![]() | | #41 | ![]() |
| Approved MSF Vendor ![]() Join Date: Sep 2011 Location: Denver Colorado
Rep Power: 5796 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,830
| Not Ranked : 0 score
| The Following 2 Users Say Thank You to EdgeAutosport.com For This Useful Post: | Death-From-A-Mile (04-05-2012), thehead (04-06-2012) |
![]() | | #42 | ![]() |
![]() Join Date: Jul 2009 Location: Key West, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,273
Groans: 143
(Thread Starter) | Not Ranked : 0 score edited first post with install pics so far.
__________________ 2016 BMW M235i [Dead] 2006 MS6 #367 Liquid Platinum 73,000 miles Engine - Killah built -L19 Headstuds - Steedspeed T3 Twin Scroll top mount goodness - Twin Scroll .83 A/R hotside GTX3071R - JMF V1 IM - Perm 6th Port - CP-E FMIC - SURE 3.25 MAF housing - customized EBay DP - Magnaflow CBE - Autotech HPFP internals Electrical - GS EBC - Cobb AP Richtune in progress Drive train - Techna-fit Stainless Steel clutch and brake lines - stoptech rotors - CorkSport RMM - Corksport Trans inserts - SURE Juggernaught & Dreadnaught - E4 heavy knob & Jbarone's Short Shift plate - Tenzo DC-5 Bronze +45 wrapped in ExtremeContact DWS 235/40-18's Fluids Transmission - Motorcraft synthetic. PTO and Rear diff - Conklin Gold Guard Plus synthetic 75W-90. Engine Oil - Rotella T6 5W-40. |
![]() | | #43 | ![]() |
![]() Join Date: Jun 2010 Location: corpus christ, tx
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,316
Groans: 68
| Not Ranked : 0 score this is the intercooler i went with 28x8x3.5 eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices same price. nice build so far
__________________ 2006 MS6 -GTX3076 .82 AR-Steedspeed Topmount mani-DJ/PERM Top mount Kit with PERM tune-CXracing FMIC-Tial .44mm WG - KMD Internals- Sure RDM, Turbine tech FDM and FMM=JBR trilogy MM- Whiteline rear sway- eibach prosport springs-jbarone SSP-COBB AP-ACT 6PUCK- ITV22-Prosport Spin On Conversion-Snow Performance stg 2 Meth-CPE Injector seals-Matt Damon OCC |
| The Following User Says Thank You to crazyp For This Useful Post: | thehead (04-08-2012) |
![]() | | #44 | ![]() |
Groans: 143
__________________ 2016 BMW M235i [Dead] 2006 MS6 #367 Liquid Platinum 73,000 miles Engine - Killah built -L19 Headstuds - Steedspeed T3 Twin Scroll top mount goodness - Twin Scroll .83 A/R hotside GTX3071R - JMF V1 IM - Perm 6th Port - CP-E FMIC - SURE 3.25 MAF housing - customized EBay DP - Magnaflow CBE - Autotech HPFP internals Electrical - GS EBC - Cobb AP Richtune in progress Drive train - Techna-fit Stainless Steel clutch and brake lines - stoptech rotors - CorkSport RMM - Corksport Trans inserts - SURE Juggernaught & Dreadnaught - E4 heavy knob & Jbarone's Short Shift plate - Tenzo DC-5 Bronze +45 wrapped in ExtremeContact DWS 235/40-18's Fluids Transmission - Motorcraft synthetic. PTO and Rear diff - Conklin Gold Guard Plus synthetic 75W-90. Engine Oil - Rotella T6 5W-40. | |
![]() | | #45 | ![]() |
Groans: 68
| Not Ranked : 0 score its been on my build since day 1
| The Following User Says Thank You to crazyp For This Useful Post: | thehead (04-11-2012) |
![]() | | #46 | ![]() |
![]() Join Date: Jan 2011 Location: Cranford, New Jersey
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 233
| Not Ranked : 0 score Anyone have pictures of how much cutting is necessary to fit the TR8 properly?
__________________ 2007 Mazdaspeed 6 (Velocity Red) 2002 Corvette Z06 (Black) 2001 Mazda Millenia S (Brilliant Black) - GONE |
![]() | | #47 | ![]() |
Groans: 143
(Thread Starter) | Not Ranked : 0 score for me, I had to cut the width of the intercooler and half way up, The crash bar is shaped like a "C" not like a bar, so I cut the bottom part off. I may be taking my front bumper off again on Wednesday, if I do I'll take a picture.
![]() | | #48 | ![]() |
Groans: 143
(Thread Starter) | Not Ranked : 0 score Updated OP with pictures of exhaust manifold in and more notes. need a stubby wrench to finish tightening mani to turbo nut and finish up intake stuff. Question.. For the ebc vacuum line from the turbo housing, since the gtx3071r doesn't have one like the k04 does, should I just drill a hold into the bt inlet and put in the nipple provided? Also, how do I tune the ebc and set it up :S
![]() | | #49 | ![]() |
Groans: 68
| Not Ranked : 0 score Id rather drill the hot pipe for a boost source or t off the mani. I run MBC so can't help you on the ebc
| The Following User Says Thank You to crazyp For This Useful Post: | thehead (04-10-2012) |
![]() | | #50 | ![]() |
| Not Ranked : 0 score Boost source - you can use a quick tap- FTG-QuickTap-CompHSG : atpturbo.com Pic compliments of @dougefresh_
| The Following 2 Users Say Thank You to TiGraySpeed6 For This Useful Post: | dougefresh_ (04-11-2012), thehead (04-11-2012) |
![]() | | #51 | ![]() |
Groans: 143
Finished with the install of everything just need some tuning. Is there a base bt map at all? I have a modified map currently with -30% wgdc and lower boost levels for now, but yeah. I need to get on the perm list. Also uploaded more pictures to op. Pretty crazy though, this turbo sounds so much different than the stock turbo, its higher pitched like a jet engine, I like it
__________________ 2016 BMW M235i [Dead] 2006 MS6 #367 Liquid Platinum 73,000 miles Engine - Killah built -L19 Headstuds - Steedspeed T3 Twin Scroll top mount goodness - Twin Scroll .83 A/R hotside GTX3071R - JMF V1 IM - Perm 6th Port - CP-E FMIC - SURE 3.25 MAF housing - customized EBay DP - Magnaflow CBE - Autotech HPFP internals Electrical - GS EBC - Cobb AP Richtune in progress Drive train - Techna-fit Stainless Steel clutch and brake lines - stoptech rotors - CorkSport RMM - Corksport Trans inserts - SURE Juggernaught & Dreadnaught - E4 heavy knob & Jbarone's Short Shift plate - Tenzo DC-5 Bronze +45 wrapped in ExtremeContact DWS 235/40-18's Fluids Transmission - Motorcraft synthetic. PTO and Rear diff - Conklin Gold Guard Plus synthetic 75W-90. Engine Oil - Rotella T6 5W-40. Last edited by thehead; 04-11-2012 at 06:32 PM. | |
| The Following User Says Thank You to thehead For This Useful Post: | Karmat (04-11-2012) |
![]() | | #52 | ![]() |
| Not Ranked : 0 score The bumper splitter fits underneath all that?
![]() | | #53 | ![]() |
Groans: 143
(Thread Starter) | Not Ranked : 0 score It just fits, however, the functionality of it is questionable, your best bet would be to cut the crash bar all the way, or check with @Alpha for his crash bar solution he mentioned in an earlier post in this thread. I know once I put the front mount on, my intake temperatures went up quite a bit which could be because the lower spoiler isn't able to bring enough air into the engine bay as it use to.
![]() | | #54 | ![]() |
![]() Join Date: Dec 2009 Location: Chicago
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,256
![]() We modified the stock splitter a bit to maintain it with the kit, for cooling purposes, and it turned out great. Hope that helps. The MS3s have always had a ton of FMIC options, but the 6ers always got the shaft... Not anymore!
__________________ PERM'D/FORGED - EFR 7163 Street Sleeper ![]() | |
![]() | | #55 | ![]() |
Groans: 143
(Thread Starter) | Not Ranked : 0 score Alrighty, so my transmission got rebuilt last week, I was hoping to put the mazda 6 diesel gears in there for that taller gear ratio but this is my only car so I didn't want to experiment on it since its not proven to work long term yet. While that was getting rebuilt I had the clutch and flywheel pulled to check the wear on them and it was bad. This is why you don't let friends drive your car. I replaced the ACT street clutch and fidenza flywheel with a resurfaced stock flywheel from Tech/Sales@EM and got a spec stage 3+ clutch from @StreetUnitMark . I also got a prosport boost gauge to replace the really old one I was using. i also got a 3bar map sensor and the Sure 3" MAF housing from @StreetUnitMark
| The Following User Says Thank You to thehead For This Useful Post: | TiGraySpeed6 (05-07-2012) |
![]() | | #56 | ![]() |
| Not Ranked : 0 score Looking forward to hearing your opinions on the flywheel now that you re going back to OEM from the Fidenza on your DD... Happy to have the weight back?
![]() | | #57 | ![]() |
![]() Join Date: Apr 2010 Location: Columbia, SC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,756
Groans: 97
| Not Ranked : 0 score is it moving under its own power again.....need track times now. |
![]() | | #58 | ![]() |
Groans: 143
(Thread Starter) | Not Ranked : 0 score i'll be picking it up today. I still have to tune it, I'm going to Minnesota for a week on wednesday so I'll be doin maf cals when I get back.
![]() | | #59 | ![]() |
Groans: 143
(Thread Starter) | Not Ranked : 0 score So upon driving my car home, its pretty crazy, my clutch pedal feels like a normal car's clutch pedal now rather than taking like 75lbs of force to push down. however, third gear takes a lot of effort to take out of gear, not really sure what the deal with that is, I'm goina take it back tomorrow and see what they say, they gave me a 6 month no questions asked warranty.
![]() | | #60 | ![]() |
![]() Join Date: Dec 2010 Location: TX
| Not Ranked : 0 score If it's only one gear, sounds like they might have messed up the rebuild. Could be synchros.
__________________ 2007 CTS-V - Trying to sell 2009 CTS-V - Not getting a cam. Ever. |
![]() | | #61 | ![]() |
Groans: 143
(Thread Starter) | Not Ranked : 0 score So we found out what it was, the shift weight was hitting my intercooler piping clamp, easy fix, yay!
| The Following 2 Users Say Thank You to thehead For This Useful Post: | Seatime3 (05-08-2012), TiGraySpeed6 (05-08-2012) |
![]() | | #62 | ![]() |
Groans: 143
(Thread Starter) | Not Ranked : 0 score So I've been trying some tuning, this wgdc stuff is a bitch, I'm still trying to figure it out but I'm not making boost very quickly and I have no leaks. let me know if I'm royally fucking this up, I think my wgdc is fairly conservative, I've been working my way up and going off of other wgdc's people are using. boost targets are 24psi from 3k-6k rpm 1750ish commanded fp.
![]() | | #63 | ![]() |
| Not Ranked : 0 score Sounds like you need to do the dreaded WGA arm preload.
![]() | | #64 | ![]() |
Groans: 143
(Thread Starter) | Not Ranked : 0 score Yeah, thats what im afraid of, i increased wgdc to 70 til 3k and it didnt help at all, damit all to hell
![]() | | #65 | ![]() |
| Not Ranked : 0 score Unless the ebcs isn't plugged in or is malfunctioning entirely, it's the WGA preload.
| The Following User Says Thank You to bmylez For This Useful Post: | thehead (05-09-2012) |
![]() | | #66 | ![]() |
| Not Ranked : 0 score Ugh... looks like the preload to me too. Good luck man. |
| The Following User Says Thank You to Realgib3 For This Useful Post: | thehead (05-09-2012) |
![]() | | #67 | ![]() |
Groans: 143
(Thread Starter) | Not Ranked : 0 score Gah, I'm really tempted just to go ewg now, tack weld the iwg shut, and throw in a screamer pipe... Only thing is, I'd have to know the iwg is shut before I can weld it, it should be since it was shut pretty good when I installed it with no vacuum/boost applied to it. Thoughts?
![]() | | #68 | ![]() |
| lulz @Raider ![]() Join Date: Jun 2010 Location: St Louis Mo
Rep Power: 3779 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 25,132
| Not Ranked : 0 score I used a grimmspeed iwg block off bracket for a 18g... It cost about 20 bucks and I was able to do all the work with the turbo still on the car.... Just a thought
__________________ 2008 MS3 gt 470hp/463tq on GT35r at 29psi Wiseco Pistons/Molar Rods/ACT 6 Puck/ARP Head Studs/TurboXS FMIC DP and RP/TurboSmart BOV/Tial 38mm EWG/PERM 5th/6th port injectors HKS CBE/ Koni Yellows and H&R springs/ HTP Whale Penis Intake/ PTP Fuel internals/SteedSpeed Mani/CP-E SafeSeals/E85 Hypnotic Tuned |
| The Following User Says Thank You to burn813 For This Useful Post: | thehead (05-18-2012) |
![]() | | #69 | ![]() |
Groans: 143
(Thread Starter) | Not Ranked : 0 score So I'm finally getting some boost built, I'm coarse tuning the wgdc today and I'll probably fine tune it tonight, looks like the logs cut out at 22.8 psi so I'll keep her at 22 lbs til I get my new map sensor in. I'll post some logs later. Had a scary moment today that made me realize I need to adjust wgdc in smaller increments... don't groan me too hard for that..
![]() | | #70 | ![]() |
Groans: 143
(Thread Starter) | Not Ranked : 0 score slowly getting the wgdc dialed in, oooh yeah... this would be so much faster if I had a laptop, lol. I do have a question if I lower the initial wgdc, would it spool up faster. I wasn't sure because it would be less load on the engine, not really sure if its better just to send all the exhaust to the turbo or not.
![]() | | #71 | ![]() |
You probably have an easy 500 RPMs of earlier spool left in the tune... This is what I am getting with a ported IM with no VTCS (which slows spool an easy 2-300 RPMS):
__________________ 08 MS3: ATP GTX3071 at 26PSI , AEM Dryflow 21-2147DK, CP-E 3.25'' MAF, CP-E Nviscid TIP, PG FMIC piping with Treadstone TR11 core, Cobb BPV, Ported IM, PG v1 manifold, CP-E catted DP, CNT CBE, KMD v2, Grimspeed EBCS, Alkycontrol Meth injection (M10 with 100% meth), E40 fuel, Cobb AP (ATR= WIN), ACT ZX4-HDSS, 3-Bar MAP, JBR RSB, and CP-E 60 Duro Engine Mount Set. (297.3WHP/366.9WTQ - on K04, 469.2WHP/420.7WTQ - on GTX3071) Last edited by cld12pk2go; 06-02-2012 at 08:44 PM. | |
| The Following 7 Users Say Thank You to cld12pk2go For This Useful Post: | 802MS3 (06-06-2012), atvfreek (06-02-2012), cshunter (07-31-2013), helmetface (06-02-2012), rghispanic88 (06-09-2012), SarcasticOne (06-03-2012), thehead (06-03-2012) |
![]() | | #72 | ![]() |
![]() Join Date: Nov 2010 Location: Manchester, NH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 25,797
| Not Ranked : 0 score All of the GTX's I've tuned hit 20+ by 3400, so you are getting there. What does your vvt table look like? EDIT: also looks like a little bit of an oscillating boost curve. Are you using the load dynamics or load error comp tables. If so what are those values. Sorry if these have all been answered. A little late to the thread
__________________ 2010 Speed3-PTE5858 Freek built/Freektuned 510hp420tq 11.321@129.93 |
![]() | | #73 | ![]() |
Groans: 143
(Thread Starter) | Not Ranked : 0 score my vvt table is whatever the stage 2 tune uses, not sure what to do with that, I haven't done anything with the error values, I don't understand what they do :p
![]() | | #74 | ![]() |
Groans: 143
(Thread Starter) | Not Ranked : 0 score Well son of a bitch, launched and something made a breaking sound. My rear end is making a clicking noise. Anyone know what that would be? Broken driveshaft maybe?
![]() | | #75 | ![]() |
Groans: 68
| Not Ranked : 0 score could be an axle. I'm always paranoid about that so the first thing I do after starting the car is turn off DSC and turn on the meth.
![]() | | #76 | ![]() |
Groans: 143
(Thread Starter) | Not Ranked : 0 score Hmm, just checked the driveshafts from the outside the look good. Thinking its the diff . How much are one of those?
![]() | | #77 | ![]() |
| Not Ranked : 0 score Pull up one click on the ebrake and test results lol
![]() | | #78 | ![]() |
Groans: 143
(Thread Starter) | Not Ranked : 0 score Does that make it fwd?
![]() | | #79 | ![]() |
Groans: 143
(Thread Starter) | Not Ranked : 0 score Meh, its something internal I'm pretty sure, just started my second part of a-school so my time is goina be limited, but man, I did a ton of tuning this past weekend, and the car pulls soo hard, I love it. well, not so much anymore, I'll be putting my car up on a lift tomorrow and see if I can spot any obvious damage, and I'll check the fluid for metal. does anyone know what the rear diff gear ratio is, i seem to remember someone saying its the same as whats in the rx-8's. But I was looking and there are a ton of different ones they use. @06Speed6
![]() | | #80 | ![]() |
| Not Ranked : 0 score The rear diff *should* be 1:1 but I dont know that for sure and the coupler should slip some so its near impossible to determine that way. I have a back half if a rear axle in the storage unit, there is no way I can guarantee that it isnt junk, I bought it on ebay for $250+shipping a couple years ago and havent done anything with it. Supposidly the gearset is rx-8 spec, but I dont know if that just means the the gearset will swap into a rx-8 axle or that the diff is a direct swap or what. I havent even opened that thing up to look. Fyi the coupler is the likely weak point and the outer case of the actual coupler can break open.
__________________ 2006 Mazdaspeed 6 P&P, flow benched, head with welded EGR and +1mm inconel exhaust valves (260/200cfm @ .500"), Web Cams, Custom crankcase breather with integrated air/oil seperator, Custom 3/4" ID pan vac system, Blow through maf, Port matched IM, CNC AN-12 ORB block oil adapter, CP-e 88mm Stage 2 pistons, Pauter 22.5mm rods, ARP main, head, and crank studs, CP-e injector seals, Injector stud kit, Cometec 88mm 5 layer HG, Deatschworks flow tested matched injectors, DCR VVT, PTP 2250psi RV, Corksport front sway, Whiteline rear sway, AWR front/rear sway links, TT FMM, AWR 70d DMM, JBR 80D PMM, SU RMM, TT FRDM, CP-e RRDM, Autotech CDFP, DW65c ITFP, Custom L/A IC with a dual pass 20x25x1.5 heat exchanger, Dual Cobra I/C pumps, 2.5" ID 700hp I/A intercooler, Custom DP, Corksport catback, Corksport exhaust hangers, chrome plated genpu valve cover, chrome plated timing cover, Spin on oil filter, Fluidyne dual pass AN-12 oil cooler, Hayden oil cooler fan controller, Dual 4.7" SPAL oil cooler fans, Canton Racing 22-480 oil tstat, Custom BMRS AN-12 oil lines, SPC ball joints, 55w/35w headlights and independently switched fogs on custom waterproof harnesses, PIAA Super Plasma driving and interior lights, rear diff cutout switch, 3M clear front cover, Volk 17x7.5 wheels, Custom tcase bearing cap upgrade, GS EBC 3 port, Redline SS hood lift, Versatune, Defi gauges, Innovate MTX-L WB gauge, triple center gauge pod, Block8head dual vent pod, Redline shift boot & ebrake cover & arm rest cover, Mazdaspeed CF ebrake handle, SBC Full Face Feramic Clutch Disc, Dashawk, ACL rod bearings, King main bearings, Cosworth BSD, Custom windage tray, Holset HX35w, Creative Performance T3 EWG manifold, HKS VTA BOV, A1 H11 head studs, Hylomar HG sealant, SSP EGR delete plate, JBR EGR IM plug, JGS 40mm Race EWG Last edited by 06Speed6; 06-04-2012 at 07:01 PM. Reason: MSF Database - Automerged Doublepost |
| The Following User Says Thank You to 06Speed6 For This Useful Post: | thehead (06-04-2012) |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f498/thehead-s-gtx3071r-front-mount-intercooler-cp-106908/ | ||||
| speedperf6rmanc3 - Page 2 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum | This thread | Pingback | 02-19-2014 04:40 PM | |
| GenPU GTX3071r build | stang9779 | 2010 MS3 - Big Turbo Builds | 519 | 04-05-2012 09:13 PM |
| what exhaust mani to get ?? | jracer | MazdaSpeed 6 - Engine, Transmission & Driveline | 18 | 12-02-2009 12:00 AM |
