 Old 06-19-2010, 10:26 AM   #1
speedyhans's Avatar
Posts: 335   (View Stats)
speedyhans has much to be proud ofspeedyhans has much to be proud ofspeedyhans has much to be proud ofspeedyhans has much to be proud ofspeedyhans has much to be proud ofspeedyhans has much to be proud ofspeedyhans has much to be proud ofspeedyhans has much to be proud ofspeedyhans has much to be proud ofspeedyhans has much to be proud of
Groaned at 56 Times in 56 Posts
Default what to do???
ok guy I need ur help, I want to go biger turbo but i dont know what i shood do my 2 options are.
cost $3k
gt3076r w/ IWG, PG mani, cpe hpf, and a cpe stand back
or
cost $6500 +
weit 5 mouth and do
gt35r w/ ewg, pg mani,cpe hpf, weit for the stand along, and get the motor bild
what would u do i dont really want to spend that much money bot i dot want to worry about the moter going boom boom!!
speedyhans is offline   Reply With Quote
 Old 06-19-2010, 10:44 AM   #2
phillyb's Avatar
Posts: 14,702   (View Stats)
Groans: 1,940
i don't care what you do, but you're like filipino or some shit...can you get me some filipino pussy?
 Old 06-19-2010, 10:49 AM   #3
ILL3ST
xcoldricex's Avatar
Posts: 2,777   (View Stats)
Groans: 105
i think you should invest in spell check.
if you don't want to worry that much about your motor exploding, then don't do anything.... or put the money into the block. save money, wait for other people to slap 35r's on the stock block and see if they explode. by that time you should have saved enough money to build the block and buy a turbo kit.
 Old 06-19-2010, 11:27 AM   #4
speedyhans's Avatar
well the thing its that I have a smoking turbo so i need to change the turbo anyway.
if ur not going to say nything helpfull go somewere els.
Last edited by speedyhans; 06-19-2010 at 11:27 AM. Reason: MSF Database - Automerged Doublepost
The Following User Says NO Thank You to speedyhans For This Un-useful Post:
 Old 06-19-2010, 11:35 AM   #5
manelscout4life's Avatar
Posts: 1,781   (View Stats)
Groans: 661
get HID's
manelscout4life is offline   Reply With Quote
 Old 06-19-2010, 12:35 PM   #6
speedyhans's Avatar
^^LMAO
 Old 06-19-2010, 12:36 PM   #7
phillyb's Avatar
Groans: 1,940
number 1 for me
 Old 06-19-2010, 12:38 PM   #8
madvillain's Avatar
Posts: 4,160   (View Stats)
Groans: 78
Option Two speedy, do not go big turbo with IWG, you will be fighting boost spike constantly and it's not worth the stress to your motor.
If you're going to get balls deep in it, do it right the first time. i think if you did option one you would be dissapointed and eventually re-do it anyways.
 Old 06-20-2010, 05:20 AM   #9
speedyhans's Avatar
well the thing i dont race the car any more, i just want to know that i have a lil more kick to then stock so im not looking for a 400 hp set up im ok with over 300hp that y im considering the fist set up
 Old 06-20-2010, 06:22 AM   #10
-cj-'s Avatar
Posts: 649   (View Stats)
-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world
If you don't want huge amounts of hp, just get a reworked stock turbo and max out on bolt ons... You don't need a bt to get into the 300s.
Mod List: ATP 3071R @ 22 psi, Grimspeed in 3-port mode, Steedspeed Manifold, Snow Performance Stage 2 Meth Kit, Cobb AP, CP-E 3" Nano SRI, CP-E Big Inlet TIP, Cobb "Stage 2" Suspension Kit, CP-E FMIC, CP-E DP, CP-E HPFP, CP-E MM, TWM STS, Custom Tuned by Fobio.
-cj- is offline   Reply With Quote
 Old 06-20-2010, 06:24 AM   #11
speedyhans's Avatar
YEA but is nice to have it lol .
Page generated in 0.29743 seconds with 24 queries
