 Old 11-24-2011, 02:22 PM   #1
frankthetankjfpc's Avatar
Posts: 6   (View Stats)
frankthetankjfpc has a little shameless behaviour in the past
Default turbo upgrade question
Call me a noob, but is it possible to just do a turbo upgrade exgt3076) and run the stock boost, fuel pump, etc. I have intake, 3in dp to full 3 in exhaust and a cobb tune. Can I just purchse the turbo, and swap the k04?
frankthetankjfpc is offline   Reply With Quote
The Following User Says NO Thank You to frankthetankjfpc For This Un-useful Post:
SWAY (11-30-2011)
 Old 11-24-2011, 02:52 PM   #2
m4tic's Avatar
Posts: 4,928   (View Stats)
no
2017 Daytona 392
STOLEN//2015 BMW S1000R
2007 MS6 w/ Cheez
The Following 2 Users Say Thank You to m4tic For This Useful Post:
breakfstincluded (11-24-2011), KusteLokal (11-24-2011)
 Old 11-24-2011, 03:02 PM   #3
can you explain the specifics as to why? It is because even at the same boost the larger turbo pushes more air?
 Old 11-24-2011, 03:05 PM   #4
super_pablo_'s Avatar
Posts: 1,648   (View Stats)
dude, if these are the type of questions you are asking, you arent ready for a big turbo.
Learn about it, then decide if u wanna do it. dont just do it cause its a bigger turbo.
The Following 3 Users Say Thank You to super_pablo_ For This Useful Post:
Chimmike (11-30-2011), KusteLokal (11-24-2011), SWAY (11-30-2011)
 Old 11-24-2011, 03:16 PM   #5
m4tic's Avatar
you didnt ask for specifics... i just answered your question. its never as simple as slapping on a turbo. boost is nothing... 15psi through a drink straw is not the same as 15psi through a firehose. stock fuel pump, especially when contemplating a turbo upgrade, is a big no no. the increased airflow/fuel demand will choke the stocker. its recommended you install new injector seals. then you need a FMIC (you better not be using the stock tmic). and dont use an OTS tune with a big turbo.. thats just asking to blow up.
2017 Daytona 392
2007 MS6 w/ Cheez
 Old 11-24-2011, 08:26 PM   #6
Thanks bmorris. I am just a little new to boost and Mazdaspeed is all. I wanted reinforcement and elaboration i suppose. I see that I have a lot of reading to do as far as where I want to take this.
I see your sporting the one black, one chrome exhaust tip like myself too. lol.
Last edited by frankthetankjfpc; 11-24-2011 at 08:26 PM. Reason: MSF Database - Automerged Doublepost
 Old 11-24-2011, 08:46 PM   #7
MarineMazda's Avatar
Posts: 354   (View Stats)
MarineMazda is the leader of the worldMarineMazda is the leader of the worldMarineMazda is the leader of the worldMarineMazda is the leader of the worldMarineMazda is the leader of the worldMarineMazda is the leader of the worldMarineMazda is the leader of the worldMarineMazda is the leader of the worldMarineMazda is the leader of the worldMarineMazda is the leader of the worldMarineMazda is the leader of the world
Hey Frank there are a few stickies in this section that might help you. I did a lot of reading before I contemplated going BT.
The GT 30 series are more efficient in higher boost ranges maybe if your looking to stay stock boost levels but lose the smoking issues look at the BNR set-ups
I would also suggest with a DP and looking for more mods to Upgrade your CDFP before anything else
MarineMazda is offline   Reply With Quote
 Old 11-25-2011, 07:11 PM   #8
What is CDFP? I have a vibrant downpipe.
Mis bolas en tu boca.
 Old 11-25-2011, 08:35 PM   #9
CAM DRIVEN FUEL PUMP. I would really suggest reading up on this platform and how it works. There is quite a lot to learn!
Doing this will also save you from being SHIT ON by some members of the board
 Old 11-30-2011, 11:08 AM   #10
exftw's Avatar
Posts: 168   (View Stats)
exftw has a reputation beyond reputeexftw has a reputation beyond reputeexftw has a reputation beyond reputeexftw has a reputation beyond reputeexftw has a reputation beyond reputeexftw has a reputation beyond reputeexftw has a reputation beyond reputeexftw has a reputation beyond reputeexftw has a reputation beyond reputeexftw has a reputation beyond reputeexftw has a reputation beyond repute
you definitely need a fuel pump upgrade or just get the internals. its going to help alot from your car going zoomzoomboom. how to put those in and where to buy them are all over this forum.
I got a GT3071 sitting on my desk... everyday i think what is going to go wrong if i put that thing in there even with all the supported mods. Ive done a ton of research and im still researching before i put this thing in.
-2006 Mazdaspeed6-
Engine: CPE FMIC, Sure Aeros, Sure Sidewinder, ATP DP, GHL CBE, TurboSmart BOV, Cobb AP, AT HPFP internals, DNP Mani, OCC
Drivetrain: SURE Dread & Jugg, CPE RMM, TT FMM, Spec Clutch, TWM SS (s2)
Suspension/Brakes: BC Coils, EBC Ultimax Rotors, Hawk HPS Pads
Exterior: NEXTMod Lip Kit, VG Sharkfin, APR Splitter Rods, Rota GForce 18x8.5 with 225/40/18 Hankook Ventus V12
Upcoming: GT3071R ...
exftw is offline   Reply With Quote
 Old 12-02-2011, 11:03 PM   #11
ms6forthewin's Avatar
Posts: 525   (View Stats)
ms6forthewin is the leader of the worldms6forthewin is the leader of the worldms6forthewin is the leader of the worldms6forthewin is the leader of the worldms6forthewin is the leader of the worldms6forthewin is the leader of the worldms6forthewin is the leader of the worldms6forthewin is the leader of the worldms6forthewin is the leader of the worldms6forthewin is the leader of the worldms6forthewin is the leader of the world
you shouldnt mod, you should start reading, then decide what you want to do with your car. There are so many setups you can go.
-2014 Evo X GSR
-2007 MAZDASPEED 6 (SOLD)
BNR S3// ALL-SUPPORTING MODS
ms6forthewin is offline   Reply With Quote
Turbo Upgrade Reid Clark MazdaSpeed 3/6 - Turbo Induction 229 08-01-2011 08:29 PM
Turbo Upgrade Question OgCoda MazdaSpeed 3/6 - Turbo Induction 8 12-24-2010 11:23 PM
Turbo Upgrade? mattizle14 MazdaSpeed 3/6 - Turbo Induction 31 02-28-2010 09:53 PM
Page generated in 0.30195 seconds with 25 queries
