Like Tree10Likes
 Old 09-18-2011, 11:22 AM   #561
IMASA's Avatar
Posts: 209   (View Stats)
Originally Posted by JohnMS3 View Post
What boost and coolant temps are you guys seeing with the corksport tmic on stop and go traffic? I got a fmic and contemplating on selling it to get a corksport tmic since my coolant temps have been very high with little gain going with a fmic.
ECT: When driving, around 18X-19XF. Stuck in stop and go city traffic, around 19X-220F. I don't think I've ever hit more than 220F.
BAT: When driving, around 90-110F. Stuck in stop and go city traffic, arround 110-135F.
BAT's rise pretty quick on a hot day when the car is stopped, but slowly goes down when the car is moving, depending on speed.
The Following User Says Thank You to IMASA For This Useful Post:
JohnMS3 (09-18-2011)
 Old 09-18-2011, 12:14 PM   #562
Bucker's Avatar
Posts: 2,856   (View Stats)
Groans: 451
When staying above 30 or 40 my BATs are ~ 10-12 degrees higher than ambients.
403whp/451ft/lb Dry Shot
The Following User Says Thank You to Bucker For This Useful Post:
 Old 12-21-2011, 12:31 PM   #563
maddocx240's Avatar
Posts: 823   (View Stats)
Question, did corksport ever resolve the stock shroud fitment issues? U figure with all the posts in this thread they would of fixed that the current ones being sold..
 Old 12-21-2011, 01:55 PM   #564
zatara's Avatar
Posts: 1,505   (View Stats)
zatara is the leader of the worldzatara is the leader of the worldzatara is the leader of the worldzatara is the leader of the worldzatara is the leader of the worldzatara is the leader of the worldzatara is the leader of the worldzatara is the leader of the worldzatara is the leader of the worldzatara is the leader of the worldzatara is the leader of the world
Some of the fins towards the top of the intercooler still get bent slightly if you use the stock shroud. It's so small and negligible that I don't even find it to be a problem, honestly.
2010 Mazdaspeed 3 Black Mica
CorkSport SRI/ TIP-- CorkSport TMIC-- Cobb DP-- CorkSport CBE-- Cobb AP Stratified Lex Tune-- Autotech Internals-- Denso ITV22's-- JBR EGR Blockoff-- JBR OCC-- JBR 88 Chrome-Molly RMM-- JBR 80 PMM-- JBR 88 TMM-- Corksport Skidplate-- JBR RSB
Red JBR shift knob-- VG Sharkfin--CS LED interior lights-- Hardwired Valentine 1 Radar detector-- 5K HID lows-- 3K HID Fogs-- 30% tint front, 20% tint rear
zatara is offline   Reply With Quote
 Old 12-22-2011, 05:40 AM   #565
Mistersix's Avatar
Posts: 2,585   (View Stats)
the part of the shroud that touches the fins can be easily corrected. the plastic is pretty soft and can be filed down with a rasp or dremel. or shaved down with a small knife.
 Old 12-22-2011, 09:13 AM   #566
CorkSport's Avatar
Posts: 3,416   (View Stats)
The trimming of the plastic on the underside of the TMIC shroud is pretty easy,
Check out the write up we did on our KB
-Derrick
WWW.CORKSPORT.COM
bigriver (12-23-2011), SJP0tato (01-19-2012)
 Old 12-22-2011, 05:29 PM   #567
maddocx240's Avatar
Ok, I guess that's not too bad.. cause I was thinking to go fmic but changed my mind.. so I will be picking up one of these soon..
 Old 12-22-2011, 06:00 PM   #568
CorkSport's Avatar
The trimming is pretty easy to do.
-Derrick
WWW.CORKSPORT.COM
 Old 01-03-2012, 05:57 PM   #569
bigriver's Avatar
Posts: 1,123   (View Stats)
Ordered a tmic using the 10% off coupon in the cs calendar. Looking forward to getting this installed!
bigriver is offline   Reply With Quote
 Old 01-07-2012, 12:34 AM   #570
YZF-R6's Avatar
Posts: 189   (View Stats)
YZF-R6 is the leader of the worldYZF-R6 is the leader of the worldYZF-R6 is the leader of the worldYZF-R6 is the leader of the worldYZF-R6 is the leader of the worldYZF-R6 is the leader of the worldYZF-R6 is the leader of the worldYZF-R6 is the leader of the worldYZF-R6 is the leader of the worldYZF-R6 is the leader of the worldYZF-R6 is the leader of the world
What is this calender coupon you speak of???
2010 MS3 Liquid Silver: TRZ Poly RMM, Cobb AP, PERM (Load-Based FTW), CP-E HPFP, SURE Aeros, HTP TIP, Corksport TMIC, SURE Boost Tubes, Magnaflow CBE, Corksport T/P, JBR LE Shift Knob & Weight, Redline MTL, Swift Spec-R, TSW Nurburgring 18x8.5, Nitto NT555 235/40/18.
If You Don't Like The Pu, Don't Play In The Pu.
YZF-R6 is offline   Reply With Quote
 Old 01-07-2012, 08:19 AM   #571
bigriver's Avatar
Corksport 2012 calendar. $15 on their website which is then donated to a charitable org. 10% off coupon is good for January 2012. Need to also register on their site and login when u order the calendar and then when u use the code so their system can validate the code. There are diff coupons each month of 2012.
The Following User Says Thank You to bigriver For This Useful Post:
CorkSport (01-09-2012)
 Old 01-09-2012, 12:49 PM   #572
CorkSport's Avatar
You can take a look at the calendar information at the link below.
Link for the calendar information
-Derrick
WWW.CORKSPORT.COM
 Old 01-12-2012, 04:06 PM   #573
YZF-R6's Avatar
For the people who have bought these recently, is the issue with the front mounting feet not sitting flush on intake manifold resolved or does it still require some shimming to sit flush?
 Old 01-12-2012, 10:37 PM   #574
YZF-R6's Avatar
Lol fuck it, im sure it fits fine. Just ordered one!!!
The Following User Says Thank You to YZF-R6 For This Useful Post:
Mooseknuckler (07-25-2015)
 Old 01-13-2012, 07:37 AM   #575
bigriver's Avatar
^^ya I think that was just a couple that Corksport took care of. I just received mine a few days ago and will install tomorrow.
 Old 01-13-2012, 05:20 PM   #576
ChrisCS's Avatar
Posts: 52   (View Stats)
ChrisCS has a reputation beyond reputeChrisCS has a reputation beyond reputeChrisCS has a reputation beyond reputeChrisCS has a reputation beyond reputeChrisCS has a reputation beyond reputeChrisCS has a reputation beyond reputeChrisCS has a reputation beyond reputeChrisCS has a reputation beyond reputeChrisCS has a reputation beyond reputeChrisCS has a reputation beyond reputeChrisCS has a reputation beyond repute
The fitment does not need the shims any longer.
ChrisCS is offline   Reply With Quote
 Old 01-15-2012, 11:40 AM   #577
bigriver's Avatar
Installed mine and fit is perfect. Just had to trim the ridge inside the shroud. I was even able to reuse the oem bolts for the shroud.
CorkSport (01-16-2012)
 Old 01-18-2012, 10:41 PM   #578
ChrisCS's Avatar
This is normal and is a known mod needed to use the factory cover on the TMIC.
 Old 01-19-2012, 10:35 AM   #579
ChimmyChong's Avatar
Posts: 592   (View Stats)
ChimmyChong is the leader of the worldChimmyChong is the leader of the worldChimmyChong is the leader of the worldChimmyChong is the leader of the worldChimmyChong is the leader of the worldChimmyChong is the leader of the worldChimmyChong is the leader of the worldChimmyChong is the leader of the worldChimmyChong is the leader of the worldChimmyChong is the leader of the worldChimmyChong is the leader of the world
Groans: 39
nvm
2010 Liquid Silver MS3
// BNR S3 // 3Bar Map+MJ Harness // JBR 3.5" WP // CS TMIC // KMD HPFP // 3" Catless DP/RP // TS Dual Port // Cobb AP // GS 3 port EBCS // ITV-22's // MD OCC // JBR Small Battery Tray //
// JBR Dog Bone RMM // JBR Heavy Knob // JBR Solid Shifter Bushings // JBR Short Shifter Plate // JBR RSB // JBR 80D PMM // 15mm Front // 10mm Rear // SPC Rear Camber Arms // Sonic Tuning Coilovers //
// 6K HID // 35% tint // 12"RF with Infinity Amp // MZ Front Lip // 17x8 Enkei RPF1's //
ChimmyChong is offline   Reply With Quote
 Old 01-24-2012, 10:56 AM   #580
bigriver's Avatar
I've been impressed with the gains so far. BATs are way down and car pulls stronger without boost as well. One of my favorite mods. Also have the CS boost tubes which fit perfectly.
CorkSport (01-25-2012)
 Old 01-26-2012, 09:13 PM   #581
ChrisCS's Avatar
That's what the freer flow will do for you. Your engine does not have to work as hard to make the same power so the power comes on sooner.
 Old 01-27-2012, 12:17 PM   #582
tweak120's Avatar
Posts: 30   (View Stats)
tweak120 is a splendid one to beholdtweak120 is a splendid one to beholdtweak120 is a splendid one to beholdtweak120 is a splendid one to beholdtweak120 is a splendid one to beholdtweak120 is a splendid one to beholdtweak120 is a splendid one to behold
Talking
Just installed mine and love it!! I can tell the difference with the power!
Very easy to install, it took abot 15 mins.
Thanks CorkSport!!
2011 Mazdaspeed3 Velocity Red w/ Tech Package
Current Mod's:
CP-E Xcel CAI | CP-E DISI Nviscid Pipe | CorkSport Racepipe | CorkSport TMIC | Autotech Internals | Denso ITV-22 | AP (Custom FreekTune) | CP-E RMM 65A | MagnaFlow 15557 Catback | Forge BOV (Blue+2) | Tint all the way around | Escort 8500 X50 Blue using a BlendMount | TWM Black Pearl A6 Leopard Shift Knob | CorkSport LED Light Kit |
tweak120 is offline   Reply With Quote
 Old 01-27-2012, 12:37 PM   #583
hank25's Avatar
Posts: 71   (View Stats)
hank25 has a brilliant futurehank25 has a brilliant futurehank25 has a brilliant futurehank25 has a brilliant futurehank25 has a brilliant futurehank25 has a brilliant futurehank25 has a brilliant futurehank25 has a brilliant futurehank25 has a brilliant futurehank25 has a brilliant futurehank25 has a brilliant future
Hmm really starting to think I am going CorkSport at this point. Appreciate you guys taking the time to answer any questions we have and please keep up the great work!
Cobb SRI Cobb BPV SURE TIP SURE RMM KMD Internals SU Test Pipe JBR Stage 2 FREEKTOONZ
hank25 is offline   Reply With Quote
The Following User Says Thank You to hank25 For This Useful Post:
CorkSport (01-28-2012)
 Old 01-28-2012, 09:21 AM   #584
CorkSport's Avatar
Very eay to install, it took abot 15 mins.
Thanks CorkSport!!
That is a quick install time!
WWW.CORKSPORT.COM
 Old 05-31-2013, 03:16 PM   #585
jrotaryb's Avatar
Posts: 416   (View Stats)
I just got mine today and installed it right away! My mechanical abilities are, well, limited but this was still pretty easy for a stubby fingered dope like me.
Everything fits nicely on my genpu, but I did have to crank down pretty good on the passenger side of the optional shroud to close the gap between the shroud and the supplied spacer. It seems to have tweaked the shroud just slightly on that side...
I checked and the height of the spacers match and the TMIC itself is seated nicely to the boost tubes and tightened down properly.
Is this normal?
pedal2plastic.wordpress.com
The driving game blog
Cobb: AP, SRI & RMM
Corksport: TIP, TMIC, RP,SSP
Autotech Internals
Bilstein PSS Coilovers
JBR RSB
Gram Lights 57F - 18x8.5 +45
Rfinkle2 tuned @21psi
 Old 05-31-2013, 03:52 PM   #586
CorkSport's Avatar
Is this normal?
Can you email me a picture? Derrick at CorkSport.com
-Derrick
WWW.CORKSPORT.COM
 Old 05-31-2013, 05:05 PM   #587
jrotaryb's Avatar
-Derrick
Done - I'm probably being overly cautious, but still...
Cobb: AP, SRI & RMM
Autotech Internals
JBR RSB
 Old 01-20-2015, 07:06 PM   #588
TORQUERULES's Avatar
Posts: 283   (View Stats)
TORQUERULES has a reputation beyond reputeTORQUERULES has a reputation beyond reputeTORQUERULES has a reputation beyond reputeTORQUERULES has a reputation beyond reputeTORQUERULES has a reputation beyond reputeTORQUERULES has a reputation beyond reputeTORQUERULES has a reputation beyond reputeTORQUERULES has a reputation beyond reputeTORQUERULES has a reputation beyond reputeTORQUERULES has a reputation beyond reputeTORQUERULES has a reputation beyond repute
Thumbs up
Got mine on. Can't wait until the weather is better so i can try it out. I chose to use the stock shroud, btw.
Fit and finish are excellent. Now to get enough posts to sell the stock tmic. And my stock wheels... ;-)
CorkSport Vincent likes this.
(SOLD) 2013 Crystal White MS3--JBR 3.5" intake, very minor PNP intake manifold, CS TMIC, CS HPFP internals, CS BPV, JBR EGR delete and block-off, CFM RMM, CS TM insert, Cobb AP V3 with Stratified Stage 3 tunes (93 and E85 mix), VTCS delete, coolant bypass, 1 step colder plugs, CS shifter bushings, CS short shifter, Damond OCC, Ultra Gauge, Progress RSB, Koni dampers, Eibach Pro-Kit springs, JBR rear spacers, 235/40/18 Nitto Motivo tires, Drag DR-49 18x8" wheels, CNT cat-less DP, CNT cat-back, DDM HIDs, etc.
2017 Mazda CX-3 Meteor Gray
TORQUERULES is offline   Reply With Quote
The Following User Says Thank You to TORQUERULES For This Useful Post:
mazdaspeedmyk (01-20-2015)
The Following 3 Users Say NO Thank You to TORQUERULES For This Un-useful Post:
faeker (01-21-2015), Vansquish (01-21-2015), WetzMS3 (01-21-2015)
 Old 01-21-2015, 08:41 AM   #589
CorkSport's Avatar
Wow old post revival!
I kid
ASHMS3 likes this.
WWW.CORKSPORT.COM
The Following 7 Users Say Thank You to CorkSport For This Useful Post:
ASHMS3 (01-21-2015), cshunter (02-05-2015), faeker (01-21-2015), Raider (01-21-2015), trancehead (01-21-2015), Vansquish (01-21-2015), WetzMS3 (01-21-2015)
 Old 01-21-2015, 11:49 AM   #590
That is funny stuff right there ^^^^
CorkSport (01-21-2015)
 Old 02-05-2015, 10:42 AM   #591
Okay, so I didn't really expect this to be a big horsepower/torque producing mod, but boy was I wrong. I am truly amazed at the additional power throughout the entire powerband, the improved response, quick boosting, etc. This is a definite eye-opener. Feeling the tires grip for traction with a quick part throttle stab in 4th gear is smile-inducing...
Sent from my Windows Phone
SpencerC (02-05-2015)
 Old 02-05-2015, 10:52 AM   #592
SpencerC's Avatar
Posts: 2,159   (View Stats)
Glad you like it so much. The TMIC definitely can make a nice difference, especially if you are already noticing heatsoak on your stock TMIC. I definitely noticed quicker response to the throttle and boost in my car.
TORQUERULES (02-05-2015)
 Old 02-05-2015, 11:32 AM   #593
mazdaspeedmyk's Avatar
Posts: 124   (View Stats)
I've always liked how it keeps my engine bay looking almost stock, especially when paired with their hood struts, SRI and CAB.
The Following 2 Users Say Thank You to mazdaspeedmyk For This Useful Post:
CorkSport (02-06-2015), WA_MS6 (02-06-2015)
 Old 02-06-2015, 11:48 PM   #594
WA_MS6's Avatar
Posts: 459   (View Stats)
I wanna get rid of my CP-e TMIC and get the CorkSport one. Just can't have the down-time due to my ms6 being my daily :/
2007 Black Mica Mazdaspeed6
AutoTech HPFP Internals
COBB AP w/ stage 2 ~ Shifter Weight
CorkSport Front Mount Kit
CP-e CBE Single Exit Exhaust
Koni Yellows
 Old 02-13-2015, 06:29 AM   #595
nomorecivic!'s Avatar
Posts: 45   (View Stats)
nomorecivic! is a splendid one to beholdnomorecivic! is a splendid one to beholdnomorecivic! is a splendid one to beholdnomorecivic! is a splendid one to beholdnomorecivic! is a splendid one to beholdnomorecivic! is a splendid one to beholdnomorecivic! is a splendid one to behold
Groaned at 3 Times in 1 Post
I'm about to buy a top mount from corksport my self right now, just browsing the forum for a possible coupon for corksport before I do haha. I am glad to see people loving the top mount makes me feel good about the decision to stick with corksport! I do have a question for corksport about your inventory tho. I just bought the CS lowering springs and they said they won't be in till April, and you guys have no live inventory tracking system online so who would I need to talk to before I buy to make sure the top mounts are in stock before I buy?
nomorecivic! is offline   Reply With Quote
 Old 02-13-2015, 12:32 PM   #596
SpencerC's Avatar
Call us to check stock on anything if you want to know before you order. Otherwise we should email/call you within one business day.
360-260-2675
 Old 02-13-2015, 12:35 PM   #597
insomniacucr's Avatar
Posts: 114   (View Stats)
insomniacucr has much to be proud ofinsomniacucr has much to be proud ofinsomniacucr has much to be proud ofinsomniacucr has much to be proud ofinsomniacucr has much to be proud ofinsomniacucr has much to be proud ofinsomniacucr has much to be proud ofinsomniacucr has much to be proud ofinsomniacucr has much to be proud ofinsomniacucr has much to be proud of
I'm not sure if corksport has tax season sales, but many of the other vendors supporting this forum do.
insomniacucr is offline   Reply With Quote
 Old 02-13-2015, 05:21 PM   #598
SpencerC's Avatar
We are not going to have a tax season sale.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f500/corksport-top-mount-intercooler-67727/
CorkSport Mazda Performance - Blog » More Turbos from Mazda This thread Refback 01-17-2012 11:00 AM
CorkSport Mazda Performance - Blog » Featured Car of the Month - Mackey’s Mazda 3 This thread Refback 01-16-2012 04:41 AM
CorkSport Mazda Performance - Blog » Oil Catch Can This thread Refback 01-13-2012 11:59 AM
corksport tmic preorders shipped on the 16th This thread Refback 04-19-2011 11:12 PM
Corksport TMIC $299 This thread Refback 01-22-2011 09:51 PM
Corksport TMIC pour 299$ :) This thread Refback 01-22-2011 02:09 PM
Page generated in 0.55210 seconds with 39 queries
