 Old 06-12-2010, 03:52 PM   #1
zx2man's Avatar
Posts: 1,356   (View Stats)
Default Tial 38mm Question
So Im gonna have a ewg fab done to my DNP turbo mani. I wanna go v-band connection. OR should I run the tial flange setup. It just a matter of preference isnt?
Also what spring should I order for a ATP 3071 setup 17-19 psi?
Thanks
TiAL 38mm V-Band External Wastegate - Modern Automotive Performance
2009 MS3
COBB AP
COBB INTAKE
COBB/TURBOXS TBE
DNP TURBO MANIFOLD
CXRACING FMIC
TURBOSMART BPV
JBARONE RMM
TURBOSMART BPV
JBARONE SHIFTERPLATE
COBB RSB
KONIG WHEELS/HANKOOK TIRES
zx2man is offline   Reply With Quote
 Old 06-12-2010, 03:59 PM   #2
danesti's Avatar
Posts: 4,186   (View Stats)
Groans: 137
pretty much a matter of preference.. i say v-band if the mani is fabbed in an way where the v-band is easily accessible. mine was fabbed up with the flange close to runner #1, and it made for a very difficult install of the EWG with v-band. that being said, i like v-band for less chance of a leak. i had a lot of confidence with it.
my guess is you want 1.2 or 1.3 bar spring... but that really depends on what you want to control boost with (electronic or just straight off the WG spring). i dont know enough about EBCs to help you there, sorry.
2008 STi
Intake
Turboback
AP
The Following User Says Thank You to danesti For This Useful Post:
zx2man (06-12-2010)
 Old 06-12-2010, 04:19 PM   #3
zx2man's Avatar
Ohhh me like Nice picture. Ill using that for reference I think when I take the mani to get it fabbed for ewg. Ill be using that compact 38mm tail mvs..should fit no prablem. I just called Surgeline tuning up and they will use some special type of boost solenoid, and then have the Cobb AP control boost. So thats the direction im going there.
They were saying a .8 bar should be fine.
Thanks again Dane
2009 MS3
COBB AP
COBB INTAKE
COBB/TURBOXS TBE
DNP TURBO MANIFOLD
CXRACING FMIC
TURBOSMART BPV
JBARONE RMM
TURBOSMART BPV
COBB RSB
 Old 06-12-2010, 05:30 PM   #4
danesti's Avatar
Groans: 137
ok glad you got some advice on the boost control.
38mm is a good call. i had a 44mm (not necessary). i really like how i had mine done and how it came out, i just wish the flange was maybe another 1/2 inch away from the runner for ease of install. otherwise it was perfect.
more reference...
2008 STi
Intake
Turboback
AP
zx2man (06-12-2010)
 Old 06-13-2010, 11:54 AM   #5
madvillain's Avatar
Posts: 4,160   (View Stats)
Groans: 78
What Dane said.. Flange is just a preference, while v-band has less of a chance to leak, if you're running spring pressure as your form of boost control I may opt for the flange for ease of install/uninstall when changing springs.
It all just depends on where your WG is located. Mine is just a pain in the dick to get to, it's vband and it takes like an hour to get the fucker off.
The Following 2 Users Say Thank You to madvillain For This Useful Post:
danesti (06-13-2010), zx2man (06-13-2010)
 Old 06-14-2010, 05:29 PM   #6
zx2man's Avatar
So....after contacting several Exhuast&weld shops in my area they highly suggest SpeedFactory in Tacoma. Ricky runs the place and is mostly a Honda guy,but all he does is turbo kits&exhaust fabrication ect. So called him up..sounded really professional, and says that will be no prablem on doing the ewg pipe. Price will be 150 bucks..which is fair to me. And im using Dane's mani for the reference Thanks again Dane!!!
2009 MS3
COBB AP
COBB INTAKE
COBB/TURBOXS TBE
DNP TURBO MANIFOLD
CXRACING FMIC
TURBOSMART BPV
JBARONE RMM
TURBOSMART BPV
COBB RSB
 Old 06-15-2010, 12:35 AM   #7
danesti's Avatar
Groans: 137
no worries. i got mine done by JM fabrications. they did an excellent job, only down side is i had to ship it.
post pics when your done! before and after install please. thanks!
2008 STi
Intake
Turboback
AP
gt3076r and tial 38mm EWG Nitr0EngiE MazdaSpeed 3/6 - Turbo Induction 18 10-05-2009 01:44 PM
MS3 with 38mm EWG tutuga MazdaSpeed 3 - Engine, Transmission & Driveline 45 03-29-2009 07:22 PM
Page generated in 0.27055 seconds with 22 queries
