Like Tree11Likes
 Old 11-13-2015, 09:23 AM   #1
mikelevi's Avatar
Posts: 362   (View Stats)
mikelevi is the leader of the worldmikelevi is the leader of the worldmikelevi is the leader of the worldmikelevi is the leader of the worldmikelevi is the leader of the worldmikelevi is the leader of the worldmikelevi is the leader of the worldmikelevi is the leader of the worldmikelevi is the leader of the worldmikelevi is the leader of the worldmikelevi is the leader of the world
Default And the record begins with a song of rebellion...
What the fuck did I get myself into? So long story short. Last car payment is this month so I figured I'd kill it. Had a smoking K04 after just 40K miles on it. Fed up, did a compression test at 180 across all 4 and figured what the hell; Might as well upgrade the turbo while I'm replacing it.
I was originally going to go BNR S3, but the GTX3076r came up for a steal and the devil on my shoulder wouldn't go away.
So this is where it stands so far:
ON:
HPFP internals
M2 DP w/stock CBE
AP v2
Duro 80 Trilogy mounts
NGK IX .026
Passport Boost Gauge
3 Bar MAP w/harness
EGR Delete and Block off
JBR OCC V1 w/check valve
Forge BPV
Slotted Stoptech Rotors
Bilstein HD Shocks
H&R Springs
Ordered and Paid for:
GTX3076r EWG 38mm w/Screamer Pipe
CP-e Seals
GS EBCS
Freektune 3.5" intake with BT Tune option
JBR TB Therm gasket and Bypass
JBR Intake Therm gasket
My engine is currently torn apart. While fixing an oil leak on the HPFP extension housing I decided to install the EGR delete and OCC. I snapped the fucking retainer clip on the PCV valve so I figured Id just pull the Intake off and replace it much easier. Then I figured while that was off, I might as well clean the valves and install new injector seals. Well I decided to be a cheap ass and not pay for overnight or 2 day shipping so the seals wont be here till Wed. Might as well PnP the mani and VTC Delete while I wait!
I'm in way over my head, but at least its exciting. I plan to run an e85 mix as the pump is one block away. I have not decided on an IC option; if its going to be upgraded TMIC or FMIC. All the FMIC options seem shitty and a ton of work on the MS6, but I have a few used kits I'm looking at and might pick up to fab.
I've been on the forum for a long time now, going from modded back to stock and now BT. Hope it goes smoothly, and thanks in advance for any help and advice for what is sure to be a lot of stupid fucking questions and fails!
mikelevi is offline   Reply With Quote
The Following 4 Users Say Thank You to mikelevi For This Useful Post:
BLKSTIG (11-15-2015), ItsNox (11-16-2015), jack_hammer (01-04-2016), SpeedRebirth (11-14-2015)
 Old 11-13-2015, 09:27 AM   #2
sh4d0w's Avatar
Posts: 565   (View Stats)
sh4d0w is the leader of the worldsh4d0w is the leader of the worldsh4d0w is the leader of the worldsh4d0w is the leader of the worldsh4d0w is the leader of the worldsh4d0w is the leader of the worldsh4d0w is the leader of the worldsh4d0w is the leader of the worldsh4d0w is the leader of the worldsh4d0w is the leader of the worldsh4d0w is the leader of the world
Groans: 45
Groaned at 7 Times in 4 Posts
Sounds like fun good luck with everything man!
2010 Black MS3
Cobb AP // Cobb EBCS // Cobb Downpipe // Cobb RMM // JBR Tru 3.5'' Intake // JBR TMM // JBR PMM // JBR RSB // CP-E Cat Back // NGK One step colder plugs // GT 3071r // Azenis 615k // Bilstein PSS B14 Coilovers // Treadstone TR8 FMIC // Bully Stage 4 Clutch // Damon EGR Delete // Autotech HPFP // AEM V1 Meth Kit 50/50 // Freektuned 94 Oct
sh4d0w is offline   Reply With Quote
 Old 11-16-2015, 03:31 PM   #3
mikelevi's Avatar
I told you this would be full of fail. Removing the injectors to install the seals and the t40 snapped clean inside.
The Following User Says Thank You to mikelevi For This Useful Post:
 Old 11-16-2015, 03:34 PM   #4
cuethenoise's Avatar
Posts: 136   (View Stats)
cuethenoise is the leader of the worldcuethenoise is the leader of the worldcuethenoise is the leader of the worldcuethenoise is the leader of the worldcuethenoise is the leader of the worldcuethenoise is the leader of the worldcuethenoise is the leader of the worldcuethenoise is the leader of the worldcuethenoise is the leader of the worldcuethenoise is the leader of the worldcuethenoise is the leader of the world
Groaned at 6 Times in 2 Posts
Good luck haha Say Anything Quote FTW!
2012 Mazdaspeed3 w/ tech package
Stage 1 Stratified OTS
JBR Powerpath Stage 2
JBR 88a RMM
HPFP internals.
cuethenoise is offline   Reply With Quote
 Old 11-16-2015, 03:47 PM   #5
mikelevi's Avatar
Ha!! Sprayed some wd and compress aired that shit right out. These fucking bolts won't budge. I guess I'll let it soak a bit in PB
Edit: need a better socket th replacement is already warping and twisting.
 Old 11-16-2015, 04:24 PM   #6
mikelevi's Avatar
Got a better 3/8 t40, mother fucking head stripped.
 Old 11-16-2015, 04:43 PM   #7
ItsNox's Avatar
Posts: 3,076   (View Stats)
Shit man I feel the fail over here. Sorry to hear. For the other three, I would let those bitches soak in PB blaster or Liquid Wrench overnight. Blast it a few times in between.
'06 Mazdaspeed 6 GT
- Miltuned
Georgia Motherfucking Nator
 Old 11-16-2015, 04:48 PM   #8
mikelevi's Avatar
Already decided that. So I bought a set of used CS seals after I already purchased the CP-e ones new. I was just going to send them back but looks like I will keep them and use the replacement bolts for the crows feet.
Any recommendations on the bolt tomorrow, easy out?
 Old 11-20-2015, 02:10 AM   #9
MSP611's Avatar
Posts: 2,291   (View Stats)
tap and reverse drill bits? or just drill it out completely. have u tried a larger torx socket yet? this is why i dont fuck around with torx's i use snapon ones or die lol... and let they bitches always soak if they are big
In progress:
 Old 11-20-2015, 08:25 AM   #10
mikelevi's Avatar
Tried the reverse out and all it did was completely round the inside out on the two torx bolts that wouldnt budge. I have the easy out tap set I will try as last resort, I really dont want to fuck up the threads on the head. First I think I might try the Irwin Nut extractor
I saw some videos of people using it on stripped torx heads. I could also try to notch the head and use either an pneumatic screw driver or pneumatic hammer and try and hammer it counter clockwise.
I had the dealership fuck my motor up when they installed the VVT and replaced the turbo 40K miles ago. Thy rolled the cam back and bent all my valves; had to replace my entire head. So I dont know if these bolts are known to seize or they overtorqued the shit but those fuckers are not moving.
Current Build: 2006 MS6 GT
Power: BNR S3V2, Freektune 3.5" Intake, PnP Intake Manifold PC Wrinkle Black, Custom 3" Magnaflow CBE, M2 Ebay DP, CS Injector Seals, TR8L FMIC, Autotech Internals, GFB BOV 70/30, JBR OCC, EGR Delete and Block Plate, GS EBCS, Cobb AP v2, NGK IX @.026, Bosch 3 Bar MAP and Harness
Looks and Feels: AWR 80 Duro Trilogy Mounts, Bilstein B6, CPE and TT diff mount, Whiteline RSB, LED Tails, 18x8 +43 MB Battles Gunmetal, PC valve cover and IC piping Black Chrome II
Emew (12-08-2015)
 Old 11-20-2015, 09:14 AM   #11
MSP611's Avatar
i have a set of those bolt removers u attached.. they do work but ive never used on a torx bolt only on regular SAE and metric bolts/nuts... worth a try.. irwin has them on amazon for cheap...
Also the air hammer isnt such a bad idea just make sure u make the notch pretty wide so the air hammer can bite... Other solution with heat would work but u better be careful with where u point the heat. i would pull all the rest of the injectors and use the heat from the injector side flashing the heat away from the current injector still installed...
In progress:
The Following User Says Thank You to MSP611 For This Useful Post:
mikelevi (11-20-2015)
 Old 11-20-2015, 10:54 AM   #12
mikelevi's Avatar
Success! Came out easy with the bolt remover!
The Following 2 Users Say Thank You to mikelevi For This Useful Post:
ItsNox (11-20-2015), jack_hammer (01-04-2016)
 Old 10-26-2019, 07:45 PM   #13
AngryOrchard99's Avatar
Posts: 8   (View Stats)
AngryOrchard99 is an unknown quantity at this point
What extractor size did you use. Or do you remember what extractor set you used. Im trying to find an extractor that fits my stripped bolt; its been a damn struggle.
AngryOrchard99 is offline   Reply With Quote
 Old 11-20-2015, 08:41 AM   #14
mxlplx71's Avatar
Posts: 3,269   (View Stats)
Groans: 128
i've used a small chisel or punch on the outside edge to push bolts counter clockwise before. i would also suggest heat but thats too close to the injector.
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
The Following User Says Thank You to mxlplx71 For This Useful Post:
 Old 11-20-2015, 11:35 AM   #15
MSP611's Avatar
sounds like a win... now change to studs and nuts and stop worrying
In progress:
impossible (02-14-2016)
 Old 11-20-2015, 12:11 PM   #16
mikelevi's Avatar
Picking up studs and nuts from Fastenal as we speak!
 Old 11-20-2015, 12:13 PM   #17
MSP611's Avatar
smart man...
In progress:
 Old 11-20-2015, 12:20 PM   #18
That is almost certainly the monkeys at the dealership overtightening. They only go to 20 lbs if I recall.
 Old 11-20-2015, 12:40 PM   #19
MSP611's Avatar
25lbs i believe... but tomatoes tomato... u are right damn dealership monkeys lol
In progress:
 Old 11-20-2015, 03:42 PM   #20
mikelevi's Avatar
Things just got real...
ItsNox (11-23-2015)
 Old 11-20-2015, 03:46 PM   #21
mikelevi's Avatar
Before pic on the PnP
 Old 11-20-2015, 04:03 PM   #22
r3d
r3d's Avatar
Posts: 182   (View Stats)
r3d has a reputation beyond reputer3d has a reputation beyond reputer3d has a reputation beyond reputer3d has a reputation beyond reputer3d has a reputation beyond reputer3d has a reputation beyond reputer3d has a reputation beyond reputer3d has a reputation beyond reputer3d has a reputation beyond reputer3d has a reputation beyond reputer3d has a reputation beyond repute
Those torx are a bitch, bended my torx socket twice.
while you are tearing the engine apart, clean the injectors it will improve your performance and gas consumption.
Building it from ground up:
r3d is offline   Reply With Quote
 Old 11-22-2015, 06:25 PM   #23
mikelevi's Avatar
So I got the cylinders wrong on the valve cleaning. Poured B12 into what I thought was 2 and 4 on TDC. I put a dow into the spark plug holes because it looked like all three valves were closed two outside were down and two inside where up. Poured B12 and it leaked down on the left two valves filled 1/4 the way.
Its a dry combustible right? Anything I need to do to fix or correct, a touch of oil?
 Old 11-22-2015, 08:09 PM   #24
MSP611's Avatar
hmmmm i would not run it if u filled those cylinders i would drain ur oil and try again...
In progress:
 Old 11-22-2015, 08:22 PM   #25
mikelevi's Avatar
I was just thinking that. Going to use the walnut media tomorrow and clean the valves. I will need to get more b12 for cylinders 1 and 3 and let them soak for another hour.
I just wanted to make sure there wasn't anything terrible going to happen I wasnt thinking about. In reality, you suck seafoam through the combustion chambers and the only difference is that it contains oil, b12 is dry.
 Old 11-22-2015, 08:11 PM   #26
Cheapspeed's Avatar
Posts: 4,481   (View Stats)
Unless you're built the 3076r is a snoozer until you get high in the RPM's. Personally I would have stuck with a more response torquey turbo, especially with AWD.
EWG's are fun though.
 Old 11-22-2015, 08:27 PM   #27
mikelevi's Avatar
Yeah, I will probably pick up another long block to build up next year and flex the most from the 3076. My goal is to sit somewhere between 350-400. Will run an e85 blend and/or maybe meth.
 Old 11-22-2015, 08:41 PM   #28
Cheapspeed's Avatar
E85 and meth, or 5th port, will be your best bet of getting close to 400whp.
 Old 11-23-2015, 08:42 AM   #29
ItsNox's Avatar
With your goals being 350-400hp I would have gone with a smaller turbo, as suggested above. It would give you another 5-800+rpms to play with. I spool around 3k rpms. Most 3076s spool around 3800 if I recall correctly. That said Im pushing my beaner above 380awhp with a simple meth system. Just something to think about since your balls deep anyways.
And cleaning my valves was, hands down, one of the very best things i've ever done for my car. Maintenance wise, without a doubt. B12 it, pick the ever loving shit out of it with the b12 in there, suck it out, and then walnut blast it into oblivious. I sandblasted my face the first time; it blasted out of the cylinder and right into my face. Good times.
'06 Mazdaspeed 6 GT
- Miltuned
2 slo pu (11-23-2015)
 Old 11-22-2015, 08:25 PM   #30
MSP611's Avatar
ya i wouldnt let it sit too long still... i would drain and retry with b12 or skip all together like u said and use crushed walnut media.
In progress:
mikelevi (11-22-2015)
 Old 11-23-2015, 07:02 PM   #31
mxlplx71's Avatar
Groans: 128
I get to around 30 PS about 3800 gt3076r, 390 awhp with Meth and e30.
I do need fine tuned though, I'm currently self tuned. Also maxing my 3" maf need 3.5 plus.
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
ItsNox (11-24-2015)
 Old 11-24-2015, 08:28 AM   #32
mikelevi's Avatar
At least I didnt fail on the PnP!
Cheapspeed likes this.
 Old 11-25-2015, 01:47 PM   #33
mikelevi's Avatar
Glad to see that the freektuned 3.5" intake works perfectly with the stock battery tray and battery. All I had to do was flips the battery tray around and drill a hole in the support bracket with a 7/16 "drill bit and use the anchor point on the right side of the battery. Seems to be very sturdy.
I had to get my car put back together after installing the injector seals, cleaning the valves, and installing some other components. I'll get it fired up after a base tune from Justin to make sure I didn't fail at anything else before installing the turbo next week.
Code Monkey (11-25-2015), jack_hammer (01-04-2016)
 Old 11-25-2015, 02:54 PM   #34
mikelevi's Avatar
Hmmm u0100 connection to ECU? Car won't start.
 Old 11-25-2015, 02:57 PM   #35
Cheapspeed's Avatar
Double check all your connections. It's likely something stupid left disconnected. Does it even try to turn?
 Old 11-25-2015, 03:05 PM   #36
mikelevi's Avatar
Nope not turning. I have the erg and vtcs unplugged but l I figured Justin would have eliminated those in the tune. Do I need to do something with those? I can't troubleshoot till tomorrow got to slang beers to waiting patrons!
 Old 11-25-2015, 03:30 PM   #37
MD1032's Avatar
Posts: 2,624   (View Stats)
Groans: 143
Try reflashing your tune.
2007 Mazdaspeed3 GT
 Old 11-27-2015, 11:21 AM   #38
MSP611's Avatar
did u prime the fuel pump? did u prime the turbo?
In progress:
 Old 11-27-2015, 11:26 AM   #39
mikelevi's Avatar
I primed the fuel pump, haven't installed the turbo yet.
 Old 11-27-2015, 09:05 PM   #40
Yes. Pray you did not crack the mani.
Easter Bunny (12-03-2015), ItsNox (11-29-2015)
Watch and listen to Jon Olsson drift his Rebellion R2K up a snowy peak Haltech Automotive News 0 04-12-2014 05:20 PM
China's record-breaking bridge spawns new record for 24-mile Lake Pontchartrain Causeway Haltech Automotive News 0 07-17-2011 10:10 AM
Page generated in 0.63110 seconds with 32 queries
