Like Tree45Likes
 Old 05-22-2015, 12:38 PM   #81
JgamB's Avatar
Posts: 2,566   (View Stats)
Originally Posted by biggman026 View Post
Looks like you have the opposite problem than I have at the track. You have trouble hooking the launch? Last time I went (on my E85 tune) I ran a 13.05 @ 110 - no trouble hooking up with awd, but my trap speed sucks (no track prep, full weight, Potenza S-04 tires)
2nd gear was killing me because no VHT on the track - I hook just as well on the road. But I'm trying to stay on topic of comparing the turbos lol, don't get me rambling about my drag strip fails.
 Old 05-22-2015, 01:51 PM   #82
MSP6's Avatar
Posts: 1,246   (View Stats)
Better gas than the 92oct mixed with the Eth would help. I run a bit more timing on 3/9 with 93oct and it frees up some IDC. I also don't knock, and those little knock hits in the upper RPM are causing the AFRs to fatten up to 11.4 and IDCs to exceed 100%.
A 4 gallon mix of E and 92 is still like 110 octane give or take. I'd imagine any knock he's seeing are false/noise.
 Old 05-22-2015, 01:55 PM   #83
RJTSi's Avatar
Posts: 205   (View Stats)
RJTSi has a reputation beyond reputeRJTSi has a reputation beyond reputeRJTSi has a reputation beyond reputeRJTSi has a reputation beyond reputeRJTSi has a reputation beyond reputeRJTSi has a reputation beyond reputeRJTSi has a reputation beyond reputeRJTSi has a reputation beyond reputeRJTSi has a reputation beyond reputeRJTSi has a reputation beyond reputeRJTSi has a reputation beyond repute
Most likely is false/noise but the knock sensor doesn't care. It'll still pull timing and dump fuel
True Red 2008.5 SPEED3 Sport...RIP
VRM 2006 Mazdaspeed6....Corksport TD05H-18g, Rambo 3.5" intake, Circuit Werks catless DP, AP E85 tuned, CX Racing FMIC piping w/ TR8, 3 port EBCS, 3-bar Map, heavy Shift weight, Shifter bushings, Autotech internals, RMM, Hawk Pads, SS clutch and brake lines
RJTSi is offline   Reply With Quote
 Old 05-22-2015, 02:05 PM   #84
MSP6's Avatar
Yeah but knock of .35 and AFR's dropping from 11.6 to 11.4 isn't going to make all that much of a difference. Plus his power had already peaked and leveled of by 6250 when he starts reading knock anyway.
Crank those AFR's to 11.8-12.0 get some IDC headroom and let'er rip.
 Old 05-22-2015, 02:35 PM   #85
JgamB's Avatar
Full E85 is ~105 octane AFAIK, and when diluted with 93oct on my mix (25%) you arrive at ~96 RON. You can still knock, and you can also see in the log where the IDCs moved a couple % immediately in response. When I get what I consider mechanical knock, it's usually a lift throttle situation and >1.0
 Old 05-22-2015, 03:01 PM   #86
MSP6's Avatar
E85 in a direct injection engine is 160 oct...or 140 octane...meth might be 160.
 Old 05-22-2015, 03:32 PM   #87
JgamB's Avatar
Please cite your source. I'm all about learning new things.
 Old 05-22-2015, 03:37 PM   #88
MSP6's Avatar
www.mazdaspeedforum.org/forum
plus http://mitei.mit.edu/system/files/2008-01-rp.pdf
The Following 2 Users Say Thank You to MSP6 For This Useful Post:
Ferdball (06-15-2015), JgamB (05-22-2015)
 Old 05-22-2015, 03:51 PM   #89
JgamB's Avatar
I was already reading that as you linked it, thanks!
I don't take those numbers at face value at all though - they used 100% Ethanol and derived artificial "effective octane" ratings because the DI system is already better at quenching than PI. It's like claiming 93oct gasoline is 130 octane in our motor due to the efficient atomization - this behavior is already compensated for and tuned for to obtain greater power, so if this theory held correct, 93 oct couldn't knock either.
The fuel in my tank isn't ~160 octane even though it might behave as such when atomized, and even so if I put too little Eth in, I still get knock.
And in the "how is this relevant to the turbo" conversation, it's because I think he got legit knock and lost IDC to it.
Last edited by JgamB; 05-22-2015 at 03:51 PM. Reason: MSF Database - Automerged Doublepost
 Old 05-23-2015, 04:13 AM   #90
MSP6's Avatar
The effective atomization is relevant because it is alcohol which cools the combustion chamber in a way that gasoline simply cannot, whether its 91, 93 etc. It is not 160 in your tank but once that shits injected its a different story. Also, even with 15% 87oct mixed in...E85 from the pump would still be 149.xxx oct so moot point. But this isn't the thread for that so end rant. Back to puppy power reviewing.
 Old 05-23-2015, 05:37 AM   #91
Lol at all of the S3 owners hoping this turbo doesn't out perform.
The Following 5 Users Say Thank You to Easter Bunny For This Useful Post:
Awal (05-23-2015), eks666 (05-29-2015), Gitcherex (12-23-2015), Thepedigree13 (05-23-2015), We Are Ninja (06-08-2017)
 Old 05-23-2015, 07:42 AM   #92
Justin@Freektune's Avatar
Posts: 954   (View Stats)
At 23-24psi on a small e85 mix and 91 the cars will definitely knock. So i would take it as being real and not false.
Going to a leaner afr be it 11.8 or 12.0 isn't going to gain much headroom for idc or pick up any noticeable power so that is the afr I would have stuck with as well. Especially when Cali 91 is involved.
Unless it's a happy Dyno. You aren't going to make 400whp on an ethanol mix. Just isn't going to happen without supplemental fuel. Heck I have gtx3076 cars maxed out at 360hp with a 3 gallon mix.
If anyone is looking for the absolute max this turbo can make. Either meth or 5th port is going to be needed to shed light on those results. This turbo will and has shown that it flows enough to max the stock fuel system.
smr87 likes this.
PTE 6062
633HP/523TQ
Quickest/Fastest Mazdaspeed
4/22/2017 New England Dragway
The Following 22 Users Say Thank You to Justin@Freektune For This Useful Post:
Amnesiac (05-23-2015), aromig (06-27-2015), AwAfrican (05-27-2015), Awal (05-23-2015), Code Monkey (05-23-2015), dale_gribble (05-23-2015), dmeadors (06-05-2015), Easter Bunny (05-23-2015), ericrapp0507@gmail.com (07-30-2015), Ferdball (06-15-2015), Gitcherex (12-23-2015), hitANDrun21 (05-24-2015), JgamB (05-23-2015), kaprikorn (07-24-2015), MD1032 (05-23-2015), Mjeezy11 (06-25-2015), MSP6 (05-23-2015), Oni (05-23-2015), sadak (01-19-2016), SternRitteR (06-01-2015), Thepedigree13 (05-23-2015), We're All Thieves (05-23-2015)
 Old 05-23-2015, 08:07 AM   #93
MSP6's Avatar
Huh, could've swore I read on here that a 3-4 gallon mix typically brings people past the knock threshold. Proved wrong I suppose @JgamB; I stand corrected
 Old 05-23-2015, 08:56 AM   #94
JgamB's Avatar
You aren't wrong per se, it's just how you look at it. If the fuel is producing an "effective" 140 octane, he needed 145 octane in the combustion chamber to not pre-detonate. (pulling numbers from my ass, but the gist is there.)
@Easter Bunny; I'm not rooting for the S3 to make more power - I want an S4!
Easter Bunny (05-23-2015), Thepedigree13 (05-23-2015)
 Old 06-10-2015, 04:10 PM   #95
Mazd1222's Avatar
Posts: 74   (View Stats)
Mazd1222 has a spectacular aura aboutMazd1222 has a spectacular aura about
Groaned at 16 Times in 7 Posts
Default Corksport turbo
Ordering the corksport turbo I'm currently running 18.5psi tuned 298whp 335tq will I be able to just drop this in or will I need to retune
Mazd1222 is offline   Reply With Quote
 Old 06-10-2015, 04:17 PM   #96
littleloogy's Avatar
Posts: 4,005   (View Stats)
Default Corksport turbo review
You can drop this in and drive, but I do not recommend going WOT without adjusting your tune or permission from your tuner. I did because I don't care about my car, but I would never encourage anyone to do it.
Sent from my iPhone 6
cshunter likes this.
The Following 4 Users Say Thank You to littleloogy For This Useful Post:
Awal (06-10-2015), Barett@CorkSport (06-10-2015), L0k1 (06-11-2015), Raider (06-10-2015)
 Old 06-10-2015, 04:31 PM   #97
Mazd1222's Avatar
Ok I just wanted to make sure because I used the bucker cheat sheet to tune on my car.
It runs great, I was going to do and e85 mix before doing the corksport turbo.
 Old 06-10-2015, 04:42 PM   #98
Well, Corksport has if documented in multiple places that tuning is required. I personally would get on board with a good etuner and go from there. Risking a vented block over $300 tune is my idea of a bad time.
Or bolt it in and redline all the gears. Not my car.
G Sp33dy likes this.
Last edited by Raider; 06-10-2015 at 04:42 PM. Reason: MSF Database - Automerged Doublepost
 Old 06-10-2015, 04:43 PM   #99
Brandon@corksport's Avatar
Posts: 170   (View Stats)
LOL More than likely you will need a re-tune! Even if you don't need one, you should want to get the most out of it regardless. Get a tune!
Cheers,
Brandon Johnson
CorkSport Mazda Performance
(360)260-2675 ext. 106
BrandonJ@corksport.com
The Following 2 Users Say Thank You to Brandon@corksport For This Useful Post:
Awal (06-15-2015), littleloogy (06-10-2015)
 Old 06-15-2015, 01:57 AM   #100
Ferdball's Avatar
Posts: 1,340   (View Stats)
Ferdball is the leader of the worldFerdball is the leader of the worldFerdball is the leader of the worldFerdball is the leader of the worldFerdball is the leader of the worldFerdball is the leader of the worldFerdball is the leader of the worldFerdball is the leader of the worldFerdball is the leader of the worldFerdball is the leader of the worldFerdball is the leader of the world
Originally Posted by hitANDrun21 View Post
update for you guys! E85 tune is done. made 362hp/360tq on the dynopak. @23.5 psi
here is the graph and data log for your viewing pleasure.
60-100 = 4.96s
http://www.mazdaspeedforum.org/forum/foru...-times-126160/
We'll need another category for the new CS turbo.
memin likes this.
Ferdball is offline   Reply With Quote
The Following 2 Users Say Thank You to Ferdball For This Useful Post:
Awal (06-15-2015), Voltwings (06-19-2015)
 Old 06-18-2015, 09:24 AM   #101
2feido's Avatar
Posts: 1   (View Stats)
2feido has a spectacular aura about2feido has a spectacular aura about
Originally Posted by aromig View Post
CorkSport is too small of an operation to manufacture their own turbos. It is built to their specs by someone else, though it has not been confirmed by whom. @dale_gribble has done his research (hats off btw), and speculated it to be Tomioka.
Per Corksports website it's a "Mitsubishi TD05H-18G"
http://www.corksport.com/support/GEN...te%20Paper.pdf
2feido is offline   Reply With Quote
The Following 3 Users Say Thank You to 2feido For This Useful Post:
Awal (07-31-2015), knocturnal (06-21-2015), littleloogy (06-19-2015)
 Old 06-18-2015, 10:32 AM   #102
Police - Grammarhead
Vansquish's Avatar
This is already widely-known. Tomioka makes a lot of turbos using Mitsubishi parts.
aromig likes this.
Easter Bunny (06-18-2015)
 Old 06-18-2015, 09:55 PM   #103
aromig's Avatar
Posts: 289   (View Stats)
aromig is the leader of the worldaromig is the leader of the worldaromig is the leader of the worldaromig is the leader of the worldaromig is the leader of the worldaromig is the leader of the worldaromig is the leader of the worldaromig is the leader of the worldaromig is the leader of the worldaromig is the leader of the worldaromig is the leader of the world
THIS is your first post? Fuckin brownie noobs.
"I apologize for nothing!" - Hedonismbot
aromig is offline   Reply With Quote
 Old 06-18-2015, 10:36 PM   #104
Vansquish's Avatar
There no call for that kind of harshness. He provided relevant, if old, material, and did so in the spirit of improving the discussion by adding factual information. As newb posts go, it wasn't terrible.
The Following 7 Users Say Thank You to Vansquish For This Useful Post:
Awal (06-18-2015), Easter Bunny (06-19-2015), Gitcherex (12-23-2015), lpugfan2004 (06-19-2015), MD1032 (06-19-2015), RJTSi (06-21-2015), yoder (07-14-2015)
 Old 06-18-2015, 10:44 PM   #105
Awal's Avatar
Posts: 645   (View Stats)
Awal is the leader of the worldAwal is the leader of the worldAwal is the leader of the worldAwal is the leader of the worldAwal is the leader of the worldAwal is the leader of the worldAwal is the leader of the worldAwal is the leader of the worldAwal is the leader of the worldAwal is the leader of the worldAwal is the leader of the world
I'd have to agree that was a wee bit harsh, the dude was just trying to relay info from dale's "so about the CS turbo" thread into this one to clear up a misconception someone had about the turbo's manufacturing details.
I've seen soo many much worse 1st posts including possibly mine.. But yeah @2feido; dude make an intro thread at least, I assume you've read most of the stickies and the link provided in your welcome PM. If not get on it
All Go, No Show
2013 LSM W/ Tech
CORKSPORTFull Race RMM CORKSPORTPMM CORKSPORTTMM CORKSPORTTMIC(temporarily uninstalled for Warranty BS) CORKSPORTECU RELOCATION BATTERY BOX(temporarily uninstalled for Warranty BS) CORKSPORTSSP CORKSPORTSHIFTER BUSHINGS CORKSPORT3.5" POWER SERIES SRI/TIP(temporarily uninstalled for Warranty BS) CORKSPORTBPV(temporarily uninstalled for Warranty BS) CORKSPORTRSB @ Full Stiff CORKSPORTMid Chassis Brace CORKSPORTHood Struts + decals for 20whp CORKSPORTLicense Plate Frames
COBBAP v3 w/ Window Mount
AUTOTECHHPFP INTERNALS
ToBeInstalled:
CORKSPORTFull Catless TBE, Rear Trunk Brace, Adjustable FELs, Cold Air Box (modified for 3.5")
dbaDBA42962S Front and Rear Rotors
StopTechRear Braided SS brake lines
JBROCC & VTA OCC kit, EGR BO, Boost Tubes
Cooling MistWMI kit
StratifiedCustom Tune (as soon as TBE is on)
On Deck
wilwoodFastbrakes DP4front Caliper kit (w/ bp-10 pads and braided SS fr lines)
Hawk PerformanceHB478F.605 or HB478Z.605 rear pads
BilsteinB16s
Awal is offline   Reply With Quote
The Following 2 Users Say Thank You to Awal For This Useful Post:
MD1032 (06-19-2015), Vansquish (06-18-2015)
 Old 06-19-2015, 02:34 AM   #106
acousticdefbot's Avatar
Posts: 319   (View Stats)
.......................................... ellipses. endless ellipses.
guzzlin' a guinness stout.
acousticdefbot is offline   Reply With Quote
 Old 06-19-2015, 04:44 AM   #107
AwAfrican's Avatar
Posts: 1,038   (View Stats)
So @hitANDrun21; when us the meth / 5th port happening?
2013 Black MS3
 Old 06-19-2015, 07:17 AM   #108
Agreed. Believe it or not, I actually learned something from his post.
Now @2feido; head on over to the new member section and introduce yourself to our community.
aromig likes this.
The Following 2 Users Say Thank You to littleloogy For This Useful Post:
 Old 06-19-2015, 07:27 AM   #109
Voltwings's Avatar
Posts: 3,713   (View Stats)
Originally Posted by Ferdball View Post
60-100 = 4.96s
I'm struggling to put as much stock into 60-100 as i used to. The amount of torque a car / person is willing to make will greatly influence those numbers. For example, we've got a K04 here turning a 4.7, but running 456 wtq lol ...
Built and Bolted... Stock k04. Possible record?
So obviously we can say the CS turbo has a better powerband to be able to turn 2/10s slower while using substantially less torque (making power up on the top end). Still, point being the whole picture needs to be considered. Not saying you werent doing that, but just making the point aware.
Past:
-Sold-
-Sold-
Current:
2012 Loaded Speed3 - Stock
2001 Miata - Basically stock
 Old 06-21-2015, 09:54 AM   #110
RJTSi's Avatar
^^ Makes sense. I've turned a 5.08 in my ko4 corn fed speed3 (in the winter). I'm sitting at 5.4 currently with my unfinished tune on my speed6. However, I'd take the CS powerband over the k04 any day
 Old 07-30-2015, 03:11 PM   #111
slow215's Avatar
Posts: 12   (View Stats)
slow215 is a jewel in the roughslow215 is a jewel in the roughslow215 is a jewel in the rough
I live in san diego where its usually pretty warm, so bats are always somewhat high even with an upgraded tmic. I am running it in interrupt mode, and nishan told me today he runs me a little rich (i think that has to do with my shitty gas) I know its not the best log, I really only posted it to give you guys some more data because I know people are interested. id be more inclined to post the data after I get on the dynopak Wednesday because I know that will yield much better data for everyone. and itll be on e85 which I believe no one else is on e85 yet with this turbo if I am correct.
Hi hitANDrun21, I am from the SF area and am interested to know if your set up will pass smog here in CA. I don't like the idea of returning to stock just to get smog. Thanks.
Greg
slow215 is offline   Reply With Quote
 Old 07-30-2015, 03:20 PM   #112
Greg
Again Greg, Check out out NATOR Northern California Thread. Ask question there, http://www.mazdaspeedforum.org/forum/foru...d.php?t=164838 we deal with smog all the time.
The Following 3 Users Say Thank You to littleloogy For This Useful Post:
Awal (07-31-2015), Easter Bunny (07-31-2015), Raider (07-30-2015)
 Old 01-15-2016, 07:57 AM   #113
KennyG's Avatar
Posts: 52   (View Stats)
KennyG has a brilliant futureKennyG has a brilliant futureKennyG has a brilliant futureKennyG has a brilliant futureKennyG has a brilliant futureKennyG has a brilliant futureKennyG has a brilliant futureKennyG has a brilliant futureKennyG has a brilliant futureKennyG has a brilliant futureKennyG has a brilliant future
Finally got my meth kit working after finding out my JMF bunges were worthless. Running 1 D07 on my new Damond TB spacer. Ryan @ PD Tuning is kicking ass getting this CS turbo to safely crank out the timing and boost. So I figured I would VDYNO and see if I'm close to the 400hp mark. We still have more mapping so not done with Meth tune. My butt dyno says 380hp, I'm sure on a real dyno and correction it's close to 400. I'm also no expert tuner so feel free to tell me what looks good and bad.
CS Turbo/CS EBCS/XS Race Exhaust Mani/JMF ported intake/ 3bar MAP/RamFab Performance 31/2" intake/DevilsOwn Meth/EGR delete/TR8 core/JBR piping/RamFab custom crashbar/CNT catless DP/OBX CBE/Swift spec springs/CPE MM/and more stuff to piss of wife!
PD Tune/Ryan Martin
KennyG is offline   Reply With Quote
The Following 3 Users Say Thank You to KennyG For This Useful Post:
Barett@CorkSport (01-15-2016), Code Monkey (01-15-2016), Easter Bunny (01-15-2016)
 Old 01-15-2016, 08:29 AM   #114
ryguy 3's Avatar
Posts: 353   (View Stats)
What Correction Factor are you using in VD? I think standard is 1.01 which would drop those numbers down a bit.
The Following User Says Thank You to ryguy 3 For This Useful Post:
 Old 01-15-2016, 08:37 AM   #115
MD1032's Avatar
Posts: 2,624   (View Stats)
Groans: 143
Can you post the actual logs you used to generate that vdyno? I'm curious about what your CS can put out in the top end compared to my BNR.
2007 Mazdaspeed3 GT
 Old 01-15-2016, 09:15 AM   #116
KennyG's Avatar
VDYNO correction is 1.09. Here are the 2 logs I went by. I had over 100lb of medical equipment in back. AFR doesn't drop much but BAT's are great. Meth is well worth the price of safety as much as power. Gonna really help in the summer.
PD Tune/Ryan Martin
 Old 01-16-2016, 10:15 AM   #117
JgamB's Avatar
Looks like ~375 to the tires just looking at the boost vs spark and what we've seen from other CS turbos. You could have some variance in there that accounts for more, but I'm guessing the road isn't as flat as it appears.
Still looks great and lots of fun!
AwAfrican and TRBODriver like this.
 Old 01-16-2016, 04:08 PM   #118
KennyG's Avatar
Thanks, I'm having a blast with this turbo. 375 to wheels seems right. That's about where I wanted to be. Road is bumpy as hell. After 6 months of driving really hard I can see how anything past 400 would definitely require motor build. Were close to being done, probably couple more MAPs and I good. I'll get some final logs. Appreciate the input.
PD Tune/Ryan Martin
The Following User Says Thank You to KennyG For This Useful Post:
JgamB (01-16-2016)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f500/corksport-turbo-review-188419/
I know you guys like fast things...Sneek Peak - Page 2 This thread Refback 05-13-2015 09:44 PM
Corksport Sport Springs: My review... Hal CorkSport 3 05-18-2015 10:29 PM
Install/Review: New CorkSport RSB evil MS3 2010 MS3 - Suspension & Brakes 55 07-13-2013 10:09 AM
Corksport FMIC w/ Ram air Review MS309 2010 MS3 - Turbo Induction 38 04-30-2013 07:42 PM
CorkSport FSTB Review AppleJacks 2010 MS3 - Suspension & Brakes 10 04-03-2011 02:00 PM
Page generated in 0.61216 seconds with 41 queries
