 Old 06-26-2010, 08:52 AM   #1
CorkSport's Avatar
Posts: 3,416   (View Stats)
Default CorkSport Mazdaspeed 6 LED Light Kit
CorkSport is happy to annouce a LED light kit for the 2006-2007 Mazdaspeed 6. The light kit replaces the headlight markers, dome lights, vanity visor lights, map lights, door lights, trunk light, and license plate lights for a total of 15 bulbs. We include easy to follow installation instructions with the kit. The kit is $55 and we have them in stock ready to ship.
Link to the Mazdaspeed 6 light kit
CorkSport LED vs Stock bulb in the visor
-Derrick
WWW.CORKSPORT.COM
 Old 06-26-2010, 08:56 AM   #2
Qwik6's Avatar
Posts: 695   (View Stats)
Qwik6 is the leader of the worldQwik6 is the leader of the worldQwik6 is the leader of the worldQwik6 is the leader of the worldQwik6 is the leader of the worldQwik6 is the leader of the worldQwik6 is the leader of the worldQwik6 is the leader of the worldQwik6 is the leader of the worldQwik6 is the leader of the worldQwik6 is the leader of the world
Sweet. How about liscence plate lights?
2006 MAZDASPEED6
FREEKTUNED @ 20PSI // COBB AP V3 // CPE TMIC // COBB SF // PG TIH // DENSO ITV22s // AUTOTECH INTERNALS // SURE TP // MAGNAFLOW CATBACK // JBR OCC // JBR IM SPACER // JBR PASSENGER & TRANNY MOUNT // SURE RMM // H&R SPRINGS // XXR 530 18X8.75 +35 // CAR LED TAILS // CPE REAR DIF MOUNT // TURBINE TECH FRONT DIF MOUNT // CPE TOW HOOK // 35% TINT // 3M DINOC WRAPPED ROOF // AUTOEXE CARBON FIBER BADGELESS GRILL
Qwik6 is offline   Reply With Quote
 Old 06-26-2010, 09:09 AM   #3
CorkSport's Avatar
They are in the kit. I have them listed above
-Derrick
Originally Posted by Stealth01 View Post
I'm a little concerned about the LEDs in the headlight housings. Everything I've read says NEVER put them in there, as the heat of that housing will fry them in short order. I asked both Superbrightleds.com and autolumination.com and both said they don't recommend LEDs in the headlights. Has someone come out with one designed for that?
I will check with Jake about this and post back up about it next week.
-Derrick
WWW.CORKSPORT.COM
Last edited by CorkSport; 06-26-2010 at 09:09 AM. Reason: MSF Database - Automerged Doublepost
 Old 06-26-2010, 08:58 AM   #4
Stealth01's Avatar
Posts: 6,910   (View Stats)
Groans: 201
Stealth01
2006 Mazdaspeed6 GT
 Old 06-26-2010, 01:10 PM   #5
Matx's Avatar
Posts: 1,681   (View Stats)
Matx is the leader of the worldMatx is the leader of the worldMatx is the leader of the worldMatx is the leader of the worldMatx is the leader of the worldMatx is the leader of the worldMatx is the leader of the worldMatx is the leader of the worldMatx is the leader of the worldMatx is the leader of the worldMatx is the leader of the world
I have leds in my parking lights and never had a problem pulled them out to take a look and looks just like new, hahve had them in for afew months now.
MS6 COBB-BROKEN: SOLD
GXP G8: Sold
EVO 8: speed rapist
14 Wrangler
Originally Posted by backward_0 View Post
.... I will be more than happy to fuck your world off....
Matx is offline   Reply With Quote
 Old 06-26-2010, 01:05 PM   #6
Kdawg207's Avatar
Posts: 2,389   (View Stats)
Kdawg207 is the leader of the worldKdawg207 is the leader of the worldKdawg207 is the leader of the worldKdawg207 is the leader of the worldKdawg207 is the leader of the worldKdawg207 is the leader of the worldKdawg207 is the leader of the worldKdawg207 is the leader of the worldKdawg207 is the leader of the worldKdawg207 is the leader of the worldKdawg207 is the leader of the world
they should be fine
nice package - did mine already but this is good for members wanting the look and grouped up
i'd add the license plates too jmo
sweet tho
~~~NJ Nator OG~~~Then AND Now, Just Better~~~
Kdawg207 is offline   Reply With Quote
 Old 06-26-2010, 04:10 PM   #7
LMB77's Avatar
Posts: 112   (View Stats)
LMB77 has a reputation beyond reputeLMB77 has a reputation beyond reputeLMB77 has a reputation beyond reputeLMB77 has a reputation beyond reputeLMB77 has a reputation beyond reputeLMB77 has a reputation beyond reputeLMB77 has a reputation beyond reputeLMB77 has a reputation beyond reputeLMB77 has a reputation beyond reputeLMB77 has a reputation beyond reputeLMB77 has a reputation beyond repute
I have had LED's in the paring lights for a few years now and have never had a problem. I do like this package deal from CS and will probably order when I order the DP. Back in stock July 15th, right Derrick?
06 Speed 6: Cobb SRI/ TIP, AP stage 2, CS TB, CP-E FMIC, Forge BPV, Cp-e rear mm. TT FMM, AT internals, Freek tuned on 50% e85.
LMB77 is offline   Reply With Quote
 Old 06-26-2010, 04:15 PM   #8
laxplayermjd's Avatar
Posts: 779   (View Stats)
group buy??
laxplayermjd is offline   Reply With Quote
The Following User Says Thank You to laxplayermjd For This Useful Post:
LMB77 (06-26-2010)
 Old 06-26-2010, 04:39 PM   #9
Stealth01's Avatar
Groans: 201
Straight off the Superbrightleds.com website, on the page for 194 bulbs, which replace the DRLs in a 6/MS6:
Warning: do not use any of these bulbs in headlamp housings or any compartment where the bulbs would be subject to the extreme temperatures that headlamps can produce - heat will cause LED failure and VOID WARRANTY !
Stealth01
2006 Mazdaspeed6 GT
 Old 06-26-2010, 07:49 PM   #10
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
I have 55w hids with piaa led lights in the housing, I never turn my headlights off and after two years, I have had no problems with them.
2006 Mazdaspeed 6
 Old 06-26-2010, 07:59 PM   #11
Superbright is just trying to cover there asses. Believe me, people do stupid things. The city lights in the MS6 are far up top enough not to be effected by this. Look for an 194 LED that looks like a light bulb.
 Old 06-27-2010, 12:02 AM   #12
Qwik6's Avatar
Ordered!
2006 MAZDASPEED6
The Following User Says Thank You to Qwik6 For This Useful Post:
CorkSport (06-28-2010)
Mazdaspeed 6 Fog Light Help boost2dms6 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 7 08-09-2009 10:27 AM
Page generated in 0.32961 seconds with 28 queries
