Like Tree33Likes
 Old 11-02-2012, 02:10 PM   #1
CorkSport's Avatar
Posts: 3,416   (View Stats)
Default CorkSport Shift Knob (Need some input)
300g which is slightly heavier than stock.
Matches MS3 interior of red and black.
Shift pattern on top
Stitched logo.
Anything else I should add or anything I should change?
msalva2, Monotonous ONE and ilias like this.
The Following 15 Users Say Thank You to CorkSport For This Useful Post:
3Gee Tee (11-12-2012), best_predator (12-06-2012), breakfstincluded (11-02-2012), daafisch (11-02-2012), easy (11-03-2012), Hectik1 (05-07-2013), JohnMS3 (11-02-2012), Kamaril (11-02-2012), kritz (11-06-2012), Monotonous ONE (05-01-2013), neotide87 (01-02-2013), Pseud0logik (11-02-2012), rfinkle2 (11-02-2012), VulgarKyle (06-25-2013), xI Leveler Ix (03-05-2013)
 Old 11-02-2012, 02:19 PM   #2
Kamaril's Avatar
Posts: 909   (View Stats)
Kamaril is the leader of the worldKamaril is the leader of the worldKamaril is the leader of the worldKamaril is the leader of the worldKamaril is the leader of the worldKamaril is the leader of the worldKamaril is the leader of the worldKamaril is the leader of the worldKamaril is the leader of the worldKamaril is the leader of the worldKamaril is the leader of the world
Groans: 77
put color on the shift pattern imo
TiGraySpeed6 and donjohnk like this.
2011 MS3 BLACK MICA W/TECH PACKAGE
BNRSv3 - COBB 3 Port Boost Controller - BOSCH 3 Bar MAP Sensor - HTP 3" Intake (Candy Red)- CS Downpipe - CS LED Fog Lights - CS Interior LED Kit - CS Hood Strut Kit - COBB AccessPORT - JBR Adjustible Rear Sway Bar - JBR Solid Shifter Bushings - SURE Flow M3 W/ Res Delete - MangnaFlow 4x3.5" Stainless Exhaust Tips - AutoTech Internals - JBR 88a Dogbone RMM - H&R Lowering Springs - NGK Iridium Step Colder - Beachshoer's Pnp Intake Manifold W/ VTCS Delete - TurboSmart Plumb Black BPV - CX Racing FMIC - 18x8 Bronze MB Motoring Battles - Nitto Motivo 235/40/18 - Hawk HPS Brake Pads - Block8head Dual Gauge Pod - Prosport Evo Boost and Coolant Temp Gauges - Autodvdgps Touch Screen DVD Player W/ Navigation - CS Radiator Cover - CS Exhaust Manifold Cover - CS OCC
Stratified Tune In Progress
SCCA Member# 450495
Class - SMF
TRMotorsport C3 17x9 Hancook 255/245 RS-3
LIQUOR AND WHORES
Kamaril is offline   Reply With Quote
The Following 16 Users Say Thank You to Kamaril For This Useful Post:
86AmishMs3 (11-02-2012), easy (11-03-2012), faeker (11-05-2012), Keko (11-03-2012), kritz (11-06-2012), Lama (11-03-2012), MazdaBoy2.3 (11-02-2012), mike w (11-08-2012), msantana101 (11-02-2012), Pseud0logik (11-02-2012), SofaKingAwesome (11-14-2012), taf0422 (03-06-2013), TiGraySpeed6 (11-03-2012), Voltwings (03-11-2013), VulgarKyle (06-25-2013), ZetaDrift (03-28-2013)
 Old 11-02-2012, 02:25 PM   #3
jpfrisch87's Avatar
Posts: 151   (View Stats)
jpfrisch87 is the leader of the worldjpfrisch87 is the leader of the worldjpfrisch87 is the leader of the worldjpfrisch87 is the leader of the worldjpfrisch87 is the leader of the worldjpfrisch87 is the leader of the worldjpfrisch87 is the leader of the worldjpfrisch87 is the leader of the worldjpfrisch87 is the leader of the worldjpfrisch87 is the leader of the worldjpfrisch87 is the leader of the world
I agree with the shift pattern color. Also, if you had heavier options, I might spring for it. At 300g, it's too close to stock to justify it imo
2012 Mazdaspeed3 Liquid Silver
CS SRI / CS TIP / CS Racepipe / CP-E TMIC / Magnaflow CBE / Cobb AP / Autotech Internals / Denso ITV22
JBR 80a RMM / JBR Bushings / JBR Cylindrical Knob / JBR RSB
SSP OCC / Forge BPV V2 / DDM 6k Lows & Fogs / CS Hoses
Yakima Whispbar
Sport Edition / Blizzak 205/60R16 Winter Mode
Dartmouth Sticker
jpfrisch87 is offline   Reply With Quote
The Following 3 Users Say Thank You to jpfrisch87 For This Useful Post:
Alexander (01-09-2013), Pseud0logik (11-02-2012), shopety2012 (11-06-2012)
 Old 11-02-2012, 02:28 PM   #4
warlord's Avatar
Posts: 756   (View Stats)
Neutral  +1 score
1) The baseball stitch looks like someone from the Helen Keller foundation did it.
2) The embossed shift pattern won't last a month without getting discolored and wrecked from your palm being on it so much. Oils in your skin will discolor it.
3) Weight is good. Anything heavier just slows you down. I'm back to oem because I shift quicker with it.
2014 IS350 (sold)
2013 MS3 Stage2 E85 (sold)
2011 MS3 Stage2 (sold)
warlord is offline   Reply With Quote
The Following 9 Users Say Thank You to warlord For This Useful Post:
2008MS3H (11-03-2012), 3ONBOOST (11-02-2012), bcmurphy87 (11-03-2012), evil MS3 (11-02-2012), neotide87 (11-15-2012), radioflyer (11-03-2012), SofaKingAwesome (11-14-2012), TiGraySpeed6 (11-03-2012), Tommy (11-02-2012)
 Old 11-02-2012, 02:34 PM   #5
evil MS3's Avatar
Posts: 1,294   (View Stats)
Groans: 55
Besides cleaning up the stitching, something else needs to be done for the shift pattern to make it stand out.
But looks great regardless. Would buy.
warlord (11-02-2012)
 Old 11-02-2012, 03:09 PM   #6
silvapain's Avatar
Posts: 6,665   (View Stats)
Groans: 136
Make one lighter than stock and you have a customer in me. Forget these fags that want big, heavy black balls in their hands.
The Following 11 Users Say Thank You to silvapain For This Useful Post:
86AmishMs3 (11-02-2012), daafisch (11-07-2012), Dimenus (12-06-2012), Easter Bunny (11-02-2012), FightaX (11-03-2012), GunGuru727 (11-02-2012), neotide87 (11-15-2012), Pointless (11-03-2012), radioflyer (11-03-2012), Speed_j23 (11-08-2012), TiGraySpeed6 (11-03-2012)
 Old 11-02-2012, 03:41 PM   #7
CorkSport's Avatar
The heavier the weight the slower it is to move but the lighter the weight it feels like crap when you put it in gear. Ever used an aluminum knob? They always feel like you are shifting air. Not to mention they burn you in the summer and are cold in the winter.
I originally did an embossed pattern because a stitch would get worn quickly by your hand. The best option might be no pattern? Option on no pattern.
This is just a sample so the final will have a better and possibly brighter stitch.
If no one can think of any other changes I will start making a bunch of them. Or if anyone can convince me to go a different way.
breakfstincluded (11-08-2012), J-Liss (11-12-2012)
 Old 11-02-2012, 03:44 PM   #8
Domino81's Avatar
Posts: 5,081   (View Stats)
First off - It's fucking beautiful...
2nd - lol that looks almost identical to my Probe shift knob. Offer those to the ProbeTalk kids and MX6.com/MX3.com. As well as the Protege guys. I think the P5 had that knob, too.
msalva2 likes this.
2008 CosmicBlue Mazdaspeed3
294whp/335wtq - Stock K04
370whp/370wtq - BNR stage 3
The Following 2 Users Say Thank You to Domino81 For This Useful Post:
bcmurphy87 (11-03-2012), kritz (11-06-2012)
 Old 11-02-2012, 03:46 PM   #9
I'm a ball fan. I'd like a leather covered 2" ball knob with a slight extension and stock weight. Like the COBB knob but with leather on top or even better alcantara.
SleeperHatch likes this.
ajkulish (07-01-2013), bob7point7 (11-03-2012), ms3blackmica (11-08-2012), seige123 (11-03-2012), Speed3eak (12-08-2012)
 Old 11-02-2012, 03:48 PM   #10
silvapain's Avatar
Groans: 136
I use a COBB knob with a SSP and no counterweight. With the shifter adjusted properly it still goes into gear just fine and I feel much more connected to the car. Heavy knobs feel like playing a shitty arcade game.
 Old 11-02-2012, 03:51 PM   #11
msalva2's Avatar
Posts: 235   (View Stats)
msalva2 is the leader of the worldmsalva2 is the leader of the worldmsalva2 is the leader of the worldmsalva2 is the leader of the worldmsalva2 is the leader of the worldmsalva2 is the leader of the worldmsalva2 is the leader of the worldmsalva2 is the leader of the worldmsalva2 is the leader of the worldmsalva2 is the leader of the worldmsalva2 is the leader of the world
Stitched logo.
I like it. I agree with the color in the shift pattern as well as cleaning up the stitching. Other than that it looks awesome.
Sent from my DROID RAZR MAXX using Tapatalk 2
msalva2 is offline   Reply With Quote
 Old 11-02-2012, 03:54 PM   #12
Domino81's Avatar
You'd like my knob, and you're welcome to play with it anytime.
The Following User Says Thank You to Domino81 For This Useful Post:
Tommy (11-12-2012)
 Old 11-02-2012, 04:34 PM   #13
Lol post it up.
 Old 11-02-2012, 04:47 PM   #14
SleeperHatch's Avatar
Posts: 3,138   (View Stats)
+1 for what @Lex said, if you did that I'd probably be buying one and selling my TWM knob.
2009 CWP Speed3
 Old 11-02-2012, 04:59 PM   #15
Domino81's Avatar
Not to derail the thread, that leather knob is very pretty.
 Old 11-02-2012, 05:19 PM   #16
Pseud0logik's Avatar
Posts: 2,042   (View Stats)
Pseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the world
Groaned at 34 Times in 31 Posts
If the choice is between an embossed pattern and no pattern then I'd say go with no pattern.
I like a heavy weighted knob so I wouldn't consider replacing my JBR heavy knob unless this one was at least 500 grams.
Pseud0logik is offline   Reply With Quote
The Following User Says Thank You to Pseud0logik For This Useful Post:
 Old 11-02-2012, 05:33 PM   #17
CorkSport's Avatar
I often hold the shifter from the side. So the factory shape is more appealing to me. If you hold it from the top the ball might be better. I will work on a sample of a ball style wrapped in leather. Probably will be roughly 300g also since that seems to be the magic middle number.
Tacheny (11-07-2012), xI Leveler Ix (11-12-2012), Zdraveca (11-02-2012)
 Old 11-02-2012, 05:36 PM   #18
Zdraveca's Avatar
Posts: 3,888   (View Stats)
Groans: 145
I really like how it is now. There is too many "ball" like shift knobs.
Sent from a GenPu
2011 MS3"Princess GRU"
GT2876r
E85 FREEKTUNE
 Old 11-02-2012, 06:13 PM   #19
CorkSport's Avatar
Sent from a GenPu
I agree. I've owned about a billion cars and possibly even more shift knobs than cars. My favorite were always leather wrapped and less ball like. I liked some of my TWM knobs but they were all metal. I had to have a sock in the car for hot days or the car was un-drivable. My hands down favorite shift knob was a TRD leather knob.
Kamaril (11-02-2012), Zdraveca (11-02-2012)
 Old 11-02-2012, 06:23 PM   #20
86AmishMs3's Avatar
Posts: 3,639   (View Stats)
Groans: 338
If you could stamp an acrylic piece through the leather for the shift pattern that would be best. That way you don't have to worry about discoloration or wear.
Current: N54 135i
DCI, DP's, Exhaust, FMIC
12.3@122
2009 Mazdaspeed 3:
GT3076 - Corkey tuned
390whp/400wtq
12.8@114
Sold
The Following User Says Thank You to 86AmishMs3 For This Useful Post:
 Old 11-02-2012, 06:29 PM   #21
Kamaril's Avatar
Groans: 77
I had a really nice TRD knob in my celica
I like the idea of an "inlay" for the shift pattern. Maybe something a layer underneath the leather (possibly different color choices). I like it with the shift pattern rather than without all together.
Also how about a "cylindrical" style leather wrapped?
Pretty much what he said (beat me to it)
SCCA Member# 450495
Class - SMF
LIQUOR AND WHORES
Last edited by Kamaril; 11-02-2012 at 06:29 PM. Reason: MSF Database - Automerged Doublepost
 Old 11-02-2012, 07:17 PM   #22
SLOWHATCH's Avatar
Posts: 2,461   (View Stats)
Groans: 274
I like it, but needs color for the shift pattern imo.
 Old 11-02-2012, 08:42 PM   #23
evil MS3's Avatar
Groans: 55
No shift pattern.
Ok, now make it so i can buy one
This going to be a limited production or always available?
 Old 11-02-2012, 09:10 PM   #24
ibcrusn's Avatar
Posts: 494   (View Stats)
ibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the world
No shift pattern or stitch it w/o the R & numbers as they would look awful that small.
'10 VRM MS3
3" JBR WP, ETS TMIC, KMD/Aviva HPFP, NGK LTR7IX, M2 TP, Grimmspeed, JBR & MD EGR delete, MD OCC, MD PMM, CPe Stg2 RMM, CS TMM insert
Mazda Motorsports C/O, JBR RSB, SPC camber arms, Konig Hypergram 17x9 +40 & 200 UTQG rubber or Drag DR-49 18x8 +45, Michelin Pilot Sport A/S 3
Strive for perfection in everything. Take the best that exists and make it better.
If it doesn't exist, create it. Accept nothing nearly right or good enough.
Sir Henry Royce
ibcrusn is offline   Reply With Quote
 Old 11-02-2012, 09:57 PM   #25
JohnMS3's Avatar
Posts: 754   (View Stats)
JohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the world
bigger and deeper embossed shift pattern?
-John
| Cobb AP | Cobb SRI/TIP | CXRacing/Godspeed FMIC | AQ Motorsports downpipe | Mazdaspeed CBE | Autotech HPFP internals | Koni Yellows | Eibach Prokit | Progress RSB | Mazdaspeed camber arms | CPE RMM | TWM shortshifter/bushings | Redlinegoods shifter/e-brake boots | Defi Red Racer boost gauge | RPM ventpod | OEM RX8 wheels | Yokohama S-drive 245/40/18 | Volt 4300K HID | Ho-en yellow fogs | Mazda5 rear rotors | Dual Fiamm horns |
JohnMS3 is offline   Reply With Quote
 Old 11-02-2012, 10:41 PM   #26
Mr.Bison's Avatar
Posts: 118   (View Stats)
Mr.Bison is the leader of the worldMr.Bison is the leader of the worldMr.Bison is the leader of the worldMr.Bison is the leader of the worldMr.Bison is the leader of the worldMr.Bison is the leader of the worldMr.Bison is the leader of the worldMr.Bison is the leader of the worldMr.Bison is the leader of the worldMr.Bison is the leader of the worldMr.Bison is the leader of the world
If it was slightly heavier with a red shift pattern, I would of already bought it :/
12' CWP MS3
--SURE Aeros SRI--Black Rear Valence--SURE Anchors--CS RMM 80D--FoMoCo Juice--CS Axleback--TWM Spector
Mr.Bison is offline   Reply With Quote
 Old 11-03-2012, 07:58 AM   #27
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
any chance of getting the CS logo instead of CorkSport full name?
11MZR likes this.
340hp / 371tq
2008MS3H (11-03-2012), GunGuru727 (11-03-2012), Mr.Bison (11-03-2012)
 Old 11-03-2012, 08:20 AM   #28
2008MS3H's Avatar
Posts: 492   (View Stats)
2008MS3H is the leader of the world2008MS3H is the leader of the world2008MS3H is the leader of the world2008MS3H is the leader of the world2008MS3H is the leader of the world2008MS3H is the leader of the world2008MS3H is the leader of the world2008MS3H is the leader of the world2008MS3H is the leader of the world2008MS3H is the leader of the world2008MS3H is the leader of the world
+1 @TiGraySpeed6
Why not offer both - same shift knob but one with pattern and one without?
2008 MS3:
MAISONVI PISTON SHIFT KNOB - AUTOTECH INTERNALS
SURE COUNTERSHIFT - SURE SHORTCUT - SURE ANCHORS
JBR TRILOGY - JBR RSB - JBR TUBING - JBR TIP - JBR SRI - JBR EGR DELETE
HYPNOTIC TUNED
2008MS3H is offline   Reply With Quote
 Old 11-03-2012, 09:05 AM   #29
GunGuru727's Avatar
Posts: 3,486   (View Stats)
GunGuru727 is the leader of the worldGunGuru727 is the leader of the worldGunGuru727 is the leader of the worldGunGuru727 is the leader of the worldGunGuru727 is the leader of the worldGunGuru727 is the leader of the worldGunGuru727 is the leader of the worldGunGuru727 is the leader of the worldGunGuru727 is the leader of the worldGunGuru727 is the leader of the worldGunGuru727 is the leader of the world
Groans: 38
Groaned at 20 Times in 14 Posts
Yeah I think Corksport on the side is too much.
FreekTuned 2006 CWP MazdaSpeed6
ATP EWG GTX3076r - HTP 3" Intake System - CPE Single Exit Exhaust
ATP Catless Down Pipe - CPE Differential Mount - CPE Top Mount Intercooler
JBR 80D Trilogy Mount Package - Grimmspeed EBCS Autotech Internals
Bosch 3 Bar Map Sensor - Bit Wise Plug n Play - GFB Hybrid BOV
Bilstein Struts - H&R Sport Lowering Springs - Cobb v3 - e85
Granite State Dyno 4/3/15: 363hp/370trq
2013 Plasma Blue Subaru STI Hatch
E85 FreekTune - Full Bolt-ons
5/14/14 - 12.4@110
2010 NASA Space Shuttle Silver GenPu
E85 FreekTune
EWG GTX3071r: 401HP/386TRQ
K04: 323HP/TachFail SAE
GunGuru727 is offline   Reply With Quote
 Old 11-03-2012, 09:11 AM   #30
Dr. Speed's Avatar
Posts: 610   (View Stats)
Dr. Speed is the leader of the worldDr. Speed is the leader of the worldDr. Speed is the leader of the worldDr. Speed is the leader of the worldDr. Speed is the leader of the worldDr. Speed is the leader of the worldDr. Speed is the leader of the worldDr. Speed is the leader of the worldDr. Speed is the leader of the worldDr. Speed is the leader of the worldDr. Speed is the leader of the world
^^ yeah, the Corksport logo might look ok if it were more discreet
| 2012 CWP | Cobb AP + AT Internals | HTP 3" Intake | 91oct + DO WMI (D07, 50/50) + 3gal E85 | UR Test Pipe | cp-e TMIC | JBR Trilogy, OCC, EGR Block, SSB | TBC Bypass |
Freektuned - 313/351 - Stock DP
Dr. Speed is offline   Reply With Quote
The Following User Says Thank You to Dr. Speed For This Useful Post:
 Old 11-03-2012, 09:19 AM   #31
+1 for CS rather than CorkSport
+1 for options with and without pattern
Last edited by Code Monkey; 11-03-2012 at 09:19 AM. Reason: MSF Database - Automerged Doublepost
 Old 11-03-2012, 10:25 AM   #32
evil MS3's Avatar
Groans: 55
I would order the full CorkSport one haha but i can see why some might just prefer CS.
 Old 11-03-2012, 12:44 PM   #33
Always liked the Audi knobs:
GunGuru727 likes this.
The Following 7 Users Say Thank You to Lex For This Useful Post:
daafisch (11-07-2012), Domino81 (11-03-2012), dpolseno41 (11-03-2012), GunGuru727 (11-03-2012), seige123 (11-03-2012), silvapain (11-03-2012), Speed_j23 (11-08-2012)
 Old 11-03-2012, 08:10 PM   #34
Amped's Avatar
Posts: 236   (View Stats)
Amped is the leader of the worldAmped is the leader of the worldAmped is the leader of the worldAmped is the leader of the worldAmped is the leader of the worldAmped is the leader of the worldAmped is the leader of the worldAmped is the leader of the worldAmped is the leader of the worldAmped is the leader of the worldAmped is the leader of the world
Groaned at 13 Times in 2 Posts
I would say don't mimic the stock knob, as I've never liked the shape and it looks to me like it's around the same shape. Go with a more unique shape, most like the spherical or cylindrical.
Colors are cool though but make the shift pattern colored.
And maybe heavier?
2006 TiGrey MS6 GT
103,xxx and counting
JBR RMM - JBR SSP - JBR Base Bushings - CS SRI/TIP - JBR Weighted Shift Knob - Turbosmart BPV - The Speedline Badgeless Grille - VG Shark Fin - O.Z. 18x8 Black Ultraleggera - Emblem Delete - 6000K Lows/Highs/Fogs - 15% All The Way Around
Amped is offline   Reply With Quote
 Old 11-03-2012, 08:18 PM   #35
ASHMS3's Avatar
Posts: 1,362   (View Stats)
Groans: 126
I like the leather wrapping. I love my JBR knob, but in the summer it feels like it's going to leave grill marks.
Tappin'
The Following User Says Thank You to ASHMS3 For This Useful Post:
ABSpeed3 (11-20-2012)
 Old 11-03-2012, 08:28 PM   #36
NCZ13's Avatar
Posts: 1,268   (View Stats)
The most comfortable knob Ive ever used was my stock protege5 leather knob. Thing fit perfectly in your hand in whatever position.
In fact..im kind of considering taking my jbr off and throwing my stock back on just for a change...
2008 Cosmic Blue Mazdaspeed3
1986 Mazda RX7
 Old 11-03-2012, 08:42 PM   #37
zoomspeed91's Avatar
Posts: 2   (View Stats)
zoomspeed91 is an unknown quantity at this point
I really like the look of it, like everyone's already said, either color the shift pattern or lose the shift pattern entirely and put a CS logo on the top of the shift knob instead of the side.
zoomspeed91 is offline   Reply With Quote
 Old 11-03-2012, 09:36 PM   #38
93silvergt's Avatar
Posts: 554   (View Stats)
93silvergt is the leader of the world93silvergt is the leader of the world93silvergt is the leader of the world93silvergt is the leader of the world93silvergt is the leader of the world93silvergt is the leader of the world93silvergt is the leader of the world93silvergt is the leader of the world93silvergt is the leader of the world93silvergt is the leader of the world93silvergt is the leader of the world
Groaned at 18 Times in 11 Posts
Throw mazdaspeed on the side rather than corksport? Or is company logo pretty much required?
2009 Mazdaspeed3 GT
Cobb SRI E4P Short Throw shifter
93silvergt is offline   Reply With Quote
The Following 3 Users Say Thank You to 93silvergt For This Useful Post:
Dr. Speed (11-04-2012), GunGuru727 (11-04-2012), jpfrisch87 (11-05-2012)
 Old 11-03-2012, 09:52 PM   #39
bcmurphy87's Avatar
Posts: 1,435   (View Stats)
what if it was more of a CS button than stitched
06 Speed6 GT- Sold
The Following User Says Thank You to bcmurphy87 For This Useful Post:
 Old 11-05-2012, 07:26 PM   #40
Spec's Avatar
Posts: 4,472   (View Stats)
How hard would it be to offer different weights, or possibly an option to add-remove weight somehow. Possibly a snap ring in the bottom you can pop off an add weight. Please everyone.
I like the design and the full corksport logo.
As was mentioned before, tighten up the stitching.
I don't see the need for a shift pattern.
Possibly to build on the acrylic inlay idea mentioned before, with a CS logo or maybe reserve this for the ball style.
Shift Knob Material Selection: Input Please XLT_66 Mazdaspeed3/6 General Discussion 17 12-30-2010 09:54 AM
Page generated in 0.59158 seconds with 49 queries
