 Old 12-02-2016, 06:54 PM   #1
eliwwjd's Avatar
Posts: 518   (View Stats)
Default corksport divorce catted downpipe 65mm review question
I was considering to purchase for Christmas a cs divorce 65mm dp but had a few questions to those who have it. At the moment I have the corksport racepipe. How is the noise and smell compare to with just racepipe? should I expect way louder sound and really bad fumes smell?
Emissions in PR are not so strict but was still wondering if I was able to pass emissions test?Is the long catted downpipe a true 3" piping from end to end? (The reason why im asking is because I see divorce model has 2 separate exhaust flows being one for the wastegate)
Hopefully somebody can help me here!
Forge BPV V2//COBB AP V3// COBB DP //ETS TMIC//AUTOTECH HPFP//JBR SRI//JBR TIP//JBR COOLANT BYPASS KIT//JBR DISI HOSES//JBR BYPASS HOSE//JBR THROTTLE BODY THERMAL GASKETS//JBR SHIFTER BUSHINGS// //RACING BEAT CBE//DAMOND MOTORSPORTS OCC//COBB RMM//CS LED KIT//CS LED FOGS//CBI OSRAM HID BULBS//CONTI EXTREME CONTACT 235/40 R18//RACESENG SHIFT KNOB//FREEKTUNED ON 93 PUMP GAS
 Old 12-02-2016, 07:22 PM   #2
MSF's Punishing Member
Pu Manchu's Avatar
Posts: 2,992   (View Stats)
Groans: 546
noise and smell are things that don't translate well across the internet.
and none of us are experts on puerto rican emissions laws, come on bro
94 M
MS6
IS350
 Old 12-02-2016, 07:52 PM   #3
eliwwjd's Avatar
Ok maybe I didn't explain myself correctly, what I meant was how bad are the fumes from the catted downpipe considering that the cat is smaller and has less cells compare to oem cat?
How much louder is it when compared to having just the cs racepipe and oem cat?
I know you are not an expert in Puerto Rican emission laws but like for instance, in the states is this cat sufficient to pass emissions test?(Just want to know, that's all)
The Following User Says Thank You to eliwwjd For This Useful Post:
ZachS. (12-03-2016)
 Old 12-02-2016, 08:36 PM   #4
sheston's Avatar
Posts: 1,847   (View Stats)
I've got a divorced downpipe (cat-less) and race pipe and muffler delete and corksport single exhaust catback, so basically nothing after the turbo except the resonator. I run Meth and haven't noticed any bad smells.
 Old 12-02-2016, 08:53 PM   #5
eliwwjd's Avatar
Thank you Sir for your answer. Just what to have an idea of what to expect from product based on user reviews. Wanted to know how louder can it get when compared when coming from my setup which is stock catback.Thank you guy!
 Old 12-02-2016, 08:57 PM   #6
darthxar's Avatar
Posts: 560   (View Stats)
But everyone behind you after you get in it wonders why their eyes are burning.
2013 VRM MS3
The Following User Says Thank You to darthxar For This Useful Post:
CorkSport (12-05-2016)
 Old 12-03-2016, 08:24 AM   #7
shamie's Avatar
Posts: 952   (View Stats)
As long as you have a cat in there you shouldn't notice any fumes. Once you go completely cat-less look out.
 Old 12-03-2016, 10:22 AM   #8
texasboy21's Avatar
Posts: 559   (View Stats)
texasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the world
If you dont have a cat you WILL smell the exhaust.
How much/how bad will depend on your personal sensitivity to it.
2012 MazdaSpeed3 - HTP 3" intake, ETS TIMC, Autotech internals, Corksport racepipe, Accessport V3, custom Freektune, CP-E RMM, Koni sports, Progress Technology RSB, AWR endlinks
2003 A4 1.8TQ
APR stg2+, MTM 420cc injectors, EuroCode FMIC, PSi testpipe, Techtonics Tuning downpipe, Forge TIP, Hyperboost DV, 240mm clutch, LWFW flywheel, B5S4 calipers, Goodridge SS lines, Stern snub, motor and transmission mounts, Powerflex rear diff bushing, 034MotorSports rear diff. carrier bushing inserts, JHM SS shifter, solid linkage, stabilizer bushing and weighted knob, Vogtland Jr. Cup Kit, B7 RS4 front and rear sway bars.
texasboy21 is offline   Reply With Quote
 Old 12-03-2016, 01:56 PM   #9
eliwwjd's Avatar
Thanks texasboy21! When i installed my cs racepipe i didn't notice any, i mean any smell at all but now that the dp comes with a low cell cat, i don't know if the smell will be noticable. Also still debating if its going to be sufficient to pass emissions test.Oh well☹️
 Old 12-03-2016, 04:57 PM   #10
Gerbilo's Avatar
Posts: 612   (View Stats)
Gerbilo is the leader of the worldGerbilo is the leader of the worldGerbilo is the leader of the worldGerbilo is the leader of the worldGerbilo is the leader of the worldGerbilo is the leader of the worldGerbilo is the leader of the worldGerbilo is the leader of the worldGerbilo is the leader of the worldGerbilo is the leader of the worldGerbilo is the leader of the world
Try checking your local emissions laws. OBD scan only? Sniffer? Visual? Bribe the guy with tostones and you're good? Figure that all out and it will help you figure out whether this DP will pass.
2010 CBM Mazdaspeed3
Freektune 93
CorkSport SRI, TIP & Race Pipe
CP-E Stage 2 RMM & TMIC
Cobb Accessport V3
Autotech HPFP Internals
Pilot Super Sport 235/40/18 - Stock Pu
Pilot Alpin PA3 215/50/17 - Sport Edition CE
2016.5 MGM Mazda CX-5 Touring
Gerbilo is offline   Reply With Quote
The Following 2 Users Say Thank You to Gerbilo For This Useful Post:
monkey.bones.007 (12-03-2016), mooseaidz (12-03-2016)
 Old 12-03-2016, 07:23 PM   #11
eliwwjd's Avatar
lol yeah! tostones. You should try them yourself they are really good. The only way to know is putting the local shop emissions sniffer to see if it pases but you can't do this unless you are actually doing your annual emissions test. People pay to get their cars passed on emissions
 Old 12-04-2016, 11:13 AM   #12
Gerbilo's Avatar
I have tried them, and they are good.
So, you know you get a sniffer test done in PR. I'd say search through the forums, look for people with similar setups to yours with the DP you are looking at and see if they are passing or failing that test. Not sure if all sniffer tests are the same, but it's a start. If you want to get more in depth, find limits for hydrocarbons, carbon monoxide, NOX, etc.
Or just get the DP and pay to get it passed like others.
Freektune 93
Cobb Accessport V3
The Following User Says Thank You to Gerbilo For This Useful Post:
mooseaidz (12-04-2016)
 Old 12-05-2016, 07:25 AM   #13
MSP6's Avatar
Posts: 1,246   (View Stats)
I think the consensus is that if you have a cat somewhere in your exhaust system and your car is warmed up you *should* pass the sniffer.
Also I had a full catless on my speed 6 when I had it and only ever smelled anything when I had a an exhaust leak from the gasket going to shit. When it was sealed up I didn't really smell anything.
 Old 12-05-2016, 06:59 PM   #14
eliwwjd's Avatar
Thanks for your inputs, they are valuable to me.
BNR s4 & Corksport Catted Downpipe JPPatterson Gen2 MS3 General Discussion 5 07-13-2017 01:57 PM
Review of the UR catted Downpipe and Resonated Testpipe on my 2008 MS3 MajesticBlueNTO Ultimate Racing 23 03-01-2015 01:19 PM
My Review: cp-e catted downpipe the_caruch MazdaSpeed 3 - Engine, Transmission & Driveline 5 06-05-2013 08:00 PM
Page generated in 0.33544 seconds with 27 queries
