 Old 03-29-2010, 08:42 PM   #1
mason's Avatar
Posts: 946   (View Stats)
Default what turbo to go with? GTs
GT 3076 or GT 35.
if it was you witch one would you get.
and what rpm do these turbos start to spool?
i really think the problem with people bending rods is that the stock turbo spools to soon in the rpm.
thanks
The Following User Says Thank You to mason For This Useful Post:
superskaterxes (03-29-2010)
 Old 03-29-2010, 08:56 PM   #2
gsrtype1's Avatar
Posts: 7,514   (View Stats)
Groans: 102
this is part my delima as well. I may do a precision turbo too.
 Old 03-29-2010, 09:01 PM   #3
2871=3000
3071=3500
76=4k
35r=4500
i love my 3076. its the best suited turbo for this displacement
gsrtype1 (03-30-2010), TheNewGuy (04-16-2010)
 Old 03-29-2010, 09:01 PM   #4
clos561's Avatar
Posts: 1,172   (View Stats)
clos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the world
get which ever you can get for the cheapest, both are good and would probably spool just over 4k.
in this video he is brake boosting but you can hear when the tires break loose and thats probably when he hits full boost. i think there are more 3076 guys. how much boost do you want to run on either turbo?
7-Inch Jensen Flip Out Touch Screen, HKS SSQ, MS CAI, Prosport Premium Amber/White Boost Gauge,2nd Cat Gutted, Delrin TRZ MM,16 inch FD rims,TWM shifter Bushings,COBB Turbo Inlet, 28psi, rebuilt stock block, custom rods and piston heads/gaskets, underdrive pulleys, big cams, big oil filter, stage4 clutch, stage4 DISI injectors, Fuel Pump, 4inch Catless TBE with screamer pipe, external wastegate spring modification,Methanol direct twin port duty cycle injection. Tuned by Nator Performance
clos561 is offline   Reply With Quote
The Following User Says Thank You to clos561 For This Useful Post:
AZSPEED3 (03-29-2010)
 Old 03-29-2010, 09:11 PM   #5
Speedkid's Avatar
Posts: 65   (View Stats)
Speedkid is just really niceSpeedkid is just really niceSpeedkid is just really niceSpeedkid is just really nice
Go for the gt35. How much power are you going for?
Speedkid is offline   Reply With Quote
 Old 03-29-2010, 09:18 PM   #6
-cj-'s Avatar
Posts: 649   (View Stats)
-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world
I think most people go with the 3076... Try out the GT35...
Or be different:
May have some fitment issues, but wait till boost kicks in....
Mod List: ATP 3071R @ 22 psi, Grimspeed in 3-port mode, Steedspeed Manifold, Snow Performance Stage 2 Meth Kit, Cobb AP, CP-E 3" Nano SRI, CP-E Big Inlet TIP, Cobb "Stage 2" Suspension Kit, CP-E FMIC, CP-E DP, CP-E HPFP, CP-E MM, TWM STS, Custom Tuned by Fobio.
-cj- is offline   Reply With Quote
The Following 7 Users Say Thank You to -cj- For This Useful Post:
JohnMS3 (04-01-2010), kilik2 (04-25-2010), nighthawk358 (04-04-2010), RayRayBauder (05-19-2010), super_pablo_ (04-18-2010), TheNewGuy (05-31-2010), ZoomZoomPSSH (05-31-2010)
 Old 03-29-2010, 09:20 PM   #7
cageyvet's Avatar
Posts: 715   (View Stats)
HTA 35r
 Old 03-29-2010, 09:22 PM   #8
Smoker6's Avatar
Posts: 984   (View Stats)
Smoker6 is the leader of the worldSmoker6 is the leader of the worldSmoker6 is the leader of the worldSmoker6 is the leader of the worldSmoker6 is the leader of the worldSmoker6 is the leader of the worldSmoker6 is the leader of the worldSmoker6 is the leader of the worldSmoker6 is the leader of the worldSmoker6 is the leader of the worldSmoker6 is the leader of the world
My GT2871r spools much earlier than 3000 with all my breather mods, though I honestly never boost below ~3500 or so anyway.
'06 Black Cherry Mica Speed6 Since 2-26-07 | 0-60: 3.87s |
CPE CAI, SU MM, Synapse BPV, Magnaflow 2.5" CBE, MDS DashHawk, TWM SS Stage 1, TT Front MM, TT Rear Diff Mount, SU StiffDiff, Whiteline RSB, BC Coilovers, mrlilguy CDFP, CPE Catted DP, HKS Twin Power Ignition System, RAYS Gram Lights 57 Maximum Time Attack, CPE TIP, Denso 2Step Colder Spark Plugs, COBB Shifter Weight, SPC Ball Joints, VTCS, BS, & EGR Delete, VentPod w/VEI Boost Guage, Saikou Michi CC, Labonte ISG-S3 (not installed), GT2871r, DNP manifold, Tial 44mm EWG, Cobb AP, TT Liquid to Air Intercooler, DMH 3" exhaust cutout.
Smoker6 is offline   Reply With Quote
The Following User Says Thank You to Smoker6 For This Useful Post:
phillyb (03-30-2010)
 Old 03-29-2010, 09:31 PM   #9
dizzin9's Avatar
Posts: 1,807   (View Stats)
dizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the world
Groans: 77
it depends if u like lag. i got a 3071 coz i like the fact it spools @ ~3700-4000 and i only WOT around these rpms anyway with stock turbo. so i eliminated PT boost and i can cruise @ 15in.Hg easy.
2008.5 MAZDASPEED3 GT TRUE RED ***GONE***
2012 FORD MUSTANG GT >>> 400A Premium _ Performance White _ 6MT _ 3.73 _ HID & Security Pkg
Koni Yellows _ Whiteline FSB & RSB _ FRPP K-Springs w/ Bump Stops, Boss 302 Strut Tower Brace, GT500 Strut Mounts, GT500 RCA, GT500-style AB
J&M PHB _ Eibach Camber Bolts _ Avant Garde M510 Satin Silver 19x9.5 40ET _ Hankook Ventus S1 noble2 275/40/19
dizzin9 is offline   Reply With Quote
 Old 03-29-2010, 09:36 PM   #10
clos561's Avatar
this looks pretty cheap, they have a 3076 for basically the same price.
cxracing.com: Ball Bearing GT35R GT35 Turbo Charger Turbocharger T3
 Old 03-29-2010, 09:38 PM   #11
18psiWhiteMS3
Lurkers
18psiWhiteMS3's Avatar
Posts: n/a
then how would u know that it spools before 3000 is u never boost below 3500
 Old 03-29-2010, 09:42 PM   #12
Smoker6's Avatar
Well I was curious once. Was a nice low boost map.
 Old 03-29-2010, 11:07 PM   #13
11cruzito11's Avatar
Posts: 824   (View Stats)
Groaned at 5 Times in 2 Posts
2871=3000
3071=3500
76=4k
35r=4500
noob question, so when the wastegate opens up thats when the turbo spools?
my wastegate opens up around 4k and full-boost on 4.5k, does that sound right?
 Old 04-01-2010, 04:56 PM   #14
mason's Avatar
im looking for around 400 whp to start. but have the ability to hit 500 if i wanted.
thats what im looking for?
 Old 04-03-2010, 10:29 PM   #15
zx2man's Avatar
Posts: 1,356   (View Stats)
Hey Dizzin...how much power you making..your running stock internals correct?.
zx2man is offline   Reply With Quote
 Old 04-04-2010, 06:34 AM   #16
dizzin9's Avatar
Groans: 77
yeah stock internals. i'm getting a pro tune next week with meth @ 18psi then i'll find out how much power i'm making.
 Old 04-18-2010, 09:46 AM   #17
mattizle14's Avatar
Posts: 96   (View Stats)
mattizle14 is a jewel in the roughmattizle14 is a jewel in the roughmattizle14 is a jewel in the roughmattizle14 is a jewel in the rough
this is the great question...how much horse do you think i would get out of my car...and the answer is...idk lol im still trying to figure it out...i want to get the gt35r but they r expensive and dont have the money right now since i kinda just went out and bought everything that is in my sig...so yea...lol
2008.5 Mazdaspeed 3 GT...Fully Forged Block...Ported Heads...Wiseco Forged Pistons/Pauter Forged Rods...COBB SRI...COBB DP...COBB AP...PnP Fuel Pump Internals...Cometic Head Gasket...ARP Head Studs...Denso Iridium HR:8...StreetUnit Rear Motor Mount...ACT 6 Puck Sprung Clutch Kit...Aluminum Flywheel...
mattizle14 is offline   Reply With Quote
 Old 04-27-2010, 06:23 PM   #18
Jessed87's Avatar
Posts: 149   (View Stats)
Jessed87 is a splendid one to beholdJessed87 is a splendid one to beholdJessed87 is a splendid one to beholdJessed87 is a splendid one to beholdJessed87 is a splendid one to beholdJessed87 is a splendid one to beholdJessed87 is a splendid one to behold
I have done quite a bit of reading up on this topic because I was having the same dilemma. I ended up going with the GT3076 for a few reasons. First of all It is a few hundred bucks cheaper and a tiny bit faster spooling than the GT35. The second reason is that the GT3076 is rated at around 500 crank horsepower at it's maximum output. I don't think I'll ever be in danger of seeing that much power unless some sort of breakthrough is made.
Jessed87 is offline   Reply With Quote
 Old 05-16-2010, 09:26 PM   #19
ILL3ST
xcoldricex's Avatar
Posts: 2,777   (View Stats)
Groans: 105
no, when the wastegate is open you're "wasting" exhaust gases that would otherwise be spinning the turbine.
 Old 05-19-2010, 12:58 PM   #20
amoosenamedhank's Avatar
Posts: 1,368   (View Stats)
Groans: 53
In reading your sig I have become very confused... how do you have ported heads?? Did you get an extra head ported as a spare?
 Old 05-19-2010, 01:02 PM   #21
BrianZX10R's Avatar
Posts: 1,163   (View Stats)
BrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the world
Groans: 88
Groaned at 121 Times in 75 Posts
gt3076 by far
1995 honda civic. 1.6L slow
2007 Kawasaki ZX10r
BrianZX10R is offline   Reply With Quote
 Old 05-23-2010, 03:04 PM   #22
cageyvet's Avatar
HTA35r
 Old 05-31-2010, 09:39 AM   #23
TheNewGuy's Avatar
Posts: 144   (View Stats)
TheNewGuy has a reputation beyond reputeTheNewGuy has a reputation beyond reputeTheNewGuy has a reputation beyond reputeTheNewGuy has a reputation beyond reputeTheNewGuy has a reputation beyond reputeTheNewGuy has a reputation beyond reputeTheNewGuy has a reputation beyond reputeTheNewGuy has a reputation beyond reputeTheNewGuy has a reputation beyond reputeTheNewGuy has a reputation beyond reputeTheNewGuy has a reputation beyond repute
once i get the money im going 3071 just because with breather mods ive heard of it spooling around 3200rpm and producing enough power to max out the mzr engine. (right now at least)
Mazdaspeed6
I work stock evo's like its my job.
I make yellow lights my Bitch.
Mods: gt3076r
TheNewGuy is offline   Reply With Quote
 Old 05-31-2010, 01:50 PM   #24
Overkill's Avatar
Posts: 15   (View Stats)
Overkill is a jewel in the roughOverkill is a jewel in the roughOverkill is a jewel in the rough
Gt35 if you looking 400+
Overkill is offline   Reply With Quote
Geneva Preview: Techart to debut 911 Turbo, Turbo S Haltech Automotive News 0 02-16-2010 03:20 PM
Turbo swap (cx-7 turbo for ms3 turbo on MS6) johnnyspeed6 MazdaSpeed 3/6 - Turbo Induction 9 09-19-2009 08:56 AM
First Drive: 2008 Ford Falcon G6E Turbo and XR6 Turbo Haltech Automotive News 2 05-04-2009 06:48 PM
Page generated in 0.41213 seconds with 37 queries
