Like Tree19Likes
 Old 01-14-2013, 01:39 PM   #1
RichieRichness's Avatar
Posts: 3,314   (View Stats)
Groans: 35
Default RichieRichness BT Build
After @CWP_MS3 blew my transfer case I decided to upgrade a few parts while the car was down for a few weeks. I wanted to go BT for a while but kept putting it off. One of those reasons was to capture the Mazdaspeed/MPS stock turbo record from @h.h.sk1nny. The other was financial. Thanks to sixual panda hookin me up with a sick deal on his old gt3071r and some local nator deals, I’m almost ready to join the BT club.
My goal is to make about 375 without aux fueling and 400+ with 5th port/meth. Reversed boost taper should keep the ZZB away. I should be good for mid to high 11 second ¼ mile times. Traps should be 116 - 118 mph.
Parts List:
Gt3071r IWG
Polished JMF intake manifold
ACT 6 Puck w/Street Light Fly Wheel
Polished JBR Wide Path Intake (Custom made without brackets and valve cover venting)
Bearing Caps from 06Speed6 (pending new production)
Polished JMF vented OCC
Perm crank case plate (waiting on production)
Powder Coated Misc. Parts
Thanks to:
@superskaterxes
@jbarone
@Vader
@dantes5823
@SIXual Panda
@Panda Express
@06Speed6
@CWP_MS3
@qtrmile beast
06Speed6, JBR, trf5000 and 2 others like this.
RichieRichness is offline   Reply With Quote
The Following 28 Users Say Thank You to RichieRichness For This Useful Post:
06Speed6 (01-14-2013), amggilly305 (01-24-2013), atvfreek (01-14-2013), AZSPEED3 (01-14-2013), CWP_MS3 (01-14-2013), Cyclops (01-14-2013), djuosnteisn (01-15-2013), Downmented (01-15-2013), Fail_6 (03-26-2013), h.h.sk1nny (01-14-2013), JBR (01-14-2013), jracer (01-15-2013), kimura (01-16-2013), leon78 (01-15-2013), Micha (01-14-2013), MS3inDC (02-06-2013), qtrmile beast (01-15-2013), robry (01-14-2013), SarcasticOne (01-16-2013), Schmitty5 (01-14-2013), SIXual Panda (01-14-2013), sleepyspeed6 (01-19-2013), Speed13 (01-19-2013), speedms6 (01-15-2013), SpeedRebirth (01-15-2013), taf0422 (02-06-2013), trf5000 (01-15-2013), Vader (01-14-2013)
 Old 01-14-2013, 01:47 PM   #2
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
First.
Rich Tuned
330WHP and 363TQ
10-19-13 Moore Automotive
 Old 01-14-2013, 01:50 PM   #3
StayBroke's Avatar
Posts: 2,075   (View Stats)
UM i need that intake manifold.
RichieRichness likes this.
 Old 01-14-2013, 01:51 PM   #4
BoominChu's Avatar
Posts: 188   (View Stats)
BoominChu has a reputation beyond reputeBoominChu has a reputation beyond reputeBoominChu has a reputation beyond reputeBoominChu has a reputation beyond reputeBoominChu has a reputation beyond reputeBoominChu has a reputation beyond reputeBoominChu has a reputation beyond reputeBoominChu has a reputation beyond reputeBoominChu has a reputation beyond reputeBoominChu has a reputation beyond reputeBoominChu has a reputation beyond repute
Groaned at 7 Times in 5 Posts
2nd
edit: DAMNIT!
BoominChu is offline   Reply With Quote
 Old 01-14-2013, 01:59 PM   #5
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
Originally Posted by RichieRichness View Post
After CWP_MS3 blew my transfer case I decided to upgrade a few parts while the car was down for a few weeks. I wanted to go BT for a while but kept putting it off.
See.... What would you do without me? :friday:And that hole is for an added cooling effect.
Rich Tuned
330WHP and 363TQ
The Following 2 Users Say Thank You to CWP_MS3 For This Useful Post:
RichieRichness (01-14-2013), Snap Off (01-16-2013)
 Old 01-14-2013, 02:13 PM   #6
Outlaw4shrt's Avatar
Posts: 751   (View Stats)
Outlaw4shrt is the leader of the worldOutlaw4shrt is the leader of the worldOutlaw4shrt is the leader of the worldOutlaw4shrt is the leader of the worldOutlaw4shrt is the leader of the worldOutlaw4shrt is the leader of the worldOutlaw4shrt is the leader of the worldOutlaw4shrt is the leader of the worldOutlaw4shrt is the leader of the worldOutlaw4shrt is the leader of the worldOutlaw4shrt is the leader of the world
good luck with the build!
2006 TGM MS6
Cobb AP w/ SELFtune // Split Second AIC1-V4H // Stratified Guardian Angel // Stratified Boost Dial // ATP GTX3071r IWG // Devils Own Stage 1 WMI // JMF v2 Intake Manifold // 4 x Siemens DEKA IV 60 lph Injectors // Outlaw4shrt In-Tank Fuel Pump Kit w/ 255 lph pump // CP-E CDFP // CP-E SAFEseals // Clutchmasters 350 & flywheel // CX Racing FMIC // HTP 3.5" Intake // 3.5 Bar MAP // Cobb EBCS // Forge BPV v1 // XS Power Exhaust Manifold // M2 Downpipe w/ Highflow Cat // Corksport 80mm CBE // Blackworks Racing VTA OCC // NGK +1's // JBR EGR delete // Speedy 17x7.5 Lite Fin's w/ Hankook Ventus V2 225/50/R17 // TooLateTuning Springs // Bilstein B6 HD Shocks // Whiteline RSB // SPC Adjustable Ball Joints // Airlift 1000 "Drag Bags" // JBR 80 duro RMM // JBR 80 duro TMM // JBR 80 duro PMM // CP-E RDM // Turbine Tech FDM // OEM Spin-On Oil Filter Conversion // Prosport Oil Pressure and Oil Temp Gauge with Oil Filter Adapter Plate, Boost and EGT Gauges // AEM UEGO Wideband O2 & Fuel Pressure Gauges // Block8head MS6 dual 52mm vent pod // Lotek triple 52mm gauge pod // Prosport EVO Single Gauge Pod // Cobb Knob // Corksport LED Kit // Corksport LED Fogs // LED Tails // Audi LED DRL's
2008 MazdaSpeed 3 - R.I.P. 1/3/13
- from ENM 2014
well actually, if you count the number of holes you'll see we have just enough
Outlaw4shrt is offline   Reply With Quote
The Following User Says Thank You to Outlaw4shrt For This Useful Post:
 Old 01-14-2013, 02:17 PM   #7
Schmitty5's Avatar
Posts: 979   (View Stats)
Schmitty5 is the leader of the worldSchmitty5 is the leader of the worldSchmitty5 is the leader of the worldSchmitty5 is the leader of the worldSchmitty5 is the leader of the worldSchmitty5 is the leader of the worldSchmitty5 is the leader of the worldSchmitty5 is the leader of the worldSchmitty5 is the leader of the worldSchmitty5 is the leader of the worldSchmitty5 is the leader of the world
Groaned at 20 Times in 12 Posts
Shwinnnggg
2010 MS3 - 13.42 at 107 - street tires - 306whp/338tq Moore automotive (dynojet)
Roadcoursing > all http://www.youtube.com/watch?v=GO-xoFpsgj4
Schmitty5 is offline   Reply With Quote
 Old 01-14-2013, 02:23 PM   #8
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
1 moar pictar of carnage.
Rich Tuned
330WHP and 363TQ
RichieRichness (01-15-2013)
 Old 01-14-2013, 02:25 PM   #9
sidekick's Avatar
Posts: 3,093   (View Stats)
Groans: 47
Damn, so what caused the transfer case to fail? Epic hoonage? @RichieRichness;
 Old 01-14-2013, 02:42 PM   #10
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
Originally Posted by boost_addict View Post
Damn, so what caused the transfer case to fail? Epic hoonage? RichieRichness;
Epic driving, son!
Actually it was a bearing cap failure, from a launch.
Rich Tuned
330WHP and 363TQ
RichieRichness (01-15-2013), sidekick (01-14-2013)
 Old 01-14-2013, 02:46 PM   #11
Navy_Mech2's Avatar
Posts: 484   (View Stats)
Navy_Mech2 is the leader of the worldNavy_Mech2 is the leader of the worldNavy_Mech2 is the leader of the worldNavy_Mech2 is the leader of the worldNavy_Mech2 is the leader of the worldNavy_Mech2 is the leader of the worldNavy_Mech2 is the leader of the worldNavy_Mech2 is the leader of the worldNavy_Mech2 is the leader of the worldNavy_Mech2 is the leader of the worldNavy_Mech2 is the leader of the world
06 MS6 |SP Built motor - Weisco Pistons .020" over, Manley H-Beam Rods, Ported Head, Ported Intake, VTCS Delete, BS Delete, VVT Actuator, Keyed Crank, 6th Port Fuel Injection | ACT 6 Puck w/ Streetlite Flywheel | Bullseye S259 .70 A/R Single Scroll | 3.5" Intake/MAF Housing | Steedspeed Twin Scroll T3 Top Mount Manifold | Tubosmart 40mm EWG | Custom DP | Custom TBE | Custom LTA Intercooler | HKS Type IV TT | Dashhawk | COBB AP | AWR RMM | PTP HPFP Guts |
KILLAH BUILT
Navy_Mech2 is offline   Reply With Quote
The Following User Says Thank You to Navy_Mech2 For This Useful Post:
 Old 01-14-2013, 02:59 PM   #12
h.h.sk1nny's Avatar
Posts: 1,392   (View Stats)
Good work Rich! I plan on putting in this gt2871r as soon as I take my record back in a few months! You may as well wait for bt, cuz you will want to put the k04 back in and take the record back, from when i take it from you taking it from me. If that makes sense lol
h.h.sk1nny is offline   Reply With Quote
The Following 9 Users Say Thank You to h.h.sk1nny For This Useful Post:
amggilly305 (01-24-2013), Fail_6 (03-26-2013), jracer (01-15-2013), RichieRichness (01-15-2013), SarcasticOne (01-16-2013), Schmitty5 (01-14-2013), superskaterxes (01-14-2013), The Panda (01-15-2013), xI Leveler Ix (01-15-2013)
 Old 01-15-2013, 08:57 PM   #13
The Panda's Avatar
Posts: 1,229   (View Stats)
The Panda is the leader of the worldThe Panda is the leader of the worldThe Panda is the leader of the worldThe Panda is the leader of the worldThe Panda is the leader of the worldThe Panda is the leader of the worldThe Panda is the leader of the worldThe Panda is the leader of the worldThe Panda is the leader of the worldThe Panda is the leader of the worldThe Panda is the leader of the world
Groaned at 8 Times in 7 Posts
Im going after this record now selling my BT kit to make this goal of 11's with k04 happen. With my RICHTUNE and the current record k04 on the car should be able to make it happen.
2011 BLACK MS3
ZZB on GT3076 Rebuild in progress
The Panda is offline   Reply With Quote
The Following User Says Thank You to The Panda For This Useful Post:
superskaterxes (01-16-2013)
 Old 01-15-2013, 10:33 PM   #14
h.h.sk1nny's Avatar
What's your current record? I hope you have some slicks and a sick 60'
 Old 01-16-2013, 06:05 AM   #15
The Panda's Avatar
We are doing it in my wifes 6
2011 BLACK MS3
 Old 01-14-2013, 04:01 PM   #16
dantes5823's Avatar
Posts: 6,576   (View Stats)
dantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the world
Groaned at 52 Times in 48 Posts
Dont let anyone drive your car now. god knows what theyll break now.
dantes5823 is offline   Reply With Quote
The Following 3 Users Say Thank You to dantes5823 For This Useful Post:
amggilly305 (01-24-2013), CWP_MS3 (01-14-2013), RichieRichness (01-15-2013)
 Old 01-14-2013, 10:26 PM   #17
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
Workin on the tcase cap drawings as fast as I can lol, dont wanna fuck em up twice.
2006 Mazdaspeed 6
The Following 3 Users Say Thank You to 06Speed6 For This Useful Post:
CWP_MS3 (01-15-2013), MarineMazda (01-15-2013), RichieRichness (01-15-2013)
 Old 01-15-2013, 04:06 AM   #18
leon78's Avatar
Posts: 2,595   (View Stats)
Nice! and you say your only gunna have a moderate tune....then next thing you know you will be shooting for the 10's. Best of luck, hope you get it back on the rd soon.
2013 Scion FR-S (Whiteout)
Less parking more racing
The Following User Says Thank You to leon78 For This Useful Post:
 Old 01-15-2013, 12:28 PM   #19
Groans: 35
i got dat wrinkle yo
Valves are cleaned too
The Following 3 Users Say Thank You to RichieRichness For This Useful Post:
Navy_Mech2 (01-15-2013), psychophyr (01-16-2013), Vader (01-15-2013)
 Old 01-15-2013, 01:58 PM   #20
Navy_Mech2's Avatar
nice job on the valves! what did you end up using to clean them b12?
KILLAH BUILT
 Old 01-15-2013, 02:06 PM   #21
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
Speaking of valves... superskaterxes; I have a bone to pick with you, sir! Leaving the vacuum on outlet side instead of the suction side. Put it in the intake port, hit the power button and b12 everywhere!
Rich Tuned
330WHP and 363TQ
maisonvi (01-15-2013)
 Old 01-15-2013, 02:24 PM   #22
Groans: 35
Hahaha oh yeah I almost forgot about you getting scundled!
The Following User Says Thank You to RichieRichness For This Useful Post:
 Old 01-15-2013, 02:47 PM   #23
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
You laugh, but remember who that hit was intended for. He knew you was coming, he knew you was gonna use the vacuum and he knew you were going to be using flammable liquids.
Not like my job is a private investigator or anything, but sounds awful suspicious to me.
Rich Tuned
330WHP and 363TQ
 Old 01-15-2013, 03:03 PM   #24
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
GL with the build Rich.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
 Old 01-15-2013, 04:28 PM   #25
qtrmile beast's Avatar
Posts: 2,423   (View Stats)
good luck rich and if you need help let me know..
track weight 3220
street weight 3370
 Old 01-16-2013, 07:13 AM   #26
Groans: 35
I will continue my stock turbo battle via @Panda Express
Tommy, I hope your ready to spend some serious cash on misc. bullshit. Get your drag bags, larger MAF, rear diff mount, dss axle, 06speed6 bearing caps, fmic, etc...
The Panda (01-16-2013)
 Old 01-16-2013, 07:33 AM   #27
dantes5823's Avatar
Nah Tommy will do it with minimal parts. Because panda.
The Following 2 Users Say Thank You to dantes5823 For This Useful Post:
superskaterxes (01-16-2013), The Panda (01-16-2013)
 Old 01-16-2013, 09:15 AM   #28
The Panda's Avatar
Im ready Rich I have a 3.5 maf is that big enough
2011 BLACK MS3
 Old 01-16-2013, 09:23 AM   #29
Groans: 35
Does that fit in your 6 without having to relocate the battery?
 Old 01-16-2013, 12:44 PM   #30
The Panda's Avatar
Yes it will fit the ms6 it came off a ms6
2011 BLACK MS3
RichieRichness (01-16-2013)
 Old 01-16-2013, 10:32 AM   #31
Navy_Mech2's Avatar
im runnin a 3.5" maf with the battery in the stock location.
KILLAH BUILT
The Following 2 Users Say Thank You to Navy_Mech2 For This Useful Post:
RichieRichness (01-16-2013), The Panda (01-16-2013)
 Old 01-16-2013, 10:47 AM   #32
Groans: 35
Right but is it JBR wide path?
 Old 01-16-2013, 10:51 AM   #33
Navy_Mech2's Avatar
Na. I probably should have asked if this is a top mount setup or not. If it is I just have a 90* tube off the turbo into the mad housing and then a filter
Sent by my thumbs
KILLAH BUILT
 Old 01-16-2013, 10:55 AM   #34
leon78's Avatar
Hey Rich...I can hook you up with 3bar MAP sensor w/ pigtail and GS 3port if ya need it for the build.
 Old 01-16-2013, 11:48 AM   #35
Groans: 35
I may need the GS ebc. However, I already has 3 bar. Wait why do you have this stuff? Were you planning on going BT at some point?
BTW I plan on going with this insead of pig tails Mazdaspeed MAP Harness - Bitwise Motorsports
leon78 (01-16-2013)
 Old 01-16-2013, 11:54 AM   #36
leon78's Avatar
Had these parts for awhile...BNR may have been in the future of the speed3....guess the FR-S will have to get turbo'ed now....
Give me a call whenever if ya need the 3 port.
 Old 01-16-2013, 02:21 PM   #37
Navy_Mech2's Avatar
hey richie do you remember how long it took you to put in your rear diff mount? im about to do mine in a day or two and was wondering if you had any tips
KILLAH BUILT
 Old 01-16-2013, 02:33 PM   #38
Groans: 35
It takes 2-3 hours. Make sure you have swivels and a friend
 Old 01-16-2013, 06:14 PM   #39
Navy_Mech2's Avatar
Haha cool thanks man
Sent by my thumbs
KILLAH BUILT
 Old 01-19-2013, 02:58 PM   #40
maxwella's Avatar
Posts: 129   (View Stats)
maxwella has a reputation beyond reputemaxwella has a reputation beyond reputemaxwella has a reputation beyond reputemaxwella has a reputation beyond reputemaxwella has a reputation beyond reputemaxwella has a reputation beyond reputemaxwella has a reputation beyond reputemaxwella has a reputation beyond reputemaxwella has a reputation beyond reputemaxwella has a reputation beyond reputemaxwella has a reputation beyond repute
Groaned at 27 Times in 13 Posts
what a great news! hope I will have enough cash to follow your path some time during the year.
RICHTUNE!
maxwella is offline   Reply With Quote
The Following User Says Thank You to maxwella For This Useful Post:
RichieRichness (02-04-2013)
RichieRichness goes BT RichieRichness MazdaSpeed 3/6 - Big Turbo Builds 5 03-07-2012 08:49 AM
Tuning With RichieRichness RichieRichness MazdaSpeed 3/6 - ECU Computer Tuning 134 01-24-2012 01:14 PM
Page generated in 0.63288 seconds with 36 queries
