Like Tree13Likes
 Old 11-10-2011, 06:10 PM   #161
QwkEVO's Avatar
Posts: 484   (View Stats)
QwkEVO is the leader of the worldQwkEVO is the leader of the worldQwkEVO is the leader of the worldQwkEVO is the leader of the worldQwkEVO is the leader of the worldQwkEVO is the leader of the worldQwkEVO is the leader of the worldQwkEVO is the leader of the worldQwkEVO is the leader of the worldQwkEVO is the leader of the worldQwkEVO is the leader of the world
Originally Posted by MS3inDC View Post
I'm wanting to se if this works with other SRIs.
I can't imagine it wouldn't or couldn't be made to. But I'm not the type to be a guinea pig.
I understand proprietary parts. But I'm not selling what I've got just to get this
Actually if you read the instructions it says it may work with other SRI like CP-E or others. I'm sure it can be made to work but I doubt Corksport wants to sign off on other manufacturers parts since they cant warranty fitment of someone else's parts.
I will say this, Corksport is right on top of my issue and doing what needs to be done to get it resolved. Their customer service is 2nd to none. One of the main reasons I will continue to buy from them even when issues may arise. My confidence the issues will be resolved are 100%.
Here are a couple shots of my install underhood:
08 MS3 //PTP Injector seals & stud kit //CP-E RMM //Corksport Sway Bar // Koni Yellow Sports // Eibach Pro Kit Springs // Enkei 18" PF01's //
QwkEVO is offline   Reply With Quote
 Old 11-14-2011, 01:26 AM   #162
TexasSpeed3's Avatar
Posts: 1,996   (View Stats)
TexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the world
Groans: 273
massive pics are massive
2011 Black Mica - Daily
JBR SSP and heavy knob and SSB | Sure RMM | Corksport SRI/TIP/RSB/TMIC | Tanabe FSTB | Cobb AP getting PERM'd | Autotech internals | H&R springs | DDM HID | pussy delete - catless ebay dp and tp
TexasSpeed3 is offline   Reply With Quote
 Old 11-14-2011, 11:50 AM   #163
QwkEVO's Avatar
Sorry man.....
 Old 11-14-2011, 01:02 PM   #164
Groans: 273
hahaha its all good. just thought i'd give you a heads up if you wanted to resize them
 Old 03-05-2012, 03:56 PM   #165
Gwynne's Avatar
Posts: 288   (View Stats)
Gwynne is the leader of the worldGwynne is the leader of the worldGwynne is the leader of the worldGwynne is the leader of the worldGwynne is the leader of the worldGwynne is the leader of the worldGwynne is the leader of the worldGwynne is the leader of the worldGwynne is the leader of the worldGwynne is the leader of the worldGwynne is the leader of the world
We have confirmed fitment on the CorkSport FMIC for SRI with a COBB Intake:
Gwynne
CorkSport Peformance
www.corksport.com
Gwynne is offline   Reply With Quote
The Following 2 Users Say Thank You to Gwynne For This Useful Post:
Boost_creep (03-09-2012), TexasSpeed3 (03-05-2012)
 Old 03-09-2012, 07:03 PM   #166
deek's Avatar
Posts: 687   (View Stats)
deek is the leader of the worlddeek is the leader of the worlddeek is the leader of the worlddeek is the leader of the worlddeek is the leader of the worlddeek is the leader of the worlddeek is the leader of the worlddeek is the leader of the worlddeek is the leader of the worlddeek is the leader of the worlddeek is the leader of the world
if you guys could route the hotside piping to the passenger i would buy it asap, problem is i already have a injen cai and only a few piping kits run that way, which is shorter and more room for intakes.
2010 Dodge Ram 1500
6 inch pro comp lift, 35x12.50x20 pro comp tires, pro comp 7089 wheels 20x9.5
deek is offline   Reply With Quote
 Old 04-20-2012, 05:45 PM   #167
Snotrocket's Avatar
Posts: 900   (View Stats)
Snotrocket is the leader of the worldSnotrocket is the leader of the worldSnotrocket is the leader of the worldSnotrocket is the leader of the worldSnotrocket is the leader of the worldSnotrocket is the leader of the worldSnotrocket is the leader of the worldSnotrocket is the leader of the worldSnotrocket is the leader of the worldSnotrocket is the leader of the worldSnotrocket is the leader of the world
Default Can't hold boost
Wondering if you may be able to shed some light on an issue i am having since the install of CS FMIC + SRI.
I have tripple checked and tightened all clamps at each coupler so i am sure i don't have a leak. I am running the stock turbo right now but i was hoping to sort out if i have an issue before going big turbo next week.
I am able to hit my boost target with a ton of added waste gate between 3000-4000 RPM but aggressively taper down to 12 psi at redline.. Prior to install i was able to hold 16 psi to redline. Is this normal for the K04 ?
2010 MS3 Black
395whp/386wtq
| Molnar Rods | CP-e Stage 2 Pistons | Much Head Work | ATP GTX3076 | Tial 38mm EWG | HTP 4 Inch Intake | BSD | Passenger and Rear MM | Denso ITV22's | OCC | Ultimate Racing TBE | Tredstone TR8C FMIC | Tial BPV | Autotech Internals | Grimmspeed ECBS 3 port | Te37 Volks| 245/45/17 Dunlop zzi tires| Cobb AP Self Street Tuned | Sonic Tuning Coilovers | Stoptech breaks and slotted roters
Snotrocket is offline   Reply With Quote
 Old 05-08-2012, 12:20 AM   #168
Bratschist's Avatar
Posts: 79   (View Stats)
Bratschist has much to be proud ofBratschist has much to be proud ofBratschist has much to be proud ofBratschist has much to be proud ofBratschist has much to be proud ofBratschist has much to be proud ofBratschist has much to be proud ofBratschist has much to be proud of
I have the box ram intake FMIC and now Im looking into getting the COBB SRI, can anyone post a comparison sheet with intake air temperature. I would appreciate both numbers from Ram air and SRI, but since I already have the Ram Air, just SRI would cut it. Have any of you done this swap yet? if so, did you like it? recommend it?
Side note. I recently used the Box pipe but instead of using the box intake, I put a K&N air filter. I logged some numbers and it was disastrous. I was getting IAT twice as hot as ambient. but somehow I imagine that with the SRI it would be different. so, can anyone help?
Upgrades so far:
  1. Window Tint 20%
  2. Ipod Integration
  3. CorkSport LED light kit
  4. TWM Performance Shifter
  5. SLS Test Pipe
  6. CorkSport FMIC and SR air intake
  7. SURE Motorsport Torq R6
  8. AccessPort Stage 2+ Map
  9. QTP Electronic Exhaust Cut-Out
  10. KMD HPFP Internals Upgrade
  11. CorkSport Downpipe
Bratschist is offline   Reply With Quote
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f500/corksport-front-mount-intercooler-sri-72481/
CorkSport Mazda Performance - Blog » 500hp MS3, Flames, Friends and Mazda Fanatics! MazdasNW End of Summer Bash This thread Refback 09-27-2011 12:51 PM
Corksport fmic blkspeed6 MazdaSpeed 6 - Engine, Transmission & Driveline 14 01-03-2011 10:26 AM
Anyone with Corksport FMIC and ram air... Nataphen MazdaSpeed 3/6 - Turbo Induction 8 12-09-2010 09:02 PM
corksport fmic and ram air kit!?! myzoomzoom3 MazdaSpeed 3/6 - Turbo Induction 9 03-31-2010 03:43 PM
AP with Corksport fmic ms3 swag MazdaSpeed 3/6 - ECU Computer Tuning 4 11-02-2008 10:48 PM
Corksport FMIC Kit bova MazdaSpeed 3/6 - Turbo Induction 22 06-12-2008 08:44 PM
Page generated in 0.29388 seconds with 25 queries
