 is the leader of the worldBigJimMs3 is the leader of the worldBigJimMs3 is the leader of the worldBigJimMs3 is the leader of the worldBigJimMs3 is the leader of the worldBigJimMs3 is the leader of the worldBigJimMs3 is the leader of the worldBigJimMs3 is the leader of the worldBigJimMs3 is the leader of the worldBigJimMs3 is the leader of the worldBigJimMs3 is the leader of the world
Groans: 76
Groaned at 22 Times in 20 Posts
BTW! Darnell said when this goes in and if i beat him he will give me the turbo.... at this point i will be going 50/50 to make sure that shit happens.
atvfreek likes this.
2006 Mazdaspeed 6
BNR S4 and supporting mods
2007 Mazdaspeed 3
Bolt on's and tune
2015 Taurus S.H.O
Intake/Tune
2016 Ford Explorer Sport
Stock
BigJimMs3 is offline   Reply With Quote
The Following 2 Users Say Thank You to BigJimMs3 For This Useful Post:
atvfreek (05-31-2012), Fail_6 (05-31-2012)
 Old 05-31-2012, 08:56 AM   #47
dougefresh_'s Avatar
Posts: 4,489   (View Stats)
Congrats on picking up the turbo! +1 on going ewg. Idk what spring combo you'll be running, but my ewg is silent until about 10-12psi. So I can drive normally, with good pick up in stealth mode. Idk how much air 28s flow, but it'll be more than the k04 at the same psi. My 76 flows about 100g/s more than the stocker at 20psi. Also, you could have you dump tube routed like mine where the only thing getting soot is the road.
I hear you though about not wanting shit or a ticket for vta. I havent got one and Ive been pulled over for screaming past a cop at 65 in a 35 (it was dusk, and I was watching the road). He just told me to 'fix your exhaust' lol.
The Following 2 Users Say Thank You to dougefresh_ For This Useful Post:
Fail_6 (05-31-2012), thehead (05-31-2012)
 Old 05-31-2012, 11:30 AM   #48
Fail_6's Avatar
@mczimer Wow thanks man I'll most likely take u up on that offer. That'd be awesome. And no, track time and dyno numbers are both before dp, fmic and e85 tune
@BigJimMs3 Dude see if you can get in touch with Alex. Need to get the numbers on this setup before she goes in. Also you coming to bay state tomorrow to get her welded?
@atvfreek Yea man, I mean that shit lol.....if the 28 isn't pulling the pu pu, 3071 (possibly gtx if necessary) is going in. So please freek this tune dude lol
@dougefresh_ I'm not taking any chances dude lol.....you know some of them go hard and I damn sure don't need anything else they can issue a citation for. Meant to ask about the turbine tech front mount. Did you install this or did you just stick with the diff mounts?
 Old 05-31-2012, 01:01 PM   #49
The TT mount is a diff mount, but for the front. It is also unnecessary, and I wouldnt bother. You definitely need a rear diff rear mount tho (referred to as a 'rear diff mount'). Other than that, Id Just get a RMM if you dont already have one.
Fail_6 (06-02-2012), helmetface (05-31-2012)
 Old 05-31-2012, 01:08 PM   #50
helmetface's Avatar
Posts: 5,685   (View Stats)
Groans: 219
VTA
SCREAMer Pipe
EWG
OR BUST!
The Following 4 Users Say Thank You to helmetface For This Useful Post:
atvfreek (05-31-2012), BigJimMs3 (05-31-2012), dougefresh_ (06-01-2012), Fail_6 (05-31-2012)
 Old 06-01-2012, 08:06 PM   #51
bwspeed's Avatar
Posts: 286   (View Stats)
bwspeed is the leader of the worldbwspeed is the leader of the worldbwspeed is the leader of the worldbwspeed is the leader of the worldbwspeed is the leader of the worldbwspeed is the leader of the worldbwspeed is the leader of the worldbwspeed is the leader of the worldbwspeed is the leader of the worldbwspeed is the leader of the worldbwspeed is the leader of the world
Neutral  :  -1 score
Nice set up! you plan on running e85? you will need it to pull them definitely. My cousins gtx3071 on 93 tune was dead even with our nator e85 cars.
Cobb AP, CNT TBE, Jbr intake CPE TMIC, JBR PMM & 88 Duro RMM, GTX 3071R turbo, Grimmspeed EBC, AEM methanol kit, 3 bar map sensor, Freektune
Moore Automotive 10/19/13
397whp 392wtq
bwspeed is offline   Reply With Quote
The Following 2 Users Say Thank You to bwspeed For This Useful Post:
atvfreek (06-01-2012), BigJimMs3 (06-02-2012)
 Old 06-01-2012, 11:45 PM   #52
Fail_6's Avatar
@bwspeed Not as nice as gtx 3071 lol....28 will do for now though. I did see the vid of the runs with the crew though. Definitely going to need e or meth, or possibly both shit lol. Justin has these damn k04's acting like they flow 400 g/s lmao.....Ran @BigJimMs3 tonight and he pulled a good 2-3 cars by 5th. Bitch claims I jumped, but he honks fucked up normally, but neither here nor there. All I know is I'm stepping on some puu when the big boy's in, simple as that
Dropped her at North Shore Machining this morning though to have the iwg flap welded. Last weld was shitty as evidenced by photos lol....hit boost and literally it blew that weak shit open. Think it was nickel or possibly a tig weld attempt. Guy plans to weld a plate a little ways in the hole, so rather than weld a seam, he'll be able to weld the top of the plate. Don't know if you can visualize, but it should be done by Monday and I won't have to try to describe the work
Updates to come
The Following 2 Users Say Thank You to Fail_6 For This Useful Post:
BigJimMs3 (06-02-2012), bwspeed (06-03-2012)
 Old 06-05-2012, 07:24 PM   #53
Fail_6's Avatar
Update time
Terboh is welded......muther fucker needed lots of pressure to get it done though.
I dropped it Friday, so dude legit had the weekend to finish. I call him yesterday and he's like ooo, mad legal shit man, didn't have time, I'll definitey get it done by tomorrow. Today is tomorrow, and again he says ooo man, had like 25 calls today, never know when the work will come, didn't have time. I'll try to finish before I leave; actually, give me a call tomorrow. So I said fuck that, I'm coming to get my shit, found another shop, and he says oooo, ok well I'll get it rolling for you now it'll be done by the time you get here. I get there, he's just starting and 30 mins later for $40, the iwg flap is permanently closed. BUT I digress . My bad. Back to build.
Weld looks legit. Don't think even if I was pushing 70 psi that thing is coming out. All in all, I'm pretty satisfied with the quality of the work. Should hold great, even if it's not pretty
Next will be mounts and 3 bar map sensor, and we should be golden. So, time to figure out a weekend to get this bitch in.
@Block8head
@helmetfail
@BigJimMs3
@dougefresh_
@atvfreek
@Lakespeed6
What are the schedules looking like?? I know I'm probably not going to have time until maybe end of June, early July
atvfreek (06-05-2012), BigJimMs3 (06-06-2012), Block8head (06-05-2012), dougefresh_ (06-05-2012)
 Old 06-05-2012, 07:48 PM   #54
Glad you got it taken care of. My schedule is pretty much a nightmare at this point, lol. I have the gf coming back in a few days, ma duke's bday down the Cape in 2 weeks, and a CPA exam on July 2. Oh, and I may have to drive to MD for a full week before that to learn an entire business and accounting system so I can do my consulting work at home when I get back. I'd plan on counting me out, but if somehow things work out and I'm free, I'll lend a hand.
GL
Fail_6 (06-05-2012)
 Old 06-05-2012, 07:54 PM   #55
Lakespeed6's Avatar
Posts: 2,403   (View Stats)
Well you're coming to my house on the 16th so any other weekend should work for me!
1990 Nissan Skyline GTR
1991 White BMW 325ic
The Following User Says Thank You to Lakespeed6 For This Useful Post:
Fail_6 (06-05-2012)
 Old 06-05-2012, 08:42 PM   #56
Block8head's Avatar
Posts: 4,345   (View Stats)
Block8head is the leader of the worldBlock8head is the leader of the worldBlock8head is the leader of the worldBlock8head is the leader of the worldBlock8head is the leader of the worldBlock8head is the leader of the worldBlock8head is the leader of the worldBlock8head is the leader of the worldBlock8head is the leader of the worldBlock8head is the leader of the worldBlock8head is the leader of the world
Groans: 206
Looks fucken tits D... we'll get the springs done this sat..
Fail_6 likes this.
O4 350z "Money pit"
06 MS6 "Gone"
BOSTON STRONG
Block8head is offline   Reply With Quote
The Following User Says Thank You to Block8head For This Useful Post:
 Old 06-06-2012, 06:29 AM   #57
BigJimMs3's Avatar
Groans: 76
Like i said im free any weekend besides this weekend. I can be parts bitch/drink bitch during this I mean i would help but to many cooks in one kitchen nothing will get done. So ill be a waiter
2006 Mazdaspeed 6
2007 Mazdaspeed 3
Bolt on's and tune
2015 Taurus S.H.O
Intake/Tune
Stock
The Following 3 Users Say Thank You to BigJimMs3 For This Useful Post:
atvfreek (06-06-2012), dougefresh_ (06-06-2012), Fail_6 (06-06-2012)
 Old 06-06-2012, 06:36 AM   #58
atvfreek's Avatar
Summer time is busy as fuck around my house, but I will try my best to be there. You need to get her on the dyno for a baseline ASAP
2010 Speed3-PTE5858
510hp420tq
11.321@129.93
BigJimMs3 (06-06-2012), Block8head (06-06-2012), dougefresh_ (06-06-2012), Fail_6 (06-06-2012)
 Old 08-22-2012, 08:39 PM   #59
dexter_5000's Avatar
Posts: 407   (View Stats)
dexter_5000 is the leader of the worlddexter_5000 is the leader of the worlddexter_5000 is the leader of the worlddexter_5000 is the leader of the worlddexter_5000 is the leader of the worlddexter_5000 is the leader of the worlddexter_5000 is the leader of the worlddexter_5000 is the leader of the worlddexter_5000 is the leader of the worlddexter_5000 is the leader of the worlddexter_5000 is the leader of the world
this thread needs some updates a couple of us made sure this didn't go down too bad today. i know he has some pics. as well as stories to tell.
@PartiAudiMazdarati @darkcherry
dexter_5000 is offline   Reply With Quote
The Following 2 Users Say Thank You to dexter_5000 For This Useful Post:
atvfreek (08-22-2012), darkcherry (08-23-2012)
 Old 08-22-2012, 11:07 PM   #60
Fail_6's Avatar
Whoo wee......this has been a helluva build...lot of fail, but we're damn near wrapped up.
First off, I'd officially like to recognize everyone coming by to lend a hand with this, specifically @Ihatefwd, @BigJimMs3, @darkcherry, @dexter_5000, who have came by just about every day since we began. I seriously would still be up shits creek without you guys, and like I said I can't express my gratitude enough.
Well we tried installing on the install meet I hosted on 8/19, and pretty much ran into nothing but fail lol....Jim and I managed to uninstall everything, intake, inlet, batt, etc save for 2 bolts, one stuck on the mani and 1 on the turbo which held the mani and k04 on. Fighting with it for the whole day, all we managed to do was strip it, which further sucked ass.
Good thing is we only needed a 14 mm socket to take all 14 bolts (10 on mani, 4 on turbo) off, but word of advice, BUY SOME PB BLASTER!!!!! And make sure you have a striped socket set handy in case the bolts dont want to budge. Another tip is if it's giving you a hell of a time, it's better to hit it with the pb and let it sit, rather than do what we did and fight something that's been on for the last 6 YEARS....
Regardless, PB'ed the shit out of it, and used the striped socket 14 mm and that bitch came right out. Below is the result of our work.
The Following 3 Users Say Thank You to Fail_6 For This Useful Post:
BigJimMs3 (08-23-2012), dexter_5000 (08-23-2012), snailD (08-22-2012)
 Old 08-22-2012, 11:25 PM   #61
snailD's Avatar
Posts: 3,039   (View Stats)
wait, so is it in?
 Old 08-22-2012, 11:29 PM   #62
Fail_6's Avatar
Sooooo, we started bolting everything in, and discovered a bit of an issue with the banjo bolt.
I'm not gonna lie, I just discovered what a banjo bolt is hahahaha......I'm man enough to admit that . For those clueless like myself, this is basically a hollowed bolt that is used route oil/coolant to the turbo. The smaller hole on top of the turbo is for the oil, and the larger holes on the front and rear are for the coolant. Issue is the stock k04 bolt didn't fit.....apparently atp makes a special "low profile" bolt (Banjo Bolt for Low Profile oil inlet - GT BB Turbos : atpturbo.com), many thanks to @Eighty8 for providing the link btw, but without this, the turbo would literally starve for oil, and eventually fuse itself together.
We tried buying a smaller bolt, which @Lakespeed6 (many thanks for the ride, tip on which hole was for the oil and coolant, and most importantly motivation hahaha) manually tried drilling it out, but the thread pattern wouldn't work. Basically until I got the bolt, we couldn't move forward, so that ceased any sort of possibility of the turbo going in for the meet. My bad fellas lol....
I let @Block8head know the bolt didn't fit, so he ransacked his garage and found the bolt below. Notice the threads on the larger numbers 9, and the other numbers 12. Also has the slight indentation like the one from atp. Mainly, the finer thread is what we needed.
dexter_5000 (08-23-2012), Eighty8 (08-23-2012), franz (08-24-2012)
 Old 08-22-2012, 11:34 PM   #63
snailD's Avatar
so he DID have it? lmao
The Following 2 Users Say Thank You to snailD For This Useful Post:
BigJimMs3 (08-23-2012), Fail_6 (08-23-2012)
 Old 08-22-2012, 11:43 PM   #64
Fail_6's Avatar
So the 6 is temp out of commission, and now I have to drive my gfs to work for Monday. How much more interesting would it make things if her car was out of commission as well?
I'm driving home and the muther fucking tranmission randomly starts slipping, and though I'm crusing at 65, the speedo says something very different rotflmmfao ....see below LOL
Pulled over, tried putting her in park, "crunch grind crunch"......fail. Tried putting her back in drive, and ending up rolling back on a damn hill into traffic.....epic fail. Tranny is officially trash. Asked @atvfreek about it and he concurred there's usually some sort of warning or sound or gear slip or sumthing before it's gone, but nope. Just died suddenly. Wtmf....
So I'm fucking panicking to figure how the hell I'm gonna get the car together on my day off Tues, and be ready for work by Wed. Luckily my man @darkcherry was able to get my gf to work @ 8:30 am, get me to see Ben and pick up the new Banjo, AND start getting shit installed.....honestly I couldn't express how big a look that was, and I will never forget it. Not to mention @Ihatefwd was going to drive me to the airport at fucking 2 am for a rental......Nator NE FTMFW in the clutch
The Following 5 Users Say Thank You to Fail_6 For This Useful Post:
atvfreek (08-23-2012), BigJimMs3 (08-23-2012), dexter_5000 (08-23-2012), franz (08-24-2012), snailD (08-23-2012)
 Old 08-23-2012, 12:20 AM   #65
Fail_6's Avatar
Ok so Tues John and I are wrenching on this thing like no tomorrow....literally from the time I dropped the gf to when she was out around 1 pm. Managed to connect the lines and line up the mani, but wtf now? It won't sit straight?
Apparently when we put the turbo on, we removed the motor mount, which by default put the block at an angle, so when we tightened down the oil return it was crooked, so it wouldn't play ball. Fought with it for a while, and eventually John left and I got some damn sleep until Rick's downstairs saying let's finish it up lol....Regardless him and @BigJimMs3 come by and we try to bolt her up. No progress is made, but I managed to drop 2 nuts in the engine bay. Fuck.
I recover one, but the other never falls out. It bothers me, but I figure wtf probably fell on something in the engine and I just didn't hear it fall.
@dexter_5000 comes out first thing this morning and we decide to take the mani off, and try to bend the oil feed to get it to sit correctly. I mention the nut I dropped, and that I might have dropped it on the exit side of the turbo, and he immediately says take it off, saving the time being safe isn't worth potentially destroying the turbo if it is there.....
Lucky thing, I unbolt it and twist it to the right, and would you know the FUCKING NUT FELL OUT!!!!!!!
WWWWWWWWWWWTTTTTTTTTTTTTTTTTTFFFFFFFFFFFFFFFFFFFFF FFF!!!
I was ready to bolt this bitch up, and would've had a fat ass nut sitting ready to destroy the fucking compressor......crysis averted, but holy shit. John comes by and we crank and get this bitch bolted in. Literally takes maybe an hr or so, including parts running.
Notice the glove on said turbo to avoid any further scares hahaha
Word of advice if you're having any fitment issues with the coolant feed, check the fitment of the turbo before you start moving the coolant hoses. I was about to move them out the bracket, but once I repositioned it I had plenty of space, as the pictures show. I did remove the black bracket @jrlms6 was hitting on by the inlet, and tightend down the two wires using the mount connected to the bracket and the bolts that were holding it in
The Following 8 Users Say Thank You to Fail_6 For This Useful Post:
BigJimMs3 (08-23-2012), darkcherry (08-23-2012), dexter_5000 (08-23-2012), franz (08-24-2012), jman46 (08-23-2012), Lakespeed6 (08-23-2012), snailD (08-23-2012), xI Leveler Ix (08-23-2012)
 Old 08-23-2012, 12:21 AM   #66
darkcherry's Avatar
Posts: 930   (View Stats)
darkcherry is the leader of the worlddarkcherry is the leader of the worlddarkcherry is the leader of the worlddarkcherry is the leader of the worlddarkcherry is the leader of the worlddarkcherry is the leader of the worlddarkcherry is the leader of the worlddarkcherry is the leader of the worlddarkcherry is the leader of the worlddarkcherry is the leader of the worlddarkcherry is the leader of the world
I just came across this thread now. Lol look forward to seeing this beast on the street once you get the final steps to this bt done. Let me know if you need anymore help.
mods:
Do wmi 50/50, freek tune 306hp/350tq.
blitz bov, cpe hpfp, tmic, excel nano sri, tip, blue duro rmm, 3" ss catted dp, 3" ss cs cat back exhaust, Cobb AP, sure short cut, counter weight, twm stage 1&2, ms cf shift knob, msd dh, autoexe rear brace, whiteline rsb, tt rear diff mount, awr pmm , winter=stock wheels w/winter tires / summer=18x8 adr hyp black wheels w/bfg force kdw, eibach sportline springs. Soon to come: bt, slotted rotors, cf fi hood
darkcherry is offline   Reply With Quote
The Following 4 Users Say Thank You to darkcherry For This Useful Post:
BigJimMs3 (08-23-2012), dexter_5000 (08-23-2012), Fail_6 (08-23-2012), Lakespeed6 (08-23-2012)
 Old 08-23-2012, 12:37 AM   #67
Fail_6's Avatar
This brings us to today. Thursday I mean.
Plan is to have baystate muffler fab me a reducer for the intake I have now so it will fit until I can buy a new one. Don't know when that will be since I still have to take care of previous tranny issues....
Also will have a dump tube fabbed exiting back into the dp. Figure I might as well replace the worm gears while I'm at, can't start skimping now. Many thanks to @Ihatefwd for running me around to pick this shit up and @slowms3 for picking up the gf btw.
Installing the 3 bar map sensor as well, bolt everything back up and possibly get it fired up finally.
I'm no expert on this shit, nor do I claim to be, so I'm not totally sure how to setup the ebcs or the map sensor to be honest. I'm guessing like below since there's no other tube that would fit the nipple on the inlet. I'm obviously going to do some more homework to know exactly how/where to install, but that's currently where we stand. Any and all tips/tricks are welcome/appreciated. Updates to come very soon.
BigJimMs3 (08-23-2012), darkcherry (08-23-2012), dexter_5000 (08-23-2012), jman46 (08-23-2012), Lakespeed6 (08-23-2012)
 Old 08-23-2012, 12:39 AM   #68
Fail_6's Avatar
Whoops forgot the damn pic haha
 Old 08-23-2012, 01:19 AM   #69
xI Leveler Ix's Avatar
Posts: 1,752   (View Stats)
xI Leveler Ix is the leader of the worldxI Leveler Ix is the leader of the worldxI Leveler Ix is the leader of the worldxI Leveler Ix is the leader of the worldxI Leveler Ix is the leader of the worldxI Leveler Ix is the leader of the worldxI Leveler Ix is the leader of the worldxI Leveler Ix is the leader of the worldxI Leveler Ix is the leader of the worldxI Leveler Ix is the leader of the worldxI Leveler Ix is the leader of the world
Groans: 75
Groaned at 31 Times in 20 Posts
Awesome Thread is Awesome! This is the setup I'll probably go with, Safe and RELIABLE BT. Not too much power to start breaking shit. lol
///VRM 2006 UNICORN Speed6 GT #02418///
STOCK AS OF 2015...
Old Stuff....
/// COBB AP /// AT HPFP /// 20psi Teck5 Tune by Ekanddsm /// JBR RMM /// HTP 3" Intake System /// SURE Dreadnaught and Juggernaut ///
/// Denso ITV22 /// Mystery Testpipe /// Fidanza Lightweight Flywheel /// Eagle Motorsports Full-Faced Clutch Upgrade ///
/// Megan Racing Springs /// SPC Adjustable Balljoints /// JBR TIGS, EGR Delete and Coolant Bypass ///
xI Leveler Ix is offline   Reply With Quote
The Following 2 Users Say Thank You to xI Leveler Ix For This Useful Post:
 Old 08-23-2012, 08:27 AM   #70
Lakespeed6's Avatar
Nice write up D wish I lived closer so I could have helped out more!
The Following 3 Users Say Thank You to Lakespeed6 For This Useful Post:
 Old 08-23-2012, 11:28 AM   #71
Fail_6's Avatar
Fuck.....been sitting here for the last 2.5 hrs trying to figure how to hookup the wastegate. I keep seeing diagrams like the one below, but there's no pressure fitting on the turbo, so I'm honestly not sure wtf to hook this thing up to. At this point, I'm debating just installing the wastegate alone with no ebcs, but I still have no idea how I'm setting these lines up. @Block8head @atvfreek @superskaterxes Any guidance here?
 Old 08-23-2012, 12:13 PM   #72
Lakespeed6's Avatar
you have to add a fitting into the silicon hose off the turbo outlet.
it comes with the ATP kit
btw way to not mention me you bitch!
atvfreek (08-23-2012), dexter_5000 (08-23-2012), Fail_6 (08-23-2012)
 Old 08-23-2012, 12:19 PM   #73
BigJimMs3's Avatar
Groans: 76
He did lol
2006 Mazdaspeed 6
2007 Mazdaspeed 3
Bolt on's and tune
2015 Taurus S.H.O
Intake/Tune
Stock
The Following User Says Thank You to BigJimMs3 For This Useful Post:
Fail_6 (08-23-2012)
 Old 08-23-2012, 12:24 PM   #74
atvfreek's Avatar
The atp turbos don't have a fitting on the turbo. So most people use a quick tap on the silicone part coming off the turbo to the hot pipe. Realistically all you need is any boost source though. So you can just splice at the bpv if needed
Freekn tappin
Fail_6 likes this.
2010 Speed3-PTE5858
510hp420tq
11.321@129.93
 Old 08-23-2012, 12:28 PM   #75
BigJimMs3's Avatar
Groans: 76
Freekn tappin
Thats the easiest way prob
2006 Mazdaspeed 6
2007 Mazdaspeed 3
Bolt on's and tune
2015 Taurus S.H.O
Intake/Tune
Stock
Fail_6 (08-23-2012)
 Old 08-23-2012, 01:23 PM   #76
Fail_6's Avatar
@Lakespeed6 Dude I did shout you out, check post #62 lol
@atvfreek So something like this?
This looks correct, but I'm guessing right now I should be fine running with just the spring pressure and ap tune?
802MS3 (08-23-2012), BigJimMs3 (08-23-2012)
 Old 08-23-2012, 01:35 PM   #77
atvfreek's Avatar
Where the fuck is the boost controller? That setup will probably make you boost to infinity
2010 Speed3-PTE5858
510hp420tq
11.321@129.93
The Following 5 Users Say Thank You to atvfreek For This Useful Post:
802MS3 (08-23-2012), BigJimMs3 (08-23-2012), Eighty8 (08-24-2012), Fail_6 (08-23-2012), StayBroke (08-25-2012)
 Old 08-23-2012, 01:41 PM   #78
atvfreek's Avatar
You have the perrin 3port correct?
Follow these instructions for EWG
http://www.perrinperformance.com/sha.../asmint720.pdf
Fail_6 likes this.
2010 Speed3-PTE5858
510hp420tq
11.321@129.93
 Old 08-23-2012, 02:02 PM   #79
Fail_6's Avatar
Damnit why couldn't I find this. This makes more sense. Just gotta find teh factory solenoid. Hopefully it's labeled........nah of course not
 Old 08-23-2012, 02:13 PM   #80
atvfreek's Avatar
It's attached to your k04.
2010 Speed3-PTE5858
510hp420tq
11.321@129.93
The Following 3 Users Say Thank You to atvfreek For This Useful Post:
802MS3 (08-23-2012), Fail_6 (08-23-2012), StayBroke (08-25-2012)
JBR Goodness!! EdgeAutosport.com EdgeAutosport.com 20 11-06-2012 10:51 AM
I Haz Teh Goodness Stealth01 MazdaSpeed 6 - Engine, Transmission & Driveline 33 09-18-2012 03:48 PM
More purple goodness. lvmazdaspeed3 MazdaSpeed 3/6 - Wheels & Tires 8 10-16-2009 02:31 PM
Thank goodness for cruise night Haltech Automotive News 0 05-10-2009 04:10 PM
Page generated in 0.74041 seconds with 34 queries
