  • 1 Post By Crarrs
 Old 04-15-2014, 02:26 PM   #1
Crarrs's Avatar
Posts: 1,662   (View Stats)
Default CorkSport Gen2 Single-Exit Catback Review
Last year, I had a single-exit axle-back built at a muffler shop. I was looking for a little more sound out of the car, but mostly wanted to lose the weight of the stock muffler. The project was a success, and cut 20 lbs out of the car (8.5 lbs vs. 28.0 lbs stock).
Shortly thereafter, CorkSport announced that they had built a prototype catback and requested feedback from the community. I was interested in it, as it was obviously a higher-quality piece than the muffler-shop special I had built, but was hesitant due to the price. I sold off my single-exit part, and started saving before the part was released. Well, a pay period with 34 hours of overtime eased any heartburn over the price, and I bit the bullet on the CorkSport part.
After I pulled the stock parts off the car, I weighed everything from both assemblies to verify the weight reduction claims.
Stock
Midpipe - 14.6 lbs
Axle-Back - 28.0 lbs
Total - 42.6 lbs
CorkSport
Midpipe - 15.4 lbs
Axle-Back - 9.4 lbs
Hardware - 0.2 lbs
Total - 25.0 lbs
Weight Delta - 17.6 lbs
Everything installed easily enough, although there were a few minor issues with the instructions that I noted in the product release thread. They'll be simple enough to correct with a revision. Once I got everything bolted up, I noted minimal clearance between the first bend in the midpipe and the tunnel. I adjusted everything as much as available to me and managed to gain about 1/8" of clearance. I haven't had any issues with interference or rattling yet, but I still have option of urethane hangers if I end up having problems later.
Clearance before adjustment
I pulled a 3rd gear datalog on the car yesterday and compared it against some older runs, and, well it's Virtual Dyno, and there's always question marks about runs not done on the same day. But I can say for sure that I picked up 20 g/s of peak airflow, so there's definitely some improvement from the part, although it's likely not quite as much as this plot is showing.
The exhaust sounds good, and not really much different from their dual-exit version. The huge concern that many others have had about the extra hole in the bumper doesn't bother me at all. I don't look at the back of my car when I'm driving it. At $200 cheaper than the dual exit, I've got to recommend it.
iPhone video of cold start
Comparison versus stock
Breaking it in the right way
mvp2010ms3 likes this.
2004 MSM TiGrey
The Following 7 Users Say Thank You to Crarrs For This Useful Post:
Celestspeed3 (04-15-2014), cody red (04-16-2014), kolosok17 (04-15-2014), Mauro_Penguin (06-16-2014), mvp2010ms3 (12-08-2015), SpencerC (04-18-2014), swsmailman (04-15-2014)
 Old 04-15-2014, 02:33 PM   #2
swsmailman's Avatar
Posts: 1,118   (View Stats)
Thank you for the numbers on the weight difference and the great review!
2013 Liquid Silver MazdaSpeed
 Old 12-08-2015, 12:11 PM   #3
mvp2010ms3's Avatar
Posts: 3   (View Stats)
mvp2010ms3 will become famous soon enough
@Crarrs, Great review!! I cannot wait to order my part. I know I am almost 2 years too late haha but I have been looking this up for months now, and only seen good things about the single exit. CAN'T WAIT!!!
mvp2010ms3 is offline   Reply With Quote
 Old 12-08-2015, 12:45 PM   #4
Brandon@corksport's Avatar
Posts: 170   (View Stats)
Neutral  :  -1 score
Awesome! You'll love it!
Cheers,
Brandon Johnson
CorkSport Mazda Performance
(360)260-2675 ext. 106
BrandonJ@corksport.com
 Old 12-08-2015, 06:43 PM   #5
sheston's Avatar
Posts: 1,847   (View Stats)
I got one for my 2011 about a year ago. I love it as well. The weight loss was just a bonus
 Old 12-09-2015, 09:28 AM   #6
Finchee's Avatar
Posts: 306   (View Stats)
Finchee has a reputation beyond reputeFinchee has a reputation beyond reputeFinchee has a reputation beyond reputeFinchee has a reputation beyond reputeFinchee has a reputation beyond reputeFinchee has a reputation beyond reputeFinchee has a reputation beyond reputeFinchee has a reputation beyond reputeFinchee has a reputation beyond reputeFinchee has a reputation beyond reputeFinchee has a reputation beyond repute
How loud is it inside the cabin? Does it drone at highway speeds like at 70-80 mph? That's around 2700-3000 rpm in 6th gear I think.
2013 Mazdaspeed3 with Tech Package
Autotech Fuel Pump Internals
Cobb Accessport V3
Continental ExtremeContact DWS06
CorkSport SRI, TIP
CP-E xFlex Stage 1 65A Rear Motor Mount
Damond Motorsports Short Shift Plate
ETS TMIC
James Barone Racing Thermal Insulating Throttle Body Gasket & Coolant Bypass Kit
Magnaflow CBE
NGK Iridium IX Step Colder Plugs
Dizzy Tune in progress...
Finchee is offline   Reply With Quote
 Old 12-09-2015, 09:32 AM   #7
Crarrs's Avatar
No droning at all. It isn't much louder than stock when cruising at light constant throttle. Sound level increases with added throttle inputs.
2004 MSM TiGrey
The Following User Says Thank You to Crarrs For This Useful Post:
Finchee (12-09-2015)
 Old 12-09-2015, 11:20 AM   #8
sheston's Avatar
Mine drones a little, but it's not a good comparison. I don't have any rear seats, carpet, plastic, spare, ....
I think the stock exhaust would probably sound loud in the cabin
 Old 12-09-2015, 05:22 PM   #9
Finchee's Avatar
Sounds promising. I can barely hear my exhaust now after swapping from the DM RMM to this almost stock-like CP-E stage1 RMM. I've also always wanted to get a CS CBE, just that the timing and availability of funds never lined up. Someday I'll get one to replace the Magnaflow on my car.
Cobb Accessport V3
CorkSport SRI, TIP
ETS TMIC
Magnaflow CBE
CPE Single exit Catback Installed! BmoreMS6 MazdaSpeed 6 - Engine, Transmission & Driveline 1 01-11-2012 11:17 AM
Page generated in 0.32899 seconds with 25 queries
