 Old 05-01-2019, 06:42 AM   #1
LenSpeed6's Avatar
Posts: 164   (View Stats)
According to Cork, the now CST4 can do 28psi but happier at around 25-26 which is probably the max of what I'd do for my particular car (for now). I wish that the CST5 was available when I was building my car, who knows what I'll end up doing in the future but upgrading the manifolds would be priority over a different turbo for me.
Unless its a chinese knock off it doesnt seem like you can go wrong with either CS or BNR.
06 Speed6
White/Black interior
Boost creep after installing Corksport Turbo vesestilldrumming 2010 MS3 - Troubleshoot/Diagnostics 205 01-21-2016 09:26 PM
Fuel Cut, Over Boost, Turbo Creep Ms6_Guy MazdaSpeed 3/6 - Troubleshoot/Diagnostics 9 04-08-2014 03:29 PM
GTX3071R boost creep/boost spike! Need help! MS3 Ventura MazdaSpeed 3/6 - Big Turbo Builds 20 05-11-2013 11:44 AM
Boost creep 86AmishMs3 MazdaSpeed 3/6 - ECU Computer Tuning 11 12-21-2011 05:30 PM
Boost creep? psmith22 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 8 07-24-2011 11:47 PM
Page generated in 0.23375 seconds with 21 queries
