Like Tree4Likes
  • 3 Post By Easter Bunny
  • 1 Post By Oni
 Old 05-30-2015, 06:45 PM   #1
nas711's Avatar
Posts: 71   (View Stats)
nas711 is just really nicenas711 is just really nicenas711 is just really nicenas711 is just really nice
Groaned at 30 Times in 8 Posts
Default Corksport turbo question
Hi all,
My corksport turbo has arrived and it is going to be fitted next week at my tuner. My tuner has no experience with this turbo so I would like a starting point from those in the know. I don't do self tune or eTune, but rather a traditional dyno approach (please don't suggest tuners ). Here are my mods:
COBB Accessport V3
COBB 3" downpipe
COBB RMM
COBB TIP
CPE TMIC
CPE Manifold
Autotech HPFP internals
COBB SF AIRBOX
COBB SRI
BOSCH 3 BAR MAP
COBB 3 PORT EBCS
3" mandrel bend from dump to custom magnaflow muffler
Resonator delete
FORGE V1 BPV
+corksport turbo*
My question is: I want to achieve a DD friendly 300-320hp with a mild tune (like a k04 replacement with a bit more mid). What kind of boost levels should he be aiming for with my listed mods? We have nice octane fuel here in Australia, so fuel is no issue (can even run e85 as it is plentiful down the road, but would rather stick to the 98 octane here as cheaper and easier).
I was also aiming for torque and boost to come in stronger at high rpms say 3.5k above, this recommended? Current k04 set up like most is quite a quick violent spool and I know thats not nice on the rods with a bigger turbo. I love the nature of the quick spool, but want this set up to last as no plans to build at the moment.
Any feedback would be appreciated and helpful on the day from those who have a corky installed and are tuning for not crazy levels.
Thank you
nas711 is offline   Reply With Quote
The Following 2 Users Say NO Thank You to nas711 For This Un-useful Post:
Hoyoman (06-05-2015), Vansquish (06-01-2015)
 Old 05-30-2015, 06:55 PM   #2
sheston's Avatar
Posts: 1,847   (View Stats)
I got that range of hp on my K04 with similar mods and Meth. All I can get out of the K04 at redline is ~17psi. I'll bet somewhere in that range would get you what you want.
It seems a waste of a good turbo to do that though. I would just ask the tuner to keep the torque below 300 or so until 3500 - 4000 rpms, then taper it up til you run out of fueling. That way you would be safe on the stock rods, but still enjoy the benefits of the turbo if you wound it out
 Old 05-30-2015, 06:56 PM   #3
If your tuner can't handle a basemap for a puppy turbo you need a new tuner.
Raider, Hoyoman and AwAfrican like this.
The Following 15 Users Say Thank You to Easter Bunny For This Useful Post:
aromig (07-18-2015), Code Monkey (05-30-2015), frothy (06-01-2015), Gr8Speed (06-01-2015), jmac (06-04-2015), littleloogy (06-02-2015), maisonvi (06-01-2015), MD1032 (06-02-2015), neganox (06-01-2015), Oni (05-30-2015), Raider (05-30-2015), SarcasticOne (06-01-2015), shaneski (06-01-2015), taf0422 (06-01-2015), Vansquish (06-01-2015)
 Old 05-30-2015, 07:01 PM   #4
Oni
Oni's Avatar
Posts: 565   (View Stats)
My thoughts exactly
Gerryisa likes this.
'12 Velocity Red Mica MS3
Cobb AP V3 // Autotech Fuel Pump Internals // HTP 3" // UR Catted V2 DP // UR Resonated TP // UR Resonated CBE // GrimmSpeed EBCS // CP-E TMIC // GFB Respons BPV // JBR Trilogy 88/80/80 // Corksport Hood Struts // Prosport EVO Boost Gauge w/ block8head vent pod // E30 Freektune
Installing Soon : Stratified GA // Bosch 3 Bar Map w/ PNP Harness
Oni is offline   Reply With Quote
The Following 2 Users Say Thank You to Oni For This Useful Post:
Easter Bunny (06-05-2015), Vansquish (06-01-2015)
 Old 05-30-2015, 07:03 PM   #5
JgamB's Avatar
Posts: 2,566   (View Stats)
Reverse taper to get the more linear power and OEM rod safety, not to mention better traction without sacrificing high RPM HP. I'll just speculate that spooling to 20psi and walking up to 22-23psi will yield just a bit more than you're looking for and be plenty safe, and you can dial in precise power with your spark advance and great pump octane.
 Old 05-30-2015, 07:24 PM   #6
nas711's Avatar
Thanks for the quick replies! My tuner is experienced with all manner of big turbo builds (is Australia's highest output wrx tuner) so they will be fine. Just asked for my own wonderings so I can tell them what to tune for (I don't want to just drop car and turbo off and say "go nuts", drive it for a period of time and have problems like I have read here many times with big turbo / stock block setups). I want to be able to go "ok, I would like it safely tuned at xx amount to keep my motor running happy for a long time" if you get me. More for my own piece of mind I suppose when I am chatting with the tuner as I have very little experience my self.
So from the replies, I am gathering keep the torque below 300ftp (400nm here in aus) in the lower power curve (3.5k) and then open up past 20 up top?
Easter Bunny (06-02-2015), Vansquish (06-01-2015)
 Old 05-30-2015, 07:38 PM   #7
JgamB's Avatar
I haven't vdyno'ed my 93 map in a long time, but it's probably in the neighborhood of 335/350 with a flat 22psi on the BNR, which I believe to be a very comparable turbo with the limited data available. Targeting 300ft-lb would be conservative and may impact inertia to carry higher power into upper RPMs, but that is something you can figure out while on the dyno.
 Old 05-30-2015, 07:44 PM   #8
nas711's Avatar
My current tune hits around 330ftp (450nm) torque at around 3K @ 19psi (k04). Reduce this for corksport turbo as bigger / more load / more stress ?
The Following User Says NO Thank You to nas711 For This Un-useful Post:
 Old 05-30-2015, 07:51 PM   #9
Oni
Oni's Avatar
Ask @Ziggo; about too much power on only gasoline with no MeOH or EtOH. Especially with as hot as it can get in Australia
Easter Bunny (05-31-2015), JgamB (05-30-2015)
 Old 05-30-2015, 07:57 PM   #10
JgamB's Avatar
A small turbo upgrade like this is very flexible - they can make insane torque and toss rods or make well into/above the 400ft-lb territory on a built motor. You need to decide where you're comfortable. If you duplicate the 330ft-lb you had on the K04 but allow the CS turbo to ramp up instead of crap out like a K04, you'll probably get the most enjoyment from it with minimal risk of engine damage.
Do work above 3.8K, enjoy the car IMO.
Barett@CorkSport (05-31-2015)
 Old 05-30-2015, 08:20 PM   #11
nas711's Avatar
Sounds good, thanks for the advice..
 Old 06-01-2015, 03:35 AM   #12
nas711's Avatar
Last question guys. I have access to e85 just down the road. Do you think I should change over to an 85 blend (I am current on 98 (94 aka I think)..not sure what that is in US terms though). If so, what blend are people using for a safe tune on a bigger turbo?
 Old 06-01-2015, 04:53 AM   #13
Kor3y101's Avatar
Posts: 193   (View Stats)
Kor3y101 has a reputation beyond reputeKor3y101 has a reputation beyond reputeKor3y101 has a reputation beyond reputeKor3y101 has a reputation beyond reputeKor3y101 has a reputation beyond reputeKor3y101 has a reputation beyond reputeKor3y101 has a reputation beyond reputeKor3y101 has a reputation beyond reputeKor3y101 has a reputation beyond reputeKor3y101 has a reputation beyond reputeKor3y101 has a reputation beyond repute
I run a 25% e85 mix most times, And has no detrimental effects. No Black Death, no tune issues (gen 2) But ask your tuner.. Where are you located in Aus just btw? And who is tuning? I'm using RayD and couldn't be happier.
'12 Black Speed 3
CS RMM -~- CS SSP & Gearbox Bushings -~- CS OCC -~- CS LED light kit -~- CS Front and Rear Sway Bar -~- UnPlugged EGR Delete -~- CS Hood Struts -~- DVC30 WMI -~- JBR 3" Widepath -~- CS HPFP -~- GrimmSpeed 3 Port -~- HKS SSQV -~- CS TMIC -~- 500W Memphis Sub/Custom Wheel Well Box -~- 3" Xforce TBE -~- RayD Tuned
Kor3y101 is offline   Reply With Quote
The Following User Says Thank You to Kor3y101 For This Useful Post:
JgamB (06-01-2015)
 Old 06-01-2015, 05:02 AM   #14
nas711's Avatar
Hey mate, I am located about 40km out of Melbourne in Victoria. I see your from brisvegas, my home town Where in bris you from? I was in north-west (Ferny Grove) for 28 years of my life, but moved down here for a job. I am getting dyno tuned by HPF down here who have done all of my mods, so I figured perhaps go an e85 mix. Where do you get e85 in bris, on the united site I can't see a lot of suppliers! I don't really have the roads etc for runs on a road with a baby, easier to take it to a dyno and do it in a day and pick it up again.
I just sent an email to my tuner, but hasn't replied so I thought I would ask around what people are generally doing. So 15 litre mix then with 98?
How safe to run this mix without a tune before I get it custom tuned with bigger turbo? (I would fill it up on the day from empty and take it for the tune).
 Old 06-01-2015, 05:11 AM   #15
Kor3y101's Avatar
Well I'm technically from Ipswich, but saying Brisbane is easier haha. I have a united servo about 5 minutes from my house. One of the perks of living near Queensland raceway haha.
Yeah, I mix anywhere between 15-20L then the rest on BP 98. I fill up to the 3/4 mark on 98 first then add the E85. I've been told up to 33% mix is safe without issue. But of course it's like anything. Tuning for it is the best to take advantage of the extra power it can produce.
Ahh okay, understood. I'm sure they will be able to work out tuning with it, they are fairly reputable down there I hear.
There's a great thread about E85 that's worth a read floating around.
'12 Black Speed 3
 Old 06-01-2015, 05:18 AM   #16
nas711's Avatar
Cheers for the info, I might give it a crack if the tuner feels its the best path on my set up. I have a united and a BP next to each other on my way to work! You think you have the e85....in victoria e85 pumps are about 10:1 than other states! Not sure why.....QLD definitely has more hoons!
Good ol Ippy! Hey , least your not from Logan mate.
Last Q : 85 mix ok to run before the tune so I can drive it to my tuner?
 Old 06-01-2015, 05:22 AM   #17
Kor3y101's Avatar
Haha, yeah it sure seems that way around here, so many Commodores haha.
Yeah, at least it's not Logan!
In regards to the E85. You can go up to a 33% mix without any dramas with tuning. I run a 25% mix on track days just for added knock protection and an octane boost without being tuned for it. So there's no dramas with that at all
'12 Black Speed 3
 Old 06-01-2015, 05:32 AM   #18
Police - Grammarhead
Vansquish's Avatar
@nas711; first things first. If you're going to run E85, you should consider whether and how often you're willing to pull the HPFP to check/clean it. There are several threads on MSF discussing how "black death" coats and gums up the pump when you use E85.
@Littloogy; has been doing some good work and research on options for HPFPs that will avoid this problem entirely. It sounds like IE is producing a HPFP that is flex-fuel compatible. Ours is not, nor are Autotech, KMD, nor Corksport (as far as I'm aware). IE HPFP Internals For E85
Here are 3 vdyno logs. The high-po one is from earlier this year (31ºF) running more boost (with a pretty substantial spike) than I'm running now. The other two are back-to-back runs from yesterday at 60ºF on the same stretch of road down and back. Average: 323/344 @ 22psi.
 Old 06-01-2015, 05:34 AM   #19
nas711's Avatar
It's all rich pimps here in Melbourne. Never see the shit I used to see in Bris or goldy cruises like silvia, s14's, 300's etc. Or rust bucket dryliners. It's all fairly new wrx's, gti's or exotics here. I see a few MPS's, but very very rarely. Commo's...yeah a bit, but pretty new ones so they are well behaved! Nothing like an ippy mainstreet VL turbo skid show! haha
Thanks for the information, much appreciated. How often is "needing to be cleaned" in terms of miles (k's) ? Was cheap to install, so I can't see why I couldn't do this every few services?
Last edited by nas711; 06-01-2015 at 05:34 AM. Reason: MSF Database - Automerged Doublepost
 Old 06-01-2015, 06:01 AM   #20
Vansquish's Avatar
Often.
If you do a little searching, you can find that out for yourself. I don't run E, so I don't worry about it.
 Old 06-01-2015, 01:31 PM   #21
JgamB's Avatar
I've been running a 25% Eth mix for 30k miles, never cleaned anything. It's beneficial for wall wash / combustion cooling even if you're not using it for optimal spark advance - I'm of the opinion it's medicinal.
You sacrifice some injector overhead for it due to the increase in specific gravity (you need 30% more eth to reach stoich), but since you're aiming for modest power, you'll have plenty of fuel.
 Old 06-01-2015, 02:56 PM   #22
speedfreak44's Avatar
Posts: 1,391   (View Stats)
@JgamB; what hpfp do you run?
I have the cs one and been running E35ish for about 10k miles with no fuel issues at all on any of my logs. Seems like most the research was done on high blends of E or with autotech internals
The line up:
 Old 06-01-2015, 03:49 PM   #23
JgamB's Avatar
I have ATs. And you're right, the sticky stuff is more for 50%+ blends.
My spill valve was spotless the one time I opened it thinking I had a fuel pump issue - it was my relief valve that had crapped out.
 Old 06-02-2015, 11:31 AM   #24
Mazd1222's Avatar
Posts: 74   (View Stats)
Mazd1222 has a spectacular aura aboutMazd1222 has a spectacular aura about
Groaned at 16 Times in 7 Posts
Looking to Purchase The cork sport turbo has anyone got a chance to test it out with
dyno numbers with good results
Mazd1222 is offline   Reply With Quote
The Following 2 Users Say NO Thank You to Mazd1222 For This Un-useful Post:
mize13 (06-05-2015), speedfreak44 (06-05-2015)
 Old 06-02-2015, 12:02 PM   #25
acousticdefbot's Avatar
Posts: 319   (View Stats)
L0k1 CS turbo experience
Corksport Turbo EWG
Raider's Beta Test of the Corksport Turbo
Another Beta Tester Review of the New Corksport Turbo!!
Corksport turbo review
multiple completed and in progress reviews of this turbo, and there will be more to come.
guzzlin' a guinness stout.
acousticdefbot is offline   Reply With Quote
The Following 2 Users Say Thank You to acousticdefbot For This Useful Post:
Easter Bunny (06-02-2015), Rich990 (06-05-2015)
 Old 06-02-2015, 02:13 PM   #26
Mazd1222's Avatar
Default corksport turbo
currently running with the bucker cheat sheet tune adjustment on my speed 6
I want to get the turbo. Do you think I will have to do a lot of changes after dropping this
in I'm currently running a max of 20psi on my ko4
 Old 06-02-2015, 02:22 PM   #27
Mazd1222's Avatar
Default Corksport Turbo
Thanks for the post acoustic
 Old 06-05-2015, 06:24 AM   #28
g00s3y's Avatar
Posts: 2,127   (View Stats)
Groans: 438
@nas711;
Not entirely true. e85 is running with no problems for me and a few others on Autotechs with the "si-1 mod", also thanks to @littleloogy;
http://www.mazdaspeedforum.org/forum/foru...-steps-186427/
littleloogy (06-05-2015)
 Old 06-05-2015, 07:06 AM   #29
I have a CS hpfp and have had no issues with E but I do not run full its anywhere from about 30-50%. I drove once on a high mix just to get to the gas station (only about 10 miles max). Been like this for about 10k miles pressures still 1700+
The line up:
 Old 06-05-2015, 09:13 AM   #30
g00s3y's Avatar
Groans: 438
Generally 50/50 mixes and below won't exhibit any of the problems that running full e does.
You should throw full corn in there and see how the CS internals do with it, you know, for science and shit.
 Old 06-05-2015, 09:28 AM   #31
Thought about it. I have a little too much to deal with right now to be spending time cleaning the pump out. Also I really do not feel like losing my sending unit lol. Hell though we have write ups now on how to fix it so I guess I have no excuses.
Would you be willing to throw me a 100% e tune base map if I offered up my car for a test run?
The line up:
Corksport TIP and SRI Breather Question JTD MazdaSpeed 3 - Engine, Transmission & Driveline 3 04-13-2015 06:16 PM
Corksport Coilover Question chrisjnas 2010 MS3 - Suspension & Brakes 5 07-09-2014 02:51 PM
corksport exhaust question 11mazdaspeed3 2010 MS3 - Engine, Transmission & Driveline 3 02-15-2012 08:53 PM
corksport dp question gt5 MazdaSpeed 3/6 - Turbo Induction 6 07-10-2010 02:05 PM
corksport dp question. LiEast MazdaSpeed 3 - Engine, Transmission & Driveline 11 08-14-2009 07:58 PM
Page generated in 0.52057 seconds with 31 queries
