Like Tree25Likes
 Old 06-01-2015, 07:40 PM   #1
Jester2552's Avatar
Posts: 126   (View Stats)
Jester2552 is the leader of the worldJester2552 is the leader of the worldJester2552 is the leader of the worldJester2552 is the leader of the worldJester2552 is the leader of the worldJester2552 is the leader of the worldJester2552 is the leader of the worldJester2552 is the leader of the worldJester2552 is the leader of the worldJester2552 is the leader of the worldJester2552 is the leader of the world
Default Corksport Turbo EWG
What's up everyone. After some thought and going back and forth between the CS Turbo and the BNRS3 I decided to go with the CS unit not only because of the great reviews but also simply because the CS turbo would get here before I leave for my deployment. I also however have been wanting to go EWG if and when I ever upgraded to here goes! So far the parts list I have include what's in my sig plus:
HTP 3" intake
Corksport Catless DP
Grimmspeed EBCS
Sk1nny's EWG stock mani
Tial 38mm EWG
Bosch 3 bar MAP sensor and PNP harness
EBay Dump tube
Cobb IWG bracket
I plan on running a 91 and 25% E85 mix that will be tuned by Nishan! Unfortunately The install day won't take place until the 13th of June for work related stuff. But I will update this thread accordingly as time goes on.
Here are some pictures so far:
Right out of the box:
With the IWG on
Cobb bracket installed:
aromig and Rob@Hypnotictuning like this.
2007 Black MS3
CorkSport Turbocharger, HTP 3" Intake, CorkSport Catless Downpipe, CorkSport Catless Testpipe, CorkSport Catback, Tial 38mm EWG, GrimmSpeed EBCS, Bosch 3 Bar MAP Sensor, Forge V1 BPV, Cobb AcessPort, CP-e Stage 2 RMM, JBR Rear Sway, Moog Endlinks, ETS TMIC, AT Internals, JBR IM/TB TIG, Bilstein B8s, Cobb Springs, Rays Gram Lights 57C6 18X8.5 ET45, 235/40 Ventus RS-3,
Tuned by Nishan
USAF 2W1 "Warheads on Foreheads"
Jester2552 is offline   Reply With Quote
The Following 4 Users Say Thank You to Jester2552 For This Useful Post:
Agent_Orange (06-01-2015), bigtattiesmcghee (06-14-2015), CorkSport Vincent (06-02-2015), Raider (06-13-2015)
 Old 06-01-2015, 08:21 PM   #2
phecker410's Avatar
Posts: 143   (View Stats)
phecker410 has a brilliant futurephecker410 has a brilliant futurephecker410 has a brilliant futurephecker410 has a brilliant futurephecker410 has a brilliant futurephecker410 has a brilliant futurephecker410 has a brilliant futurephecker410 has a brilliant futurephecker410 has a brilliant futurephecker410 has a brilliant futurephecker410 has a brilliant future
If you don't mind me asking, how much did all this cost you with shipping?
one distributor, or multiple?
06 MS6 Sport,ZZB and warranty motor replacement 8/9/14
SU SRI w/ COBB MAF:::JBR TIP:::JBR 80aTRILOGY:::Strat+ Base Map:::MATT DAMOND FULL EGR DELETE:::VTCS Delete:::CP-E SafeSeals
phecker410 is offline   Reply With Quote
 Old 06-01-2015, 08:49 PM   #3
h.h.sk1nny's Avatar
Posts: 1,392   (View Stats)
Lookin good Jake!!! Glad you are getting it all together. You can totally knock that out over a weekend. Can't wait to see what she puts down. Will be a mean auto x and street car for sure
h.h.sk1nny is offline   Reply With Quote
The Following User Says Thank You to h.h.sk1nny For This Useful Post:
Jester2552 (06-01-2015)
 Old 06-01-2015, 11:28 PM   #4
Jester2552's Avatar
I got the Turbo and DP from CS and everything else minus the exhaust mani from Edge. I think all told it came out to a little over 2k
2007 Black MS3
Tuned by Nishan
 Old 06-02-2015, 06:40 AM   #5
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
Picture of said manifold?
Rich Tuned
330WHP and 363TQ
10-19-13 Moore Automotive
 Old 06-02-2015, 08:07 AM   #6
Barett@CorkSport's Avatar
Posts: 85   (View Stats)
Barett@CorkSport is the leader of the worldBarett@CorkSport is the leader of the worldBarett@CorkSport is the leader of the worldBarett@CorkSport is the leader of the worldBarett@CorkSport is the leader of the worldBarett@CorkSport is the leader of the worldBarett@CorkSport is the leader of the worldBarett@CorkSport is the leader of the worldBarett@CorkSport is the leader of the worldBarett@CorkSport is the leader of the worldBarett@CorkSport is the leader of the world
HTP 3" intake
Grimmspeed EBCS
Tial 38mm EWG
EBay Dump tube
Cobb IWG bracket
With the IWG on
Even though I'm a bit bummed you don't want our sweet IWG, I am interested to see how one of these operate with an EWG setup. Will you be running a screamer pipe? (I would be ).
With the Cobb IWG Lock Bracket I noticed that the bolt head sticks out over the CHRA a bit. Check fitment of the supplied coolant line to make sure everything clears before you get to deep in the install. It looks like it should be fine, but we have never check clearance for this setup. Good luck with the install, can't wait to see your results!
Awal likes this.
Barett Strecker
Product Development Engineer
CorkSport Mazda Performance
barett@corksport.com
360-260-2675
2009 MS3 with most of the CS goodies you can buy...and some you can't...
Barett@CorkSport is offline   Reply With Quote
The Following 4 Users Say Thank You to Barett@CorkSport For This Useful Post:
Awal (10-01-2015), bigtattiesmcghee (06-14-2015), England15j (06-02-2015), Jester2552 (06-02-2015)
 Old 06-02-2015, 08:40 AM   #7
Jester2552's Avatar
Nothing pretty but it will serve its purpose until I get back from the middle east and buy either the boost junkyz or the cp-e manifold.
2007 Black MS3
Tuned by Nishan
The Following User Says Thank You to Jester2552 For This Useful Post:
jack_hammer (06-02-2015)
 Old 06-02-2015, 08:46 AM   #8
Jester2552's Avatar
Clearance is just fine and was actually the first thing I checked before I tightened everything down . I have heard nothing but good things about how you all set up the IWG, but I kind of just wanted something different and because Nishan says quote "IWG is for pussies" hahaha. Was either going to be EWG on the BNR or your guys' turbo. And if people run EWG without a screamer pipe, I do not want to meet those people
ZOOMBIE and Awal like this.
2007 Black MS3
Tuned by Nishan
The Following 3 Users Say Thank You to Jester2552 For This Useful Post:
Awal (10-01-2015), Barett@CorkSport (06-02-2015), speedfreak44 (06-02-2015)
 Old 06-02-2015, 09:10 AM   #9
h.h.sk1nny's Avatar
@Jester2552; I run ewg without a screamer pipe lol. Just waiting to get mine fabbed up.
 Old 06-02-2015, 09:43 AM   #10
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
So ugly. lol But I guess that's the nature of the beast when trying to weld to cast iron.
Rich Tuned
330WHP and 363TQ
The Following 2 Users Say Thank You to CWP_MS3 For This Useful Post:
Darthspeed3 (06-14-2015), Jester2552 (06-02-2015)
 Old 06-02-2015, 09:58 AM   #11
speedfreak44's Avatar
Posts: 1,391   (View Stats)
Do you think that will hold to any type of longer term abuse?s
The line up:
 Old 06-02-2015, 10:01 AM   #12
Jester2552's Avatar
Are you just running an open wastegate right now?
2007 Black MS3
Tuned by Nishan
 Old 06-02-2015, 10:02 AM   #13
h.h.sk1nny's Avatar
LOLz yup, just till my screamer pipe is fabbed up
 Old 06-02-2015, 10:02 AM   #14
Jester2552's Avatar
Sk1nny had been running this manifold for a really long time. at least a year and a half I think? Its only temporary for me until I get the funds for a nice mani
Oh even better than a screamer pipe then right? haha I meant the people who just route the ewg back into the exhaust
2007 Black MS3
Tuned by Nishan
Last edited by Jester2552; 06-02-2015 at 10:02 AM. Reason: MSF Database - Automerged Doublepost
 Old 06-02-2015, 10:04 AM   #15
Yatta's Avatar
Posts: 1,862   (View Stats)
@h.h.sk1nny; or @Jester2552; does the ewg clear the TMIC or is that hoping for too much?
 Old 06-02-2015, 10:06 AM   #16
Jester2552's Avatar
Im hoping it does because I will be using the ETS TMIC I have on currently. It'll be close but I think it'll be fine
2007 Black MS3
Tuned by Nishan
 Old 06-02-2015, 11:18 AM   #17
Yatta's Avatar
will be watching, I have a CS TMIC and there are a lot of stock manifolds on ebay for cheap...
 Old 06-02-2015, 02:06 PM   #18
Brandon@corksport's Avatar
Posts: 170   (View Stats)
Interested to see how it will work with ewg!
Cheers,
Brandon Johnson
(360)260-2675 ext. 106
BrandonJ@corksport.com
 Old 06-02-2015, 03:31 PM   #19
AwAfrican's Avatar
Posts: 1,038   (View Stats)
Looking forward to the results! And maybe a sound clip
2013 Black MS3
 Old 06-13-2015, 12:20 AM   #20
Jester2552's Avatar
So update. Tonight @ZOOMBIE; and I successfully got everything out. I had heard horror stories about the downpipe but honestly the 5 bolts weren't that bad at all. The only hiccup we had was that whoever installed the primary O2 sensor just decided that threads aren't important and completely destroyed them. It was a BITCH to get out.
Picture of said fail:
Obligatory downpipe salute:
To my utter amazement, even with almost 118k on the clock, my K04 has ZERO shaft play! I test fitted the EWG with the ghetto rigged mani and ran into some fitment issues however so it's looking like I might have to hammer in some of the fire wall to get it to fit. But other than that the fun begins tomorrow!!
Awal and AwAfrican like this.
2007 Black MS3
Tuned by Nishan
The Following 10 Users Say Thank You to Jester2552 For This Useful Post:
Awal (10-01-2015), BLKSTIG (06-13-2015), BrianB6 (07-06-2015), Code Monkey (06-13-2015), Easter Bunny (06-14-2015), impossible (06-14-2015), lpugfan2004 (06-13-2015), Raider (06-13-2015), Rich990 (06-13-2015), SpeedRebirth (06-13-2015)
 Old 06-13-2015, 07:47 AM   #21
ZOOMBIE's Avatar
Posts: 75   (View Stats)
ZOOMBIE is a glorious beacon of lightZOOMBIE is a glorious beacon of lightZOOMBIE is a glorious beacon of lightZOOMBIE is a glorious beacon of lightZOOMBIE is a glorious beacon of lightZOOMBIE is a glorious beacon of light
Just so everyone knows there will be videos made of drive bys, in car, fly bys, and everything else your heart could possibly desire.
2013 Mazdaspeed Tech Package
HTP 3", Autotech HPFP Internals, Grimm Speed 3 Port EBCS, CS TBE, CS 70 DURO RMM, COBB FMIC, Cobb AP v3, JBR EGR Delete, DAMON OCC, CS Springs, JBR RSB, Evo X Wheels with 235/40/18 Nitto NT05, 25% e85 mixture, and tuned by Nishan.
ZOOMBIE is offline   Reply With Quote
 Old 06-14-2015, 12:05 AM   #22
Jester2552's Avatar
So another update. Got the turbo and everything in fine along with the downpipe. However it turns out that AutoZone's part number for the primary 02 sensor is incorrect. Which upon further research on here is known so I guess my fault for not researching more after I discovered a new one was needed. Basically that means I wont be able to finish this up until a new one gets here on Tuesday. Once I get that in I can put the intake and EBCS on as well.
Few random pictures of how everything is shaping up
As always the corksport instructions were very clear and accurate. Made everything quite a bit easier to accomplish. For never having swapped a turbo ever in my life I felt like it went in fairly smoothly. Hardest part for me was putting on the oil feed line but even that wasn't too much of a big deal. Really looking forward to actually getting this thing back on the road!!!
2007 Black MS3
Tuned by Nishan
The Following 2 Users Say Thank You to Jester2552 For This Useful Post:
Awal (10-01-2015), Easter Bunny (06-14-2015)
 Old 06-14-2015, 07:37 AM   #23
pirate steve's Avatar
Posts: 248   (View Stats)
pirate steve is the leader of the worldpirate steve is the leader of the worldpirate steve is the leader of the worldpirate steve is the leader of the worldpirate steve is the leader of the worldpirate steve is the leader of the worldpirate steve is the leader of the worldpirate steve is the leader of the worldpirate steve is the leader of the worldpirate steve is the leader of the worldpirate steve is the leader of the world
Why did you go with CS's divorced downpipe for an EWG build over a bellmouth one?
2011 grey MS3: HTP TIP, COBB SRI, HPFP internals, CS TMIC, Dammond EGR delete, Dammond OCC, M2 full DP all of the cats deleted, freektune OTS+, denso ITV22, Maisonvi turbo bolt, CP-e S2 RMM
pirate steve is offline   Reply With Quote
 Old 06-14-2015, 10:30 AM   #24
Originally Posted by bigtattiesmcghee View Post
How the hell do I get my hands on one of these? Didn't see it for sale on CS website... Looks awesome man.
Look harder!
CS TURBA!!!
AwAfrican likes this.
The Following User Says Thank You to pirate steve For This Useful Post:
Jester2552 (06-14-2015)
 Old 06-14-2015, 10:39 AM   #25
L0k1's Avatar
Posts: 171   (View Stats)
L0k1 is the leader of the worldL0k1 is the leader of the worldL0k1 is the leader of the worldL0k1 is the leader of the worldL0k1 is the leader of the worldL0k1 is the leader of the worldL0k1 is the leader of the worldL0k1 is the leader of the worldL0k1 is the leader of the worldL0k1 is the leader of the worldL0k1 is the leader of the world
This is neat.
2009 ZZB'd MS3 Black -FUCK CO-SIGNING(YES I AM AN IDIOT but its mine now going to have fun with it)
17x8 anti freeze green Rota boost rims
CP-E Stage 2 RMM//// Autotech Interals//
[Sold]2010 MS3 Black
CS TURBO and CS shift knob fully weighted
HTP 3.5" intake and Battery tray
UR catted DP/RP and custom CBE
CP-E Stage 2 RMM// ETS 3.25" TMIC// Autotech Interals forge BPV// Grimspeed ebcs// 3bar map"// JBR short shift plate
Not installed:Fortune 500 coil overs/ Boost gauge/ AFR gauge/ JBR eyelids/Camber arms/ JBR OCC/ Guardian angel/ Devils own meth stage 2
381 whp/ 396wtq
Purple Drank
L0k1 is offline   Reply With Quote
The Following User Says Thank You to L0k1 For This Useful Post:
 Old 06-14-2015, 11:30 AM   #26
AwAfrican's Avatar
Sexier than myself naked...
Pics or gtfo
2013 Black MS3
The Following 2 Users Say Thank You to AwAfrican For This Useful Post:
BLKSTIG (06-14-2015), Easter Bunny (06-14-2015)
 Old 06-14-2015, 02:24 PM   #27
Jester2552's Avatar
Didn't really register to me that I did that until all the parts got here. But in the end it doesn't really matter because Ill max out fueling before I max out the exhaust flow anyways. I guess if I ever go built motor and add aux fueling I'd pick up a bellmouth
2007 Black MS3
Tuned by Nishan
pirate steve (06-14-2015)
 Old 06-14-2015, 03:11 PM   #28
knocturnal's Avatar
Posts: 266   (View Stats)
Thank you for posting a comparison pic. That thing is considerably larger than the K04
Mods:
Stratified Tuned Stage 2 OTS+
273whp/330wtq
SnailD Tuned on Meth
316whp/359wtq
412whp/373wtq
 Old 06-14-2015, 06:36 PM   #29
It'd be interesting to see if you could splice the EWG dump tube into the downpipe's wastegate runner.
The wastegate looks pretty tight to that heat shield as is though.
 Old 06-14-2015, 10:51 PM   #30
Jester2552's Avatar
But then I would miss out on the screamer pipe goodness! Haha you could probably do that thought if you really wanted to
2007 Black MS3
Tuned by Nishan
 Old 06-15-2015, 04:42 AM   #31
AwAfrican's Avatar
Why? I suppose it could be done but if you wanted to run it back in why wouldn't you just run an IWG? Just a thought.
Love me some screamer pipe!
2013 Black MS3
The Following User Says Thank You to AwAfrican For This Useful Post:
Jester2552 (06-15-2015)
 Old 06-16-2015, 04:24 PM   #32
Jester2552's Avatar
So forgot to update yesterday but I was having problems fitting the dump tube so I went to the local exhaust shop and just had him put a slight 15 degree or so bend in it to get it to fit and now she's in:
Just got the 02 sensor from EdgeAutoSport that I over nighted. HUGE thanks to them for getting that item out to me quickly and on time. Really always have been impressed with their service! Everything should be ready to start up tonight! Cannot wait to see what Nishan can get out of my set up. Videos incoming!
cshunter likes this.
2007 Black MS3
Tuned by Nishan
Code Monkey (06-16-2015), Erick13Speed3 (06-16-2015), memin (06-16-2015), Raider (06-17-2015)
 Old 06-16-2015, 05:05 PM   #33
Cant wait for vids!
Cheers,
Brandon Johnson
 Old 06-16-2015, 07:04 PM   #34
ZOOMBIE's Avatar
Making videos.
 Old 06-16-2015, 10:19 PM   #35
Jester2552's Avatar
Alright here are the goods. First start up and everything else from there!
2007 Black MS3
Tuned by Nishan
The Following 15 Users Say Thank You to Jester2552 For This Useful Post:
89T (06-27-2015), Awal (10-01-2015), Code Monkey (06-16-2015), DaUberSchwebel (07-21-2015), h.h.sk1nny (06-17-2015), Jeremy M (06-20-2015), JgamB (06-16-2015), kaprikorn (08-04-2015), lnumbp (06-17-2015), lpugfan2004 (06-17-2015), memin (06-16-2015), Raider (06-17-2015), Rich990 (06-18-2015), Sinister_Speed3 (06-16-2015), va7kpt (06-20-2015)
 Old 06-17-2015, 04:47 AM   #36
AwAfrican's Avatar
You can hear that things just screaming! Plus sword clash
2013 Black MS3
Jester2552 (06-17-2015)
 Old 06-17-2015, 11:16 AM   #37
Sounds good!
Cheers,
Brandon Johnson
The Following User Says Thank You to Brandon@corksport For This Useful Post:
 Old 06-20-2015, 01:30 PM   #38
Jester2552's Avatar
So i Autocrossed today just on the third revision and man this thing is a rocket now! Here is a video for your viewing pleasure!
ZOOMBIE likes this.
2007 Black MS3
Tuned by Nishan
The Following 7 Users Say Thank You to Jester2552 For This Useful Post:
89T (06-27-2015), Awal (10-01-2015), blakjak0271 (06-20-2015), CaptainCode (06-23-2015), Code Monkey (07-05-2015), Jeremy M (06-20-2015), Shwaykid (06-23-2015)
 Old 07-06-2015, 01:16 AM   #39
memin's Avatar
Posts: 994   (View Stats)
OP any updates or VD?? thread is going dead.
 Old 07-06-2015, 01:49 AM   #40
Djohns's Avatar
Posts: 3,944   (View Stats)
This is awesome. Possible setup for my near future
2010 black mica speed3
Soon:built motor
So, about the new Corksport turbo... dale_gribble CorkSport 1859 08-01-2017 01:32 AM
Corksport turbo review hitANDrun21 CorkSport 117 01-16-2016 04:08 PM
corksport DP to garrett turbo? Swinger13 MazdaSpeed 3/6 - Turbo Induction 14 10-05-2012 08:29 PM
Page generated in 0.61661 seconds with 35 queries
