  • 1 Post By CorkSport
  • 1 Post By moonrider_99
 Old 10-06-2016, 02:38 PM   #1
moonrider_99's Avatar
Posts: 185   (View Stats)
moonrider_99 has a reputation beyond reputemoonrider_99 has a reputation beyond reputemoonrider_99 has a reputation beyond reputemoonrider_99 has a reputation beyond reputemoonrider_99 has a reputation beyond reputemoonrider_99 has a reputation beyond reputemoonrider_99 has a reputation beyond reputemoonrider_99 has a reputation beyond reputemoonrider_99 has a reputation beyond reputemoonrider_99 has a reputation beyond reputemoonrider_99 has a reputation beyond repute
Groaned at 46 Times in 14 Posts
Default Corksport RSB bracket broken (check yours!)
Greetings,
I was under my car and saw one of the brackets from the RSB completely torn (the other one's faith will be similar, I'm sure). The RSB was installed approx. 2 years ago in 2014. Some rust is expected after a couple of winters but that's quite a surprise. Please check yours just in case!
Anyone with similar issues?
2017 Ford Focus RS - Stock
2004 MSM
- AEM Intake - BEGI - FM Turboback - Turbosmart BPV - Hallman Boost Controller - ...
"I'm a Turbo addict, I know."
SCCA Philadelphia: (http://www.phillyscca.com/solo/)
2012 MS3 Silver w/ Tech Package - sold in '17
2009 WRX Stage 2- sold in '12
moonrider_99 is offline   Reply With Quote
 Old 10-06-2016, 02:56 PM   #2
[R]usty's Avatar
Posts: 2,204   (View Stats)
Brackets break all the time, it's no biggie. They're usually made by energy suspension and pretty flimsy TBH. Corksport could possibly replace them free of charge but they'll end up break again especially if you're seeing that kind of corrosion. I've gone through 2 sets myself with my JBR .125. You can get billet brackets if you don't want to deal with it again. Both JBR and corksport sell them. I personally bought these off of amazon:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
They're cheaper than energy suspension replacements, a lot thicker and feel more sturdy overall. I think companies like JBR and Corksport should ditch those energy suspension brackets and switch to Prothane; they're better in my experience and fit our frames fine. The only downside is no grease fittings but I never used them anyway.
2010 Mazdaspeed3 w/tech
 Old 10-07-2016, 08:38 PM   #3
Thanks for the advice, I'll upgrade shortly. It's surprising how flimsy are the brackets supplied by CS, lol.
2004 MSM
 Old 10-11-2016, 12:50 PM   #4
CorkSport's Avatar
Posts: 3,416   (View Stats)
Pretty much all brands use the same same steel brackets. We changed all our brackets to the billet aluminum style and we no longer sell the stamped steel style with our swaybars.
OP give us a call and talk to Vincent here to see what he can do for you.
-Derrick
CMajor likes this.
WWW.CORKSPORT.COM
KiwiFlavor (10-12-2016), Mastermind46 (11-23-2016), Nailedit187 (11-23-2016), WetzMS3 (10-11-2016)
 Old 10-12-2016, 09:23 AM   #5
Silaramic's Avatar
Posts: 54   (View Stats)
Silaramic has much to be proud ofSilaramic has much to be proud ofSilaramic has much to be proud ofSilaramic has much to be proud ofSilaramic has much to be proud ofSilaramic has much to be proud ofSilaramic has much to be proud ofSilaramic has much to be proud ofSilaramic has much to be proud ofSilaramic has much to be proud of
Is the bar installed upside down? Mine has the sticker right side up and on the right side of the RSB.
Nevermind, I just checked mine and the arms are the same angle. Difference is the sticker placement.
Last edited by Silaramic; 10-12-2016 at 09:23 AM. Reason: MSF Database - Automerged Doublepost
Silaramic is offline   Reply With Quote
 Old 10-12-2016, 09:52 AM   #6
classic neal.
 Old 10-12-2016, 11:24 AM   #7
classic neal.
defs
 Old 10-12-2016, 07:54 PM   #8
Atticaz's Avatar
Posts: 621   (View Stats)
Atticaz is the leader of the worldAtticaz is the leader of the worldAtticaz is the leader of the worldAtticaz is the leader of the worldAtticaz is the leader of the worldAtticaz is the leader of the worldAtticaz is the leader of the worldAtticaz is the leader of the worldAtticaz is the leader of the worldAtticaz is the leader of the worldAtticaz is the leader of the world
Greetings,
You need to purchase their billet brackets. They are solid. You must have got that bar before the billet brackets were out and came with it. That sucks. Those brackets you have there are garbage.
http://corksport.com/mazda-billet-sw...-brackets.html
2017 Mustang V6 - Soon to be Supercharged
2007 MAZDASPEED3 - SOLD
Atticaz is offline   Reply With Quote
 Old 10-13-2016, 11:06 AM   #9
smurugby12's Avatar
Posts: 278   (View Stats)
smurugby12 is the leader of the worldsmurugby12 is the leader of the worldsmurugby12 is the leader of the worldsmurugby12 is the leader of the worldsmurugby12 is the leader of the worldsmurugby12 is the leader of the worldsmurugby12 is the leader of the worldsmurugby12 is the leader of the worldsmurugby12 is the leader of the worldsmurugby12 is the leader of the worldsmurugby12 is the leader of the world
Depending on how long you plan to own your car, you may want to look into the Hotchkis RSB Bracket. 4 winters and no issues on mine, and I only grease it about 3 times a year which is negligent.
@Nliiitend1; also has not had issues with them I believe.
Edit: I see Corksport now has a similar bracket to the Hotchkis
smurugby12 is offline   Reply With Quote
The Following User Says Thank You to smurugby12 For This Useful Post:
Nliiitend1 (10-13-2016)
 Old 10-13-2016, 11:19 AM   #10
nindoja's Avatar
Posts: 2,395   (View Stats)
Greasing a bar? Man, I've had my JBR bar on for over 3 years and haven't greased it but once. I also seem to be lucky in that I'm still on the original energy suspension brackets that haven't broken.
I guess it's a benefit that I don't get that much rust down in the south.
True Red 2009 MS3
Tune: hypnotic tuned
Critical Stats:
// 305whp/352tq
 Old 11-18-2016, 06:10 PM   #11
Corksport worked with me and I got the new beefier billet brackets. Install completed, problem solved. Thank you CS.
Atticaz likes this.
2004 MSM
The Following 4 Users Say Thank You to moonrider_99 For This Useful Post:
Atticaz (11-18-2016), CorkSport (11-21-2016), mooseaidz (11-18-2016), Nailedit187 (11-23-2016)
 Old 11-21-2016, 01:18 PM   #12
CorkSport's Avatar
It would take some serious work to break the billet brackets. Glad we got you sorted out.
-Derrick
WWW.CORKSPORT.COM
CorkSport Product Release! ? CorkSport Mazdaspeed 3 Lowering Springs Now Available CorkSport CorkSport 0 08-05-2011 06:30 PM
So Corksport sent ME a check today!!! Novej CorkSport 0 04-04-2011 09:40 PM
Page generated in 0.34406 seconds with 29 queries
