| CorkSport To say that CorkSport is passionate about Mazda Performance is understatement. It is the essence of what we do. Our mission to offer unparalleled customer service and support, an uncompromising commitment to the community, and deliver top quality performance parts is demonstrated with each product we develop to help fulfill your vehicles performance potential. At CorkSport we believe it doesn’t have to come in a fancy package or be the most expensive product on the market to be the best. |
![]() | | #41 | ![]() |
| Not Ranked : 0 score Sent from my SM-N900V using Tapatalk
| The Following 2 Users Say Thank You to WetzMS3 For This Useful Post: | KiwiFlavor (11-29-2016), Shwa (12-08-2016) |
![]() | | #42 | ![]() |
![]() ![]() Join Date: May 2013 Location: Buffalo Grove, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 245
Groaned at 61 Times in 31 Posts
__________________ DUMB MILLENNIAL RICER | |
![]() | | #43 | ![]() |
| Not Ranked : 0 score Both. Don't make the banhammer come out. Sent from my SM-N900V using Tapatalk
![]() | | #44 | ![]() |
![]() Join Date: Sep 2013 Location: Mt. Greenwood, Chicago, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 583
__________________ 2010 CBM Mazdaspeed3 Freektune 93 CorkSport SRI, TIP & Race Pipe CP-E Stage 2 RMM & TMIC Cobb Accessport V3 Autotech HPFP Internals Pilot Super Sport 235/40/18 - Stock Pu Pilot Alpin PA3 215/50/17 - Sport Edition CE 2016.5 MGM Mazda CX-5 Touring |
| The Following User Says Thank You to Gerbilo For This Useful Post: | mooseaidz (11-29-2016) |
![]() | | #45 | ![]() |
![]() Join Date: Dec 2013 Location: Plainfield, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,712
| Not Ranked : 0 score Ah typical mazdaspeedforums ADHD. Gotta love it. So let's divide up his car, Chris gets lower tie bar and a brand new set of CS cams, I get the skid plate, anyone else calling dibs on anything?
__________________ 2010 black mica speed3 The go: Depo racing: downpipe (100 cell count), custom: FMIC. HTP: 3.5" intake, under route piping. JBR: shortshifter, RSB. Autotech: HPFP internals. Go fast bits: hybrid BPV, VMR: 18x8.5 V710s, Bridgestone: potenza re760 245/40/18, KW: v3 coilovers,SPC: camber arms, freektuned, Damond Motorsports: dual OCC, PMM, PCV plate, RMM, TMM, EGR delete, FoSt mani, Corksport: battery box(fuck this thing), injector seals, Cobb: EBCS, AP v3. AEM: methanol. Seibon: carbon fiber hood. UR: catback. Bosch: 3bar. BNR: s4, DNP: EWG manifold, Tial: 38mm mvs EWG. The show: 5% tint all around, 50% tint windshield, rally armor mudflaps, Sony XAV64BT touchscreen headunit, katskin leather interior, CPE relocation plate, Maisonvi weighted shift knob, Corksport hoodscoop, black housing headlights. Soon:built motor |
![]() | | #46 | ![]() |
| Not Ranked : 0 score I want his spoiler! Dibs!
![]() | | #47 | ![]() |
![]() Join Date: Aug 2012 Location: Middle Coast
Rep Power: 263 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 436
Groans: 126
| Not Ranked : 0 score I have been driving with this new bar since Friday, and my impression so far is:
__________________ Genpoo stuff |
| The Following User Says Thank You to sharksinspace For This Useful Post: | mooseaidz (11-29-2016) |
![]() | | #48 | ![]() |
![]() Join Date: Aug 2013 Location: Ft Myers, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 34
Dibs on another boost leak Sent from my iPhone using Tapatalk
__________________ CS TIP/SRI CS RMM CS Sexy Steering Wheel CS Springs & Struts CS Shirt Throw Shifter CS Shifter Bushings CS TBE CS Boost Tubes CP-e TMIC HKS BOV in resirc DM Vented OCC DM TMM DM PMM DM SSP Autotech Internals Custom E33 Freaktune | |
| The Following User Says Thank You to Jonb82 For This Useful Post: | KiwiFlavor (11-29-2016) |
![]() | | #49 | ![]() |
![]() Join Date: Jan 2015 Location: Lincoln, NE
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 93
| Not Ranked : 0 score @CorkSport; would these be better suited for a bigger turbo to help with spool or is there little effect on that with this upgrade? Sent from my iPhone using Tapatalk
__________________ 07 Black Mica MS3: Built motor- SP63 Pro Series 88mm 9.5CR pistons, Manley H-beam rods, Clevite Main/Rod bearings, ARP main studs, L19 head studs, ACT 6-puck sprung clutch w/ Prolite Flywheel, AP V3, Stratified E85 tune/EBCS, NGK plugs, Autotech internals, Corksport injector seals/short shift plate/shifter bushings/LED kit, Cp-e FMIC/catless down pipe, Damond RMM/TMM, Mazdaspeed CBE, JBR SRI/TIP/recirc hose/BSD/oil pan baffle/EGR delete/51r battery box, Forge V2 BPV, Koni yellows, and Cobb springs, Gold Enkei RPF1 w/ 245/45/17 sport comp 2's |
![]() | | #50 | ![]() |
| Approved MSF Vendor ![]() ![]() Join Date: Mar 2008 Location: Vancouver, WA
Rep Power: 4731 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,820
Derrick | |
![]() | | #51 | ![]() |
Were they tested on any cars pushing 30+psi and a higher than stock rev limiter? If so, how have the valves and valve springs held up? Sent from my iPhone using Tapatalk
__________________ 07 Black Mica MS3: Built motor- SP63 Pro Series 88mm 9.5CR pistons, Manley H-beam rods, Clevite Main/Rod bearings, ARP main studs, L19 head studs, ACT 6-puck sprung clutch w/ Prolite Flywheel, AP V3, Stratified E85 tune/EBCS, NGK plugs, Autotech internals, Corksport injector seals/short shift plate/shifter bushings/LED kit, Cp-e FMIC/catless down pipe, Damond RMM/TMM, Mazdaspeed CBE, JBR SRI/TIP/recirc hose/BSD/oil pan baffle/EGR delete/51r battery box, Forge V2 BPV, Koni yellows, and Cobb springs, Gold Enkei RPF1 w/ 245/45/17 sport comp 2's | |
| The Following User Says Thank You to zjnspeed3 For This Useful Post: | Pu Manchu (12-02-2016) |
![]() | | #52 | ![]() |
| Banned ![]() Join Date: Jun 2010 Location: Austin, Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 46
Groaned at 8 Times in 5 Posts
| Not Ranked : 0 score |
![]() | | #53 | ![]() |
| COCKSTRONG ![]() ![]() ![]() Join Date: Jul 2011 Location: Your Mom's House
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,809
Groans: 890
__________________ Searching for something? Try MS3Shadow's Custom Search EVERY "I DON'T USE MSF" FACEBOOK RETARD EVER | |
| The Following 7 Users Say Thank You to SofaKingAwesome For This Useful Post: | Djohns (12-02-2016), g00s3y (01-19-2017), Mauro_Penguin (12-06-2016), monkey.bones.007 (12-05-2016), mooseaidz (12-02-2016), Pu Manchu (12-02-2016), Shwaykid (12-02-2016) |
![]() | | #54 | ![]() |
![]() Join Date: Apr 2013 Location: Somersworth, NH
Rep Power: 878 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,570
| Not Ranked : 0 score lol!
__________________ 2012 NASA Spaceship Gray MS3 BNR S3 - JBR Tru 3.0" - CP-E TMIC - Corksport catless DP - Corksport catted race pipe - Forge V2 - Autotech internals + AP v3 - Swift springs - Enkei RPF1 17x9 + 45 (5mm JBR spacers in the front) - Freektune 320/346 |
| The Following User Says Thank You to KiwiFlavor For This Useful Post: | mooseaidz (12-02-2016) |
![]() | | #55 | ![]() |
| Not Ranked : 0 score probs
| The Following User Says Thank You to WetzMS3 For This Useful Post: | mooseaidz (12-02-2016) |
![]() | | #56 | ![]() |
| Not Ranked : 0 score LOL
![]() | | #57 | ![]() |
Groans: 438
| Not Ranked : 0 score I don't need these, but I also didn't need to do any mods to my car either... Oh well...
__________________ All good things must come to an end... |
| The Following 3 Users Say Thank You to g00s3y For This Useful Post: |
![]() | | #58 | ![]() |
![]() Join Date: Nov 2016 Location: loveland, Ohio
Rep Power: 0 ![]() ![]() ![]() Thanks: 1
| Not Ranked : 0 score any videos yet...im very curious and I might be forced to build my motor here soon...
__________________ '12 tech package corksport TBE turbosmart supersonic xxr 530 gold 18x8.75 +20 235/40 BFG g-force a/s |
![]() | | #59 | ![]() |
(Thread Starter) | Not Ranked : 0 score Our shop car is apart for a future part to be released so I have been able to shoot any video. It should be back together this week. Derrick |
![]() | | #60 | ![]() |
| Not Ranked : 0 score another new part??? your just making the anticipation worse
| The Following 2 Users Say Thank You to whitedevil For This Useful Post: | KiwiFlavor (12-05-2016), mooseaidz (12-05-2016) |
![]() | | #61 | ![]() |
![]() | | #62 | ![]() |
| Not Ranked : 0 score I'm more than willing to save you the trouble of putting up a sound clip. Just send me a set I'll get them in and post a sound clip for you! No hassle!
![]() | | #63 | ![]() |
There are a few cars who've been running the first run of these for quite a while. I'm sure there are videos of these cars if you know where to look and really are curious.
__________________ 2013 MS3 Black Mica SLUGGISH RUGGISH BONE SLUNTWORKS SPEEDSHOP | ||
![]() | | #64 | ![]() |
| Not Ranked : 0 score Pretty sure there is one if not two cars with the cams in these videos. I could be remembering timing wrong. http://youtu.be/dKKgwRguCG8 http://youtu.be/CH1kusFWdyk
![]() | | #65 | ![]() |
__________________ 2010 black mica speed3 The go: Depo racing: downpipe (100 cell count), custom: FMIC. HTP: 3.5" intake, under route piping. JBR: shortshifter, RSB. Autotech: HPFP internals. Go fast bits: hybrid BPV, VMR: 18x8.5 V710s, Bridgestone: potenza re760 245/40/18, KW: v3 coilovers,SPC: camber arms, freektuned, Damond Motorsports: dual OCC, PMM, PCV plate, RMM, TMM, EGR delete, FoSt mani, Corksport: battery box(fuck this thing), injector seals, Cobb: EBCS, AP v3. AEM: methanol. Seibon: carbon fiber hood. UR: catback. Bosch: 3bar. BNR: s4, DNP: EWG manifold, Tial: 38mm mvs EWG. The show: 5% tint all around, 50% tint windshield, rally armor mudflaps, Sony XAV64BT touchscreen headunit, katskin leather interior, CPE relocation plate, Maisonvi weighted shift knob, Corksport hoodscoop, black housing headlights. Soon:built motor | |
| The Following User Says Thank You to Djohns For This Useful Post: | mooseaidz (12-06-2016) |
![]() | | #66 | ![]() |
(Thread Starter) | Not Ranked : 0 score Maybe I should have said parts, there are 5 scheduled to be released before July 2017 for the Mazdaspeed 3/6. -Derrick |
| The Following 6 Users Say Thank You to CorkSport For This Useful Post: | jax ms3gt (01-18-2017), KiwiFlavor (12-06-2016), Mattyhawk1 (12-06-2016), MS3Shadow (12-06-2016), sharksinspace (01-10-2017), WetzMS3 (12-06-2016) |
![]() | | #67 | ![]() |
![]() Join Date: Nov 2010 Location: Houston, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,489
| Not Ranked : 0 score Deleted. Never mind.
__________________ Past: - 2010 Speed3 W/ GTx3576 ~500 whp - -Sold- -Mustang 5.0 450 whp / 352 wtq -Sold- Current: 2012 Loaded Speed3 - Stock 2001 Miata - Basically stock ... Something, somewhere, went horribly wrong. Fastest gtx3576 powered, 6th port injected, 25% e85 fueled, stock suspension, silver mazdaspeed 3 in South Houston. Because its my internet record, and I said so. |
![]() | | #68 | ![]() |
| Not Ranked : 0 score hmm
| The Following User Says Thank You to whitedevil For This Useful Post: | mooseaidz (12-06-2016) |
![]() | | #69 | ![]() |
| The Following User Says NO Thank You to unokevin1 For This Un-useful Post: | Mauro_Penguin (12-09-2016) |
![]() | | #70 | ![]() |
Groans: 890
| Not Ranked : 0 score Say that again?
![]() | | #71 | ![]() |
![]() | | #72 | ![]() |
![]() Join Date: May 2013 Location: CO
Rep Power: 2407 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,487
| Not Ranked : 0 score This hopefully provides entertainment for my Friday. crapatalk, yes it sucks for free. |
![]() | | #73 | ![]() |
| Not Ranked : 0 score ![]() I think this is what he had in mind Sent from my iPhone using Tapatalk
| The Following 6 Users Say Thank You to Jonb82 For This Useful Post: | AnimalMother (12-11-2016), FSRRM (01-04-2017), Gerbilo (12-09-2016), KiwiFlavor (01-11-2017), monkey.bones.007 (12-09-2016), SofaKingAwesome (12-09-2016) |
![]() | | #74 | ![]() |
![]() Join Date: Dec 2015 Location: New Zealand
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 15
| Not Ranked : 0 score Any updates on these cams? dyno's with K04, WOT videos? |
![]() | | #75 | ![]() |
![]() Join Date: Apr 2013 Location: San Antonio TX
Rep Power: 221 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 362
__________________ COBB BROKE JMS FIXED MazdaSpeed. Errrone can afford |
![]() | | #76 | ![]() |
Groans: 126
| Not Ranked : 0 score But tell me moooooorrreeeee
![]() | | #77 | ![]() |
| Not Ranked : 0 score Would it be possible to purchase blanks?
![]() | | #78 | ![]() |
| Not Ranked : 0 score If it's popsicle it's possible. So the real question is, is it popsicle?
![]() | | #79 | ![]() |
![]() | | #80 | ![]() |
![]() | Not Ranked : 0 score Nice! |
| Lets talk Camshafts | CorkSport | 2010 MS3 - Engine, Transmission & Driveline | 118 | 12-03-2013 07:36 PM |
| camshafts who has them? | b4n30n3 | MazdaSpeed 3 - Engine, Transmission & Driveline | 5 | 12-31-2011 05:34 PM |
| Cosworth camshafts | jlefebvre123 | MazdaSpeed 3 - Engine, Transmission & Driveline | 9 | 06-28-2011 01:37 PM |
