Like Tree3Likes
  • 2 Post By Lex
  • 1 Post By 86AmishMs3
 Old 04-10-2012, 10:05 PM   #1
Default PSA: Internal Wastegates and ATP turbos
**This applies to all MS3/MS6 years and models. Really this applies to all turbo cars.**
Alright boys and girls. I have seen this happen so many times now that I feel it should be common knowledge:
The ATP turbos with internal wastegate (WG) will creep. Badly. Boost will be hard to control and keep below 23-24 psi in most setups and this pegs the stock MAP sensor and is not a desirable situation in terms of safety and control.
A principle that everyone should be aware of is that a boost controller (MBC or EBC) can only INCREASE boost from what the turbo does on spring pressure alone. If boost creeps up to 24psi just on spring pressure, not matter what controller you have on there, it will NOT lower your boost.
What is boost creep?
It is the phenomenon where the wastegate can't flow enough of the exhaust gases to keep the turbo from spinning faster and increasing boost. If the WG can't flow enough of these gases, they will start going through the turbine. This in turn spools the turbo faster causing more boost. More boost = more exhaust = faster turbine = even more boost. You see, if the WG is inefficient, poorly flowing, and too small (and the internal ATP ones are big time) it will not allow you to properly control boost even though the actuator has a spring in it that is set for low boost (such as 8 or 14 psi).
Here are the things that will make creep worse with an inefficient WG:
- A big intake
- A nice open exhaust (no cat, aftermarket downpipe)
- A well flowing intercooler
- Cold weather
- Higher gears will generate more creep
- High WG arm preload
Here's how to fix it. The best fixes are done before the install
- Run an EWG. These are large and generally have no issues with creep.
- Port the stock WG hole and the path that gases travel to get out through it. Port this hole so that the flapper door seals it, but it is just a few mm smaller than the flapper door. Remember to remove the turbine housing when doing this - you don't want metal shavings in the turbo
If you have already installed the turbo, here are things that may help:
- Run a smaller intake (COBB SRI versus 3.5 inch)
- Run a cat, or restrict the exhaust (I know this is counter-intuitive to power but it helps)
- Reduce preload on the WG arm
- Feel comfortable with running 24 psi and buy a 3 bar MAP sensor and get a good tune
- Buy a boost gauge and keep an eye on boost!
While we're talking boost control and big turbos - the most consistent and easiest method to raise boost is through an MBC. This is after you have taken control of creep. The GS EBCS is ok in some cases, and in some it will cause boost oscillations that are sometimes hard to tune/smooth out. This can increase the difficulty and time of the tune.
An important note on choosing wastegate spring pressure. Choose the spring that is closest (but under) the boost you plan to normally run. This will result in the best response and control. A boost controller becomes less effective at controlling boost levels that are much higher than spring pressure. Aim to not exceed 2-2.2x (this is a maximum) wastegate spring pressure via a boost controller.
Below is a datalog showing a classic example of ATP boost creep. Notice that the WGDC is at 0 - meaning the ECU is doing all it can to reduce boost, and the MAP sensor is pegged.
TiGraySpeed6 and thehead like this.
The Following 58 Users Say Thank You to Lex For This Useful Post:
06Speed6 (04-11-2012), 6oost3d (04-11-2012), 865ms3 (04-11-2012), 86AmishMs3 (04-12-2012), ak_spray (04-11-2012), atvfreek (11-20-2013), BlueStreak (04-12-2012), Broxer (04-11-2012), charlesfist (04-13-2012), Dahouse702 (04-11-2012), dereeek (04-10-2012), Dmurray06 (04-11-2012), dot584 (04-10-2012), Easter Bunny (04-11-2012), forever_skyline (04-13-2012), ganque (06-04-2012), GLORIFIEDBOZO (04-11-2012), h.h.sk1nny (04-11-2012), helmetface (08-11-2012), IshiKage (04-10-2012), ItsNox (07-17-2013), jman46 (04-12-2012), jracer (04-11-2012), MattJackson86 (03-28-2013), maxspeed3 (09-03-2012), Micha (05-27-2012), Mistersix (03-22-2013), Monotonous ONE (04-12-2012), mrmonk7663 (04-13-2012), Ms3_Miami (04-14-2012), nighthawk358 (04-11-2012), Nliiitend1 (04-10-2012), Outlaw4shrt (12-13-2013), outshined (04-12-2012), p057 (04-12-2012), paveltol (04-12-2012), Pseud0logik (04-12-2012), redboat (11-21-2013), RobT2009 (08-02-2012), Seatime3 (05-12-2012), silvapain (04-10-2012), skiptowncat (06-15-2013), stokes620 (03-16-2013), thehead (04-11-2012), TiGraySpeed6 (04-11-2012), Toddy22587 (06-02-2012), Tokay444 (04-12-2012), torquemaniac (12-16-2013), trancehead (02-18-2014), TriO (04-10-2012), triplejumper18 (04-12-2012), TWOptSL0W (04-12-2012), uncorked11 (04-12-2012), Vader (04-12-2012), warlord (04-13-2012), wolly6973 (04-12-2012), xhymer (04-10-2012), xxdjfate76xx (04-12-2012)
 Old 04-11-2012, 11:57 AM   #2
TRSpeed's Avatar
Posts: 1,537   (View Stats)
TRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the world
Great write up Lex
Sent from my DROID4 using Tapatalk 2
2008.05 True Red Mazdaspeed3
Lex Tuned
GTX3071r | 38mm Tial WG | Hallman MBC
Cobb AP E85 30% |CPE Big MAF | CPE Big TIP | CPE FMIC | SS Ex Mani | CPE Catted DP | CNT CBE | CPE Triple Gauge Pod |
Autotech HPFP Internals | Denso ITV22 | TS BPV | TWM ShortShifter | JBR Shifter Bushings | JBR 88 RMM |
Razo Heavy Shift Knob | 20% Tint | DDM 55W HID | Hankook Ventus V12 | H&R Springs
TRSpeed is offline   Reply With Quote
 Old 04-11-2012, 09:41 PM   #3
Robust Mongoloid
09Speed3Z's Avatar
Groans: 399
Sticky.
Go.
Now.
______________________
Built By NATOR
Tons of Ricer Mods
 Old 04-12-2012, 03:16 AM   #4
TWOptSL0W's Avatar
Posts: 3,289   (View Stats)
Groans: 125
just a note on internal wastegates and their wastegating power
Always gotta 1-up me huh
Edit: you CAN'T run 24 psi without creep with free flowing exhaust and big intake. It will still creep. I creep to 29-30 psi at redline at some points
 Old 04-12-2012, 04:12 AM   #5
86AmishMs3's Avatar
Posts: 3,639   (View Stats)
Groans: 338
Good write up. Like I've told everyone port the wastegate it's so easy to do when the turbo is off the car. Buy a dremel and get to work. If you have better shop tools then use those like I did. Even with a moderate porting job and catted downpipe I creep to 18 psi @ RL with 15psi spring pressure. I can deal with 3 psi.
Before I went catted downpipe I was seeing around 25psi @ 6100 which was crazy. I'm pretty sure even if I agressively ported, with a big intake, high flow intercooler, and no cat I would still creep fairly well.
IWGs are just finicky. In my case down right frustrating and was debating on going EWG. But with the right parts and know how I was able to manage it...and now my car runs perfect.
Also as an add on Lex I would put something in about spring pressure and boost response.
Spring pressure determines boost response. The closer the spring pressure boost to the desired set boost pressure the better response you'll have.
When I first got this turbo and installed it was soo loose at like 6psi and it would actually bind in the open position. I preloaded it all the way and still was at like 7-8 psi and boost response was horrible. It wasn't until 5000+rpms that I would reach 20psi. This is typical in a very overdamped process. The MBC can only multiply the effects of a wastegate spring pressure by so much.
So like me and others have done...we've had to cut the wastegate arm down. You may have to do this in your case. I ended up cutting 3/4" off mine. It would have been better to contact ATP and get the correct spring.
When you cut the wastegate actuator arm and you have to use force to get the arm back on the flapper you are extending the spring and effictively increasing the spring pressure. This does come at a cost though. By cutting the actuator arm to increase spring pressure instead of swapping wastegate cans you run the risk of an underdamped process and getting mechanical spike. This spike will show up with a MBC or EBC. In the MBC you will see one spike and then it settle. The EBC will try to correct the spike, overcorrect and create boost ocillations.
I've had every problem in the book with my ATP turbo. Through fail I've gained a better understanding and have been able to cure and manage the flaws of an IWG.
thehead likes this.
Current: N54 135i
DCI, DP's, Exhaust, FMIC
12.3@122
2009 Mazdaspeed 3:
GT3076 - Corkey tuned
390whp/400wtq
12.8@114
Sold
The Following 6 Users Say Thank You to 86AmishMs3 For This Useful Post:
JasonMzdSpd3 (05-12-2012), Lex (04-12-2012), Outlaw4shrt (12-13-2013), RichieRichness (03-05-2013), thehead (05-30-2012), wolly6973 (04-12-2012)
 Old 04-12-2012, 04:47 AM   #6
v8 convert
p057's Avatar
Posts: 1,782   (View Stats)
p057 has disabled reputation
Groans: 220
Not to be a naysayer or anything, just another point of view:
I "recently" purchased and installed an ATP GT3071r. No sign of boost creep, but im feeling its more my BPV leaking just a small amount and almost stabilizing the pressure.
But could it be that either some of these are ported properly now or just new ones are? There are people buying new turbos with the same excessive creeping they did before?
p057 is offline   Reply With Quote
 Old 04-12-2012, 05:03 AM   #7
TWOptSL0W's Avatar
Groans: 125
Smaller turbo less creep. 3076 will give more creep
 Old 04-12-2012, 06:37 AM   #8
v8 convert
p057's Avatar
Groans: 220
Ahhhh, i just read your post @TWOptSL0W
Originally Posted by TWOptSL0W View Post
tl;dr
atp iwg is good for 20-22 psi but not more or less
I am sticking at 21PSI tapering to 19.8... i see your point.
However, i am not putting the boost higher because i promised g/f and myself no more racecar and halt modding for now................, at least until i move away from florida (a year from now)
it will be interesting to see how it reacts when i decide to upgrade MAP sensor and up the boost to ~25.
 Old 04-12-2012, 10:53 AM   #9
driver311's Avatar
Posts: 1,769   (View Stats)
Running a high flow magnaflow 3 inch cat and atp 3 inch intake and I had no creep on my gtx3071 with no porting. I had control all the way to 13psi. ONce the cat came off the car creeped bad. So in other words a nice hf cat will help the issue ALOT if not entirely eliminate it. With minimal loss in power maybe 3-5whp at most. Oh and the car will sound much better in my opinion. The car will have more of a deep groal vs any rasp.
good write up and just my .02. LOL
Mazdaspeed
The Following 3 Users Say Thank You to driver311 For This Useful Post:
802MS3 (04-13-2012), 86AmishMs3 (04-12-2012), JasonMzdSpd3 (05-12-2012)
 Old 04-13-2012, 01:42 PM   #10
uncorked11's Avatar
Posts: 1,238   (View Stats)
Groans: 165
This turbo was received around the 4th of April, installed last weekend it will be ported very soon or swiched to EWG. I heard ATP "fixed" the issue and rolled the dice only to lose, for future buyers after all the ass pain to install, just take the extra time to port first, I wish i did.
New....Camaro SS/RS
Stocked out selling parts.
2011 Black MS3
2006 Jeep Wrangler
-20 grand of Shit
The Following 2 Users Say Thank You to uncorked11 For This Useful Post:
JasonMzdSpd3 (05-12-2012), Lex (04-13-2012)
 Old 04-13-2012, 03:21 PM   #11
2zz mr-s
dooderek's Avatar
Posts: 5,119   (View Stats)
Groans: 239
moving to teh stickying
The Following 2 Users Say Thank You to dooderek For This Useful Post:
ak_spray (04-13-2012), Nliiitend1 (04-16-2012)
 Old 09-30-2012, 07:20 PM   #12
Last_Loser's Avatar
Posts: 739   (View Stats)
Last_Loser is the leader of the worldLast_Loser is the leader of the worldLast_Loser is the leader of the worldLast_Loser is the leader of the worldLast_Loser is the leader of the worldLast_Loser is the leader of the worldLast_Loser is the leader of the worldLast_Loser is the leader of the worldLast_Loser is the leader of the worldLast_Loser is the leader of the worldLast_Loser is the leader of the world
So I just bought the gtx 3076 r with a 14 spring in it are they still having a problem with this or has it finally been fixed? Would the Cobb actuator arm help this any?
Under Construction
Last_Loser is offline   Reply With Quote
 Old 09-30-2012, 08:03 PM   #13
Read son.
uncorked11 (09-30-2012)
 Old 09-30-2012, 08:10 PM   #14
86AmishMs3's Avatar
Groans: 338
Port the wastegate....it's extremely easy to do. You'll kick yourself if you have issues and didn't just take a couple simple steps. If you have a catted downpipe I wouldn't worry as much. If you're catless....then definitely port as much as possible.
Current: N54 135i
12.3@122
2009 Mazdaspeed 3:
390whp/400wtq
12.8@114
Sold
 Old 09-30-2012, 08:13 PM   #15
7mileshome's Avatar
Posts: 350   (View Stats)
7mileshome is the leader of the world7mileshome is the leader of the world7mileshome is the leader of the world7mileshome is the leader of the world7mileshome is the leader of the world7mileshome is the leader of the world7mileshome is the leader of the world7mileshome is the leader of the world7mileshome is the leader of the world7mileshome is the leader of the world7mileshome is the leader of the world
No its not fixed, you have to port it. Have GTX, IWG ported and holds commanded WGDC till redline. 15psi
port
it
2012 Mazdaspeed3 LSM
Should have gotten a speed6
2008 Mazdaspeed3 GT Black Mica [sold]
Built motor, Etc.
383 hp 401 tq GTX2867R @ 25 psi
7mileshome is offline   Reply With Quote
 Old 09-30-2012, 08:15 PM   #16
Last_Loser's Avatar
Yeah I'm catless with grimmspeed ebcs
Under Construction
 Old 03-19-2013, 07:13 PM   #17
Resident Baus
duappleganger's Avatar
Posts: 504   (View Stats)
duappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the world
Groans: 34
Groaned at 56 Times in 18 Posts
I'm going to be installing an IWG GTX3071r at the end of april and ill definitely be porting it. I'll post some before and after pics and maybe a how-to.
2011 Black Mica MS3
FREEKTUNE (On hold 'til EWG) ATP GTX3071R IWG (soon to be EWG) Full Race exhaust manifold CP-e whale peen + 3.25 in. intake
COBB EBCS + Downpipe + BPV + AP Stage 2 Corksport CBE + Brake Pads Ultimate FMIC NGK Iridium IX @ .28 DDM HID 6000k
Autotech CDFP Internals JBarone EGR delete, TB + IM gaskets, SSP + Shift Anchors, 88D RMM, 70D passenger + tranny mount, RSB, and OCC
HTP battery box TSW Nurburgrings 18x8.5 MBR w/ Michelin Pilot Super Sports 235x40x18 +45 Goodridge SS Brake Lines
Installation TBD: H&R springs + Koni yellow shocks + struts
duappleganger is offline   Reply With Quote
 Old 11-19-2013, 05:40 PM   #18
speed34win's Avatar
Posts: 21   (View Stats)
speed34win will become famous soon enough
Someone said that blogger turbos have more creep, I have a gt3582r from ATP and I have no creep but my boost at 5700 I think it is will just drop to like 7psi and it looks like it trys to build back up but it just keeps fluctuating. Anyone got any ideas and I am almost certain that I don't have a boost leak.
speed34win is offline   Reply With Quote
 Old 11-19-2013, 06:07 PM   #19
Sounds like a boost control issue or wastegate actuator issue. Do you have the 7psi wastegate spring?
What are you using to control boost?
 Old 11-19-2013, 08:31 PM   #20
speed34win's Avatar
I have had both 7 psi and I think its 14 and got tuned on both and still the same problem and I have a 3 port grimmspeed electronic boost controller
 Old 11-19-2013, 09:22 PM   #21
What does it do on spring pressure alone with the boost control solenoid bypassed?
 Old 11-19-2013, 09:25 PM   #22
speed34win's Avatar
Not really sure it should hold any boost I would assume because of the way the waste gate duty cycle is tuned with a electronic vs stock but I will check tommorow haha
 Old 11-20-2013, 09:02 AM   #23
Just run a single hose from the boost source to the WG actuator with no solenoid in the way. Just mechanical spring pressure.
PSA: Internal Wastegates and ATP turbos Lex 2010 MS3 - Big Turbo Builds 0 04-10-2012 10:31 PM
just a note on internal wastegates and their wastegating power TWOptSL0W Mazdaspeed3/6 General Discussion 2 04-04-2012 09:11 PM
For all of those with BNR turbos.. numbnuts22715 MazdaSpeed 3/6 - Turbo Induction 66 01-09-2012 10:37 AM
ATP 1 Bar iwg turbos I Love Brownies MazdaSpeed 3/6 - Turbo Induction 93 08-30-2011 01:28 PM
What about these turbos? trigun22 Mazdaspeed3/6 General Discussion 7 12-01-2010 05:50 AM
Page generated in 0.43325 seconds with 34 queries
