 Old 05-08-2013, 09:17 AM   #1
Opdahl's Avatar
Posts: 4,232   (View Stats)
Opdahl is the leader of the worldOpdahl is the leader of the worldOpdahl is the leader of the worldOpdahl is the leader of the worldOpdahl is the leader of the worldOpdahl is the leader of the worldOpdahl is the leader of the worldOpdahl is the leader of the worldOpdahl is the leader of the worldOpdahl is the leader of the worldOpdahl is the leader of the world
Default Wisco's Forged Motor & GTX3076 Build
Well looks like I am going to be joining the built block and BT club. I did a compression test a few weeks ago and it indicated that I have a ringland failure. Anyways I decided if I have to rip apart the motor I might as well make it stronger in the process and go the forged + BT route. Right now I am finalizing my build list for the motor, as this will be a two step process. Build the motor within the next month or two and go BT after everything on the motor is broken in.
This is my first "performance" rebuild so if I am missing something important you should probably let me know. Here is what I have on the list so far..
Wiseco Pistons .020 over
Manley Rods
CPE Safe-Seals
ARP Head and Main studs
JBR BSD, I'll probably see if I can get the machine shop to just put a bolt in there for me.
MZR Rebuild kit from Edge W/ New oil pump, VVT, Timing chain
Most likely forgot something but whatever I'll remember it later. For the turbo I plan on doing a EWG GTX3076 kit from Edge as well. If I do have the funds I would much rather find a "better" setup T3 manifold, Twinscroll, ect.
It's about time I start doing some work.
2007 MS3 | Cobb AP | JBR 80 RMM | HTP 3" Intake | CNT Turboback | Forge V2 | NGK Plugs | KMD Internals | CPE TMIC | FreekTune | JBR RSB
2009 Ninja 650R
Opdahl is offline   Reply With Quote
The Following 6 Users Say Thank You to Opdahl For This Useful Post:
BackRoads (05-09-2013), blackmicamps6 (05-08-2013), captain slow (05-08-2013), Dimenus (05-08-2013), jracer (05-11-2013), mxlplx71 (05-08-2013)
 Old 05-08-2013, 09:23 AM   #2
Dimenus's Avatar
Posts: 2,825   (View Stats)
Groans: 33
Look at this scrub go. I'll be there for moral support and beer, and well beer.
2012 Velocity Red Mica
 Old 05-08-2013, 10:29 AM   #3
holeinmypocket's Avatar
Posts: 1,129   (View Stats)
holeinmypocket is the leader of the worldholeinmypocket is the leader of the worldholeinmypocket is the leader of the worldholeinmypocket is the leader of the worldholeinmypocket is the leader of the worldholeinmypocket is the leader of the worldholeinmypocket is the leader of the worldholeinmypocket is the leader of the worldholeinmypocket is the leader of the worldholeinmypocket is the leader of the worldholeinmypocket is the leader of the world
Sorry u aren't the first Wisconsins first built motor just thought of let u know...anyways looking forward to this tread
Just sayin
Last edited by holeinmypocket; 05-08-2013 at 10:29 AM. Reason: MSF Database - Automerged Doublepost
holeinmypocket is offline   Reply With Quote
The Following User Says Thank You to holeinmypocket For This Useful Post:
sick_role (05-08-2013)
 Old 05-08-2013, 10:34 AM   #4
Opdahl's Avatar
Just sayin
From all of the people who are active in NATOR WI, no one has built a motor yet. I'm only as good as the information that I have received.
I really could care less if I'm the first one or not. I just wanna go fast!
2009 Ninja 650R
The Following User Says Thank You to Opdahl For This Useful Post:
 Old 05-08-2013, 11:37 AM   #5
captain slow's Avatar
Posts: 5,559   (View Stats)
Groans: 398
Sweet! If you need help with it let me know, the drive down would be worth the knowledge learned. I can help hand over tools or document it, whatever you need.
 Old 05-08-2013, 11:44 AM   #6
MS6 Sanchez's Avatar
Posts: 405   (View Stats)
MS6 Sanchez is the leader of the worldMS6 Sanchez is the leader of the worldMS6 Sanchez is the leader of the worldMS6 Sanchez is the leader of the worldMS6 Sanchez is the leader of the worldMS6 Sanchez is the leader of the worldMS6 Sanchez is the leader of the worldMS6 Sanchez is the leader of the worldMS6 Sanchez is the leader of the worldMS6 Sanchez is the leader of the worldMS6 Sanchez is the leader of the world
Groaned at 7 Times in 4 Posts
Don't forget that you have NATOR IL to the south, I bet a few guys wouldn't mind driving up to give you a hand
'06 Mazdaspeed6 Sport | LPM
MODS:
COBB SF | COBB TIP | SURE RMM | CXRacing FMIC | M2 DP | NGK Laser Iridiums | Magnaflow CB | COBB AP Stg 2 SF+TIH+IC 93 | Autotech FP Internals | JBR SSP, SSB, and Heavy Knob | EBC Ultimax Rotors | EBC Red Stuff Pads | Plastidipped Grill | 20% Tint all around 50% Windshield
I'm SO stock it HURTS
MS6 Sanchez is offline   Reply With Quote
The Following User Says Thank You to MS6 Sanchez For This Useful Post:
Opdahl (05-08-2013)
 Old 05-09-2013, 09:47 PM   #7
BackRoads's Avatar
Posts: 575   (View Stats)
BackRoads is the leader of the worldBackRoads is the leader of the worldBackRoads is the leader of the worldBackRoads is the leader of the worldBackRoads is the leader of the worldBackRoads is the leader of the worldBackRoads is the leader of the worldBackRoads is the leader of the worldBackRoads is the leader of the worldBackRoads is the leader of the worldBackRoads is the leader of the world
Sub'd - looking forward to learning from your experience!
2007 Sunlight Silver MazdaSpeed3 Sport | BNR S3v2 | Autotech Internals | Cobb TIH | 3BAR MAP Sensor | Denso itv-22's | MSCAI | ETS 3.5" TMIC | Synchronic DV | Stratified EBCS | Guardian Angel | UR Test Pipe | Cobb AP | Koni Yellows | JBR RMM | CORN YEAH! | 265,000m | Tuned by STRATIFIED!!!
To install: CPE SafeSeals
2012 Velocity Red MazdaSpeed3 w/Tech | Autotech Internals | Sure Aeros V2 | 98,000m
BackRoads is offline   Reply With Quote
 Old 05-10-2013, 11:49 PM   #8
Swinger13's Avatar
Posts: 3,480   (View Stats)
Groans: 53
I like your idea of breaking in the motor then putting on a BT; did you consider possibly putting everything on at once then just running a conservative tune for the break in period?
Performance:
Stratified Tune in progress
 Old 05-11-2013, 06:03 AM   #9
Opdahl's Avatar
I did think about putting everything on at once but that just doesn't sit well with me. The last thing I would want is something to malfunction and that causing a multitude of things to blow up. That is a lot of new parts to install at once, I would much rather make sure that the engine is solid before I start throwing some actual boost at it.
Also I am a college student so my funds aren't exactly plentiful. The only way that I could really afford this is by buying/installing it in stages. It looks like I'll be living off Ramen for the next few months again. Woot!
2009 Ninja 650R
Swinger13 (05-11-2013)
Time for some EFR Forged Madness! Motor Build Advice Needed >>> Alpha MazdaSpeed 6 - Engine, Transmission & Driveline 103 06-03-2014 03:34 PM
2006 ms6 forged motor/gtx3071r build Juliandlr1004 MazdaSpeed 3/6 - Build Diaries 82 08-07-2013 06:35 PM
LakeSpeed6 GTX3076 Build Lakespeed6 MazdaSpeed 3/6 - Big Turbo Builds 60 04-12-2013 08:09 AM
Coaststarlight's Forged Motor Build Thread! Coaststarlight MazdaSpeed 6 - Engine, Transmission & Driveline 37 02-09-2011 02:30 PM
Page generated in 0.28947 seconds with 26 queries
