![]() Join Date: Jan 2010 Location: charles co, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,295
(Thread Starter) | Not Ranked : 0 score Manley Rods Wiesco Pistons 9.5:1 CPE manifold Tial 44 gate (14psi spring) 5/6 port (currently not installed) soon full exhaust no cat porting intake 3.5 intake AP Tr10 intercooler ok so here is my probem. Broken in the motor and went into boost to see how the car felt. Boost rises to about 30+ psi.... WTH.... i saw it backed out. check the gate to make sure diaphram wasnt sicking went out again and boosted it again 30+ before i let off.... Change the gate to another known gate and boost still hit 30+ psi..... So we then bypassed the boost solenoid and ran a hose straight to the wastegate to eliminate the solenoid being the problem still boost to 30+ psi. With all these test and this high of boost we could never hear the wastegate open. Check the pressure from the compressor to the wastegate was fine. So we took it to the far extreme and took the gate completely off the car and we were still able to make 11 psi on with not gate on the manifold and nothing blocking the manifold.... WTH... Any suggestions..
__________________ Best time is 12.28@112 with a 1.68 60ft "GONE HUNTING BE BACK IN 11 SECS" 365HP and 333 TQ AT 20Psi gt3076 7 blade track weight 3220 street weight 3370 fully built motor//carrilo rods//cp pistons//ACT 6 puck//all mounts//gt3582 turbo//CPE manifold//ported intake//h&r coils//brembo brakes//tr10 I/C//accessport |
Groans: 60
| Not Ranked : 0 score Sounds like there is a casting problem in the manifold.. I'd look for an obstruction where the wastegate takeoff meets the collector.
| The Following User Says Thank You to SSinstaller For This Useful Post: | qtrmile beast (12-17-2018) |
(Thread Starter) | Not Ranked : 0 score I will take the gate off tonight and look in there.. i figured due to size of runners i wouldnt have to worry about this but i will investigate more tomorrow...thx
| Not Ranked : 0 score I don't think you'll find a defect in the manifold. Getting to 11 psi boost with the wastegate completely off is possible. The branch for the WG on the CPE mani is perpendicular to the gas flow from the runners so the turbine will get a good amount of air due to the inertia of the mass flow spinning the turbine alone even with the wastegate off. I'd just run the lightest possible spring you can find for the 44mm WG and take it from there. Using a 14 psi spring doesn't always mean you'll get 14 psi boost irrespective of other aspects of the construction.
__________________ Last edited by Tomas; 12-17-2018 at 05:36 AM. |
| The Following User Says Thank You to Tomas For This Useful Post: | qtrmile beast (12-17-2018) |
| Not Ranked : 0 score wow i'm surprise an ewg generate so much creep. Between uncontrolled 30+psi and 11 psi, you could probably find a spring to creep in between ? What is the turbo ?
| Not Ranked : 0 score Being able to run 11psi with a gaping hole in your manifold tells me you don't have much exhaust pressure in your manifold and/OR, as stated above, exhaust flow favors the turbine housing by design or obstruction and will shoot right on past the WG port. Exhaust pressure and boost pressure work together to push the WG open. Which is why EWG have the port on the tophat too. Applying boost pressure to the tophat ensures the WG stays closed no matter how much exhaust pressure you have (even with a very weak spring) and it will only open when the EBCS tells it to. So you could try a very weak spring and switch to a 4-port setup and see what happens.
| The Following User Says Thank You to Fstrnyou For This Useful Post: | qtrmile beast (12-17-2018) |
The turbo is a 5858... also i think this this is not the correct definition of "CREEP"
__________________ Best time is 12.28@112 with a 1.68 60ft "GONE HUNTING BE BACK IN 11 SECS" 365HP and 333 TQ AT 20Psi gt3076 7 blade track weight 3220 street weight 3370 fully built motor//carrilo rods//cp pistons//ACT 6 puck//all mounts//gt3582 turbo//CPE manifold//ported intake//h&r coils//brembo brakes//tr10 I/C//accessport Last edited by qtrmile beast; 12-17-2018 at 12:38 PM. Reason: MSF Database - Automerged Doublepost | |
I'm curious to know how it goes and if you can find a spring to come closer to your boost goal.
__________________ Mazda for life...or until i can afford something better... 2007 rusted Speed6... Forged with meth and a 3076 in progress... 1993 Ford Probe KLZE 143dB 2012 Mazda3 Gs-sky 6.5l/100 when transporting speed parts 1989 GM 6.2 diesel pickup Wife drive 2010 CX7 2007 speed3 burned (i'm proud to ran 12.7s with it) ...Because French Canadian... If you check for leaks and you didn't made a test under compressor pressure, you aren't done checking for leaks.... | |
![]() Join Date: Feb 2012 Location: Li ny
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,290
Groans: 74
| Not Ranked : 0 score So with my 14 psi spring i was creeping to 21 at rl with the 5858jb with the ported s cover FWIW. Have you tried to run the gate with no hose? How are the hoses ran? When i did my first pull i messed up the routing of the hoses and hit 30psi just like you. Fixed them and i was good to go.
__________________ MECP 2012 BM PTE 5858 Vband .82ar // Tial EWG // CPE Mani // 3" Turboback // JBR Under route hot pipe // MD ST mani+spacer with PI // Siemens 60lb Injectors // Splitsecond inj controller // JBR 88 duro RMM/TMM // MD PMM // TWM Full replacement shifter // JBR CC // Autotech FP Internals // SP63 SB/Manley rods SP63 pro pistons // Treadstone FMIC TR824 // FoMoCo Tranny Jizz // South Bend Clutch Stage 3 enduro// GFB Respons // FJ 4" intake // WMI 100% VPM1 // Air Lift 1000 in rear // N2MB WOT BOX Rfinkle tune in progress The Brooklyn beater: 2005 1.8 Auto Sentra |
| Not Ranked : 0 score You can pressure test it just to confirm connections and spring choice with a portable tank or compressor and a regulator. A boost gage connected with a T to get a more accurate reading and figure out at which boost pressure the gate is really fully open. This would quickly point out plumbing or spring problems. There is many ways to plumb it but personally, i would keep it simple to make it work first. https://www.onpointdyno.com/boost-co...ht-save-money/
__________________ | |
What manifold do you have? If not a cpe manifold this might be a irrelevant conversation sorta. Creep comes from the inability to slow the exhaust flow to the turbine wheel down hence wastegates job.. As for the routing of my hoses.... when it first happened i decided to do process of elimination, the boost source my be clogged, so i pulled the nipple off and look in there. That turned out to be fine. Replaced the nipple. Routing was nipple to #3 port on EBCS and then from there #1 to the side of the wastegate. Didnt work, so for shits and giggles i put it on the top port didnt work...Then i ran a hose from the compressor housing to the bottom of the wastegate to eliminate the EBCS as the problem Didnt work....then to make sure i am getting pressure from the compressor to the wategate i put a manual boost gauge in between the comepressor and wastegate.. Got the 30+ i was seeing on my AP... Connected the manual boost gauge to the bypass vacuum source still got 30+ psi... Had another wastegate from my car( remember this is a customers car that i am having a problem with) Also rememebr i too have a CPE manifold with a gt35r on it currently with no issues. Installed that gate because i thought maybe i in stall the spring in the customers gate wrong or maybe i pinched the diaphram during install of the cap. STILL HITTING 30+ psi Now we are the no wastegate test: Was testing if we got boost then that either does one or two things. Leads to a manifold defect or what the other guy was saying about air flowing past the wastegate hole. If very low 1-3 psi or no boost then its a wastegate issue. Results 13 psi with no gate on there... and now we are here.....got it
__________________ Best time is 12.28@112 with a 1.68 60ft "GONE HUNTING BE BACK IN 11 SECS" 365HP and 333 TQ AT 20Psi gt3076 7 blade track weight 3220 street weight 3370 fully built motor//carrilo rods//cp pistons//ACT 6 puck//all mounts//gt3582 turbo//CPE manifold//ported intake//h&r coils//brembo brakes//tr10 I/C//accessport Last edited by qtrmile beast; 12-18-2018 at 08:21 PM. Reason: MSF Database - Automerged Doublepost | |
Groans: 74
I have port 2 on my GS to the bottom port of my tial, port 3 to the compressor housing and port 1 vta. The top of the wastegate is vta. I would take the wastegate apart and see if something is jammed up inside. Push on the valve and make sure it actuates. Spring pressure shouldnt be 30psi unless the gate isnt opening because it is binding.
__________________ MECP 2012 BM PTE 5858 Vband .82ar // Tial EWG // CPE Mani // 3" Turboback // JBR Under route hot pipe // MD ST mani+spacer with PI // Siemens 60lb Injectors // Splitsecond inj controller // JBR 88 duro RMM/TMM // MD PMM // TWM Full replacement shifter // JBR CC // Autotech FP Internals // SP63 SB/Manley rods SP63 pro pistons // Treadstone FMIC TR824 // FoMoCo Tranny Jizz // South Bend Clutch Stage 3 enduro// GFB Respons // FJ 4" intake // WMI 100% VPM1 // Air Lift 1000 in rear // N2MB WOT BOX Rfinkle tune in progress The Brooklyn beater: 2005 1.8 Auto Sentra | |
Thank you for your comment but i addressed this in the first post...."changed the gate to a known working gate"...
__________________ Best time is 12.28@112 with a 1.68 60ft "GONE HUNTING BE BACK IN 11 SECS" 365HP and 333 TQ AT 20Psi gt3076 7 blade track weight 3220 street weight 3370 fully built motor//carrilo rods//cp pistons//ACT 6 puck//all mounts//gt3582 turbo//CPE manifold//ported intake//h&r coils//brembo brakes//tr10 I/C//accessport | |
![]() Join Date: May 2014
Rep Power: 0 ![]() Thanks: 0
Hate to bring this back but... I'm having the EXACT same problem. Did you find any resolution to this? I have gone through all of the tests you did including removing the wastegate COMPLETELY from the manifold and I'm actually getting 16psi by 6500rpms.... through just a giant hole in the manifold LOL! CPE turbo manifold with PTE Vband entry 5862. With wastegate on and 5psi spring I max out fueling by 6k rpms at 25psi having to let off With NO SPRING in the wastegate I still hit 24psi by 6500rpms With NO WASTEGATE on the manifold I hit 16psi by 6500rpms and it was still climbing I've been going back and forth with CPE's head engineer and he of course keeps telling me this isn't possible and that it's my wastegate. I sent him the logs without having a wastegate on the car, but haven't heard back yet. I'm hoping it's a casting defect or something, but I have another manifold lined up to swap out. I've been fighting this for months and now at least people can't say I'm losing my mind lol! Last edited by Fah-Q; 01-31-2019 at 07:53 PM. | |
| Not Ranked : 0 score It is very strange that Tomas get good results while you aren't, can you see anything in the casting that could restrict the path to wg ? I'm curious to hear about CPE feedbacks...
I've recently tracked down as many cpe/ 5862 combo running speed people as possible and almost all but one have told me they have enough boost creep that they can't have a di only tune.. Basically the lowest boost told to me besides the one guy claiming 14 psi to redline was 26psi by 6200. I'm sure if he revved higher that would keep climbing. Some might say who cares just turn it up, but there's other things this hinders. What if you have a PI or meth issue and your fail safe can't drop boost? I digress... Regardless when I had my manifold off i didn't notice anything out of the ordinary but I also didn't engineer it so who knows. I'm still waiting on a response from CPE. In the mean time I have no choice but to just roll with it and hit 30+ psi. Just hoping op maybe made some headway on the issue as I'm at a total loss now lol. I'll report back with what the engineer says about my logs and new info on the issue. | |
| Not Ranked : 0 score I was reffering to few post above yours where Tomas say it work fine from 18-30psi but i have no clue about the details...
Or better yet... CPE manifold w/ PTE vband entry in general I guess, but CPE still claims this has never happened. Last edited by Fah-Q; 02-01-2019 at 02:30 PM. | |
| Not Ranked : 0 score ok and probably that any change to route more flow into the WG will reduce flow efficiency into the turbine....This also tell that your 5862 is easy to spin... I get your point about fail safe systeme but even if it isn't the solution, you can still install a boost fuse. Instead of bypassing turbine flow, you can exaust/recirculate boost by the BPV. the Stratified GA do this or make your own with an EBCS connected to the BPV vaccuum port. When triggered, the solenoid valve let any pressure to escape from the BPV head to let it open under boost. If you hear the BPV opening under boost you will know something is wrong and probably lift off the pedal as a reflex...You can even trigger it by overboost too.
Hopefully the engineer will get back with me, he's usually pretty quick to respond or if OP found what was going on that would be awesome too! | |
![]() Join Date: Jun 2012
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 242
| Not Ranked : 0 score I have a custom DP, CPE mani with 6062 turbo and Precision 46mm ewg on a 15psi psi spring, it seems to start at 18psi after spool slowly goes to 19 at 5500rpm and stays at that until 7000rpm on a base map. I did just receive a map targeting 22psi but something in my clutch area that sounds like a lunched throw out bearing has made it un driveable until we can get the gear box out and see what's going on FML Will be interesting to see what the actual cause of the guys going to well over 20psi, that's a massive over shoot.
__________________ Gen 2 2012 - Precision 6062 Turbo - CPE Exhaust Mani - PTE 46mm EWG - 2NV Industries built Forged bottom end - PNP Head - JMF V2 Intake Mani- Custom DP UR Cat Back - HTP 4 inch intake - TR8 FMIC - Custom FREEKTUNE METH Port Injection - Cobb 3 port EBC- Autotech internals - FREEKTUNED. |
If mine would just stay at or below 20 I'd do a fucking cartwheel lol.. Hopefully Monday CPE will respond to my logs and all. We'll see what they say. Zac | |
![]() | | #24 | ![]() |
__________________ Gen 2 2012 - Precision 6062 Turbo - CPE Exhaust Mani - PTE 46mm EWG - 2NV Industries built Forged bottom end - PNP Head - JMF V2 Intake Mani- Custom DP UR Cat Back - HTP 4 inch intake - TR8 FMIC - Custom FREEKTUNE METH Port Injection - Cobb 3 port EBC- Autotech internals - FREEKTUNED. | |
![]() | | #25 | ![]() |
![]() Join Date: Feb 2012 Location: Australia
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 250
Groaned at 7 Times in 3 Posts
@Fah-Q; - Did you happen to shine a torch into the wastegate entry pipe from the manifold to check the casting where the five pipes join?
__________________ - 2008 Gen1 MS3 Cobb AP ~ Autotech HPFP Internals ~ HTP 3" Intake ~ Custom Testpipe ~ Cobb RSB ~ Sticky Tires. Self tuned on E85 | |
![]() | | #26 | ![]() |
| Not Ranked : 0 score it's a 3 bar that is scaled properly, I thought of that as well at first. My 120+ idc backs up that I'm definitely hitting some serious boost lol. |
![]() | | #27 | ![]() |
I offered to take the manifold off and bring it down the CPE to look at since they're really only a an hour or so away from me now and they basically told me to eat a dick lol. They told me to weld a wastegate to my turbine housing ![]() Essentially they "check every manifold before it's shipped and there's no possible way our manifold is causing the creep, you need to go with a bigger turbine housing or weld a wastegate to the one on there"... I've had a lot of people send me logs, some with and without creep. The ones without boost creep I noticed the throttle plate was closing considerably. I brought this up to CPE and they were like "oh that's a great idea" So either way, guess it's just band aid and move on LOL | |
![]() | | #28 | ![]() |
You'd think one could rely on the wastegate to be able to control boost without resorting to that hey?
![]() | | #29 | ![]() |
| Not Ranked : 0 score Using throttle to control boost is a bandaid for a bad manifold design or possibly poor quality control of the product.
![]() | | #30 | ![]() |
![]() | | #31 | ![]() |
| Need help with a boost problem | Jmoore | Gen2 MS3 General Discussion | 2 | 12-02-2017 02:03 PM |
| Boost problem | BooSTed_Hatch | 2010 MS3 - Troubleshoot/Diagnostics | 2 | 07-02-2014 06:23 AM |
| Need help controlling boost | Mchart | 2010 MS3 - ECU Computer Tuning | 64 | 09-26-2012 08:05 PM |
| MS3 Boost Controlling | starscream | MazdaSpeed 3/6 - Turbo Induction | 11 | 03-28-2011 01:58 PM |
| Controlling boost spike? | booya620 | MazdaSpeed 3/6 - Turbo Induction | 0 | 10-19-2008 06:32 PM |
